Post edited by rmissin_7f18077604 on
    How did you install the bridge plugin, and where did you download it from?
    Which version of Photoshop are you using?   The version of the plugin should match the version of DAZ Studio that you are also using, what version is that?
  • rmissin_7f18077604rmissin_7f18077604 Posts: 21
    edited June 2016
  • brainmuffinbrainmuffin Posts: 1,329
    As, I said "latest versions of everything", I fixed this using manual installation, DIM had put them in the wrong place.
    I find DIM puts stuff in the wrong place constantly. So much so that I'm having to reinstall everything again.
    DIM does not put stuff in the wrong place (with the exception of the ocassional borked install zip), it places files where you let/tell it to.
    edited June 2016
    No DIM can be trusted because it is just doing what the end user tells it to.  Don't blame the software because you wont open the Preference settings and make the adjustments to get it to work your way.
    edited June 2016
