• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • Looking for Leg Braces... help!
    Ive not looked myself, but alot of props I get from the google sketchup warehouse, then export them with an obj exporter plug-in. Might be worth a look ?
    By
    sammyd1988 sammyd1988 August 2012 in Daz Studio Discussion
  • Google Sketchup Import Errors
    I am brand new to DAZ 3D softwares. I thought it would be a fun way to dive into Bryce and get my learn on by importing some models I've previously built in Google Sketchup. But... I keep getting this error in Bryce when trying to import:
    An unexpected error has occurred (generic failure).
    Software Versions:
    Bryce 7.1 Pro
    Google Sketchup 8 (free edition)
    Exporting items from Sketchup as .dae files. I am able to import other .dae files into Bryce that I have downloaded from TurboSquid.
    Any help on resolving my import problems would be greatly appreciated.
    By
    westy808 westy808 July 2012 in Technical Help (nuts n bolts)
  • [solved] Daz Studio to load in Google Sketch-up
    Re-texture any surface with transparencies to remove the transparency map and opacity settings.
    Export your model as obj. (ignore invisibles, collect maps)
    Use a 3d party OBJ import plug-in for sketchup, if you do a Google search you will find dozens of them.
    Sketchup native Collada export appears to be unable to import models from Daz Studio or Blender that were exported in Collada format.
    By
    StratDragon StratDragon July 2012 in Daz Studio Discussion
  • Modeling for Daz Studio. (To understand a good way to adapt a mesh for a prop)
    Thanks Pendria, as I said in my reply to Frank, I have used all the edge tools, and you forgot to mention the chamfer tool under the surface modeling tab, they all make a difference, although It seems I am having to adapt my modelling to the smoothing angle in Daz Studio.
    @ JustmeNhere That is very good information, thank you for that.
    Personally I use many 3d creation apps. Wings, True Space 7.61 beta8 and Sketchup are on the top of my list, Hexagon I like as it has I feel, good work flow capabilities and a smooth interface, a lot of apps. including the the afore mentioned 3 all have the ability to alter this kind of real-time and rendered smoothing, wings even lets you designate hard and soft edges, but that is another track.
    Unfortunately as far as I can tell Hex, does not have this ability, it has various real-time light set ups but no way to adjust smoothing angle on the materials. which is a shame since it works hand in hand with Daz Studio with the capability to "send to daz" and vice versa.
    My conclusion is that Daz Studios 89.9% smoothing angle, for me anyway, is far to high although there must be a reason for it, I think maybe as it predominantly uses organic shapes ie. humanoid, animal, plant etc but I maybe completely "barking" up the wrong "tree" with that hypothesis :)
    By
    TapiocaTundra TapiocaTundra July 2012 in Daz Studio Discussion
    Thanks bringho I agree
    A case of trying too hard to get it right and not letting the software to do its job, it does not help that the original model I made was never intended for Daz it renders quite well in Bryce, Pov and Kerkythea,
    Sketchup helps me model with very precise unit measurements easily you see, which I find important, not all 3d modelling software makes it quite so easy.
    I was not planning to use it for Daz but am enjoying the lesson :)
    By
    As I figured bringho, being used to a different, lets call it "old fashioned" as I am, technique to produce a detailed model I am amused that I have to strip it down to make it look ok in Daz.
    I wonder if anyone here uses Sketchup in their work flow to make props n stuff ?
    By
    Hello Daz Studio people
    I am currently re-building a model of a ukulele that I made in Sketchup some months ago, I am mainly using Hexagon, with the intention of making a nice prop for Daz Studio and Poser, during the process I have come up against a few learning curves, as goes with understanding any new procedures. I made a post in the Hexagon forum concerning booleans and the way Studio handles them on "send to Daz"
    At the moment I am trying to understand the way Daz Studio smooths objects on import, it seems that everything is defaulted to 89.9%, I am forever having to switch it down to around 45% in the surfaces tab.
    As I say I have had to practically re-build it, as what I have found is my model, and my modelling approach is maybe too detailed and have had to take out loops etc. to adapt to this kind of smoothing.
