• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • [SOLVED] Rigging Heeled Shoes Question
    Hello!  I don't post much and I hope I got this in the right forum.  Apologies if I did not.
    I've modeled a pair of wedge heeled boots for use with G9F.  When loaded in and fit to G9, there is no distortion of the mesh.  I have them rigged and weight mapped and the rigging works great.  I've created "fit" morphs for all of the Daz 9 characters and official body shapes I own to fix any issues with those shapes and they work perfectly when those morphs are dialed into G9.  There's no distortion or mesh breakage at all when posed.
    [I tried using up-to-date Edge and Chrome browers and both PNG and JPG files formats and I cannot get an image to upload for anything.  It's stuck on "uploading" and never finishes.  They're tiny... in the KB range.  Help?...]
    My problem occurs when a morph that is not "built into the boot" is dialed into G9.  For those morphs, the arch of the top of the boot "breaks" (it's a jagged, raised line in the mesh that is horizontal-ish across the center of the top of the foot, not the sole) and the only way to fix it that I've found is to bring it back into Blender, smooth it, and create another morph for it.
    Is there a way to rig the boot to avoid this issue?  I'm specifically talking about non-official "9" characters.  If it's an official G9 shape or dial used in a vendor character, I can fix it.  But for some vendor characters that morph the foot without using the official dials, there is breakage.  It likely has to do with autofollow and the character morphs in question, but that doesn't get me any closer to an answer.
    Boot specifics:  Used transfer utility and Rigged with weight maps.  No toe bones (all toe bones removed from boot).
    Things I've tried to fix it:  Modifying weight maps directly, adding adjustment morphs to the top arch.  I even looked at rigidity mapping and dForce weight mapping to see if I could make the shoes dForce.  Nothing works once it's fit to G9.
    I'm looking for options if there are any.  :)  Any and all help is greatly appreciated!
    [EDITED TO ADD]  I've also tried smoothing and sub D.  Neither worked.
    By
    Saba Taru Saba Taru July 2023 in Technical Help (nuts n bolts)
  • the cloth to daz and transfer utility appear jagged and cracked,how to fix it
    Mada said:
    You will need to do some weightmapping after using the transfer utility. Because of the design, (and this is especially true of long sleeves far away from the figure or loose clothing) Daz Studio can only estimate which part of the garment belong to which part of the figure. So with long sleeves like that half of the sleeve will be set to the hips, some to the arm and then when you pose the outfit breaks because the face grouping is incorrect.
    There are 3 ways around it - one is to simulate using dforce from a standing pose and a default figure and then transition on a timeline into your pose and shape, the 2nd is to do at least some weightmapping so that when you pose the figure the sleeves move with the arms and not the hips, and the third is to pose your figure and drape in MD and then bring that into DS, but that means you can only use it as a static prop.
    I have some tutorials and videos on rigging clothing here, still a WIP but its useable :) : https://pixeldustvr.com/DazTutorials/
    Looking at the simulation result - did you turn on smoothing? That will help with the jagged points
    Wow, this tutorial is really cool, just what I need. I would love to learn how to add weights or dfroce to clothes, especially very complex clothes. When I lowered the smooth iterations, the cracks disappeared, but the jaggies remained
    By
    sucan2015 sucan2015 July 2023 in Daz Studio Discussion
  • Beak Problem
    Was the bird made by a 3rd party specifically for Poser?  Did you model the bird mesh yourself, then rig it in Poser?  Did you convert to fbx format out of Poser and import into Studio?  Or, did you make the mesh, rig it in Daz Studio, and it happens to work in Poser?
    Are there separate bones for the upper and lower part of the beak, which I assume from the weightmapping statement?  Because a beak is relatively stiff, does it need to be rigged?  Could approximate what you want with a morph to open the beak?  Note that a morph will not turn like an arc, so the anser may be 'no' if you are not rendering still images.
