How to save and load an UV map ? Or how to edit the UV map ?
Noah LGPNoah LGP Posts: 2,617
edited March 2018 in New Users
Hi,
I would like to extract an UV map and assign it to a new surface I create, how can I do ?
Post edited by Noah LGP on
  • Richard HaseltineRichard Haseltine Posts: 107,987
    Are you wanting to remap a model, or to add a new surface with the existing mapping, or to produce a template on which to paint?
  • Noah LGPNoah LGP Posts: 2,617
    I split an existing surface into 2 new surfaces, I would like to modify the UV map because I plan to use a diffuse map which doesn't match to the current UV map.
    You can do that in many modelling applciations - including Hexagon. Export (at base resolution and  with only the model you want to change visible) as OBJ, edit the UVs in your modeller (you can probably load the desired texture or template as a guide though I haven't checked this in Hexagon), save as OBJ, and use the Load UV set from the Surfaces pane option menu (the lined button in the top corner or right-click the tab) to bring the modified OBJ in. Once loaded the new UV set will appear as an option in the UV set setting for surfaces.
    edited March 2018
    Thank you very much, you answered to my question, I was curious to know if Daz Studio could edit it.
    Then I will use MilkShape3D, I know this software for a long time.
