Why is DAZ Studio using 100% CPU anytime you select Iray
trashkollectortrashkollector Posts: 22
edited February 2021 in Daz Studio Discussion
 I started DAZ 4.14 w/o adding anything to the viewport.  (no characters  - empty scene)
Then selected Iray render for an empty scene.
CPU peggged at 99% to 100% , WTH...
Also, I have GeForce card and it barely utlizes the GPU.
Is 4.14 just trash?
What version can I find that is stable.
The fans are firing like my pc is getting ready to explode.
Post edited by Chohole on
  • TheKDTheKD Posts: 2,711
    What GPU? What driver you use? Is CPU checked for rendering? Personally I turn CPU off in all renders, as it just seems to slow everything down to molasses, even with a OK-grade ryzen CPU lol.
  • This is likely to be a driver issue - make sure you are using 451.48 (or later, although if you have issues with a later driver it may be worth rolling back on a clean install through DDU)
