how to manually install Genesis 2 base figures
edited December 1969 in Poser Discussion
Hi,
I am trying to manually install the Genesis 2 base male figure in Poser Pro 2014. I downloaded both the Genesis2MaleStarterEssentials.zip file and the Genesis2MaleStarterEssentialsPoserCF.zip file and unpacked them, but I can't figure out where to copy their contents.
Apparently Poser needs the files in the Genesis2Male StarterEssentials, but that folder structure looks like it's set up for DAZ, so where do I put those files in Poser?
The Genesis2MaleStarterEssentialsPoserCF file structure is set up for Poser, so I assume I can just copy these files to the Runtime folder.
I do have the DSON importer already installed in Poser. Can anybody help me with this? Thanks.
  • fixmypcmikefixmypcmike Posts: 19,710
    Install the Starter Essentials to the same place so that the Runtime in it merges with your Runtime. The folders you need for Poser are the Runtime and Data folders; the Data folder needs to be in the same folder as the Runtime.
  • edited December 1969
    It worked, thanks so much Fixmypcmike :-)
