you're favorite G-String or Thong Underwear from behind?
My favorite is for Victoria 4 lol but this is a close second and fits G8F
https://sharecg.com/v/101009/gallery/21/DAZ-Studio/Trekant-Bikini-G8F
Where can i found anatomical elements for genesis 8?You have to buy a pro bundle. They are included in all the pro bundles that aren't teens or toons. Like for example, the Victoria 8 Pro Bundle has the female anatomical elements, and the Michael 8 Pro Bundle has the male elements. Or you can buy 3rd party elements at other stores.
The Definitive Well That Didn’t Go As Planned ThreadPrompt: Woman piloting a spacecraft crash lands and is savaged by a house cat.
Seed: 1964012014
LoRA: Victoria 9
Note the added helicopter, different cables, different spaceship and improved number of cat limbs compared to the old one which I got twice on the same day, which is
Background information - sampler, scheduler, multiple seed values
It is possible that behind the scenes multiple nodes are linked that each feature different seed values.
The rough shape of the image remains because of the shared main seed.
Small details are altered because of different secondary seed values.
Example:
During generation steps 1 - 35 the sampler "euler" is used with the scheduler "normal". seed: [..]53290.
During generation steps 35-70 the sampler "dpmpp_3m_sde_gpu" is used with the scheduler "sgm_uniform". seed: [...]91798.
As a result of this combination the rough shape of the noise is locked in during the first 35 steps with seed 53290.
When you run the same workflow again during steps 35-70 the image is altered in some small ways each time.
Different servers with different builds?
The odd thing here is that I am able to get the same image variations as richardandtracy.
Run some images, log out and log back in...
After loging in you may be connected to a different server.
During the beta not all of them may use the exact same build of Daz AI Studio for testing purposes...
AIUTO...CHI CONOSCE L’ITALIANO? PARTE QUATTORDICIvangelrise said:
Rieccomi con una domanda, stavolta molto basic.
Se su un prodotto è scritto che è compatibile con DAZ 1.5, funziona anche sul 4.22 attuale, giusto?
Più in generale, una cosa che è scritto essere compatibile con una versione di DAZ vecchia lo è anche con una più nuova? Non vorrei comprare robe che poi non mi funzionano, anche se costano poco.
Si funziona tutto a patto che tu abbia tutti i pacchetti richiesti dal prodotto stesso.
Michael 4/Victoria 4 te li da gratis la DAZ ma ci sono figure vecchie come David, Star, ecc... che devi avere in libreria (quindi acquistare).Per cui vedi bene cosa richiede.. e vedi se i materiali sono per Iray (Iray è stato aggiunto qualche anno fa.. potresti essere costretto a convertire i materiali)
Icon Creator Pro [Commercial]Hello,
It's a great tool and a huge time saver for rendering cleaner and better icons
I have a couple of problems with the current version (and don't know if it's a problem with the script or if I'm doing something wrong so I'm hoping wiser minds will be able to sort them):
1. There is a small typo when I'm trying to launch Icon Creator without any asset selected in the Content Library (written Lebrary in this case):
2. If Local Dimension is 'On' on the camera used to render an icon, with a resolution higher than the one set in the script (512x512 in my case), the render will be slower, as if the script was using the Local dimension as a target instead of using the resolution I set. I said as if because the final tip file is a 512x512 file, but the rendering time was in line with the rendering time of that same scene at the resolution set in the Local Dimension tab of the camera.
Here are the results of a test with a scene small enough to render in a couple of minutes with my CPU (Victoria 8.1, hair, clothes and the default beach HDRI):
a. Scene with Local dimension set to Off:
Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CPU: 432 iterations, 4.608s init, 35.634s render
[INFO] :: Finished Rendering
[INFO] :: Total Rendering Time: 46.83 secondsb. Scene with Local Dimension set to On (1024x1024):
Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CPU: 400 iterations, 4.197s init, 123.164s render
[INFO] :: Total Rendering Time: 2 minutes 13.53 secondsc. Render done at 1024x1024 (using the Render button):
[INFO] :: Total Rendering Time: 2 minutes 23.75 seconds
[INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Device statistics:
[INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CPU: 414 iterations, 4.527s init, 131.892s renderIs it possible to automatically reduce the rendering resolution in this case (eventually keeping the ratio used if the camera is not a 1:1 for the people who are using a non square tip picture) ? If it's not, raising an alert could be useful to avoid unusually long rendering time.
AIUTO...CHI CONOSCE L’ITALIANO? PARTE QUATTORDICICon i render ci fai quello che ti pare, li puoi anche sfruttare commercialmente se vuoi. Le altre licenze servono per poter usare i modelli per creare dei giochi o per fare stampe tridimensionali da rivendere.
E' vero quello che dice Crios per i freebies, molti non consentono usi commerciali per cui non ci puoi fare render o animazioni che poi usi per trarne profitto.
Qualche rarissimo modello ha delle limitazioni nell'uso, qui alla DAZ c'era un modello (per Victoria 3, mi pare, preistoria) di Anne Marie Goddard che aveva delle limitazioni sul tipo render che potevi fare, non ricordo bene quali fossero (parliamo di 20 anni fa, almeno)
A Day in the Year of a Life - Gallery#251
A Lady named Victoria
Testing, one two, threeI thought I would try testing one of thte characters in the AI so I started with Victoria 9.
1) After clicking V9 and entering Victoria in the prompt the AI generated an image of a house but no Victoria?
This is not impressive especialy as the house wasnt even Victorian in style.
2) Next I generated again but with x8 images and six of them at least had her in the image.
3) I then moved onto entering the Parameters/Genesis 9/Full Body Morphs into the prompt.
