Facegen now on sale...get it!
Below is my further experiments with FaceGen. I have applied skin from: http://www.daz3d.com/kelly-for-victoria-7
treated with: http://www.daz3d.com/n-g-s-anagenessis-2-revolution
Reference photo had a smile expression:
so I dialled Smile 04 to -50%, to get more neutral expression.
V4.2 with morphs++ does not work properlyHi, Holger. Welcome to the forums.
In Poser, when you load a figure such as Victoria 4, only the base figure loads. If you wish to use any of the morph packages that you may have, including the base morphs that come with the figure as well as Morphs++, those morph packages have to be loaded manually into the figure. Make sure you have the figure (V4) selected when you load the morphs. It is also important to understand that the Poser content library will not only show the injection files used to load the entire morph package (such as Morphs++), but also will show the individual morphs contained within that package which can be loaded individually if you wish. If you want to load the entire package, you can scroll down in the content library pane under Pose - DAZ's Victoria 4 - Morph Injections, and you should see the list of entire morph packages you have for V4. Those are what you want to inject to have access to everything. (see attached screenshot) Double clicking on Morphs++ with Victoria 4 selected in the viewport should load the package and when you expand Morphs++ in the parameters pane, you should see the spinners for applying the morphs for various body parts. Note that some of the morphs only show if the correct V4 body part is selected in the viewport, i.e. the head.
There may be times when you might wish to only inject specific morphs from a package, but most of the time I simply load the entire package and then I can access any ones I want to use from the parameters pane below.
3D Art FREEBIE CHALLENGE-Febuary 2017- WINNERS ANNOUNCED -Entries Thread OnlyLove Is In The Air 2
Here is my try, not much to the story, I was thinking how to do this picture when I realized that rules have been changed so here is what I have made. This is second picture with this title so I named it number 2, and it is named by a song with the same name.
Done with Daz Studio 4.9
Items marked with an asterisk require registration.
Not Counting: G2f
Freebies:
1.)* 'Alexandra' Edgy Slingbacks For G2F
2.)* Pencil Skirt For Genesis Basic Female (Reupload)
3.)* Tina Armstrong's Hair for Genesis 2 Female
4.)* Floors-n-Walls
6.)* MRL Icons: Hearts
7.)* Free Sofa prop for Daz Studio
9.)* Render Profiles for DAZ Studio 4.5 (Rendered on Insane)
3D Art FREEBIE CHALLENGE-Febuary 2017- MAKE HIM/HER PAY FOR IT YOU SAY!! SLVM-Main ThreadLove Is In The Air 2
Not Counting: G2f
Freebies:
4.)* Floors-n-Walls
LINKS CHECK OUT PLZ MOVE TO ENTERIES THREAD
V4.2 with morphs++ does not work properlyHi everone,
maybe somebody can help me, solving the following issue. I am using Poser 11 Pro. After injecting the morph++ to Victoria 4.2 things do not work as they should (or as I think they should - I am quite a newbie):
- When injecting morphs for figures, all head morphs work , but
- most the body morphs do not work (although some do I am referring to ones that are supposed to work with V4.2 / morph++)
- None of the morphs in the library at Pose: Poser11/Daz's Victoria 4/Morph Injections/ does seem to do anything (although I do not know, how they are supposed to work) at the same time, I do find some morphs in the parameter tabs for the various body parts.
It took me hours of trying, without getting that fixed. Any ideas what to do?
Cheers Holger
N.G.S. Anagenessis II - Revolution [Commercial]May I recommend that you copy the content of that \shader presets\n.g.s. anagenessis 2 folder and create a new folder in your mapped content folder called NGS manual shaders. Paste the copied contents in to that folder. The cloud folders are not supposed to be directly user facing so you are not supposed to see everything in that data folder....
Thank you, I moved the "Manual Apply" folder to MyLibrary/Shader Presets, I can see them now.
The genitalia seens fine, but now the skin colors are diferent, the skin around the genitalia is lighter than the rest of the body.
I'm very inexperienced at changing surface details like diffuse, glossy, and so on. Can you suggest what I could change to match?
