Custom G2F keeps crashing Daz
crosswind said:
From the log, I could find your Ds 'crashed' for a couple of times.. it seems that each time after loading your figure, you just manipulated it for 2 - 3 minutes before crash... unfortunately Ds log recorded nothing the moment it crashed...
So just try the above mentioned first... and yes, ceq3 MorphMergeAndSplit plugin fixed head/neck issue long time ago... As to the creation of single morph dial / adjust rigging to shape / ERC freeze etc., there're too many tutorials, just follow the steps correctly and see if that'll work or not...After testing for a while using the Morph Merge And Split, adjusting rigging and end points, the problem really seems to be on the mesh, rather than rigging, probably. One specific body morph always crashed for some reason, Daz was always saying something about DzMorphDeltas::clearVertCount... The other body morphs took some extra time to load but almost never crashed...
Well, I guess I just need to avoid that body morph for now then. Just so you know I was using the body morphs from My Little Ponies (17 Character Pack) on VAM Hub. I "converted" a lot of body morphs and none have done something like this so not sure what's happening, I would understand if I was using the head but I'm only using the body...
[Released] RSSY Clothing Converter from Genesis 2 Female to Genesis 8 Female [Commercial]foxyfoxfurries said:
Hello whats up :)
I bought this item RSSY Clothing Converter from Genesis 2 Female to Genesis 8 Female | Daz 3D and I have this outfit that I want to convert Dynamic Martial Arts Gi: Genesis 2 | Daz 3D.
When I follow the steps I dont find in people genesis 2 female in my folder , So it also means I dont find what I want to convert , Have any idea how can I convert it? thank you ! :)
I will upload the images soon if it will help for some reason it wont upload right nowThe Dynamic Martials arts for G2F/G2M is optitex dynamic cloth, so is not even properly rigged to Genesis 2 female. There is no way this script will work on that item out of the box.
To get it to G8F one option is to add a dForce modifier and then run a timeline simulation to get from G2F to G8F (morph G8F into G2F clone at the start of the timeline and have the morph reduced to 0 by the end).
You then have to export the clothing as an obj, then reimport and finally use the transfer utility to make it G8F conforming.
Another option is to use the transfer utility to make the clothing G2F conforming and then save that as an asset. You will then be able to use this script.
I realise this is no where near as easy as just using this script, but that it not an option.
[Released] RSSY Character And Material Conversion Bundle Genesis 8 to Genesis 9 [Commercial]carlosgimpera said:
Laurita said:
Not exactly a great success. Neither on a stock Aurore 8 (left) nor on a custom character.
I saw this post and wanted to try Aurore. The only thing I had to do was to turn down the main Aurore Character dial once converted. That makes the character a plain G9 shape with Aurore Mats suit, no wrinkles. Then I just dialed up Aurore head and body morph- just those - and there you have it. HD morph caused issues, so I let it off as well.
This did not work for me at all. I keep getting the popup to either zero or restore the figure 0's. Did you? What did you choose?
[Released] RSSY Character And Material Conversion Bundle Genesis 8 to Genesis 9 [Commercial]RiverSoftArt said:
Eboshijaana said:
Naturally, I had to experiment on the update.
It is not AS broken as pre-update, but not quite the transfer utility level.I also exposed a few TU settings in the data/RiverSoft Art/Common/RSG8G9CharacterConversionConstants.dsa file. You could try setting some of those.
Okay, I've spent a few hours testing the converter with the file edited. I tried using the EXACT same settings between the converter and TU.
Thoughts;
1. Regardless of settings, the Converter changes the body of g9 while TU leaves it alone.
2. Could the 'reverse source shape from target' setting affect the above?
I will try to use my self-made clone for the converter, just to see if it would affect things.[Released] RSSY Character And Material Conversion Bundle Genesis 8 to Genesis 9 [Commercial]With the converter, I've notice most of the models I have do not use FBM/FHM in their morph naming but use Head or Body instead. I have attempted to resave the name of the morphs to start with FHM/FBM, but still have issues because sometimes I wind up having doubled morphs. Was it ever considered to see if the morph name includes Head or Body as an OR statement?
[Released] RSSY Hair Converter from Genesis 8 to Genesis 9 [Commercial]
Finally, use your favorite Genesis 8 Hair without limitations on your Genesis 9 characters! Automatically convert almost your entire library of hair items using the new Hair Converter from Genesis 8 Female to Genesis 9 or the Hair Converter from Genesis 8 Male to Genesis 9! The Hair Converter scripts provide batch execution for automatically converting your Genesis 8 Hair to Genesis 9 Hair in your library. Easily select the hair items in your library, select an output directory, and execute the script. Even better, icons and categories are copied from your original Genesis 8 hair to the new Genesis 9 hair items.Your new Genesis 9 hair is completely Smart Content aware! They will show up when you select a Genesis 9 character. Plus, all materials shown in Smart Content for your Genesis 8 item will show for your converted Genesis 9 item.
- Convert Genesis 8 Hair, including multi-part hair such as wearables, for use by Genesis 9 characters.
- Adds new movement bones to converted hair, adding functionality the original products lacked (may not work with all dForce hair)
- Copies icons from Genesis 8 hair to Genesis 9 hair for a professional look
- Copies Smart Content Products! Converted hair will be organized into similar products as the original items. The converted product mirrors the original hair items' products, organizing multiple converted items into one converted product and even using the product image from the original products.
- Converted Hair is Smart Content enabled! All materials shown in Smart Content for your Genesis 8 item will show for your converted Genesis 9 item.
- Automatically convert your entire library of hair with one operation!
Items without metadata can be converted but will not show up in Smart Content. They may also need to be converted using a Force Convert Item(s) button.
The script may not be able to convert all hair items without issues. Mid and high-level ponytails that were originally moved with bones will lose that functionality during the conversion process. In addition, though beards can be converted by the script, because of limitations in the conversion process, open-mouth expressions can possibly tear on the facial hair.
The script adds rigged bones to hairs on conversion, but cannot do this with hairs where the entire hair was grown from a cap with dForce (there isn’t enough actual geometry to work with, because dForce strands can’t be seen as geometry by Transfer Utility). It WILL work with hairs like many AprilYSH hairs that have dForce but also have geometry.
