• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Missing products in DAZ Central
    Little Nook and
    Wooden Rowboats
    Dont list in DAZ central but do in Install Manager.
    Wooden Rowboats is this weeks DAZ + freebie
    Little Nook is in this weeks new releases. Its in my product library and it shows up in Install Manager but not DAZ central.
    By
    D.Robinson D.Robinson January 2023 in Technical Help (nuts n bolts)
  • Show Us Your Bryce Renders Part 12
    :(   I posted mine late at night central time USA.
    Thank you all for the nice comments.  That image is very old so it's not eligible for the contest.
    I just uploaded it to see if it would work.
    By
    NGartplay NGartplay January 2023 in Bryce Discussion
  • Daz Central Base Path
    If there are Install Manager settings already in place Daz Central will let them stand, just noting that paths are managed by Install Manager.
    By
    Richard Haseltine Richard Haseltine December 2022 in Technical Help (nuts n bolts)
    I am installing daz central on my computer and trying to change the base path in it from my C:/ to my D:/. But it resets everytime i try and change back to the c:/.
    I had no problem changing the Daz Studio Install location but for some reason the Base path change does not set. Anyting i am doing wrong or need to change?
    By
    frank_198a781736 frank_198a781736 December 2022 in Technical Help (nuts n bolts)
  • [Released] Render Doctor [Commercial]
    Ok, so here is the Log inside Render Doctor. I selected the 14 Polished Granite shaders from the NVIDIA vMaterials 2.0.0 set. It dies as soon as it tries to apply the first preset to the object in the scene.:
    21:51:14 GMT-0600 (Central Standard Time): Starting Rendering (simulated=false) for 28 images
    21:51:14 GMT-0600 (Central Standard Time): Applying preset D:/3D Graphics/My DAZ 3D Library/Presets/Shader Presets/Iray/NVIDIA/NVIDIA vMaterials 2.0.0/Stone/Granite Polished/Polished Granite - Golden Galaxy.duf
    DAZ Studio log file attached along with a screenshot of the crash reporter from DAZ when closing Studio after this happens. I'll see if I can get the text of the Stack Trace in that dialog. Let me know if I can provide anything else.
    Something I'm not sure I noted before. If I select one of the presets that doesn't work and try it by itself, it crashes. If I apply the preset to the object first, then it works as long as it is the only preset I try to render.
    EDIT: I snapped a shot of the Machine Info too from the crash reporter. This bit in the output files is what caught my attention before:
      <error>
        <what>ACCESS_VIOLATION</what>
        <process>
          <name>DAZStudio.exe</name>
          <id>75748</id>
        </process>
        <module>C:\Program Files\DAZ 3D\DAZStudio4\QtCore4.dll</module>
        <address>0033:000000006998C8F8</address>
        <function>
          <name>QEventLoop::exit</name>
          <offset>8</offset>
        </function>
      </error>
    By
    vanish vanish December 2022 in Daz PA Commercial Products
  • 3Delight Useful Stuff?-Put It Here:)
    Sven Dullah said:
    pavsikakyj said:
    Is there a way ti reinstall omnifreakers shaders? Those for emissive surfaces. I suspect the don't work properly
    That would be the Omnifreaker UberArea Light Shader, which is part of the DS defaults starter pack, if I'm not mistaken. So yeah it should be possible to let DIM reinstall the stuff (or do a manual install, the only methods I use, won't touch connect or central with a 20 foot pole;)And I've used it with no issues in DS4.20.
    What kind of issues are you seeing?
    The light behaves weird after shader applied. In previous vesions I can make any object to be a source of light with  UberArea Light Shader now it works differet. Only light plane gives some illumination
    By
    pavsikakyj pavsikakyj December 2022 in Art Studio
    That would be the Omnifreaker UberArea Light Shader, which is part of the DS defaults starter pack, if I'm not mistaken. So yeah it should be possible to let DIM reinstall the stuff (or do a manual install, the only methods I use, won't touch connect or central with a 20 foot pole;)And I've used the shader with no issues in DS4.20.
    By
    Sven Dullah Sven Dullah December 2022 in Art Studio
  • purchases not appearing in daz central
    Daz Central is kinda screwed up at the moment. To find uninstalled purchases go to Daz Studio Assest on the left side of the screen, this will open your library. Then click twice on the 'Action' button on the right side of the screen above your assets. This should bring any items not installed to the top of the list. If none of your assets are showing in Daz Xentral, then I don't know.
