How to set environment to default (png)? *SOLVED*
daancouzijndaancouzijn Posts: 53
* SOLVED *
Hey,
I have a bit of a dumb question but my I was working in a scene, and normally I render characters without environment. It only renders a png, so the shape of the character and the background is non-existent. But now I added a scene builder to test something out but I can't manage to delete it. Even closing the program and restarting won't do the trick. How do I get my default setting back?
Daan
Post edited by daancouzijn on
  • Richard HaseltineRichard Haseltine Posts: 109,347
    If you post the solution that might help others in future.
  • daancouzijndaancouzijn Posts: 53
    I solved this by going into the 'environment' tab in the render settings panel, clicked on the little icon image next to the environment map slider and selected 'none'.
    edited May 2019
    Thanks. Turning Draw Dome off should also work.