FYI: this is the best hair converter script we have done. I (RiverSoft Art) finally figured out how to convert multi-part hair (the other generation (G3-G8, etc) scripts would skip these hairs). It creates converted hair Smart Content Products as well as files. Finally, it is much more robust.
[Released] RSSY Character And Material Conversion Bundle Genesis 8 to Genesis 9 [Commercial]N-RArts said:
RiverSoftArt said:
N-RArts said:
I'm trying to convert an 8.1 character, but the conversion hangs on ERC Freezing: Neck Size. Which means the program becomes unresponsive, and I have to force close Daz Studio.
Where are converted morph files saved to in the data folder? I have to delete them and start again.
What does the Daz Log say? If you bring up the Daz Log (Help->Troubleshooting->View Log File...) in Notepad++, Notepad++ will detect when the log file changes so you can get all the messages DS sent out before it hung? It might be that it hung in a different place.
As far what happens after ERC freeze, the next major steps are creating the character property, saving the morphs, copying the materials, and then finally saving the character.
I've uploaded two logs (just in case you want more info). One for the Character Converter using G8.1F. The other is the Custom Character Converter using G8F.
With the Custom Character Converter I had an infamous "random restart", when Daz Studio became unresponsive. It crashed when the converter came across one of the philthrum morphs.
Since Daz log usually lags 1-3 messages behind when it crashes, it makes it a little difficult to figure exactly when it crashed. However, it either crashed during all the steps to create the controller property or just after. Thankfully, we can figure that out.
Go to data/RiverSoft Art/Common/RSG8G9CharacterConversionConstants.dsa and load it in a text editor. Change:
var BREAK_POINT = "";
to
var BREAK_POINT = "CHARACTER PROPERTY";
Run again. If it crashes, please post the log. If it DOESN'T crash, the script will stop after creating the character controller. If that step was successful, it tells me more. Please post the log. (BTW, make sure to change the BREAK_POINT variable back or every conversion will always stop at this point)
[Released] RSSY Character And Material Conversion Bundle Genesis 8 to Genesis 9 [Commercial]Eboshijaana said:
No one asked me - Diomede screenshots on whatever - Warning AI Discussion OKDiomede said:
And the fourth is the woolly mmammoth, which is just a Poser mammoth with Carrara hair replacing the conforming hair. For some reason the tusks were not working. I did manage to get around to model replacement tusks, but I never finished the walk cycle for the mammoths.
the mammoth looks similar to the model I have which is a morph for the old Daz elephant I think.. called mammuth
the tusks are ok with that one ... I wonder if your model is different
as mine didn't have any conforming hair...
[Released] RSSY Character And Material Conversion Bundle Genesis 8 to Genesis 9 [Commercial]Naturally, I had to experiment on the update.
It is not AS broken as pre-update, but not quite the transfer utility level.[Released] RSSY Character And Material Conversion Bundle Genesis 8 to Genesis 9 [Commercial]RiverSoftArt said:
This is the last information when the Character Converter Log crashed:
2023-05-31 04:20:09.638 [DEBUG] :: Adjust Rigging to Shape = true
2023-05-31 04:20:09.638 [DEBUG] :: DoERCFreeze Genesis9 Value null false
2023-05-31 04:20:09.675 [INFO] :: ERC Freezing: Neck Size
2023-05-31 04:20:10.339 [DEBUG] :: Setting PBMNeckSize modifier value to 0
2023-05-31 04:20:10.353 [DEBUG] :: SetMorphs Genesis9 RSSYG8_1FEJFM Lip Lower Size,RSSYG8_1FPHMNoseTipRound,RSSYG8_1FPHMNoseBridgeSlope,RSSYG8_1FN-Ra - Gen8 - Nite,RSSYG8_1FPHMPhiltrumWidth,RSSYG8_1FPHMPhiltrumDepth,RSSYG8_1FPHMPhiltrumAngle,RSSYG8_1FPBMNeckSize -0.9397590160369873,-1,0.5301204919815063,1,0.854285717010498,0.22857140004634857,-0.4514285922050476,-0.1809999942779541
2023-05-31 04:20:10.353 [DEBUG] :: Setting RSSYG8_1FEJFM Lip Lower Size modifier value to -0.9397590160369873
2023-05-31 04:20:10.364 [DEBUG] :: Setting RSSYG8_1FPHMNoseTipRound modifier value to -1
2023-05-31 04:20:10.374 [DEBUG] :: Setting RSSYG8_1FPHMNoseBridgeSlope modifier value to 0.5301204919815063
2023-05-31 04:20:10.384 [DEBUG] :: Setting RSSYG8_1FN-Ra - Gen8 - Nite modifier value to 1
