Skyler skin 3delight
TheKD
Skin is not looking right to me, I don't use iray at the moment. It seems like the bump setting is off, and there is some grid as well. Oh, probably should mention it's g3f version of her.
800 x 800 - 1M
800 x 800 - 1M
Post edited by TheKD on
Yeah, I saw the same thing. Also using 3Delight and G3F version. Didn't matter what light I used, either (viewport, distant, AoA Advanced) or what shading rate. The only thing that fixed it was turning down the Bump Noise Strength on the skin surfaces to 10% or less. For some reason, it came set at 48.4%.
Ah thanks, dropping that down did the trick. I normally don't render in daz studio, only when I need to redo bad icons, or make .tip files and whatnot. No reason to set up a houdini scene for something that simple.