Here is what I did:
1. Load Figure.
2. Apply New Genitalia.
3. Select Genesis 2 Female on scene tab and double click on "Anagenesis 2 Genesis 2.dse", click ok at the end.
4. Select New Genitalia For Victoria 6 - 2.0 on scene tab.
5. Open the Surfaces tab expanding New Genitalia...
6. Select "Anus" and then click "ngs shader_new.duf".
7. Select "Hips" and then click "ngs shader_new.duf".
8. Select "Labia Minora" and then click "ngs shader_new.duf".
9. Select "Vagina&Rectum" and then click "ngs shader_new.duf".
10. Select all the 4 before and click "NGS 2 Freebie Script.dse".Nyarai!!!Thank you, xyer0, Diva and BlackTalonArts! *__*
I'll add a few points:
1: My Products Used list was very long, so most of it gets cut :p If anyone needs to know a product, let me know!
2: I reshaped (messily) Dax Hair in ZBrush so it hung a little better in some promos. (Also, I love that hair and am in serious danger of over-using it...)
3: I hope the lighting examples were kinda useful. (Some of the HDRI shots may have had mesh lights for key, rim, or both. Specular looks a little nicer.)
4: If people want examples of my skins on other morphs, like Victoria 7, I can provide that. I hate detracting from the main character/person, but I know I'm one to buy skins for skins and slap them on OC's.
Anywho, thank you for the support! I love making skins! (That's a hard one to explain to people....) >=)
Immediate purchase for me, and thanks to you listing other products you used, it generated sales from me for a few of them too. So you're paying it forward in my book. I have several of the light sets you used in your promos, which is an amazing thing for you to include as part of the process. It helps sell her seeing her in those different lights, and helps even more to know I have most of them!!! Keep doing this!!
Not Counting: G2f
Freebies:
4.)* Floors-n-Walls
RRRR - It could be true - 5th anniversary contestThanks, Totte. Only 11? You can do it! Wait 'til September and October and you have 20!
Pull #1:
Classic Men's Hats (Content Paradise)
Lorelei Mertail for Genesis 2 Female(s)
Lucy for Everyday 1950
Eye Surface for Genesis
Superhero Training Gear (LB)
Victoria 5 (LB)G3 needs a few more bonesSimonWM achieved swallowing/breathing/blinking frames/actions for Genesis 2 via three products (Genesis 2 Alive!, Muscularity Morphs for Genesis 2 Male(s) and
Muscularity Morphs for Genesis 2 Female(s)) and for Genesis, Michael 4, and Victoria 4 via one product each (also called Alive! and prefixed by the appropriate figure name) combined with Daz muscle morph packages. Since Genesis 3 seems to have been ignored for the most part by any enterprising animation utility developer, who knows if he will bother with a G3 version.
Methods for transforming a render into Victorian era painting?Hmmm. Maybe you can point to a portrait of the type you're looking for. Queen Victoria lived a very long time, through several eras of art styles, including impressionism -- seems pretty clear you're not looking for that. There really isn't a single "Victorian" movement. Your starting image suggests you're looking for a German romanticism style, popular in the first half of the 19th century. From a brushstroke staintpoint, perhaps you're I'm thinking you're looking for something like this (it's too highkey, but look just the oil technique):
http://www.oilpaintingfactory.com/english/oil-painting-98084.htm
Frankly, I'm not sure you can readily achieve this with a filter, at least not without using several. If you have Photoshop there are some oil canvas actions you can get (try Google search, or the Envato marketplace if you don't mind springingf for $5 or so), and you can certainly do it by wet-brush tracing using a program like Painter or ArtRage.
My opinion only, but I think you will want to severely de-emphasize the background in your starting portait. The back wall and frames picture there are far too dominant.
Nope. Perhaps specifying "Victorian" era was more ambitious or specific than I intended. I got the renders to a point that I really enjoy and that is where they will stay. While I think it would be a great challenge to try and achieve total period accuracy, I new from the start that I wasnt going to fully attempt that. I landed on Victorian simply because thats the gown I chose. Vampire, murder and steampunk were ideas that were also moving around in my head when I made this. Thanks for the critique though. I do like to read honest opinions about my renders, positive or negative. Feedback is always welcome.
