Genesis 2 female trouble
Hi,
When I load genesis 2 female in Poser 10 it appears with a morph, but it is not possible, because I just load default figure. Why?
  • Richard HaseltineRichard Haseltine Posts: 109,603
    Which morph, or can't you tell? Usually this would mean that a morph had been saved with a non-zero default value - as has been the case with some freebies. If you have DAZ Studio does it load that way in DS? If so you could use the Currently Used group in the Parameters pane to see exactly which morph was the problem.
  • IsazformsIsazforms Posts: 210
    You re rigth, its a problem with data morph resources. There is a stranger folder and files in it. Thanks for you reply Richard.
