Unable to launch DS
logansfictionlogansfiction Posts: 11
I have installed and uninstalled daz studio and the manager a few times now. I have also made sure my firewall allows it AND reinstalled several times postgresqul with and without Valentina per forums.
Nothing is working and this is a new PC so I know it's not some anit-virus program because I have not installed any yet.
Help.
It only says upgrading cms... and thinking but never opening.
  • What security software are you uisng? Have you installed content, or have you copied content across from a previous system? What about the database - is that copied across?
    This computer has nothing on it as far as security yet. It's new. I have not copied content from other systems nothing. Downloaded daz and have an external hardrive for the rest and this is what is happening....
  • I reinstalled a couple of things and it moved from Upgrading CMS to "please wait" that doesnt ever open the studio still.
    I have reinstalled a ton of times and made sure my firewalls not blocking this thing. I had it open before once upon a time but it just literally stoppped working when I logged in as myself and now I cant get it to do anything.
  • Could you print the error for us? Appearently sounds like it's missing some kind of framework that has been moved/removed for you. Very hard to say what is the problem withou more information.
  • I have the error log how do I share it here? by link?
  • does this work?
    pdf
    pdf
    errorcodes.pdf
    600K
  •  DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Windows\SYSTEM32\MSVCR100.dll" at 0033:0000000067B9C145, memmove()+485 byte(s)
  • Merged threads to keep everything together, and edited title.
  • Do you get a DS crash report, with the log file?
    I am not sure where to look for that? I posted above what it gave me. Where would the crash report be?
  • I tried to upload the log file here it won't do it.
  • This is a brand new PC I am updating drivers but someone told me to back up the OS and completely clean it and start over again? Does that sounds like a good idea sigh
  • I emailed them the log is there a way to opload it here?>
  • You would get a pop-up dialogue, with a More Information button to click, which would yield a zip with the log file and some more technical stuff.
  • Ok I got it to open! but now it says this a valid postgresql connection could not be established (I have checked my firewall this is added)
  • If you look in task Manager while DS (or Install Manager, or both) are running do you see half-a-dozen or so entries for postgresql is the processes list (you will  need to click the More Details button if you don't already have that enabled)?
  • Ok i got cms to work! FYI one way is to add folders and change the pathway however now my logins are failing even after I updated passwor.
    The reco is to reinstall but I just finally got this all to work!
  • NEVEMIND IT WORKED YAY!
    Resolve :D
  • allyboralallyboral Posts: 0
    My first time installing daz and I can't bypass upgrading cms, it just sits there and watch me for hours, I disabled my anti virus, same issue arise it those not bring any error just can't bypass Upgrading cms and I am tired, please I need a video tutorial how to bypass this stage.
