Why is my DForce gravity going sideways? - SOLVED
DiomedeDiomede Posts: 15,401
edited May 2021 in The Commons
I modeled a simple prop in the shape of a glove.  I applied DForce to it intending for it to fall to a tabletop (simple primitive cube) and lie flat.  After applying a DForce surface to the glove prop and initiating a simulation, the glove starts sideways.  I have even tried converting to a conforming figure and applying DForce with no figure present.  Still sideways.
Hmmm?
Ultimately, what I am going for is a stereotypical tophat, cane, and gloves that go with a fancy tux or evening suit as per the pic below.
456 x 402 - 23K
Post edited by Diomede on
  • DiomedeDiomede Posts: 15,401
    edited May 2021
    some screenshots
    1431 x 897 - 170K
    689 x 540 - 26K
    And here is the glove mesh
    935 x 836 - 133K
  • algovincianalgovincian Posts: 2,670
    edited May 2021
    Is the cube mesh dense enough? Is the glove starting out intersecting the cube?
    - Greg
    ETA: Also, the glove mesh looks pretty dense in some spots (denser than the threshhold).
    Post edited by algovincian on
  • blazblaz Posts: 261
    My guess is the problem are the fingertips (And maybe at the wrist). The mesh is too dense so you get continuous collisions. What I would do is create new surfaces for the fingertips and the base (wrist) and lower collision offset for only this new surface.
    Thank you for your suggestions.
  • felisfelis Posts: 6,025
    The problem is that the default collision distance is 2 mm, so if there is less than that between vertices it will build up energy and perform strange movements.
    Thank you again, everyone.
    I made a revised mesh with a lower resolution.  Much improved results.
    I have enough info now to experiment with.
    Cheers.
    879 x 650 - 49K
    1264 x 788 - 109K
    edited May 2021
    After playing with the dforce surface parameters
    Now that I have a better idea of what is going on, I will create a better mesh (finger to palm ratio) and play around a little more.
    I consider this issue solved.
    Thanks again.
    904 x 646 - 32K
