RRRR "As the story goes" Render Contest *CLOSED*
Totte #2
(I put the final one here too)
Campfire stories
Out of luck to find work, Will went to the camp site at the high peek of mount Souza. There he met Chris, a former star-fleet pilot, and proud owner of a ship named Century Goose. Chris was in company with his first mate, Naomi, and the bot DBU-1802. Chris was looking for an additional crew member for his transportation operations, as Naomi had decided to jump ship and retire.
Not to be late for a wedding
The crew of the spaceship Century Goose, got a very odd transport request. Crates with special flowers for the wedding of the daughter of Governor Fidel van Stout, Gabriella van Stout. The wedding was to take place in the only town on the planet Foxton, Foxton city. The flowers are very special can cannot be grown at Foxton, as they require an atmosphere with a high level of Argon, an atmosphere humans cannot survive in. The flowers can only grow on Basilax XII, far out in the outer rim. Suddenly, on the way back, the Argon FLTZ feeder unit sounded an alarm. There was some kind of blockage in the heat exchange unit, but a quick repair fixed it.
Computer says no
Will, Kento and Chris, three independent out rim cargo transporters, by some called smugglers, arrived at the moon Firo-VII to refuel their vessel Century Goose. The automatic fuel station refused to accept their transponder codes, it just said "Computer says no". Chris, who had worked at a similar station knew where to give it a little nudge. After the little nudge it said "The codes are old but they still checks out" and then they could finally fuel up.
A political marriage
When they finally reached Foxton city on Foxton, the flowers were delivered and Will thought that this was it, but, Governor Fidel van Stout asked Will to be the unrelated witness at the marriage. A marriage witness is a tradition here in the outer rim, to prevent forced marriages. The witness has one purpose, to check that both parties are committed to the marriage by their own free will. Will realised that in this case, Gabriella van Stout was not. Her father has a huge debt to Sir Davac, his soon to be son in law, a debt that would be erased by the marriage.
The Escape
Will took Miss van Stout under the arm and they made a quick exit through the church backdoor. He found an air motorcycle, and they rode off towards the old water mine, in ancient times call an oasis. There, they met Max Fredricks, privateer and smuggler. They decided to come aboard his large ship, and leave Foxton for good. Mr Fredricks looked at Will and said, when Miss Stout could not hear, "I think you have something going on there..."
The Kiss
After they successfully escaped Foxton, and took a lift with Max Fredricks to the small moon of Zepa-VII, Will and miss Stout finally got s moment for themselves. Miss Stout said at the small bar table: "Will, you are my knight in shining armour, my hero, my prince!". Will got so touched that he moved over to her side, and kissed her, and poof, he was turned into a gigantic toad, and they lived happily ever after.
RRRR "As the story goes" Entries only threadTotte #2
"Space fairytale"Campfire stories
Computer says no
The Escape
The Kiss
Mattymanx - a detailed .22lr spy pistolMattymanx said:
If the original artist grants permission or has a license allowing modifications then you would be ok to post it online. I have many conversions of Star Trek and Star Wars models for Daz Studio that were done because there was permission granted before I downloaded the model
Hey there @Mattymanx - I'm a big fan of your work! The site I pulled the model from does not explicitly list any licenses for use, so I've reached out to the author to find out directly from them. I'll update when and if I hear anything back. I'd want to UV map the model before I released it, and I'm fairly novice at that - do you think you could help me out if it comes back favorable?
Mattymanx - a detailed .22lr spy pistolguitarec said:
I did some work converting a Beretta 950B (.22 short) 3D CAD object I found online. Was quite the learning experience. Ultimately, I modified a duplicated barrel object to add a treaded extension, rigged everything with sliders, created a few material presets, etc. Unfortunately, the mesh is high poly, and because I didn't make the mesh myself, I don't believe I can release it. Also, I didn't unwrap the meshes for UV maps, so the materials look flat. I did post a suggestion here for "Modern Compact/Concealed Weapons", hoping Porsimo sees it...