    I have not usually had to make a mesh less detailed to make it look smoother before :)
    I wondered if anyone has had a similar experience and maybe will offer some words of advice and wisdom to help me finish this little project, I am hoping to give it away as a freebie. as I am the one usually downloading the free stuff.
    Thank you.
    By
  • real dimensions
    That is pretty much true for all software is it not? If I build in Googles SketchUp only SketchUp users would get the same Size. Bryce or Hexagon or any other program would need a reference of some type would they not?
    By
    Jaderail Jaderail July 2012 in Technical Help (nuts n bolts)
  • Heroes, Heroines and 3D Graphics - July Freebie Contest
    A/C Hero
    A woman & her daughter wait for a repairman to check out the A/C unit before going to a cosplay party.
    Of course this guy is a hero, he came right on over when she called, he’ll know if it’s an easy fix or an expensive one. :)
    Woman:
    Akio 3 #
    Glamour hair - DAZ 2.3 free content
    Gothic Lolita dress #
    LD stockings for A3
    Pumps #
    Hello Kitty earrings
    Man:
    DAZ model pack - Hiro 3
    Exphair
    Small Sins set #
    Ppant pants by POSERMAMMA - link broke.
    Child:
    Chibi Miku - Link bad?
    Scene:
    Alley #
    Street #
    potted plant - RDNA freebie NLA
    Moth on bush - 24 down *** MDC required item.
    Rubber duck 10 down *** MDC required item.
    Scooter #
    Carry case #
    cellphone - lost link
    Coke cup - bottom of page
    Free sky dome & lights from tutorial. #
    Sketchup models, not counted:
    A/C unit
    AC tester
    Poses by me, with a lot of dial tweaking.
    # free site registration required.
    Software used:
    Rendered in DAZ Studio 2.3.
    //EDIT:
    As requested by Dollygirl, this is the unedited toon render of my second entry.
    For big go Here.
    By
    nitehawk_ltd nitehawk_ltd July 2012 in Freebies
  • Help Filling In The Dots ( A discussion about booleans, domains and sending to Daz Studio)
    In fact I made the ukulele some weeks ago using Sketchup but as I wanted try and make a nice version for Poser or Daz Studio have had to practically re-build the darn thing, here is a cheap Bryce Pro render, just with materials, Bryce can be very forgiving on .obj imports.
    If my old Dad had got me a Rickenbacker 330 instead of a uke I might not have been plodding around with 3D stuff and been very wealthy by now :P
    By
    TapiocaTundra TapiocaTundra July 2012 in Hexagon Discussion
  • Font -> OBJ tool?
    Hexagon may be able to do this. Is Daz still giving it away fro free?
    http://www.daz3d.com/shop/software/hexagon/hexagon-2-5-download-version/
    Also Sketchup can create text but the free version limits export of mesh as "kmz" for Google Earth or "dae" Collada file.
    Daz Studio can read "dae" Collada file and then export it as an obj mesh. However it may not be a clean mesh.
    http://sketchup.google.com/
    By
    Gigabeat Gigabeat July 2012 in The Commons
  • Star Trek Builders Thread!
    Glad you guys like the little bubbleship ;).
    I'll confess, I haven't put as much thought into it as you might be crediting me for; I started out with Gillman's Sketchup model, and even though there's nothing of it here, I used it as something of a templete to get started, and that's where the broad wedge of the entryway came from. It appears that the opening was wedge-shaped, just maybe not as wide an angle as modeled here. That's okay with me - I'm good with explaining it as making a more 'filmable' craft ;).
    As for the front 'hatch,' yeah, nothing of what we saw ever explained how that could possibly work, or even account for a hatch ever having been there! The interior trim of the cockpit wrapped around and out the opening, making it fairly impossible to ever have something that sealed that space, and the overall design just never lent itself to anything that could either hinge away or slide into the existing bodywork. It's possible that the vehicle was only intended for temporal/dimensional travel and never meant to be a closed design at all - maybe the fins maintain its alignment with the timestream or whatever ;). With all the power this thing seemed able to channel, maybe it even had a limited transporter/replicator device with the sole purpose of creating or removing the entry hatch :coolhmm:. If one were to spend some time on adding details not seen (and therefore, not truly eliminated), I could see the little craft having a set of tripod legs, with part of the hatch swinging down with a stairway, but that still doesn't really explain where the upper half would go, unless, as postulated, it was split in the middle and each section could nest inside the hull on either side of the doorway (but then it probably wouldn't have the vital equipment right there in the panels of the open entryway ... )
    Ahhh, Treknology ... nothing is ever simple ... ;).