    By
    stripe6499_9253833ae8 stripe6499_9253833ae8 December 2022 in Daz Studio Discussion
    I got a new computer.  Updated to the new daz.  None of my [ast purchases are available for download in daz central or in daz studio.
    By
    jaredenh jaredenh December 2022 in Daz Studio Discussion
  • Forum icons missing--they are fine in store & Other Forum Issues
    I laughed and coffee went out my nose.. My keyboard is not happy... laugh
    McGyver said:
    Icons?... We don't need no stinking icons.
    This is the problem with people these days... needing icons and labels and explanations of what buttons and links do...
    Where is that pioneer spirit of pushing buttons and seeing what explodes... do you think the pilgrims got to pilgrim rock pushing labeled buttons?
    Did Wilma and Orlando Right label the controls on their jet-copter the Spirit of Saint Nicolas when they took off for Paris from Kittycat, West Carolina?
    Did the crew of Apollo 10 1/2 have pretty labeled buttons with fancy explanations or icons on them when they landed on Mars?
    Did the technicians at Chernobyl have labels on their knobs and buttons when they... Okay, bad example...  but the rest?
    No.
    They were brave pioneers who didn't give a spit about a little trial and error...
    Do you think Captain Skully Skullburger needed to see where he was going when he landed his goose guts cover airliner in the lake at Central Park?...
    No... he trusted his instincts and listened to Opie Kanopie and let the Force™ guide him...
    We rely too much on our fancy buttons, links, icons and working GUIs nowadays... our ancestors didn't even have monitors when they forged the internet out of mammoth bones and dinosaur dung.
    We've gotten too soft and could never survive out in the woods or in a zombie apocalypse without big glowing arrows floating in the air, pointing out safe foods or hungry zombies.
    DAZ is just doing everyone a service by getting us out of our comfort zone and pushing us to think for ourselves... to experiment and try thinking outside the can.
    Ask yourself if you really even need a monitor or is that just something you've been told to buy by the GUI cartels who are trying to rob you of your instincts and intuition and turn you all into helpless sheeple who need to be spoon fed like... I don't know... sheeples without hands?...
    Whatever... Free your mind and stop relying on your eyeballs and stupid lousy icons and buttons.
    By
    Zethara Zethara December 2022 in The Commons
    No.
    By
    McGyver McGyver December 2022 in The Commons
  • Metadata problems - (Reason found)
    Using Central, Studio won't see anything until the product is installed. Connect will know if and when you log in, which is to be avoided if using DIM or Central. It just might "update" the metadata whether you want it to or not.
    By
    NorthOf45 NorthOf45 December 2022 in Technical Help (nuts n bolts)
    I install with DAZ Central.
    By
    horse1412000 horse1412000 December 2022 in Technical Help (nuts n bolts)
    I should have first asked how you normally install your products. Sounds like you are using Connect, but I use DIM. So, you did not see the product in the Available tab (or any others) in Smart Content?
    If using Connect, it will overwrite the metadata you just changed the next time you log in, as I understand it. If using DIM or Central, copy the metadata file back into the zip in case you need to re-install at some point.
    Either way, best to write a ticket to get the root problem corrected, if it is just a matter of changing the GlobalID. Not finding the conflict could prove fruitless, though.
    (...and I now see that exporting metadata from a Product view will include the GUID, but still only User Data.)
    By
  • Authinstalltoolprompt?
    Richard Haseltine said:
    Install Manager is logging in to your Daz account, so it needs the same email and password as the website.
    I would have to say you're wrong because I can log into the Website just fine. But I can not update anything in Daz Central and to get Daz open I have to open the "Daz to Blender" bridge, which automatically opens Daz it seems. But that's the only way I can get access to my Daz. I have send an email to support "but I'm sure we all have experienced how that goes?"
    I'm on an iMac OS X 10.13 Mavrick and CAN NOT upgrade the OS any further because of hardware reasons and it's too expensive to update the whole PC just to go to 10.14 "for really no reason because 10.13 is working just fine"
    So, I just wanted to input my thoughts on this. I have made a YouTube video going over the my issues with Daz "because I teach people how to make money using Daz, Blender, ZBrush, Marvelous Designer, through a number different paths that I have been doing for years now. So I do put Daz through the ringer and "in my personal opinion" it's only GREAT claim to fam is it's ability to create characters. That's about where it ends.
