HD Poke-through
PerttiA said:
marble said:
So my first attempt at using the Fit Helper has been a failure. It seems that it does not like the G8 having geografts (and almost all my adult female characters have geografts). As I dial in the Chest Fixer, for example, the geografts I use (Meipe's Headlights) expand out (or in) dramatically. This makes the product a non-starter if that can't be overcome but I have no idea where to start.
@Sickleyield doesn't do commercial threads for her products so I can't ask her. Maybe she will spot this thread.
DS sees the geografts as wearable items, so if the fix morph is meant to effect clothing, it will effect the graft too.
Most of the fitting/fixing morphs that I have seen are actually made by adding the morph to the base figure twice, the first one with positive effect and autofollow, the second one with negative effect and without autofollow (hidden dial) - This way, one doesn't see any change on the base figure but the fitted items are effected.
If the highlighted statement is the case then I have no use for these @Sickleyield fix products and I'll just return them. Pity, I was hopeful that they might be a solution to all the poke-through and badly fitting woes I have with clothing on morphed characters. Even dForce doesn't help in many cases - especially those horrible distortions we see with larger women around the breast area where dForce does a very poor job of correcting or smoothing those distortions.
Export face created in FaceGenShould be only one morph if you created it in facegen. it should have told you were the face morphs were saved. just send them the morph files you created with face gen, then they can install it into their version of Daz Studio. Now if there are other morphs that are from a PA or Daz that you used to enhance the facegen face or the body, those cannot be shared, only a shaping preset can, assuming your friend has the same morph files installed..
AIUTO...CHI CONOSCE L’ITALIANO? PARTE TREDICIOk, è ora di riportare il thread nei suoi giusti binari, dopo la divagazione "missilistica"
Come dicevo qualche post fa, sto completando un geograft tutto mio. E' completo di tutto: morphs, rig, UV, textures... Ora però sto litigando con il rig, perchè quando applico il geograft e poi setto un morph al personaggio, le ossa vanno un pò a spasso, specialmente quelle non "collegate" al rig di base del personaggio. Si risolve utilizzando Edit-> Adjust rig to shape, poi ho applicato il ERC Freeze... ma per qualche ragione, il geograft non mantiene le impostazioni al salvataggio e poi riapertura del geograft.
Cosa sbaglio? Devo forse fare questa operazione per tutti i morph di Genesis? E' da un pò che non creo un geograft e la memoria è quello che è alla mia veneranda età...
How to get Genesis 8 expressions working on Genesis 8.1PerttiA said:
M-C said:
Son of the Raven said:
Edit 2: Although it worked after I did everything, upon reloading the scene one part of the expression was no longer working: eyes closed. Had to use eyes blink instead.I have exactly the same issue.
I could swear it worked before and I´m not sure when it stopped. Anyways, I think I have narrowed it down to beeing an issue with keyframing.
Here´s how to recreate the issue:
1. Open up a fresh scene and load a Genesis 8.1 female. (I haven´t checked males but might be the same)
2. Dial in the "Eyes Closed" morph to whatever value you like. Everything should work so far and it will continue to work as long as you stay at frame 0.
3. Now move your timeline slider to any other frame and set a keyframe with the "Eyes Closed" morph still dialed in. It still works at this point but...
4. Save and reload your scene. The "Eyes Closed" morph has stopped working and your figures eyes are open again.
As far as I can tell the "Eyes Closed" morph is the only one that is affected by this so far but it´s a big issue if one is doing a lot of batch rendering like I do. Everytime the queue loads a new scene the expresion is messed up.
We can´t be the only ones with that problem. Anyone else?
Could be a symptom of having the morph (eyes closed) installed in several locations, not only in the official locations but also within character folders.
Some months ago I was wondering why the length of G8F figures was reset every other time I opened a scene and found the lash morphs in several places they were not supposed to be.
