Is there anyway to get rid of all the loose strands of Caprice Hair?
This hair is very nice, but there are thin, loose strands all over the place. Is there a way to get rid of those loose strands?
See all those super thin, loose strands? They're all over the place, is there anyway to get rid of them?
https://www.daz3d.com/caprice-hair-for-genesis-3-and-8-females
I don't have the hair to try it out, but it looks like there are a ton of morphs included. Did you run through those to see if it gets the hair the way you want it?
It doesn't have those morphs sadly.
I had to export the hair to Zbrush via GOZ, mask all the strands, invert mask, then shrink. It was very annoying, but at least I improved my Zbrush skills as a result.
Have you checked to see if they have their own grouping in the Surfaces tab? You may be able to just make them invisible with Cutout Opacity (Iray) or Opacity (3DL).
I wish it was that easy. That would've been the best solution.