RRRR "As the story goes" Render Contest *CLOSED*Block #2 Pull#3
#4850 Sculpted Rocks Collection (Rendo) (Crap was a Vue product, blame Rendo CSV again)
#4388 Viking Makeup Shell and Jewelry Addon for Genesis 9 (#88705)
#3092 Construction Bot (#67185)
#469 Around the Campfire (#22182)Keeping:
#934 Renegade for Genesis 3 Male(s) (#23371)Also used:
Willis HD for Genesis 3 Male ds + Blue Steel Poses
Christian 8 + Sci-Fi Settler + Commander Hair
Skies of Economy
Improvised Benches Construction Kit
Sophia 9 HD + Chet Hair + Recon Outfit + Next Generation Rifles and AccessoriesScripts and Shaders used:
Ultra Scenery XTPrequel to Pull #2
Campfire stories
OT - 'cause some of us need a little breakCatherine3678ab said:
A comedian piano player :-)
This one reminds me of the Born Free/Star Wars Theme:
https://youtube.com/shorts/ryNZwPQAP4I?si=btFJl14nc1221aPX
[snip]
Ah, Victor Borge
. Yes, Danish comedian Victor Borge was a very funny guy as well as a good pianist (when he wanted to be). Several comedic skits. But probably the most famous is his phonetic punctuation marks skit. Well, it was very funny in the '60s.
OT - 'cause some of us need a little breakA comedian piano player :-)
And here's another way to ride a bike ;-)
https://youtube.com/shorts/xkCxUW1WeQQ?si=OkDLiTEl_j9txovn
Daz Jedi Outfit + addonmemcneil70 said:
I haven't watch the later group of Star Wars movies, but based on my memories of the first group, Ep. 4 - 6, I found in my runtime some options that may either give clothing for background characters (non-Jedi) or possibilities for Jedi robes with work. Unfortunately, most of my best ones were in the M3/M4 clothing and I am not listing them. Many were for females, but could work on males.
From Rendo by Lully, dForce - Divergence for G8F
The PA Sshodan's store - https://www.daz3d.com/sshodan
https://www.daz3d.com/dforce-legend-outfit-for-genesis-9 and https://www.daz3d.com/legend-outfit-texture-add-on
https://www.daz3d.com/eastern-fantasy-warrior-outfit-for-genesis-8-males and https://www.daz3d.com/eastern-fantasy-warrior-outfit-textures (the main outfit caused me to recall Star Wars when I first saw it. The textures are a bit much.)
https://www.daz3d.com/dforce-huntress-outfit-for-genesis-8-females
https://www.daz3d.com/dforce-hooded-outfit-for-genesis-8-females and https://www.daz3d.com/dforce-hooded-outfit-textures
https://www.daz3d.com/dforce-dystopian-future-outfit-for-genesis-8-females and https://www.daz3d.com/dforce-dystopian-future-outfit-textures
https://www.daz3d.com/sky-jumper-outfit-for-genesis-8-female-s (it has textures but they are way too brightly colored for Star Wars.)
https://www.daz3d.com/street-sweeper--cyber-samurai-for-genesis-8-male (Not sure if you could use bits and pieces of this outfit and with shaders tone it down.)
https://www.daz3d.com/dforce-dawn-warrior-outfit-for-genesis-8-males and https://www.daz3d.com/dforce-dawn-warrior-outfit-textures (not as flowy as you are looking for, but if matched up with a cloak from Sshodan or another PA...?)
There are the laser sword thingies in Daz's store, so I am sure you have them but this is the latest I have: https://www.daz3d.com/laser-swords-and-poses-2-for-genesis-3-and-8
Unfortunately, flowing outfits for the guys seem to be scarce. I thought I had more Asian style robes, but couldn't track them down except one that is wrong for your purpose and exploded everytime I tried to use it. Maybe other folks on the forum knows of good options here or on Rendo that will work as Jedi robes.
