• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Memory lapse ... what happened to my M1 ?
    I have Victoria the beginning. I thought I had Michael... was there one? I have 2, 3, 4, 5, 6, 7 of each of them..and some reduced res characters from the early crew. But where is my M1 ???
    I contacted DAZ support to see if I could get a copy, and they told me to send in a receipt of puchase, which I thought was a bit petty considering I have been a customer since the very beginning, and why would I have a receipt from 16 years ago anyway?  I have over 3000 items in my product catalog ... one older than dirt character wouldn't be too much to ask for, especially since I know I bought him way back.....
    Just want to render all of them.
    By
    daveso daveso March 2017 in The Commons
  • Pre-made characters vs. morphs, which should purchase
    if I'm wanting to create a custom character is it better to buy the premade characters, like victoria7 and then customize them or get the morph dials to change the genesis 3 to fit the need?
    I've purchased some packs and know you can slihglty tweek and add features to victoria 7, like changing skin or body type slighlty if you have other characters purchased. and i've purchased some morphs to tweek the face further, but wondering what i should invest in more.
    Thanks
    By
    elliotdylan elliotdylan March 2017 in Product Suggestions
  • Problem at rendering with Victoria 7
    Maybe the expression is setting the morph - though if so the master slider should appear in Currently Used (unless it's on the head, I suppose, in whichc ase you would need to see it there). Presumably the Victoria 7 shape is also listed as Currently Used? Click the gear icon on its slider, then select Parameter Settings, and look in the Controller tab at the bottom of the dialogue - what is listed?
    By
    Richard Haseltine Richard Haseltine March 2017 in New Users
    I'm sorry for the ignorance Richard but I don't know what "central content location or single master content system" means :(
    I use one account to download the content to the pcs. The content is the same. The currently used are:
    Brow Squeeze
    Cheek Crease
    Cheek Eyes
    Jaw Side
    Fear
    Eyelids
    Eyes Squint
    Mouth Narrow
    S
    But I use a pre-made expression from """i13 100 Essential Expressions for Victoria 7""" on Olympia 7
    By
    Super cheese sandwich Super cheese sandwich March 2017 in New Users
  • Quality Anatomical elements
    Addition, the Pro pack needs to be for the generation you are using, so if you are using Genesis 3, you'd need something like Victoria 7 Pro pack, or Michael 7 Pro pack (or any other of the sevenses.
    By
    BeeMKay BeeMKay March 2017 in New Users
  • What's wrong with Genesis 3 hands?
    I followed this tutorial for transferring a V4 character to Genesis. The basics of transferring to G3F seem to be the same. I transferrred SamV4. I dialed in Victoria 4 from Actor>Generation X>***People***.  It worked fine and the G3F hands pose fine. Maybe take a quick look at the tutorial and see it you missed a step or something.
    By
    barbult barbult March 2017 in Technical Help (nuts n bolts)
    I have applied the Victoria 4 Shape to the Genesis 3 figure (after using GenX2 to import a V4 character).
    I tried the rigging tip but it barely helped. The issue remains.
    Where is the Victoria 4 shape (which group is it in in the parameters pane)?
    Genesis 3 Female/Actor/Generation
    By
    Mortze Mortze March 2017 in Technical Help (nuts n bolts)
    By
    Richard Haseltine Richard Haseltine March 2017 in Technical Help (nuts n bolts)
    By
    Are you applying the morphs to a base Genesis 3 Female, or have you also applied the Victoria 4 shape? If so, which is it?
    By
  • Young Teen Laura
    Named character bases (other than Victoria and Michael) started with gen3 I think. I do remember that Laura has the same UV as V3, and there are a few add-on character skins which had promos of Laura, V3 and (I'm pretty sure) Stephanie Petite all wearing the same skin.
    All of the generation 3 figures, ie male and female are based off a single mesh and UV, so can wear each others skins.
    Aiko 3 is a bit different, there is a problem with the leg textures, that's why Ibis for V3 has a special texture that works for Aiko 3. Same with Carina for V3, here you must use the P5P6 mat for Aiko 3 otherwise you get the same problem. Not sure about the technicalities behind it though.
    I had forgotten about that - Aiko 3 (and Hiro 3, as I recall) had an extra material zone/surface in the legs compared to V3/M3 - the UVs were (nearly) the same, just the way the mesh was divided.