    By
    Ptrope Ptrope July 2012 in The Commons
    Well, here's a quick WIP - I needed Lazarus's timeship for an image I'm working on, and found a good Sketchup model of it online by Gillman, but it just wasn't refined enough for me (I'm really picky, I guess ;)), so I decided to model it from scratch.
    Still need to finish the interior, and this seat is a placeholder from the Sketchup model ...
    By
  • WELCOME TO THE 5TH ANNUAL JUNE FREEBIE CHALLENGE!
    nitehawk_ltd said:
    My last entry of the month.
    Backyard Barbecue
    Party on the 4th of July.
    The girls are Aiko 3
    The girls T-shirts are A3-unDs #
    T-shirt tex is Funny-unDs #
    The guys are Hiro 3 (See Aiko 3 above).
    Girl facing:
    June for A3 #
    Mitsu Hair #
    Shorts -> Downloads -> clothing -> A3 set at bottom of page.
    Girls back:
    Elwing for Aiko #
    Shorts - top row on right.
    Guy on left:
    Jamie hair 2 down
    HL Jeans
    Pants tex #
    Guy on right:
    Short layered hair
    Small Sins set # retextured
    party supplies:
    BBQ grill #
    Italian restaurant table #
    Table
    Plates #
    Cake 5 down
    Big burger - 4 down
    Watermelon & lettuce Trumarcar freebies
    Cooler Trumarcar freebie
    Background:
    House #
    Beach chair #
    Free sky dome #
    Items with broken links:
    Holiday Room table & chairs - DAZ 24 days xmas, day 3 - Daz old forum page. - Link on page bad.
    Flip flops # - rendo - bad link
    Harmony And Discord Boots by Adzan. - Link lost.
    Potted plant - RDNA freebie - NLA
    Couch - link lost
    Soda cans - BionicRooster - no link.
    Sunset Skies 01, Bryce-made by KickAir8P - no link.
    Paid items:
    T-shirt # retextured
    Lydia hair #
    Some sketchup models, that don't count:
    Heinz ketchup
    Mustard bottle
    Vlasic pickles
    Mayo (pickle jar retexured)
    Propane tank
    Used the lights that came with the house, plus 3 spots under overhang.
    # Free site registration required.
    Software used:
    Paint Shop Pro 7
    For big go HERE
    another snakes one in under the gun, nice bbq nitehawk, tons of freebies
    By
    jeeperz jeeperz June 2012 in Freebies
    Backyard Barbecue
    Girl facing:
    June for A3 #
    Mitsu Hair #
    Girls back:
    Elwing for Aiko #
    Guy on left:
    Jamie hair 2 down
    HL Jeans
    Pants tex #
    Guy on right:
    Short layered hair
    party supplies:
    BBQ grill #
    Table
    Plates #
    Cake 5 down
    Big burger - 4 down
    Background:
    House #
    Beach chair #
    Free sky dome #
    Couch - link lost
    Paid items:
    Lydia hair #
    Heinz ketchup
    Mustard bottle
    Vlasic pickles
    Propane tank
    Software used:
    Paint Shop Pro 7
    Better late than sorry!. Nice fun render.
    By
    music2u4u music2u4u June 2012 in Freebies
    Backyard Barbecue
    Girl facing:
    June for A3 #
    Mitsu Hair #
    Girls back:
    Elwing for Aiko #
    Guy on left:
    Jamie hair 2 down
    HL Jeans
    Pants tex #
    Guy on right:
    Short layered hair
    party supplies:
    BBQ grill #
    Table
    Plates #
    Cake 5 down
    Big burger - 4 down
    Background:
    House #
    Beach chair #
    Free sky dome #
    Couch - link lost
    Paid items:
    Lydia hair #
    Heinz ketchup
    Mustard bottle
    Vlasic pickles
    Propane tank
    Software used:
    Paint Shop Pro 7
    For big go HERE
    By
    nitehawk_ltd nitehawk_ltd June 2012 in Freebies
    Casual said:
    Darcie accidentally discharges a bottle of water on Amy.
