Can Carrara... (Realism mini-challenges) WIP/RENDER THREAD
mschackmschack Posts: 337
edited October 2021 in Carrara Discussion
Render thread for the realism mini-challenges
Challenge thread: https://www.daz3d.com/forums/discussion/525876/can-carrara-realism-mini-challenges-challenge-thread
Post any render to any challenge at any time.
Feel free to post WIPS here also to show your progress.
Include an explanation of your secrets if you wish surprise
Post edited by mschack on
«1
  • mschackmschack Posts: 337
    edited October 2021
    Challenge 1 WIP
    I was already working on this when I had the idea for this thread smiley
    Still needs alot of work, modeling and tweaking the glass texture, the lens flare glow looks good.  Unfortunately Glare and 3d Aura don't work through glass.
    The rim light comes from a bulb light directly behind the 'bulb'.  Needs more rim light though to better match the challenge image.  Maybe tweaking the glass shader will help.  A little fresnel maybe.
    1024 x 876 - 152K
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,624
    edited October 2021
    could be fun
    1920 x 1080 - 84K
    That looks cool!
    mschack said:
    That looks cool!
    thanks, yours too, lighting closer heart
    edited October 2021
    not getting quite the effect blush
    mine a party light maybe?
    2000 x 2000 - 203K
    1920 x 1048 - 275K
    try a spot with a lens flare just in front of the bulb pointing at the camera
  • DiomedeDiomede Posts: 15,410
    Popping in the thread just to say this is a great idea.  No time now to participate but will make some time in the not too distant future.
    edited October 2021
    Octane render and added thickness to the bulb, it did have thickness but clipped for some reason in Octane so now double thickness.
    it was lathed from a polyline tracing
    is smoothed 4X but still a bit facetty in Octane
    I need a better screw, that is not actually spiralled, might use spline room to make one
    1920 x 1080 - 241K
    Oh nice!  Does Octane automatically add that glow to glow shaders?
    to an extent but I tweaked an octane shader, glow otherwise has very low blackbody emission
    I also added glare and bloom
    Not sure of an easy way of doing that in Carrara though I've seen a youtube tutorial for doing such a thing in hexagon...
    draw a shape then extrude a spiral
    the settings are the annoying part as much starting over
    I did one and stuck it on a cylinder but ended up converting to a vertex model and offsetting
    this is that file
    zip
    zip
    bulb.zip
    129K
    1920 x 1080 - 59K
    Octane animation (not the file in thread above)
    edited October 2021
    Looks ok, though like the look of that filament glow from octane better...
    1024 x 876 - 292K
    I like yours yes
    Thanks!
    video of Carrara native one
    edited October 2021
    Crazy glass animals...
    1024 x 1024 - 323K
    edited October 2021
    my glassware
    various vertex doodles mostly lathed, ball was a sphere extracted around edges
    digital painters glass shaders
    1920 x 1080 - 2M
    Cool looking, did you model all those?
    yes
    edited October 2021
    my rapid attempt, even basic lighting took a couple hours, gave up on sun and skylight
    if keen later might try FLUIDOS
    1920 x 1080 - 3M
  • HeadwaxHeadwax Posts: 10,466
    really nice light bulb moments
    sorry to sit this one out, I spend all my time avoiding realism!!
    edited October 2021
    don't gain much sunlight instead of indirect light and skylight rendering
    except 3 more hours and only this far...blush
  • Bunyip02Bunyip02 Posts: 9,292
    edited October 2021
    Perfume Bottle sitting on a mirror outside
    1600 x 1200 - 3M
    2775 x 1036 - 581K
    Post edited by Bunyip02 on
    Wow that is a pretty scene!  How do you get the foam?
    Good render Bunyip, the sky gives some nice reflections...
    Thanks Headwax, feel free to comment any time.  And keep up your non-realism work!
    Digital Carvers Guild terrain tools
    Surf