Not much diffiernce in generated body types generated and was still ocaisionly not generating Victoria in some images.
I would like to be positive in some degree but I am not impressed, this thing is many generations behind the competion.
can you make old generation M4/V4 3delight era clothing Iray?To convert Poser 4/3DLight Victoria 3 clothing to Iray, I tend to select all the garment's surfaces and then apply the DAZ Uber shader in the "[content]|Shader Presets|Iray|DAZ Uber" library directory. This moves most of the maps to the right places and does a fair conversion, then you can tweak it to get exactly what you want afterwards. Must be the same process for the newer V4 clothing. Regards, Richard.Celebrity Look-a-Likes for 3D figures Part 4nabob21 said:
Stephen,
Which morph and texture did you use for the Linda Carter Wonder Woman image?
Character Morph: https://sharecg.com/v/100824/gallery/21/DAZ-Studio/WW-Character-and-Material-Bundle [Plus 50% of LCWW for G2F (purchased from the website that we are verbitten to mention)]
Character Texture: https://www.renderosity.com/marketplace/products/91051/vv-ginger-for-victoria-42-genesis
Hi all! I'm Optiprimart!That looks like: https://www.daz3d.com/victoria-9-hd
Show us your Daz AI Studio ImagesVictoria 9 has decided, that she does not need to use helmet on Mars,
or maybe it was on the earth camp and the sand was just painted to red.
Who Is This Character from Sale Banner?It looks a bit like Victoria 9 with either a dark skin used or her own skin darkened (no idea how to do it).
When victoria 4 and michael 4 for genesis 9?I would be your friend, @bejaymac if you happened to post a link to what you are saying about this incredible individual that wrapped a victoria 4 morph around that wascally-g9-thing.
I'm done going 'forward' with thedaz and want to preserve my victoria 4 characters in the newer more vibrant resolutions. and i love your dancing emoji. Thank you.
Totally lost my enthusiasmWell, here's a shout out to the vendors then if it makes you feel any better!
I bought a copy of Poser 6 way back when, then moved to Daz Studio sometime during the G3/Victoria 7 days. Funny thing is, all I do is make background and screensaver pics for my pc. I have a small online presence, no interest in learning modeling, pretty much suck with photoshop but love material zones and material shaders.
Anyways, as a non-artist that doesn't consider my renders art, but that does spend alot (my wallet weeps), thank you!
XYZ Yu Hair simulation errorHi,
I put XYZ Yu Hair on Victoria 9. When i run simulation, I get:
> Error preparing objects to simulate and collide.
The log file has only:
> [WARNING] :: ..\..\..\src\dzdynamicsengine.cpp(2691): ERROR: clCreateBuffer (-61)
Daz version: 4.22.0.16
Steps to reproduce:
* Load Vic9 into a new scene.
* load XYZ Yu Hair
* Simulate
Any ideas?
Llola Lane’s RENDER A MONTH Challenge 2024 (ALL are welcome to join) (CLOSED)If the dragon can breath fire, they will have a nice pile of crispy cooked crows, @Diomede
Speaking of cooking something, my April entry is here too: Peaceful birds (well, if you're not a worm of course). It's a follow-up from my March entry:
After riding a couple of hours in the morning, Victoria and Lacey enjoyed a well-earned picnic.
After a picnic, what’s better than lying around under a tree ?
Doing so with birds singing around you, of course!
my DAZ AI threadbalding old man only wearing bib and brace overalls, no shirt, with spectacles, akubra hat, standing in front of a red color wheelbarrow, in front of a tomato patch
used Michael, Wang, Victoria and Angela
Show us your Daz AI Studio ImagesA couple of 'portraits of a woman...' (cant remember the actual prompt); the first was based on the Victoria option, the second not.
Anyone else a bit concerned by the pivot towards adult content?Masterstroke said:
caravelle said:
Masterstroke said:
Nudity does NOT mean porn.
No person, not even a child, has ever been harmed by just looking at a nude body.Right: Nudity does not mean porn. But it depends on how a person was brought up. If someone has been told since childhood that nudity is sinful and that looking at naked people leads straight to hell, the sudden sight can be shocking even for adults.
I have nothing against nudity at Daz, but if, like at the other shop, an avalanche of voluptuous breasts were to roll towards me now, it would disturb me. This excess on the often terribly cheap looking promos for an oversupply of skimpwear is the reason why I only buy very selectively from this other shop.
I aggree on that. I think it is hard to find a set of rules, allowing nudity, but avoiding those over the top, right in your face, super stylized sexual imageries at the same time.
Not, because it disturbs me, but because DAZ is just not he place for that.
I'd be all in for allowing an artistic erotic nudity level, like known from 70s Playboy or photo art galleries.Most of the Playboy proctorial of Fifties and Sixty's are less shocking, than some of the Victoria Secret ads of today, or the Red Carpet of the VMA's. (I'm thinking Lil' Kim at the 1999 MTV Music Award (btw she was 25 at the time)) Some of of those early pictorials wouldn't even by considered racy by today's standards, but they were shocking in the Fifties.
Actually nude is rather boring, some are beautiful while others ... well are not as beautiful.
But add a little silk and lace, and it will amp up the spice, cause you add mystery. Why do you think Lingerie was invented and why it is so varied?
A suggestive drape, as just the right spot, while not displaying anything, can be for lewd then being naked, for it is suggestive.
As for the store being the place for such images?... Well I could say, what if I am looking for a texture and need to see what this Morp does with texture.
I know there is the 30 day return policy, but how many items do you actually in your content library, which you wish you could have return, after working with them, but the 30 days are up? I know I have a few.