I do know that good shader packs have been coming out that would fix any fabric issues even if the colors are wrong.
Mary
Yeah, well I just took the time and fixed up the Jedi outfit from Star Wars Battlefront 2 (2017) game.
But thanks for the suggestions... even tho I use G9 now
Furious over 93799 Sci-Fi Add On Bundle - Why? Please ReadI agree with the OP, that it would have been better to list the
https://www.daz3d.com/sci-fi-space-kit-bundle
as requirement: Sometimes wishful thinking let's me forget to check out everything, before i buy.
Still, as a star trek fan i guess i would swallow it and buy the other bundle. Edit: it is 67$ atm.
Furious over 93799 Sci-Fi Add On Bundle - Why? Please ReadEach of the bundled packs state what they are an add-on for: NCS Runner, NCS Mess Hall, Sci-Fi Tech Gadgets, etc... And the sale page clearly shows the base items and the Star Trek add-on. This is more an issue of paying attention than poor advertising.
Furious over 93799 Sci-Fi Add On Bundle - Why? Please ReadHello All,
This is mainly a vent or a rant because this isn't the first time this happened to me, but it is a poor selling tactic. The first time it happened was with a artist selling an item, but this time this is a Daz product.
Okay, so I purchased item #93799, which is the Sci-Fi Fan Art Add-On Bundle. Being a huge fan of Star Trek, I figured this was a must have. So I purchased it. Of course, I went through everything starting with the character add-ons, and those were fine. However, when I got to the ship it wouldn't properly load. It kept saying that some items were missing. So naturally I think there is something wrong with the package. So I was ready to write to technical support about it, but I tried the other ship based packages today and they all had errors saying items are missing. I said to myself that can't be because why would they release a bundle with so many issues.
So after a bit more digging and pulling up the individual items I look in the requirements section, and each one of the ship based items is just an Add on. So I am here wide eyed about this because if you click on the bundle, in the requirements section it says: Genesis 9 Starter Essentials:
https://forum.daz3d.com/sci-fi-fan-art-bundle
Now if you go down to the decription. NO WHERE does is it say that it requires the individual NCS items.
Not for nothing, when you release an item like this and that it doesn't include a required item for it to work, SAY SO!
Yeah, now, I know that one might argue that the package says ADD-ON, but not to what. The skins and face shapes work fine given that it does tell you that it is for Genesis 9 and that you need the Genesis 9 Starter Essentials. BUT, there is NO mention of the required ship items. I only found out that you need each individual NCS package by clicking on the individual items and reading it's requirements.
Not for nothing, but that is a poor way to advertise a product and I am NOT happy about it, especially given the cost of the product.
There should be a paragraph right at the beginning, in addition to what is needed under "requirements", stating that the NCS product line is needed for ship add-ons to work.
Needless to say, I am quite disappointed. So yeah, I am going to return the package.
Just my 2 cents.
There's Always Another Sale Thread -- Discussions Only Pt 2I got the Sophia 9 bundle because A) I had a bunch of expiring tokens, B) I personally need more sci-fi stuff in general and C) I like the overall look of Sophia and what the bundle offers.
However, I agree that the recent releases are looking mostly the same. It's very similar to the Kara 9 Bundle (which was pretty cool). And when you add that plus the recent Star Trek bundles, it's a bit too much Sci-Fi in a short period. If another comes along like this, I might just get the character and that's it. I would have loved a Lady Luck bundle with Celtic fantasy assets and magical effects. I'd love for it to include:
Character-A dainty, Celtic look to rival Victoria (way too many characters look the same, too). Hair-A long flowing D-force with an addon that include magical effects. Makeup-Colorful makeup and also a golden skin variant of the character(just like Snow Queen). Outfits-Something trickster or magician themed. Unicorn-an addon to the Daz horse 3 with pegasus wings. Lucky special effects and magic weapons.