2023-05-31 04:20:10.410 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumWidth modifier value to 0.854285717010498
2023-05-31 04:20:10.421 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumDepth modifier value to 0.22857140004634857
2023-05-31 04:20:10.432 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumAngle modifier value to -0.4514285922050476
2023-05-31 04:20:10.443 [DEBUG] :: Setting RSSYG8_1FPBMNeckSize modifier value to -0.1809999942779541
2023-05-31 04:20:10.455 [DEBUG] :: CreateCharacterControllerProperty Genesis9 Nite 8 1 v2 RSSYG8_1FEJFM Lip Lower Size,RSSYG8_1FPHMNoseTipRound,RSSYG8_1FPHMNoseBridgeSlope,RSSYG8_1FN-Ra - Gen8 - Nite,RSSYG8_1FPHMPhiltrumWidth,RSSYG8_1FPHMPhiltrumDepth,RSSYG8_1FPHMPhiltrumAngle,RSSYG8_1FPBMNeckSize -0.9397590160369873,-1,0.5301204919815063,1,0.854285717010498,0.22857140004634857,-0.4514285922050476,-0.1809999942779541 /Actor/People
2023-05-31 04:20:10.531 [INFO] :: Creating Character Controller Property: Nite 8 1 v2
2023-05-31 04:20:10.531 [DEBUG] :: SetMorphs Genesis9 RSSYG8_1FEJFM Lip Lower Size,RSSYG8_1FPHMNoseTipRound,RSSYG8_1FPHMNoseBridgeSlope,RSSYG8_1FN-Ra - Gen8 - Nite,RSSYG8_1FPHMPhiltrumWidth,RSSYG8_1FPHMPhiltrumDepth,RSSYG8_1FPHMPhiltrumAngle,RSSYG8_1FPBMNeckSize -0.9397590160369873,-1,0.5301204919815063,1,0.854285717010498,0.22857140004634857,-0.4514285922050476,-0.1809999942779541
2023-05-31 04:20:10.532 [DEBUG] :: Setting RSSYG8_1FEJFM Lip Lower Size modifier value to -0.9397590160369873
2023-05-31 04:20:10.539 [DEBUG] :: Setting RSSYG8_1FPHMNoseTipRound modifier value to -1
2023-05-31 04:20:10.545 [DEBUG] :: Setting RSSYG8_1FPHMNoseBridgeSlope modifier value to 0.5301204919815063
2023-05-31 04:20:10.550 [DEBUG] :: Setting RSSYG8_1FN-Ra - Gen8 - Nite modifier value to 1
2023-05-31 04:20:10.562 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumWidth modifier value to 0.854285717010498
2023-05-31 04:20:10.566 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumDepth modifier value to 0.22857140004634857
2023-05-31 04:20:10.571 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumAngle modifier value to -0.4514285922050476
2023-06-02 02:49:25.621 +++++++++++++++ DAZ Studio 4.21.0.5 starting +++++++++++++++++And this is the last of the log info for the Custom Character Converter:
2023-06-02 03:16:21.460 [DEBUG] :: Adjust Rigging to Shape = true
2023-06-02 03:16:21.461 [DEBUG] :: DoERCFreeze Genesis9 Value null false
2023-06-02 03:16:21.461 [INFO] :: ERC Freezing: Philtrum Angle
2023-06-02 03:16:22.262 [DEBUG] :: Setting PHMPhiltrumAngle modifier value to 0
2023-06-02 03:16:22.270 [DEBUG] :: Setting PBMNeckSize modifier (safename = RSSYG8_1FPBMNeckSize) value to -0.1809999942779541
2023-06-02 03:16:22.274 [DEBUG] :: AdjustRiggingToShape Genesis9 true true false false
2023-06-02 03:16:22.275 [DEBUG] :: Doing Adjustments...
2023-06-02 03:16:23.857 [INFO] :: Vert 0
2023-06-02 03:16:23.873 [INFO] :: Vert 1
2023-06-02 03:16:23.889 [INFO] :: Vert 2
2023-06-02 03:16:23.905 [INFO] :: Vert 3
2023-06-02 03:16:23.922 [INFO] :: Vert 4
2023-06-02 03:16:23.939 [INFO] :: Vert 5
2023-06-02 03:16:23.955 [INFO] :: Vert 6
2023-06-02 03:16:23.971 [INFO] :: Vert 7
2023-06-02 03:16:23.987 [INFO] :: Vert 8
2023-06-02 03:16:24.003 [INFO] :: Vert 9
2023-06-02 03:16:24.019 [INFO] :: Vert 10
2023-06-02 03:16:24.035 [INFO] :: Vert 11
2023-06-02 03:16:24.051 [INFO] :: Vert 12
2023-06-02 03:16:24.067 [INFO] :: Vert 13
2023-06-02 03:16:24.083 [INFO] :: Vert 14
2023-06-02 03:16:24.099 [INFO] :: Vert 15
2023-06-02 03:16:24.115 [INFO] :: Vert 16
2023-06-02 03:16:24.132 [INFO] :: Vert 17
2023-06-02 03:16:24.148 [INFO] :: Vert 18
2023-06-02 03:16:24.164 [INFO] :: Vert 19
2023-06-02 03:16:24.180 [INFO] :: Vert 20
2023-06-02 03:16:24.196 [INFO] :: Vert 21
2023-06-02 03:16:24.212 [INFO] :: Vert 22
2023-06-02 03:16:24.228 [INFO] :: Vert 23
2023-06-02 03:16:24.244 [INFO] :: Vert 24
2023-06-02 03:16:24.260 [INFO] :: Vert 25
2023-06-02 03:16:24.276 [INFO] :: Vert 26
2023-06-02 03:16:24.292 [INFO] :: Vert 27
2023-06-02 03:16:24.308 [INFO] :: Vert 28
2023-06-02 03:16:24.324 [INFO] :: Vert 29
2023-06-02 03:16:24.341 [INFO] :: Vert 30
2023-06-02 03:16:24.357 [INFO] :: Vert 31
2023-06-02 03:16:24.373 [INFO] :: Vert 32
2023-06-02 03:16:24.389 [INFO] :: Vert 33
2023-06-02 03:16:24.405 [INFO] :: Vert 34