    Lonnie.
    By
    pokersith pokersith December 2022 in New Users
  • 8.1 male base figure?
    Weird. 8.1 is a starter essentials. If you didn't install it manually with DIM or Daz Central, it should download straight from Daz.
    Did you Register Daz Studio (it should be done automatically while being installed if you login to your account in DIM or Daz Central) ? Help > Register DAZ Studio.
    Default Genesis Males, whether 8 or 8.1, should be in the same folder: My DAZ 3D Library > People > Genesis 8 Male.
    By
    hansolocambo hansolocambo December 2022 in Technical Help (nuts n bolts)
  • Can't log into Daz Studio or Daz Installation Manager .... incorrect password
    leemoon_c43b45a114 said:
    I've just noted in my thread on this issue that logging in with DAZ Studio doesn't work either (on my 3 Macs.)
    Lee
    Yeah, same here. I'm simply trying to login to DAZ Central. I can type in my email address, but I only click on the password field and I get infinite spinner. I have force quit the app several times but it wont let me type a password. Infinite rainbow spinner.
    (Edited by Mod to fix quote)
    By
    azuremoss azuremoss December 2022 in The Commons
    @Barbult Thank you for that detail! So yes, it sometimes works fine and others it crashes Studio. I am intrriguied by your success with the polished granite presets that fail consistenly for me. (All others in the vMaterial set work as expected) Hmm. I wouldn't think the geometry would have anything to do with it, or the HDRI lighting I'm using. I will try the 4 you havfe in that log and see what I get.
    EDIT: I just tried with the 4 you ran successfully selected. It crashed immediately. Here is the log as it stands:
    16:12:56 GMT-0600 (Central Standard Time): Starting Rendering (simulated=false) for 8 images
    16:12:56 GMT-0600 (Central Standard Time): Applying preset D:/3D Graphics/My DAZ 3D Library/Shader Presets/Iray/NVIDIA vMaterials 2.0.0/Stone/Granite Polished/Polished Granite - Golden Galaxy.duf
    So I'm left with my original fear that it is something specific to my setup. Crap.
    By
  • FLUIDOS II for Daz Studio - update 2.2 [commercial]
    ioonrxoon said:
    Alberto said:
    ioonrxoon said:
    @Alberto I've opened a ticket for this and Richard reported it as well I believe, but unfortunately nothing's being done, figured I'd let you know as well before returning it. There are no manual installers for the LITE version in library.
    In fact, there is not manual installers for the plugin, only for the content. The installing is via DIM.
    Then why is it listed on the product page? I don't use dim and got it (+ some of the presets in advance, that are now past the 30 day date) based on this misinformation.
    Sorry, I missed your reply.
    Are you asking about the Install Types section?
    Install Types:  DazCentral Daz Connect DIM Manual Install
    I suppose it's alluding to the manual installation of contents. I didn't create this particular section (It's reserved for DAZ, because they made the installers)
    However, if you want to install the plugin manually, there is a way, but you have to use the DIM to download the files (but not for installation).
    This is the procedure for Fluidos original, but it's the same for Fluidos II Lite: https://www.daz3d.com/forums/discussion/comment/3922111/#Comment_3922111
    To register the plugin: https://www.daz3d.com/forums/discussion/comment/3916516/#Comment_3916516
    By
    Alberto Alberto December 2022 in Daz PA Commercial Products
  • The I Miss the Old Days Complaint Thread
    Too little support for seniors all around.. If I didn;t have my RR pension and our Gov't pensions, we'd be hurting...
    As fas as heat - we have 4 boilers with a total of 14 Million BTUs in the boiler room on our building's roof..
    kyoto kid said:
    ...the building I'm in is primarily intended for seniors like myself who are more vulnerable to illness and the idea of putting those cheap heaters in instead of a central system was stupid. Even though the building is federally subsidised, the rents are above what people in my situation should be paying. . About 48% of my monthly SS benefit goes just for rent alone for a small studio flat (plus high utility bills in winter).
    The trouble is there isn't much in the way of alternatives as low income housing here is at a critical shortage with many wait lists closed indefinitely.
    By
    hacsart hacsart December 2022 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
