• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Problem with DazToUnreal for G8/UE5.2 - Broken Skeleton? [FIXED! :D]
    If you used the Daz To Unreal's default G8 skeleton in UE5.0. Maybe after update to UE5.2, the Daz To Unreal plugin's default skeleton changed or lost the reference.
    You can try to regist the skeleton to the new G8 skeleton under engine-plugin-DazToUnreal in UE5.2.
    Or copy the G8 skeleton to a custom folder in UE5.0 and regist your skeletal mesh to the new skeleton and then transfer the project to UE5.2.
    By
    woyodo woyodo July 2023 in Unreal Discussion
  • Is there a product that can change G81's skeleton to G9 or UE5'S Skeleton?
    Gordig said:
    If UE5 has an auto-rigger, that's what you should use. You can't simply "change" the skeleton without needing to redo the weight mapping.
    The Twist Bones between Arm and Leg make the animation system a problem to modify. Like retarget and some nodes in animBP. So, if there is a Skeletal Change product to transfer to UE5's skeleton and auto weight mapping, that will be very helpful.
    By
    woyodo woyodo July 2023 in Product Suggestions
  • Let's appreciate/discuss today's new releases - ongoing thread
    barbult said:
    The forum finally let me upload this ZIP file for closing the Sexy suspender Shirt for G9. (I only made a morph for the G9 shirt, not the G8 shirt). Open the zip file and copy the data and People folders to your content library. Use the Sexy Suspender Shirt Closed G9 wearable preset to load the closed shirt on Genesis 9. You will find the wearable preset in People/Genesis 9/Clothing/AF/Sexy Suspender folder in the Content Library. Please let me know if this doesn't load properly for you, in case I left something out of the ZIP file.
    The wearable preset will set the Shirt Closed morph to 100%, add a dForce Add-on and adjust the position of some of the buttons. The Shirt Closed morph is not intended to be used by itself (without the Wearable Preset), but you can experiment with it if you wish.
    The wearable preset has worked pretty well for me on "normally" shaped characters, but it doesn't work well on fat bellies like Nikolai or Thimor. Remember that the FBMs included in the Sexy Suspender product will cause distortion when they get automatically dialed in by Daz Studio, but dForce and smoothing have overcome most of those problems for me.
    Thanks so much! Will download tonight after work immediately. You're a gem.
    By
    tsroemi tsroemi July 2023 in The Commons
    You da best! I'm wishlisting that product now.
    By
    paulawp (marahzen) paulawp (marahzen) July 2023 in The Commons
    Cool ~ enlightened though I haven't got the item yet, bu now I know what could be shared...yes
    By
    crosswind crosswind July 2023 in The Commons
    By
    barbult barbult July 2023 in The Commons
  • Scene optimizer and DUF file size
    Yea, that was the culprit ~~ the simulated result on each frame with be saved in DUF file. I ever made an animation with simulated hair and dress on timeline (1700 frames), then the saved file size was nearly 3GB...
    If you just go for static rendering while have to use timeline to simulate a dForce item, you may export the simulated result of the last frame to obj file, clear the simuation and import back obj with Morph Loader Pro to create a single dial of the 'simulated morph' on that dForce item. That'll be all fine...
    By
    crosswind crosswind July 2023 in Technical Help (nuts n bolts)
  • What Male Character/Skin/Eyes Are This?
    The skin looks a bit like Alistair, but the morph is probably a custom one of the Promo artist and likely not available for purchase.
    By
    zombietaggerung zombietaggerung July 2023 in The Commons
    felis said:
    You should be able to save the morph, save the dForce add-on, and then save the clothing as a wearable preset.
    Then your packet only include data that your yourself has generated, as the rest will reference the product.
    That's what I thought, too. Thanks for the confirmation.
    By
    By
    felis felis July 2023 in The Commons
    barbult said:
    tsroemi said:
    barbult said:
    I saved it as a wearable preset with the Blender morph I created applied at 100%. and the dForce addons I created to hold the closed area closed, and the changed positions of rigid follow nodes and buttons. The lower buttons had to be moved to the top layer of the closed area, as though the shirt were buttoned and the buttons poked through the buttonhole. It might be better to save it as a separate asset, so those inappropriate FBM don't get dialed in. Good suggestion, I think.
    This looks awesome! Is there any chance you could upload the morphed version?
    I will have to investigate what would be feasible/legal. I can't upload anything that would include the original asset data. because that would not be legal. The Blender morph by itself is not enough for the total result.
    No, you can't... I was blamed once by Richard...crying
    By
    By
    barbult said:
    crosswind said:
    barbult said:
    xyer0 said:
    I wish dForce Sexy Suspender Outfit had a shirt closed morph. It's a great looking shirt. I guess I could put a t-shirt under it.
    I played with it in Blender and i was able to close it. It's not perfect. I'm not very experienced with Blender, so I'm sure somebody else could do a better job. None of the included FMBs really work after closing it, because they expect the vertices to be in very different places. Between smoothing and dForce, I didn't have a problem fitting it to Kala 9.
    (My rendered image won't attach. Usually it works very late at night. Not this night.This forum is really falling apart.)
    Edit: Another day, another change in forum behavior. I was able to upload my image tonight.
    Nice play ! I don't have it but it might be better to save a unique Figure / Wearable preset for the 'Closed Shirt'... It's not really necessary to make a single dial for 'Closed Morph'... updating Base Geometry may be just fine. Some existing shirt morphs may not be needed either while some could be tweaked in Blender... As for FBMS, it shoud be fine with dForce and Smoothing modifiers. It fits pretty well on Kala.
    Pretty good techniques indeed .  yes
    By
    @barbult that is a great job.
    And if that is how the outfit had come I might have at least looked at it or even bought it. It is a pity as it looks like the PA put some nice detailing into the pants and shirt, to leave off an option to make it more versatile and saleable.
    Mary
    By
    memcneil70 memcneil70 July 2023 in The Commons
  • Basic tutorial for transferring Genesis3 female morphs to Genesis8 female
    crosswind said:
    6 years ago.... You just search the morphs' Names / Lables from Parameters pane, could not find them?
    Nope. I've found some videos by WP Guru that explain a process that is working for me, so until I figure out why GenX isn't working anymore on my system, I can transfer older morphs to Genesis 3. XTransfer is working fine for me, so going from G3 to G8 isn't a problem, and I can use what I've learned to transfer from G8 to G9 if I need to.
    By
    riftwitch riftwitch July 2023 in Technical Help (nuts n bolts)
    By
    By
  • Shape Shift for Genesis 9 (Commercial)
    Are there plans for a version of  X-Transfer from Genesis 8/8.1 to 9 in the future?
    By
    Hatchetman Hatchetman July 2023 in Daz PA Commercial Products
    By
    This is what a unique ID looks like. If this is the same as another morph (it ignores prefixes for some reason) it causes a duplicate error. I added a generated string of random numbers and letters to ensure it is unique.
    By
    Zev0 Zev0 July 2023 in Daz PA Commercial Products
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