2023-06-02 03:16:24.421 [INFO] :: Vert 35
2023-06-02 03:16:24.437 [INFO] :: Vert 36
2023-06-02 03:16:24.453 [INFO] :: Vert 37
2023-06-02 03:16:24.469 [INFO] :: Vert 38
2023-06-02 03:16:24.486 [INFO] :: Vert 39
2023-06-02 03:16:24.502 [INFO] :: Vert 40
2023-06-02 03:16:24.518 [INFO] :: Vert 41
2023-06-02 03:16:24.534 [INFO] :: Vert 42
2023-06-02 03:16:24.551 [INFO] :: Vert 43
2023-06-02 03:16:24.567 [INFO] :: Vert 44
2023-06-02 03:16:24.583 [INFO] :: Vert 45
2023-06-02 03:16:24.599 [INFO] :: Vert 46
2023-06-02 03:16:24.615 [INFO] :: Vert 47
2023-06-02 03:16:24.631 [INFO] :: Vert 48
2023-06-02 03:16:24.647 [INFO] :: Vert 49
2023-06-02 03:16:24.663 [INFO] :: Vert 50
2023-06-02 03:16:24.680 [INFO] :: Vert 51
2023-06-02 03:16:24.696 [INFO] :: Vert 52
2023-06-02 03:16:24.712 [INFO] :: Vert 53
2023-06-02 03:16:24.728 [INFO] :: Vert 54
2023-06-02 03:16:24.744 [INFO] :: Vert 55
2023-06-02 03:16:24.761 [INFO] :: Vert 56
2023-06-02 03:16:24.777 [INFO] :: Vert 57
2023-06-02 03:16:24.793 [INFO] :: Vert 58
2023-06-02 03:16:24.809 [INFO] :: Vert 59
2023-06-02 03:16:24.825 [INFO] :: Vert 60
2023-06-02 03:16:24.841 [INFO] :: Vert 61
2023-06-02 03:16:24.857 [INFO] :: Vert 62
2023-06-02 03:16:24.873 [INFO] :: Vert 63
2023-06-02 03:16:24.889 [INFO] :: Vert 64
2023-06-02 03:16:24.905 [INFO] :: Vert 65
2023-06-02 03:16:24.921 [INFO] :: Vert 66
2023-06-02 03:16:24.937 [INFO] :: Vert 67
2023-06-02 03:16:24.953 [INFO] :: Vert 68
2023-06-02 03:16:24.970 [INFO] :: Vert 69
2023-06-02 03:16:24.986 [INFO] :: Vert 70
2023-06-02 03:16:25.003 [INFO] :: Vert 71
2023-06-02 03:16:25.020 [INFO] :: Vert 72
2023-06-02 03:16:25.036 [INFO] :: Vert 73
2023-06-02 03:16:25.052 [INFO] :: Vert 74
2023-06-02 03:16:25.068 [INFO] :: Vert 75
2023-06-02 03:16:25.084 [INFO] :: Vert 76
2023-06-02 03:16:25.101 [INFO] :: Vert 77
2023-06-02 03:16:25.120 [INFO] :: Vert 78
2023-06-02 03:16:25.136 [INFO] :: Vert 79
2023-06-02 03:16:25.152 [INFO] :: Vert 80
2023-06-02 03:16:25.168 [INFO] :: Vert 81
2023-06-02 03:16:25.186 [INFO] :: Vert 82
2023-06-02 03:16:25.203 [INFO] :: Vert 83
2023-06-02 03:16:25.219 [INFO] :: Vert 84
2023-06-02 03:16:25.235 [INFO] :: Vert 85
2023-06-02 03:16:25.252 [INFO] :: Vert 86
2023-06-02 03:16:25.269 [INFO] :: Vert 87
2023-06-02 03:16:25.285 [INFO] :: Vert 88
2023-06-02 03:16:25.302 [INFO] :: Vert 89
2023-06-02 03:16:25.317 [INFO] :: Vert 90
2023-06-02 03:16:25.334 [INFO] :: Vert 91
2023-06-02 03:16:25.351 [INFO] :: Vert 92
2023-06-02 03:16:25.367 [INFO] :: Vert 93
2023-06-02 03:16:25.383 [INFO] :: Vert 94
2023-06-02 03:16:25.401 [INFO] :: Vert 95
2023-06-02 03:16:25.416 [INFO] :: Vert 96
2023-06-02 03:16:25.432 [INFO] :: Vert 97
2023-06-02 03:16:25.449 [INFO] :: Vert 98
2023-06-02 03:16:25.465 [INFO] :: Vert 99
2023-06-02 03:16:25.481 [INFO] :: Vert 100
2023-06-02 03:16:25.497 [INFO] :: Vert 101
2023-06-02 03:16:25.513 [INFO] :: Vert 102
2023-06-02 03:16:25.529 [INFO] :: Vert 103
2023-06-02 03:16:25.545 [INFO] :: Vert 104
2023-06-02 03:16:25.561 [INFO] :: Vert 105
2023-06-02 03:16:25.576 [INFO] :: Vert 106
2023-06-02 03:16:25.593 [INFO] :: Vert 107
2023-06-02 03:16:25.610 [INFO] :: Vert 108
2023-06-02 03:16:25.626 [INFO] :: Vert 109
2023-06-02 03:16:25.642 [INFO] :: Vert 110
2023-06-02 03:16:25.658 [INFO] :: Vert 111
2023-06-02 03:16:25.675 [INFO] :: Vert 112
2023-06-02 03:16:25.691 [INFO] :: Vert 113
2023-06-02 03:16:25.708 [INFO] :: Vert 114
2023-06-02 03:16:25.724 [INFO] :: Vert 115
2023-06-02 03:16:25.740 [INFO] :: Vert 116
2023-06-02 03:16:25.756 [INFO] :: Vert 117
2023-06-02 03:16:25.772 [INFO] :: Vert 118
2023-06-02 03:16:25.789 [INFO] :: Vert 119
2023-06-02 03:16:25.807 [INFO] :: Vert 120
2023-06-02 03:16:25.823 [INFO] :: Vert 121
2023-06-02 03:16:25.839 [INFO] :: Vert 122
2023-06-02 03:16:25.855 [INFO] :: Vert 123
2023-06-02 03:16:25.871 [INFO] :: Vert 124
2023-06-02 03:16:25.887 [INFO] :: Vert 125
2023-06-02 03:16:25.903 [INFO] :: Vert 126
2023-06-02 03:16:25.920 [INFO] :: Vert 127
2023-06-02 03:16:25.936 [INFO] :: Vert 128
2023-06-02 03:16:25.952 [INFO] :: Vert 129
2023-06-02 03:16:25.968 [INFO] :: Vert 130
2023-06-02 03:16:25.984 [INFO] :: Vert 131
2023-06-02 03:16:26.001 [INFO] :: Vert 132
2023-06-02 03:16:26.018 [INFO] :: Vert 133
2023-06-02 03:16:26.034 [INFO] :: Vert 134
2023-06-02 03:16:26.050 [INFO] :: Vert 135
2023-06-02 03:16:26.066 [INFO] :: Vert 136
2023-06-02 03:16:26.082 [INFO] :: Vert 137
