M4 and poser pro 2014
feedesneigefeedesneige Posts: 21
edited December 1969 in Poser Discussion
The MiddleGrasp for M4++ on the hand doesn't work in poser pro 2014
same for RingGrasp for M4++
not able to move those fingers at all.
What should I do?
Thank you.
  • mrposermrposer Posts: 1,134
    They are working for me... just tested it.... you might double check (I have been known to select the wrong hand myself).
  • Richard HaseltineRichard Haseltine Posts: 109,577
    That sounds as if you may have zeroed the hidden constant morph used to lock those fingers with the three finger morph from the Creature Creator. Try using the Edit>Restore menu to restore the figure to its default state. They are working here.