After removing the misplaced and unneeded morphfiles, the lashes haven't been acting up since.While looking for the lash morphs, I also found that having unnecessary duplicates of base morphs included within installation files for characters/clothing was not something limited to only one product.
That actually seemed to be the reason for my problem.
Somehow the morphs have sneaked their way into the FACS folders of my 8.1 figures. As these folders usually only contain "alias" and "facs" files the eCTRLEyesClosed morphs seemd to be missplaced there.
Deleting them indeed got rid of the problem.Thank you very much @PerttiA !
Face transfer so much betterThis is a 4.20 one I did a few days ago. I don't use the eyes that Face Transfer creates but I do use the skin. The main issues I feel like I run into are washed-out faces and disproportionate jawlines.
As I'm about to do an entire renovation of my cast of characters, I'm currently working on improving/streamlining my creation process. So I'm always curious about other people's work with Face Transfer.
Using DAZ/3D figures ‘as is’ in (semi-)professional 3D productions?I would not consider using them "as is" as lazy, if the look is what one is happy with, why not.
Although, if I was just starting with DS, I would be quite picky about buying characters and only buy ones that have something to add to the gene pool, exceptional materials or "one of the kind" geometry - Don't be fooled by the promo renders with clothing, hair, environment and lighting that is not even included with the product. Getting a good set of morph packs instead, would give so much more at least as far as the geometry is concerned.
At one time, I went through all my characters by dialing them on the gray "Genesis 8 Female Dev Load" and checking if the geometry was something I wanted to keep. Ended up removing more than half of them as some had almost no change to the base figure and others were just bad or otherwise unnatural looking.
Using DAZ/3D figures ‘as is’ in (semi-)professional 3D productions?Using DAZ/3D figures ‘as is’ in (semi-)professional 3D productions?
Maybe a case of running before I can walk In DAZ but I would like to know all the same...
In the world of contemporary musical production using samples from sample packs and stock presets for VST synthesizer instruments ‘as is’ (i.e. without seriously tweaking/modifying them) is generally frowned upon although there are a few famous sample pack riffs and 'factory' synth sounds etc. that have been used (pretty much unmodified) in chart hits.
Is there a similar ‘ethos’ in the (semi-)professional 3D world? Is using a figure from say, the DAZ shop, without serious modification the hallmark of laziness or amateurism or are there perfectly fine applications in 3D productions using those figures (almost) ‘as is’?
Context: I have only recently discovered the diversity that a plugin like ‘Face transfer’ can bring and that there are tuts (and shape libraries) that focus on tweaking those imported results. Should I just concentrate on that in stead of buying (nearly) every cute/fancy character on sale? Obviously, I should also mention that I do know about mixing existing character/figure shapes within the “Shaping” tab of DAZ studio, producing some of my personal favorites (but not quite the prettiest!).
Thx!
Looking for Conan the Barbarian for M4 or F4mmitchell_houston said:
I know there's a M4 barbarian here at Daz, but he doesn't look like the classic comic book Conan. I've done a little hunting for him, and although I've found plenty of props and clothes, I haven't found a really convincing head morph.
Any and all help greatly appreciated.
Frazetta has been my hero for ages. The impact he had on artists is/was enormous. I can't tell you where to find Conan on Daz but I used a legacy actor from iClone in my comics and a lot of kitbashing from Daz and various sources. Just a suggestion : any Daz muscled male will do. It's the "stance" and environment that are important. Frazetta did Conan from the back more times than he did from the front. In fact, Conan's appearance changes from image to image in Frazetta's work. Just saying.
[Released]Bruce HD for Genesis 8.1 Male [Commercial]Yeah, I just have to say that the morph, texture, gens morphs, and smile morphs are so awesome. Like really.
Exporting morphs to FBX for use in C4D R15Solved the problem. When setting up the Morph Export Rules, I had to use head.eCTRL instead of head.CTRL. Added the 'e' and things worked great.