2023-06-02 03:16:26.098 [INFO] :: Vert 138
2023-06-02 03:16:26.114 [INFO] :: Vert 139
2023-06-02 03:16:26.130 [INFO] :: Vert 140
2023-06-02 03:16:26.146 [INFO] :: Vert 141
2023-06-02 03:16:26.162 [INFO] :: Vert 142
2023-06-02 03:16:26.178 [INFO] :: Vert 143
2023-06-02 03:16:26.196 [INFO] :: Vert 144
2023-06-02 03:16:26.212 [INFO] :: Vert 145
2023-06-02 03:16:26.228 [INFO] :: Vert 146
2023-06-02 03:16:26.244 [INFO] :: Vert 147
2023-06-02 03:16:26.260 [INFO] :: Vert 148
2023-06-02 03:16:26.276 [INFO] :: Vert 149
2023-06-02 03:16:26.292 [INFO] :: Vert 150
2023-06-02 03:16:26.309 [INFO] :: Vert 151
2023-06-02 03:16:26.325 [INFO] :: Vert 152
2023-06-02 03:16:26.341 [INFO] :: Vert 153
2023-06-02 03:16:26.356 [INFO] :: Vert 154
2023-06-02 03:16:26.373 [INFO] :: Vert 155
2023-06-02 03:16:26.390 [INFO] :: Vert 156
2023-06-02 03:16:26.406 [INFO] :: Vert 157
2023-06-02 03:16:26.422 [INFO] :: Vert 158
2023-06-02 03:16:26.438 [INFO] :: Vert 159
2023-06-02 03:16:26.454 [INFO] :: Vert 160
2023-06-02 03:16:26.471 [INFO] :: Vert 161
2023-06-02 03:16:26.487 [INFO] :: Vert 162
2023-06-02 03:16:26.503 [INFO] :: Vert 163
2023-06-02 03:16:26.519 [INFO] :: Vert 164
2023-06-02 03:16:26.535 [INFO] :: Vert 165
2023-06-02 03:16:26.551 [INFO] :: Vert 166
2023-06-02 03:16:26.567 [INFO] :: Vert 167
2023-06-02 03:16:26.585 [INFO] :: Vert 168
2023-06-02 03:16:26.601 [INFO] :: Vert 169
2023-06-02 03:16:26.617 [INFO] :: Vert 170
2023-06-02 03:16:26.634 [INFO] :: Vert 171
2023-06-02 03:16:26.649 [INFO] :: Vert 172
2023-06-02 03:16:26.666 [INFO] :: Vert 173
2023-06-02 03:16:26.682 [INFO] :: Vert 174
2023-06-02 03:16:26.699 [INFO] :: Vert 175
2023-06-02 03:16:26.715 [INFO] :: Vert 176
2023-06-02 03:16:26.731 [INFO] :: Vert 177
2023-06-02 03:16:26.747 [INFO] :: Vert 178
2023-06-02 03:16:26.763 [INFO] :: Vert 179
2023-06-02 03:16:26.780 [INFO] :: Vert 180
2023-06-02 03:16:26.797 [INFO] :: Vert 181
2023-06-02 03:16:26.813 [INFO] :: Vert 182
2023-06-02 03:16:26.829 [INFO] :: Vert 183
2023-06-02 03:16:26.845 [INFO] :: Vert 184
2023-06-02 03:16:26.862 [INFO] :: Vert 185
2023-06-02 03:16:26.878 [INFO] :: Vert 186
2023-06-02 03:16:26.894 [INFO] :: Vert 187
2023-06-02 03:16:26.910 [INFO] :: Vert 188
2023-06-02 03:16:26.926 [INFO] :: Vert 189
2023-06-02 03:16:26.942 [INFO] :: Vert 190
2023-06-02 03:16:26.958 [INFO] :: Vert 191
2023-06-02 03:16:26.976 [INFO] :: Vert 192
2023-06-02 03:16:26.992 [INFO] :: Vert 193
2023-06-02 03:16:27.008 [INFO] :: Vert 194
2023-06-02 03:16:27.024 [INFO] :: Vert 195
2023-06-02 03:16:27.040 [INFO] :: Vert 196
2023-06-02 03:16:27.056 [INFO] :: Vert 197
2023-06-02 03:16:27.072 [INFO] :: Vert 198
2023-06-02 03:16:27.088 [INFO] :: Vert 199
2023-06-02 03:16:27.104 [INFO] :: Vert 200
2023-06-02 03:16:27.121 [INFO] :: Vert 201
2023-06-02 03:16:27.136 [INFO] :: Vert 202
2023-06-02 03:16:27.153 [INFO] :: Vert 203
2023-06-02 03:16:27.170 [INFO] :: Vert 204
2023-06-02 03:16:27.186 [INFO] :: Vert 205
2023-06-02 03:16:27.202 [INFO] :: Vert 206
2023-06-02 03:16:27.219 [INFO] :: Vert 207
2023-06-02 03:16:27.235 [INFO] :: Vert 208
2023-06-02 03:16:27.251 [INFO] :: Vert 209
2023-06-02 03:16:27.267 [INFO] :: Vert 210
2023-06-02 03:16:27.283 [INFO] :: Vert 211
2023-06-02 03:16:27.299 [INFO] :: Vert 212
2023-06-02 03:16:27.315 [INFO] :: Vert 213
2023-06-02 03:16:27.331 [INFO] :: Vert 214
2023-06-02 03:16:27.347 [INFO] :: Vert 215
2023-06-02 03:16:27.364 [INFO] :: Vert 216
2023-06-02 03:16:27.381 [INFO] :: Vert 217
2023-06-02 03:16:27.397 [INFO] :: Vert 218
2023-06-02 03:16:27.413 [INFO] :: Vert 219
2023-06-02 03:16:27.429 [INFO] :: Vert 220
2023-06-02 03:16:27.445 [INFO] :: Vert 221
2023-06-02 03:16:27.461 [INFO] :: Vert 222
2023-06-02 03:16:27.477 [INFO] :: Vert 223
2023-06-02 03:16:27.493 [INFO] :: Vert 224
2023-06-02 03:16:27.509 [INFO] :: Vert 225
2023-06-02 03:16:27.525 [INFO] :: Vert 226
2023-06-02 03:16:27.542 [INFO] :: Vert 227
2023-06-02 03:16:27.559 [INFO] :: Vert 228
2023-06-02 03:16:27.575 [INFO] :: Vert 229
2023-06-02 03:16:27.591 [INFO] :: Vert 230
2023-06-02 03:16:27.607 [INFO] :: Vert 231
2023-06-02 03:16:27.623 [INFO] :: Vert 232
2023-06-02 03:16:27.639 [INFO] :: Vert 233
2023-06-02 03:16:27.655 [INFO] :: Vert 234
2023-06-02 03:16:27.671 [INFO] :: Vert 235
2023-06-02 03:16:27.689 [INFO] :: Vert 236
2023-06-02 03:16:27.706 [INFO] :: Vert 237
2023-06-02 03:16:27.722 [INFO] :: Vert 238
