Creating interior HDRI help
When I found I could use Iray on my older computer, I was delighted. The problem was the render time! Then I found HDRI's and was even more delighted. Topping it all off, I found out I could make my own HDRI's... while the exterior ones look amazing and work nicely with the characters, the interior ones turn out faaaaaaaaar too big! It's more like Jack and the Beanstalk inside the giant's castle! I'm quite sure there's a trick to making the interior HDRI render settings fix it so when it's made into an environment map after rendering it looks more proportionate to the characters. I've only gotten away with using forced perspective tricks and trick camera angles so far, but the whole idea of using an HDRI for me was to be able to render the scene at any angle without the background bogging down the computer or getting in the way. Clearly, there's a correct set of dimensions I can put in the render settings to make this work, because I've seen interior HDRI's in the DAZ shop! Clearly they wouldn't be there if they had the whole Jack and the Beanstalk problem mine have.
I've since tweaked the settings for unlimited render time, but overall, this is the video I've followed to create HDRI's:
For my 4-year-old computer, HDRI's are a major blessing, despite taking 2 1/2 days to render. If there's a better way to make HDRI's in DAZ, I sure haven't found it. I love making my own because they don't slow down the computer and I already have the lighting the way I want it, meaning I can focus on camera and character setups for my comic book scenes without lights and background getting in the way.
So, any idea what dimensions in the render settings would fix the problem for making interior scenes into HDRI's?
This is really interesting, but does it really save much time?
Using an HDRI instead of a full 3D environment will save a massive amount of time. You can render say, a scene where you have a few people in a HDRI livingroom in a fraction of the time it takes to render those same people on a full 3d prop livingroom. Its not even close.
There was a recent thread about creating your own "fake" HDRIs. You should totally check that out.
https://www.daz3d.com/forums/discussion/189166/make-your-own-hdris/p1
Yeah but you need to render the living room first, and if you want your people to move around in that living room it won't work. Right?
