Error for "DSON importer for Poser"
williamng.chinawilliamng.china Posts: 0
edited December 1969 in Poser Discussion
I’m trying to install the DSON Importer for Poser with the Install Manager. However it is giving me an error:
Install Manager cannot find a required path. The installer for “DSON Importer for Poser (Win 64-bit)” requires that the installed path for “Poser Pro 2014, Pro 2012 (64-bit)” be defined. Make sure that a path for this application is present on the “Applications” page of the “Settings” dialog, then try again.
My Poser Pro 2014 default path:
64 bits --> "C:\Program Files\Smith Micro\Poser Pro 2014"
32 bits --> "C:\Program Files (x86)\Smith Micro\Poser Pro 2014\PoserPro.exe"
I have installed Poser Pro 2014 (32 bits & 64 bits), Why does the installation Manager require a path for "a path of save filter", can someone help me? thanks!
  • TheWheelManTheWheelMan Posts: 1,014
    Which version of Windows are you using?
  • fixmypcmikefixmypcmike Posts: 19,710
    In DIM click the gear (Settings) in the upper right corner, go to the Applications tab, and use the + sign in the lower left to add the version, bit depth, and paths for Poser.