2023-06-02 03:16:27.739 [INFO] :: Vert 239
2023-06-02 03:16:27.756 [INFO] :: Vert 240
2023-06-02 03:16:27.772 [INFO] :: Vert 241
2023-06-02 03:16:27.788 [INFO] :: Vert 242
2023-06-02 03:16:27.805 [INFO] :: Vert 243
2023-06-02 03:16:27.820 [INFO] :: Vert 244
2023-06-02 03:16:27.837 [INFO] :: Vert 245
2023-06-02 03:16:27.853 [INFO] :: Vert 246
2023-06-02 03:16:27.869 [INFO] :: Vert 247
2023-06-02 03:16:27.885 [INFO] :: Vert 248
2023-06-02 03:16:27.901 [INFO] :: Vert 249
2023-06-02 03:16:27.917 [INFO] :: Vert 250
2023-06-02 03:16:27.933 [INFO] :: Vert 251
2023-06-02 03:16:27.950 [INFO] :: Vert 252
2023-06-02 03:16:27.967 [INFO] :: Vert 253
2023-06-02 03:16:27.983 [INFO] :: Vert 254
2023-06-02 03:16:27.999 [INFO] :: Vert 255
2023-06-02 03:16:28.015 [INFO] :: Vert 256
2023-06-02 03:16:28.031 [INFO] :: Vert 257
2023-06-02 03:16:28.047 [INFO] :: Vert 258
2023-06-02 03:16:28.063 [INFO] :: Vert 259
2023-06-02 03:16:28.079 [INFO] :: Vert 260
2023-06-02 03:16:28.095 [INFO] :: Vert 261
2023-06-02 03:16:28.111 [INFO] :: Vert 262
2023-06-02 03:16:28.127 [INFO] :: Vert 263
2023-06-02 03:16:28.145 [INFO] :: Vert 264
2023-06-02 03:16:28.161 [INFO] :: Vert 265
2023-06-02 03:16:28.177 [INFO] :: Vert 266
2023-06-02 03:16:28.193 [INFO] :: Vert 267
2023-06-02 03:16:28.209 [INFO] :: Vert 268
2023-06-02 03:16:28.226 [INFO] :: Vert 269
2023-06-02 03:16:28.241 [INFO] :: Vert 270
2023-06-02 03:16:28.258 [INFO] :: Vert 271
2023-06-02 03:16:28.274 [INFO] :: Vert 272
2023-06-02 03:16:28.290 [INFO] :: Vert 273
2023-06-02 03:16:28.306 [INFO] :: Vert 274
2023-06-02 03:16:28.322 [INFO] :: Vert 275
2023-06-02 03:16:28.339 [INFO] :: Vert 276
2023-06-02 03:16:28.355 [INFO] :: Vert 277
2023-06-02 03:16:28.372 [INFO] :: Vert 278
2023-06-02 03:16:28.388 [INFO] :: Vert 279
2023-06-02 03:16:28.403 [INFO] :: Vert 280
2023-06-02 03:16:28.419 [INFO] :: Vert 281
2023-06-02 03:16:28.435 [INFO] :: Vert 282
2023-06-02 03:16:28.452 [INFO] :: Vert 283
2023-06-02 03:16:28.468 [INFO] :: Vert 284
2023-06-02 03:16:28.484 [INFO] :: Vert 285
2023-06-02 03:16:28.500 [INFO] :: Vert 286
2023-06-02 03:16:28.516 [INFO] :: Vert 287
2023-06-02 03:16:28.533 [INFO] :: Vert 288
2023-06-02 03:16:28.549 [INFO] :: Vert 289
2023-06-02 03:16:28.566 [INFO] :: Vert 290
2023-06-02 03:16:28.582 [INFO] :: Vert 291
2023-06-02 03:16:28.598 [INFO] :: Vert 292
2023-06-02 03:16:28.614 [INFO] :: Vert 293
2023-06-02 03:16:28.630 [INFO] :: Vert 294
2023-06-02 03:16:28.646 [INFO] :: Vert 295
2023-06-02 03:16:28.662 [INFO] :: Vert 296
2023-06-02 03:16:28.679 [INFO] :: Vert 297
2023-06-02 03:16:28.695 [INFO] :: Vert 298
2023-06-02 03:16:28.711 [INFO] :: Vert 299
2023-06-02 03:16:28.729 [INFO] :: Vert 300
2023-06-02 03:16:28.745 [INFO] :: Vert 301
2023-06-02 03:16:28.761 [INFO] :: Vert 302
2023-06-02 03:16:28.778 [INFO] :: Vert 303
2023-06-02 03:16:28.794 [INFO] :: Vert 304
2023-06-02 03:16:28.810 [INFO] :: Vert 305
2023-06-02 03:16:28.826 [INFO] :: Vert 306
2023-06-02 03:16:28.842 [INFO] :: Vert 307
2023-06-02 03:16:28.859 [INFO] :: Vert 308
2023-06-02 03:16:28.876 [INFO] :: Vert 309
2023-06-02 03:16:28.893 [INFO] :: Vert 310
2023-06-02 03:16:28.911 [INFO] :: Vert 311
2023-06-02 03:16:28.930 [INFO] :: Vert 312
2023-06-02 03:16:28.948 [INFO] :: Vert 313
2023-06-02 03:16:28.968 [INFO] :: Vert 314
2023-06-02 03:16:28.987 [INFO] :: Vert 315
2023-06-02 03:16:29.005 [INFO] :: Vert 316
2023-06-02 03:16:29.023 [INFO] :: Vert 317
2023-06-02 03:16:29.040 [INFO] :: Vert 318
2023-06-02 03:16:29.059 [INFO] :: Vert 319
2023-06-02 03:16:29.078 [INFO] :: Vert 320
2023-06-02 03:16:29.096 [INFO] :: Vert 321
2023-06-02 03:16:29.115 [INFO] :: Vert 322
2023-06-02 03:16:29.134 [INFO] :: Vert 323
2023-06-02 03:16:29.157 [INFO] :: Vert 324
2023-06-02 03:16:29.176 [INFO] :: Vert 325
2023-06-02 03:16:29.193 [INFO] :: Vert 326
2023-06-02 03:16:29.211 [INFO] :: Vert 327
2023-06-02 03:16:29.229 [INFO] :: Vert 328
2023-06-02 03:16:29.250 [INFO] :: Vert 329
2023-06-02 03:16:29.269 [INFO] :: Vert 330
2023-06-02 03:16:29.286 [INFO] :: Vert 331
2023-06-02 03:16:29.302 [INFO] :: Vert 332
2023-06-02 03:16:29.318 [INFO] :: Vert 333
2023-06-02 03:16:29.334 [INFO] :: Vert 334
2023-06-02 03:16:29.350 [INFO] :: Vert 335
2023-06-02 03:16:29.368 [INFO] :: Vert 336
2023-06-02 03:16:29.384 [INFO] :: Vert 337
2023-06-02 03:16:29.400 [INFO] :: Vert 338
2023-06-02 03:16:29.417 [INFO] :: Vert 339