    You can still share skins between A3 and H3 with the other generation 3 characters, but not by simply applying the same mat file, due to this extra mat zones. If you go into the surfaces tab and copy the SkinTorso settings into those for SkinThigh, SkinKnee, and SkinShin and it will work. So in short they can all wear the same skins, it just takes a few more clicks in some cases (ie A3 and H3). Attached is A3 using V3's standard skin.
    By
    Havos Havos March 2017 in The Commons
  • Young Teen Laura
    By
    Richard Haseltine Richard Haseltine March 2017 in The Commons
  • Young Teen Laura
    By
    Taoz Taoz March 2017 in The Commons
    Are all three using the same central content location? Or copies of a single master content system? If reinstalling Victoria 7 doesn't help that suggests that some other property is driving the Victoria 7 shape - what is listed under Currently Used with the base figure selected?
    By
  • Llynara's Loony Bin (WIP Thread)
    Thanks, Allie! V3 is the taller one in brown. The smaller one is Gwennili for V7. She does have fantastic features! Kayless did a wonderful job on her.
    By
    Llynara Llynara March 2017 in Art Studio
  • 3D Art FREEBIE CHALLENGE-MARCH 2017- WINNERS ANNOUNCED!! KISS THE BLARNEY STONE -Entries Thread Only
    Mysterious Dryad
    I tried to make dryad again and this time it worked, only that it is a bit Mysterious, I guess a bit evil... I have loaded that backdrop and rest of the picture followed. I figured out that those leaves on dryad are Ivy and I have just cleaned Oaks in my gardens, and ones that I take care of, of it https://en.wikipedia.org/wiki/Hedera_helix#Damage_to_trees. I think it should be done one in a 2 years, and I have seen a very large oak destroyed by Ivy that I cleaned but he didn't survived as I hoped he will.
    Anyway Happy St. Patricks day. I hoped I will finish this picture yesterday, but electricity went out so I had to do render again, but at least I have watched part of the parade in Dublin, live on my new Samsung cell phone and it seems it is from 16-19 March.
    Done with Daz Studio 4.9
    Items marked with an asterisk require registration.
    Not Counting: Victoria 4
    Freebies:
    1.)* V4 Dryad
    2.) Mat-Poses for V4 Dryad by ManFromAbora
    3.)* Element Stone Props (DS Version)
    4.) Laticis Imagery FREE Object - Crystals 1 to 5
    5.) Laticis Imagery FREE - Stone Throne
    6.)* Ultimate Shader Pack for DAZ Studio UPDATED_2011 (used for coins)
    7.)* Evil Mushrooms
    8.)* Render Profiles for DAZ Studio 4.5 (Rendered on Insane)
    Paid:
    Gregoria Hair
    Genesis Supersuit (Shaders used on pot)
    Strange Substances Pack 1
    By
    MilosGulan MilosGulan March 2017 in Freebies
  • 3D Art FREEBIE CHALLENGE-MARCH 2017- KISS THE BLARNEY STONE-Main Thread
    Here is my try, I started it before Chohole explanation blush
    Mysterious Dryad
    Freebies:
    1.)* V4 Dryad
    7.) Evil Mushrooms
    Paid:
    Gregoria Hair
    All freebies checked, I believe the Mushrooms need a registration so please add an * to that one other than that you are free to move  it to the entries
    By
    Linwelly Linwelly March 2017 in Freebies
    Mysterious Dryad
    Freebies:
    1.)* V4 Dryad
    7.)* Evil Mushrooms
    Paid:
    Gregoria Hair
    By
    I use batch render to render a couple scenes when I'm going to sleep. Recently I'm having a problem with Victoria 7. In my scenes there are other character. Not Victoria. But in every scene there is Victoria morph at 100%. Head and body. What can I do to solve this? I tried with desinstalling Victoria but it doesn't work.
    Thanks for advice
    By
  • Young Teen Laura
    But they are not the same figure. We did get at least Stephanie as a separate figure in the previous generation, and I think also Aiko.
    They are different figures in the sense that they all have a separate obj file and cr2 file, but the they are all based on the same underlying mesh, just morphed differently to create the obj for each one. Thus the UV layouts are identical, and hence they can share skins.
    Yes (though the UVs do vary a bit, look at the eyebrows on the same map applied to different figures - and the grouping varied a bit too, which limits the options for swapping morphs on the male figures).
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