Thinking aloud: Geoshell/L.I.E. "UV camera" requestI don't even know if this is possible (or maybe I'm just missing something that IS out there), but I'll throw it out there: I'd like to see a feature or utility for Studio that allows you to create a projected UV 'on the fly' and use it to place a decal image without distortion. On t-shirts and other clothes that are UV-mapped by the vendor to allow you to put words or pictures on them, the image distorts any time a morph is applied, especially on female figures, because the flatter the breasts, the more the polygons get shifted, even though clothing doesn't really distort that way. What would be useful would be something like a "UV camera" that you can place perpendicular to a surface, adjusting it to get the best 'lay' for the image, which would be visible in the viewfinder, and then when you 'snap' the shot, it either applies the overlay as a layered image or on a geoshell (I don't know if it's possible to assign different UVs to layers in the same surface, but that would sure help!), creating a planar UV from the angle at which the camera was placed, using parallel projection rather than perspective. So if it's a t-shirt, you stand the figure, load the UV camera in front (or in back) of it, aimed at the body, adjust the height and angle of the camera (you would want to rotate it in order to properly project downward on the upper chest, for example, as opposed to straight at a wall or the side of a vehicle), the size of the overlay, and then 'click,' and you see the overlay on the t-shirt. You could use it for any surface, on a person or car or wall or military vehicle - anything that you would put a decal on if it were a model.
I would guess that something like this exists in high-end programs like Substance Painter or 3DS, but I'm thinking of a Studio end-user who wants to use off-the-shelf items without having to buy and learn a completely different program and become, basically, a content creator.Help - Eye pouch morphThis has a Eyes Puffy Lower morph, but I think it's only a subtle effect, and doesn't do extreme puffiness. But, who knows what happens if you push it beyond its parameter limits.
Genesis 8 Female Head Morphs
https://www.daz3d.com/genesis-8-female-head-morphs
3D Art Freebie Challenge May 2022 - "Cozy Corner" - Entries Thread Only3D Art Freebie Challenge May 2022 "Cozy Corner"
"Afternoon Tea"
[Best watched at full size for details.]Starring: Linda
The tale: (Entirely fictional)
Since they haven't seen each other much in the past year, Linda decided to organize an Afternoon Tea for her three best friends. She was just setting the table when the doorbell rang and the first two of her friends arrived, she's a little nervous, will they like it and have a good time in this corner of the garden?
Non-Motion Picture Soundtrack:
The Moody Blues - Tuesday Afternoon (© 1968) https://www.youtube.com/watch?v=5xvb9Udzc6M
COUNTABLE FREEBIES: (Alphabetic order)#01! 33 Eyes Materials for the Genesis 8 + 8.1 people by LevKornowska
https://www.renderosity.com/freestuff/items/88372/33-eyes-materials-for-the-genesis-8-81-people **#02! Bezel Set Ring for G3F G8F by AllenArt
https://sharecg.com/v/95896/gallery/21/DAZ-Studio/Bezel-Set-Ring-for-G3F-G8F **#03! Bud Vases by Cybrea
https://www.renderosity.com/freestuff/items/90939/bud-vases **#04! Chameleon ROse2 for Genesis 8 Female by zoro_d
https://www.renderosity.com/freestuff/items/85859/chameleon-rose2-for-genesis-8-female **
[Lashes morph used]#05! Crocus (OBJ) by XfrogPlants