2023-06-02 03:16:29.432 [INFO] :: Vert 340
2023-06-02 03:16:29.449 [INFO] :: Vert 341
2023-06-02 03:16:29.465 [INFO] :: Vert 342
2023-06-02 03:16:29.481 [INFO] :: Vert 343
2023-06-02 03:16:29.497 [INFO] :: Vert 344
2023-06-02 03:16:29.513 [INFO] :: Vert 345
2023-06-02 03:16:29.529 [INFO] :: Vert 346
2023-06-02 03:16:29.545 [INFO] :: Vert 347
2023-06-02 03:16:29.564 [INFO] :: Vert 348
2023-06-02 03:16:29.580 [INFO] :: Vert 349
2023-06-02 03:16:29.596 [INFO] :: Vert 350
2023-06-02 03:16:29.612 [INFO] :: Vert 351
2023-06-02 03:16:29.628 [INFO] :: Vert 352
2023-06-02 03:16:29.644 [INFO] :: Vert 353
2023-06-02 03:16:29.660 [INFO] :: Vert 354
2023-06-02 03:16:29.676 [INFO] :: Vert 355
2023-06-02 03:16:29.692 [INFO] :: Vert 356
2023-06-02 03:16:29.708 [INFO] :: Vert 357
2023-06-02 03:16:29.725 [INFO] :: Vert 358
2023-06-02 03:16:29.741 [INFO] :: Vert 359
2023-06-02 03:16:29.759 [INFO] :: Vert 360
2023-06-02 03:16:29.775 [INFO] :: Vert 361
2023-06-02 03:16:29.791 [INFO] :: Vert 362
2023-06-02 03:16:29.808 [INFO] :: Vert 363
2023-06-02 03:16:29.824 [INFO] :: Vert 364
2023-06-02 03:16:29.840 [INFO] :: Vert 365
2023-06-02 03:16:29.857 [INFO] :: Vert 366
2023-06-02 03:16:29.873 [INFO] :: Vert 367
2023-06-02 03:16:29.889 [INFO] :: Vert 368
2023-06-02 03:16:29.905 [INFO] :: Vert 369
2023-06-02 03:16:29.921 [INFO] :: Vert 370
2023-06-02 03:16:29.937 [INFO] :: Vert 371
2023-06-02 03:16:29.954 [INFO] :: Vert 372
2023-06-02 03:16:29.971 [INFO] :: Vert 373
2023-06-02 03:16:29.987 [INFO] :: Vert 374
2023-06-02 03:16:30.003 [INFO] :: Vert 375
2023-06-02 03:16:30.019 [INFO] :: Vert 376
2023-06-02 03:16:30.040 [INFO] :: Vert 377
2023-06-02 03:16:30.056 [INFO] :: Vert 378
2023-06-02 03:16:30.072 [INFO] :: Vert 379
2023-06-02 03:16:30.088 [INFO] :: Vert 380
2023-06-02 03:16:30.104 [INFO] :: Vert 381
2023-06-02 03:16:30.120 [INFO] :: Vert 382
2023-06-02 03:16:30.137 [INFO] :: Vert 383
2023-06-02 03:16:30.155 [INFO] :: Vert 384
2023-06-02 03:16:30.171 [INFO] :: Vert 385
2023-06-02 03:16:30.187 [INFO] :: Vert 386
2023-06-02 03:16:30.204 [INFO] :: Vert 387
2023-06-02 03:16:30.223 [INFO] :: Vert 388
2023-06-02 03:16:30.240 [INFO] :: Vert 389
2023-06-02 03:16:30.257 [INFO] :: Vert 390
2023-06-02 03:16:30.274 [INFO] :: Vert 391
2023-06-02 03:16:30.411 [DEBUG] :: Adjust Rigging to Shape = true
2023-06-02 03:16:30.411 [DEBUG] :: DoERCFreeze Genesis9 Value null false
2023-06-02 03:16:30.411 [INFO] :: ERC Freezing: Neck Size
2023-06-02 03:16:31.216 [DEBUG] :: Setting PBMNeckSize modifier value to 0
2023-06-02 03:16:31.224 [DEBUG] :: CreateCharacterControllerProperty Genesis9 N-Ra G9 Nite RSSYG8_1FEJFM Lip Lower Size,RSSYG8_1FPHMNoseTipRound,RSSYG8_1FPHMNoseBridgeSlope,RSSYG8_1FN-Ra - Gen8 - Nite,RSSYG8_1FPHMPhiltrumWidth,RSSYG8_1FPHMPhiltrumDepth,RSSYG8_1FPHMPhiltrumAngle,RSSYG8_1FPBMNeckSize -0.9397590160369873,-1,0.5301204919815063,1,0.854285717010498,0.22857140004634857,-0.4514285922050476,-0.1809999942779541 /Actor/People
2023-06-02 03:16:31.225 [INFO] :: Creating Character Controller Property: N-Ra G9 Nite
2023-06-02 03:16:31.226 [DEBUG] :: SetMorphs Genesis9 RSSYG8_1FEJFM Lip Lower Size,RSSYG8_1FPHMNoseTipRound,RSSYG8_1FPHMNoseBridgeSlope,RSSYG8_1FN-Ra - Gen8 - Nite,RSSYG8_1FPHMPhiltrumWidth,RSSYG8_1FPHMPhiltrumDepth,RSSYG8_1FPHMPhiltrumAngle,RSSYG8_1FPBMNeckSize -0.9397590160369873,-1,0.5301204919815063,1,0.854285717010498,0.22857140004634857,-0.4514285922050476,-0.1809999942779541
2023-06-02 03:16:31.226 [DEBUG] :: Setting RSSYG8_1FEJFM Lip Lower Size modifier value to -0.9397590160369873
2023-06-02 03:16:31.237 [DEBUG] :: Setting RSSYG8_1FPHMNoseTipRound modifier value to -1
2023-06-02 03:16:31.247 [DEBUG] :: Setting RSSYG8_1FPHMNoseBridgeSlope modifier value to 0.5301204919815063
2023-06-02 03:16:31.256 [DEBUG] :: Setting RSSYG8_1FN-Ra - Gen8 - Nite modifier value to 1
2023-06-02 03:16:31.277 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumWidth modifier value to 0.854285717010498
2023-06-02 03:16:31.285 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumDepth modifier value to 0.22857140004634857
2023-06-02 03:16:31.293 [DEBUG] :: Setting RSSYG8_1FPHMPhiltrumAngle modifier value to -0.4514285922050476INSERT "RANDOM" RESTART HERE