It would be strange (eh, maybe not for DAZ) but at least different. Come on, Daz, it's still March; It's not too late to make this kind of bundle!
Star Trek Builders Unite 8: THE REBOOTCould we get a Jeffrey Combs face shape? He's been like nine different Star Trek characters. Plus for Halloween we could do Herbert West.
AIUTO...CHI CONOSCE L’ITALIANO? PARTE QUATTORDICIMolto bello, ma si vede l'esterno tramite vetrate ^_^;;;
E' anche un po' piccola per le mie esigenze.
Io ho molti ponti di comando alla Star Trek, col Capitano al centro, e cerco un'astronave in stile compatibile, possibilmente con motore a curvatura.
Comunque, questa è veramente bellissima, e ho già il bundle.
^_^
AIUTO...CHI CONOSCE L’ITALIANO? PARTE QUATTORDICISecondo me c'è una inesattezza nella pagina di Wikipedia italliana.
Nella Wikipedia giapponese c'è scritto 堀井雄二と鳥山明がテレビアニメ(勇者アベル伝説)を担当し、新人の稲田浩司とライターだった三条陸が漫画担当に起用された。Cioè che Toriyama ha lavorato all'anime, non al manga.
A parte questo, mi interesserebbe trovare qualche astronave grande almeno come l'Enterprise, con uno stile alla Star Trek. In particolare, dal ponte di comando non si dovrebbe vedere all'esterno tramite vetrate.
Guarderò al più presto su ShareCG, grazie ^_^
AIUTO...CHI CONOSCE L’ITALIANO? PARTE QUATTORDICITiziano said:
Kainjy said:
Toriyama oltre a Dragon Ball aveva fatto anche Dr Slump e Arale, DAI la grande avventura e collaborava nel mondo dei videogiochi (Dragon Quest, Chrono Trigger e a breve usciva Sandland).
Non credo che Toriyama abbia fatto DAI. E' solo disegnato con uno stile simile.
https://it.wikipedia.org/wiki/Dragon_Quest:_The_Adventure_of_Dai
Ci ha lavorato, certo non al 100% (come anche Dragon Ball dove veniva aiutato vista la mole di episodi e manga usciti). DAI tra l'altro è un "remake" di Dragon Quest 4, serie dove lui ha sempre fatto il character designer.
L'astronave che stile lo vuoi ? Stile Star-Trek ? Stile Star Wars ? Stile Mass Effect ?
Su ShareCg si possono trovare molte cose interessanti: https://sharecg.com/pf/full_uploads.php?pf_user_name=ptrope&division_id=0&s=dd&pn=1
Star Trek Builders Unite 8: THE REBOOTI have never known Paramount/CBS to go after fan art as long as it's free. Even if it's not family friendly.
FWIW, they've joined the TeePublic fan art program. You can sell Trek stuff at TeePublic, as long as it follows their guidelines.
RedBubble also has a fan art program. It used to include Star Trek, but no longer does. Not sure what happened there. The stuff that was submitted when Trek was a "branded partner" is still for sale, but you're no longer allowed to submit new Trek stuff.
Greybro's Ground - A Render A Day
Thanks so much. It's really got my imagination firing.3Diva said:
I love the Star Trek fan art render! That turned out great!
Daz Jedi Outfit + addonI haven't watch the later group of Star Wars movies, but based on my memories of the first group, Ep. 4 - 6, I found in my runtime some options that may either give clothing for background characters (non-Jedi) or possibilities for Jedi robes with work. Unfortunately, most of my best ones were in the M3/M4 clothing and I am not listing them. Many were for females, but could work on males.
Mary
Daz Jedi Outfit + addonGordig said:
MetalSunde94 said:
So hope to "again" see some Star Wars alien head morphs for G9!
Star Wars head morphs would be quite a bit more involved than Star Trek, given that Star Trek aliens are just humans with some stuff glued to their face.
Would be perfect for G9's HD capabilities then!
