I want to use NVIDIA technique of upscalling to cut render time.
JamesJames Posts: 1,179
edited February 2025 in Daz Studio Discussion
Which upscaller do you think the best to keep the details?
Post edited by James on
  • If you render to canvasses there is a Scale setting for each canvas when it is selected.
  • barbultbarbult Posts: 26,621
    Is that some kind of after the fact upscaling, or does it render at a higher resolution?
    According to https://raytracing-docs.nvidia.com/iray/manual/index.html#reference#render-target-canvases
    Controls upscaling. A value of 1 indicates regular rendering, while a value of 2 will cause the rendered image to be scaled to double its original resolution in width and height. Upscaling is handled by the Deep Learning-based Denoiser, which must be made available for this option to be accepted. While the denoiser must be available, it does not need to be globally active, i.e. upscaling implies denoising for upscaled canvases without mandating denoising of other canvases.
    The canvas resolution must meet the requirements described in the subwindow group of the ICamera interface, where all values are multiplied by the upscaling factor. Note that this is true regardless of whether the denoiser is actually active.
    That's interesting. I didn't know there was a canvas upscaling option. Thanks for researching it.
  • JamesJames Posts: 1,179
    I use the scale option in canvas from 1 to 2.
    But it doesn't upscale.
    the resolution remain the same.
  • I have often run my image series though both Rife to interpolate and Real ESRgan to upscale
    one can use Automatic 1111 extensions or standalone programs like Flowframes and Waifu2X-Caffe
    (I do both)
    or something like Topaz Gigapixel if happy to pay for it
  • nonesuch00nonesuch00 Posts: 18,844
    Is the iRay render engine using DLSS to predict neighboring pixels in the next render passes to speed up renders or is it doing it all every pass, every pixel? If so, it there a way to turn it on and off?
    Post edited by nonesuch00 on
    Which doesn't seem to work.
    4.23.1.8 studio beta, tesla p40 for rendering.
    Nope, the Canvas scaling value of 2.00 did not produce a canvas any larger than the dimensions set in the Render Settings General tab. I am using DS 4.23.1.27 Public Build, and I rendered a Beauty Canvas.
    572 x 950 - 76K
  • algovincianalgovincian Posts: 2,670
    I have no experience with this feature and prefer to do this sort of thing in post, but I did read the docs out of curiosity and noticed that the denoiser must be available. From the docs that Richard linked to:
    Upscaling is handled by the Deep Learning-based Denoiser, which must be made available for this option to be accepted. While the denoiser must be available, it does not need to be globally active . . .
    Might be something to try if it wasn't available when you tested.
    - Greg
    ETA: Posted after following the link Richard posted but should have noticed that he already quoted this info in his post - doh! Anyway, was the denoiser available when you rendered?
    Post edited by algovincian on
    - Greg
    I tried enabling the SSIM denoiser, and the post denoiser, in various combinations, and got bubkis.
    Starting to think this is 20 series and above option only, as it may require tensor cores.
    - Greg
    Yes, as I understand the settings. These were the scene render settings.
    565 x 600 - 88K
    Post edited by barbult on
    I have activated the denoiser, but no luck in upspcaling.
    ver. public build 4.23.
    4070ti
  • Yes, Daz devs have had a poke at this and it doesn't seem to be ebhaving as in the docs - they are investigating.
    It seems in the current update, they remove the upscale.
    Too bad.
    Too bad.
    They who? This seems to be something not working as documented in Iray itself.
    DAZ devs.
    I update my public build. to 4.23.1.36
    The slider for upscale not existing anymore.
  • Richard HaseltineRichard Haseltine Posts: 109,577
    James said:
    DAZ devs.
    It is hidden unless applicable, as specified by nVidia - though the issue of its not working when the conditions are met remains open. See http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#4_23_1_30
  • TheKDTheKD Posts: 2,711
    (I do both)
    There is a project on github called chainner, it's worth a look if you want to do some AI upscaling, but don't have the cash to toss at topaz.
    (I do both)
    Daz Studio alows post-process scripts, to run after a render, see http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/rendering/render_post_process/start . Chainer has a command-line that could be called by the script to do the processing https://github.com/chaiNNer-org/chaiNNer/blob/main/docs/cli.md .
    (I do both)
    Oh damn, I never even thought of that. Seems like something worth messing with someday when I got a nice chunk of free time. Thanks for that great idea Richard.