2023-06-02 03:48:15.898 +++++++++++++++ DAZ Studio 4.21.0.5 starting +++++++++++++++++Well If You Want Gen 9 Capability In FaceGenBe prepared to pay [for Genesis 9 Capability In FaceGen] , $130.00 bucks worth for the "new" version , which basically just adds automatic dot placement and Gen[esis] 9 compatibility. I downloaded and took a look at the demo even loaded the created morphs into Daz , guess what ? The morphing system has not improved no more points for images to create more accurate morphs , same same. I have to say , if I am gonna shell out $130.00 bucks in this economy there better be a vast improvement and sadly ladies and gents this ain't it . That said come on Face Transfer for Gen 9 !!!
Aging Morphs for Genesis 8 (Commercial)Hey,
I just picked up this Morph package. I click on a Gen 8 model, double click the morph, and nothing happens. I don't see an instruction with the download, so wanted to at least hear if you're supposed to do something else before I ask for a refund.
Lashes for individual eyesThis seems not an issue of tweaking individual eyelash but fixing the distortion of right eyelash that comes from an eye or eyelid related expression, i.e. upper eyelid on the right 'squeezes' the eyelash into its geometry...
You may select the Eyelashes node and check its hidden properties, see if there's any eye or upper eyelid relevant ejcm (expression JCM) morph which can be tweaked... Since it's a pretty common issue, I myself usually use GoZ to fix it and import back as a delta morph to the eyelashes, pretty quick...Genesis 9 Tongue 100% on loading and posing?I found no Tongue related morph dialed on loading.. What is the morph dial exactly?
Default is as attached...
[Released] RSSY Character And Material Conversion Bundle Genesis 8 to Genesis 9 [Commercial]Jeremion said:
I only tried to convert Michael 8.1, and so far I don't get it fine as G9. Issues on the eyes (not well placed, nor good size and when trying to move them with powerpose, they just go out of the head xD) and the morph around the eyes is not OK. So, I don't know really what to do to get better result. I will try again.
Michael should not be a problem at all. You do not need the eye dialog. It sounds like a morph was created on the eyes that are moving them. Check in \data\DAZ 3D\Genesis 9\Genesis 9 Eyes\Morphs to see if there is an eye morph that could be engaging that messes things up (a quick way is just to rename this directory so none of the eye morphs engage. Look for this folder under the first directory listed in the Daz Studio Formats section of the Content Directory Manager (which is usually My Library)
RiverSoftArt said:
Submitted update today:
- Added user options for Transfer Utility settings to hopefully improve morphs
- Added Distance Tolerance option
- Added Adaptive Tolerance option
- Fixed ExecuteScript to NOT do an IncludeFile call. This was messing up on the mac
- Fixed bug in LoadMaterialSuits function where calling IncludeFile twice was messing up on the mac
Here's hoping the additions will work. I'm glad to have helped even if only a bit.
Thanks for testing
G8M Loading ErrorFirst off, Thank you all so much for the help. I found the head morph and deleted it then cleared the cache and it solved the error. How can I edit the Head morph so that it doesn't do that anymore, or do i need to just create the morph again and this time make sure to save it correctly?
G8M Loading ErrorBejaymac said:
A missing DUF/DSF warning when loading a base figure means you have at least one morph with bad Parent data, a quick check of the log shows you have three of them, the internal asset ID's are "Taishi Zhao Head Morph", "Test" and a second "Test".
Probably just as well bad "Parent data" DSF files don't get loaded, as two files with the same internal ID will cause coding conflicts at the very least.Find the three files and delete them, then start DS and go edit > preference (or hit F2), near the bottom of the General tab you'll see a section called "DSON cache files", at the end of the line will be a "Clear" button, click it to wipe out the cache just in case there's any stray data in there that shouldn't be.
Any idea what folder to find them in or how to find out what folder?
G8M Loading ErrorA missing DUF/DSF warning when loading a base figure means you have at least one morph with bad Parent data, a quick check of the log shows you have three of them, the internal asset ID's are "Taishi Zhao Head Morph", "Test" and a second "Test".
