DAZ Install Manager failing.... [RESOLVED]
OminousAutumnOminousAutumn Posts: 401
edited February 2022 in New Users
I used time machine (mac) to transfer my old laptop to a new laptop. Daz central wont work with Monterey. Daz Install Manager was able to download all of the files I own but it is failing to install them. What the heck is going on?? It "fails" all installs all the way down the list. Any suggestions or ideas?
Daz software opens with no problem and even loaded assests that dont exist in my smart content which is empty...as it should be I guess until I figure out why Install is failing... Cheers!
1656 x 1738 - 1M
Post edited by OminousAutumn on
  • Check the log file, available through the gear icon at top-right (in the Advanced Settings dialogue if it doesn't have a direct command).
    Ok I opened it and have four tabs in the advanced settings menu. Accounts, DLs, Installation, Applications. What am I looking for and what do I need to do? Dont see any log file...
  • frank0314frank0314 Posts: 15,098
    Click on that wheel and just select show log. It's towards the bottom I believe. I'm not possitive if it is there for the Mac version but it is where it is in the Windows version
    Post edited by frank0314 on
  • OminousAutumnOminousAutumn Posts: 401
    my bad. got it. what dots do i need to connect? screenshot is the most recent log.
    1920 x 1590 - 880K
    888 x 372 - 194K
    found it but not sure what to make of it...see above screenshots
    I don't think you can install much if you have 3 bytes of space like the log says
    652 x 145 - 59K
    ok. how do you fix it since the actual amount of available space is 2TB? its a new laptop...
    The last time I used Mac's was over 30 years ago, so I don't know, but as the log says the installer is only seeing 3 bytes of available space in that location. Maybe a problem with permissions.
    I erased the computer and started everything from scratch. When I installed this time, it did prompt me to choose a pathway. It all works now. How do you decide the path without a prompt, for future reference.?
    Thanks to everyone for helping.
  • cgidesigncgidesign Posts: 442
    Changing the paths in DS and DIM:
    Note: the paths shown in the screenshots are my custom ones, they are not valid for a default installation.
    1401 x 293 - 133K
    1158 x 747 - 205K
    Post edited by cgidesign on
  • i cant install  any of those free things DAZ 3d comes with i get the same message. i even copy paste the same paths in the path screen and same message...im crying inside :.(
    This is quite an old thread, which message are you getting? What is your operating system? Are you using the default settings or have you made custom settings?