    Click here to see the 1920x1200 pixels version
    Scene build in Daz Strudio 3 Adv.
    transfered to blender using mcjTeleBlender
    tweaked and renderd using Blender-Cycles
    items in the scene
    * * * * * * free ones * * * * * *
    two glasses and a bottle by Teknology3D & France
    http://kctc.francemi.net/KCTC_Beach_2010/shops_02.htm
    Garden Table by Ulven
    http://www.sharecg.com/v/21950/View/5/3D-Model/Garden-Table
    Beach #57 Cyclorama texture by HoboBo
    http://www.sharecg.com/v/63090/view/11/Poser/Beach-57-Cyclorama-texture#
    Pergola Paradise by SAM'S 3D
    http://www.renderosity.com/mod/freestuff/details.php?item_id=65018
    Water Bottle Prop by AdamThwaites
    http://www.most-digital-creations.com/free_poser_poses_textures_morphs_props_37.htm
    Texture maps for balls ( beach ball ) by RobinWood
    http://www.robinwood.com/Catalog/FreeStuff/Textures/TexturePages/BallMaps.html
    Candy Box by elleque
    http://www.renderosity.com/mod/freestuff/details.php?item_id=55788
    Pepsi Soda Bottle by Laz
    http://sketchup.google.com/3dwarehouse/details?mid=b6e511e727e6f317f4bdca145ed48dc6&prevstart=48
    football ball by papus3d
    http://www.renderosity.com/mod/freestuff/details.php?item_id=68615
    Aiko3 bikini bottom (lingerie) by Tofusan
    http://tofusan.cocolog-nifty.com/blog/download.html
    Mitsu Hair for A3, part of the Anime Star Fighter bundle
    http://www.daz3d.com/shop/anime-star-fighter/
    Aiko4 by Daz 3D
    http://www.daz3d.com/shop/aiko-4-base/
    balustrade - mCasual/Jacques
    not public (yet)
    cyclotron - mCasual/Jacques
    not public (yet)
    splish effect - made using mcjTracePath and mcjPscht.dsa - mCasual/Jacques
    https://sites.google.com/site/mcasualsdazscripts/mcgtracepath-for-mcjtracer
    mcjPscht.dsa - not public (yet)
    other items in the scene
    Aiko3 by Daz 3D
    http://www.daz3d.com/shop/aiko-3-0-starter-pack/
    Aiko4's top - Casual Outfit For V4 A4 G4
    http://www.daz3d.com/shop/casual-outfit-for-v4-a4-g4/
    Aiko 4's bikini top by Daz 3D
    http://www.daz3d.com/shop/victoria-4-2-complete/
    Wow...mcj...good to see you entering. Love your scripts.
    By
    items in the scene
    Aiko4 by Daz 3D
    not public (yet)
    not public (yet)
    Aiko3 by Daz 3D
    very nice casual, sounds like something i would do
    By
    items in the scene
    Aiko4 by Daz 3D
    not public (yet)
    not public (yet)
    Aiko3 by Daz 3D
    By
    mCasual mCasual June 2012 in Freebies
  • Just Because I Can. STUPID THREAD II
    wendy♥catz said:
    I bought a car but have to wait until Monday to get it registrered,
    using a loan car that costs twice as much as the one I bought
    https://fbcdn-photos-a.akamaihd.net/hphotos-ak-ash3/527694_3942585817092_16850942_n.jpg
    it is a 2001 Toyota Corolla Ascent, the only specific 3D model I could find was $120,
    cannot recall where, think it was Turbosquid
    some here not too bad but model search not accurate and not all named
    http://www.the3dstudio.com/product_search.aspx?id_category_2=6&price_min=1&level=1&sort=pricea&search=toyota corolla ascent
    lots of Corollas on Google sketchup warehouse but not mine
    Nice car, Wendy!! <*thumbs up*>
    The thing about Toyota is that they're pretty solid, so you can't go wrong in choosing one. And the best of luck to you, Wendy.
    By
    Norse Graphics Norse Graphics June 2012 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