https://www.cgtrader.com/free-3d-models/plant/other/xfrogplants-crocus **#06! DOA 6 Marie Rose - Head and Body Morphs for G8F by TritiumCG
https://www.deviantart.com/tritiumcg/art/DOA-6-Marie-Rose-Head-and-Body-Morphs-for-G8F-825236730 **
[Head morph 50%]#07! Dog Rose (OBJ) by XfrogPlants
https://www.cgtrader.com/free-3d-models/plant/bush/xfrogplants-dog-rose **#08! Ellie for G8F by Shinteo
https://www.patreon.com/posts/ellie-for-g8f-39378399
[Head morph 50%]#09! European Hornbeam Hedges (OBJ) by XfrogPlants
https://www.cgtrader.com/free-3d-models/plant/bush/2021-pbr-european-hornbeam-hedges-collection-carpinus-betulus **#10! Floral cupcakes by cabcab
https://www.renderosity.com/freestuff/items/91091/floral-cupcakes **#11! G8F Walking Poses 06 to 10 by richardandtracy
https://www.renderosity.com/freestuff/items/89214/g8f-walking-poses-06-to-10 **#12! Genny Bracelet 2021 G3F/G8F/G8.1F by AllenArt
https://sharecg.com/v/97560/gallery/21/DAZ-Studio/Genny-Bracelet-2021-G3F-G8F-G8.1F **#13! Grandma's teaset by NanetteTredoux
https://www.sharecg.com/v/81367/related/11/Poser/Grandmas-teaset **#14! Gwennili Hair for Genesis 3 female by kayleyss
https://www.renderosity.com/mod/freestuff/gwennili-hair-for-genesis-3-female/77151 **#15! Iray Jewelry Shaders by AllenArt
https://sharecg.com/v/95893/gallery/21/DAZ-Studio/Iray-Jewelry-Shaders **#16! Kiara Interior HDRI by Poly Haven
https://polyhaven.com/a/kiara_interior#17! Kristen Stewart - Head and Body Morphs for G8F by TritiumCG
https://www.deviantart.com/tritiumcg/art/Kristen-Stewart-Head-and-Body-Morphs-for-G8F-841957993 **
[Head morph 50%]#18! Linda - Character for G3F with texture maps by Edelzwicker
https://www.sharecg.com/v/89731/related/21/DAZ-Studio/Linda-Character-for-G3F-with-texture-maps **#19! Little Flower Studs for Genesis 8 and/or 8.1 Female by AllenArt
https://sharecg.com/v/98499/gallery/21/DAZ-Studio/Little-Flower-Studs **#20! Maddy for GF8 Charakter Shape by MysticArtDesign
https://sharecg.com/v/98461/browse/21/DAZ-Studio/Maddy-for-GF8-Charakter-Shape **
[LIE Blush Make up & freckles, customized]#21! Meadow Plant (OBJ) by CGAXIS
https://cgaxis.com/product/meadow-plant-8/ **#22! Melitaea britomartis (OBJ) by Digital Archive of Natural History
https://sketchfab.com/3d-models/melitaea-britomartis-20a41658fa284141815977b277a08520 **#23! My Heart Necklace for Genesis 8 Female by Amy Aimei
https://www.deviantart.com/amyaimei/art/My-Heart-Necklace-for-Genesis-8-Female-729010047 **#24! Off Shoulder Dress - additional textures by eblank
https://www.renderosity.com/freestuff/items/90051/off-shoulder-dress-additional-textures **#25! Off The Shoulder Dress for G8F by amyaimei
https://www.deviantart.com/amyaimei/art/Off-The-Shoulder-Dress-for-Genesis-8-Female-740372467 **#26! Pavement Cafe Props - Cafe Table & Cafe Chair by elleque
https://sharecg.com/v/96816/gallery/11/Poser/Pavement-Cafe-Props-Cafe-Table-Cafe-Chair **#27! Pavement Cafe Props- Pavement by elleque
https://sharecg.com/v/96901/browse/11/Poser/Pavement-Cafe-Props-Pavement#28! Pavement Cafe Props - Roadside Tree Ginkgo by elleque
https://sharecg.com/v/96834/browse/11/Poser/Pavement-Cafe-Props-Roadside-Tree-Ginkgo **#29! Pd-Soft Leather Daz Studio Shaders for Iray by Parrotdolphin (Janet)
https://sharecg.com/v/80223/gallery/7/Material-and-Shader/Pd-Soft-Leather-Daz-Studio-Shaders-for-Iray **#30! Pillow by kratzdistel
https://www.renderosity.com/freestuff/items/80880/pillow **#31! Pumps 01 for G8F by amyaimei
https://www.deviantart.com/amyaimei/art/Pumps-01-for-Genesis-8-Female-705955762 **#32! Small Grass Flower by Erock3D
