[SOLVED] Help! How can I get back to Face Transfer 1?
SpeculativismSpeculativism Posts: 148
I've got a registered copy of Face Transfer 1 but when I try to use it recently I keep getting the trial version of Face Transfer 2 instead. I don't know how to make the trial version go away and bring back my registered version of Face Transfer 1. Does anyone have the solution?
Post edited by Speculativism on
  • LeanaLeana Posts: 13,504
    From what I've read, it should automatically use Face Tranfer 1 when you use G8 and 2 when you use G9.
  • Richard HaseltineRichard Haseltine Posts: 111,382
    Yes, the figure used determines which you get (Face Transfer 2 is more than just a Genesis 9 update, but nevertheless that is a ket difference ebtween them https://www.daz3d.com/forums/discussion/662091/face-transfer-2 )
    Thanks. I'm still not sure what the problem is but I've got a few possibilities which I'm investigating. I started with no figure selected and it went to Face Transfer 2. It did not give the option of using genesis 8 so I'm looking at whether the installation of Genesis 8 is broken somehow.
    You should be able to seelct Genesis 8 Male/Female as the target in the pane (it's the same pane whichever pluginis being used).
  • SpeculativismSpeculativism Posts: 148
    edited July 2024
    Thanks Richard and Leana. I'm old and forgetful.
    The problem was with my brain.
    I had forgotten that Face Transfer 1 only works on my Windows computer and I was trying to find it on my Mac. I have the two computers side-by-side and some things only work on the Windows one.
    I only realised what it was after I'd uninstalled and re-installed several things and was at my wit's end. Then I looked at the web page for Face Transfer Unlimited and noticed that it was Windows only.
    Sorry to have bothered you.