Nyarai!!![bolded by me] I LOVE LOVE LOVE this addition to the promos! Best idea ever. Besides the fact that I'm in love with your creations, seeing her under different lighting conditions REALLY helps.
Anywho, thank you for the support! I love making skins! (That's a hard one to explain to people....) >=)Methods for transforming a render into Victorian era painting?Hmmm. Maybe you can point to a portrait of the type you're looking for. Queen Victoria lived a very long time, through several eras of art styles, including impressionism -- seems pretty clear you're not looking for that. There really isn't a single "Victorian" movement. Your starting image suggests you're looking for a German romanticism style, popular in the first half of the 19th century. From a brushstroke staintpoint, perhaps you're I'm thinking you're looking for something like this (it's too highkey, but look just the oil technique):
Antarctica Expedition clothingWasn't there a really old set that went along with this
http://www.daz3d.com/mush-hounds-sled-pack
Don't think its availble anymore.
As I recall it was a aprtial clothing set, parts of it were isntead textures for other sets. Ah, I ddi buy the full set and this is what it says for the clothes:
The rugged wilderness needs rugged gear. Outfit your character in Meshworkz' Champion Clothes Set. A conformable parka for Michael 3/Victoria 3 includes a HoodDown morph to let the wind through your character's hair. Hands will stay warm with Mittens (a HideHands PoseMAT has been included) and there are protective Goggles to insure a wonderful snow adventure. And for those with the High Fantasy Naiar Edana Clothes and DAZ's Morphing Fantasy Dress, you'll find bonus textures.
I checked and, sadly, I don't own that set and can't currently find it offered anywhere
ETA: Beats578's Skidress might be useable as arctic clothing but it is too modern for Ansiko's set.
Novica & Forum Members Tips & Product Reviews Pt 8Here is FWSA Sushmita HD for Victoria 7 and her Jewelry with some of her makeup and jewelry.
Beautiful barbult!
Nyarai!!!Thank you, @xyer0 - I had a quick look (just the thumbnail from the offer she is included in) and I hesitated but passed. Then I saw this thread and with a deep sigh actually looked at the product and well, isn't she just abso-blooming-lutley lovely! And mine, dammit!
Please take a peek at your Messages!Thank you back, SimonJM, you darling, you! I'm dressing her now for an excursion.
Anywho, thank you for the support! I love making skins! (That's a hard one to explain to people....) >=)2: Excellent work on Dax Hair; it looks just like she has a perm. 3: The lighting examples were ABSOLUTELY useful because now I have an idea where to start. And thanks for telling us that you added some mesh lights on some of the shots. 4: If you have any of these lying around already, then please post them. Otherwise, I dial my own morphs to put under your skins (I own your entire store except for Quinn and Ceridwen---whom I will get as soon as she goes back on sale). Thanks for the extra renders.
Anywho, thank you for the support! I love making skins! (That's a hard one to explain to people....) >=)Novica & Forum Members Tips & Product Reviews Pt 8Learning Carrara 8.5 Training Video... "Thiiiiiiiis close"....Ah okay. I don't have DAZ Studio installed at the moment, which is probably why I don't have runtimes being found. Should I install that? Does it come with some good content included to use in Carrara that's otherwise not available? I try not to let my HD get cluttered with software I'm not actively using, but I can install it if it provides more content to work with.
And while I'm at it, I know at some point it was explained to me what the different generations of the Genesis characters were, and what the different named sets belong to (Victoria, Michael, etc). I tried searching through my past posts and can't find the post/thread now. Figures.
Ultimately, I want to set up a basic "palette" of characters, skins, hairs, etc. to draw from in my scenes, but I don't want to have an enormous library to sift through every time I want to add something. Let's say I'd like to have 1 of each gender, maybe a clothing/prop sets (fantasy, sci-fi, etc), a couple hair options, and a selection of morphs to start with. Just enough to learn the workflow, without drowning in options. As I get more experienced and feel more confident/comfortable with how everything works, I can add more options. But for now I'd like to apply the K.I.S.S. principle :p.
So, what would y'all recommend to start with as an absolute "basic" character setup?