https://erock3d.com/download/small-grass-flower/#33! Snapdragon (OBJ) by XfrogPlants
https://www.cgtrader.com/free-3d-models/plant/other/xfrogplants-snapdragon **#34! Sparrow by AdamThwaites (Most-Digital-Creations)
https://www.most-digital-creations.com/sparrow.htm#35! SY 200 Morphs for Genesis 8 Head and Body by SickleYield
https://sharecg.com/v/91888/view/21/DAZ-Studio/SY-200-Morphs-for-Genesis-8-Head-and-Body **#36! Teak Bench Garden old 1 texture 4k (FBX) by k3v1nc0
https://sketchfab.com/3d-models/teak-bench-garden-old-1-texture-4k-79edba863c5a43b69a6e499c6adca942 **
NO-COUNT ITEMS:--- Iray Satin Shaders by AllenArt
--- Scene Lights for Iray by Lali Kamala (The Holiday Loyalty Sale 2021 Free Item)PURCHASED/PAID FOR ITEMS: None 100% Freebies
*1 E-mail address required
** Registration required
#x! Countable Items (Bold ones are used by me for the first time I think.)
--- No longer available freebies
++ Free with DAZ Studio (or the Essentials)
$x. Purchased/Paid For Item
Rendered with DAZ Studio 4.10.0.123 (nVidia Iray)Other free software used: GIMP v2.10.30 and Irfanview 4.60
Postwork: used the AltaLux Image Enhancement Filter (Effect) by Stefano Tommesani that comes with Irfanview and some filters (oa) that come with GIMP. Also used mcjLut by mcasual (https://sites.google.com/site/mcasualsdazscripts9/mcjlut) with the free RocketStock LUTs (Neon 770.CUBE).
"Afternoon Tea"
Four (4) Arms for Genesis 8WendyLuvsCatz said:
actually what is needed is a morph and visibility preset that can be applied to a separate figure turning it into a pair of arms only which can be placed anywhere along the abdomen.
then it could also wear matching clothing that the hierarchical visibility settings can be applied to
The problem with that is generally texture seams, unless there are maps made specially for the connected figure 9and even there, without hiding and grafting the seam line would move as the figures were posed).
Art of the PromoIf we hadn't seen some reporters in real life risking life and limb to stand in front of inclement weather and try to report from the maelstrom , this Pretty3D promo for News Reporter Outfit would seem extreme. Great way to show off a built in wind morph in the garment.
We'll ignore the spelling and the hurricane reference.
My Custom Dress Looks Weird After Transfer UtilityIt should be like this:
How to do this correctly?
Tricera for G8.1 Male [commercial]Cheetahka said:
Is there a possibly you could make 4 different shape morph sliders as alternatives to just the included "base Tricera shape" of the figure?
-1 for just the head
-1 for just the body
-1 to adjust the back (make it smoother/flush) when NOT using the tail attachment as there is a piece of flesh that juts out from where the tail attachment should be making it appear seamless when attached.
-1 to adjust the back so you CAN have a seamless transition should you choose to use the attachment on a different model. I like to kit-bash :3
Thank you for all the wonderful products you make!
Your time and consideration on this request is appreciated!
Sincerely,
Cheetahka
The extreme proportions of the character do not allow for seperate head and body morphs. But there is in fact a morph for if you do not care to use the tail called "Raw Tricera Tail-HD" if you dial it to zero the back is smooth.
3D Art Freebie Challenge May 2022 - "Cozy Corner" - Main Thread OnlyJackyBrown said:
"Afternoon Tea"
"Afternoon Tea"
All freebies approved, please hurry up to the entries ;)