    You will find several tutorials on related topics in SickleYield's youtube channel.  She covers rigging, adding bones, weightmapping, and more.  Good luck.
     https://www.youtube.com/@SickleYield/videos
    By
    Diomede Diomede July 2023 in The Commons
  • Dforce Destroying Cloth
    Have you used Transfer Utility to fit / conform the skirt to the figure?
    By
    crosswind crosswind July 2023 in New Users
  • Julius 9
    AllenArt said:
    xyer0 said:
    AllenArt said:
    Julius 9 mixed with Freja. 40% Freja/60% Julius - specifically the Julius Young Adult morph. Not bad ;). The skin is Freja's too as is the HD. I did angle her eyes up about 50% because the Julius morph pulled the outer corners down.
    AI is jealous. I love your earrings; thanks for making them free.
    Aw, you're welcome :)
    I'm finding that Julius mixes in pretty well on the female side, especially if you like that type of nose. My mother has one, so I don't mind it a bit. LOL
    The earrings are so good everyone should have a copy.: https://www.renderosity.com/freestuff/items/88254/fandangle-earrings-for-genesis-2-female . If AllenArt isn't going to shout about them, I feel I need to!
    Regards,
    Richard
    By
    richardandtracy richardandtracy July 2023 in The Commons
  • Linking a JCM with a rotation range
    Dodger said:
    I seem to be having success just adding a controller when I load the morph target. Then all I have to do after is set the min to 0 and hide it, it's looking like. Unless I'm misinterpreting this.
    That method works well yes. :)
    By
    Mada Mada July 2023 in Daz Studio Discussion
    By
    Dodger Dodger July 2023 in Daz Studio Discussion
  • [Released] Magic - Smart Actions for Posing [Commercial]
    nlbs said:
    Fairyteller said:
    nlbs said:
    Fairyteller said:
    nlbs said:
    After the last update. There's a serious problem with the product. For some reason, Right Shoulder and Right Collar reset their positions after applying Magic Pointer to bake to transforms on Genesis 8.1. Same goes for Left and Right Foot.
    I can't reproduce it for some reason. It feels to me like it's working as intended but maybe there's something I'm not seeing.
    If we take the Right Shoulder for example, do you know of a set of rotation values that is problematic/lost?
    Here's the problem in question in detail. I hope this helps.
    https://imgur.com/a/GdlNjGp
    It helps a ton, thank you.
    I think I understand what's happening. Do you by any chance use any of these Pose Control morphs, such as "Arms Front-Back Right" or any other pose morph slider?
    https://i.imgur.com/ScHUpgi.png
    Could you maybe try resetting them all to their default value before you bake, and tell me if this "fixes" the baking problem? "Fix" is not the right term, I know, but if my intuition is correct then I have a pretty good idea how to fix this for real.
    No, I don't. I only use Pose Controls for the Neck and Torso, but I always bake them to Transforms. And I don't use any products such as Pose Architect or the like. But you were absolutely spot on about Arms Front-Back. That was the culprit. Apparently, the pose I applied for the Arm used Control Pose for Arms, which is super odd considering it's from a product and products usually have all the poses baked to Transforms. Since I never use Arms Front-Back, it didn't occur to me to check for that. From now on, I'll always keep my eyes on such shenanigans. Thank you for your amazing tool and great support.
    Cheers!
    I think I have an idea to somehow make it work even with these controls dialed in. Compatibility with other methods of posing is important to me, I will do some internal testing, see if there's an elegant solution for the best of both worlds.
    Have a great day!
    By
    Fairyteller Fairyteller July 2023 in Daz PA Commercial Products
    Actually Hanfu (汉服) is pretty unique... Transfer Utility cannot well project it with proper weight even on a Base figure, especially in the areas of armpits (with long and wide sleeves), crotch (inner thigh), etc...
    Opt1: Create projection template(s) base on typical Hanfu designs if you frequently make Hanfu(s), then use the template(s) in TU.
    Opt2: Send it back to MD to re-simulation or fix it with Blender or Zbrush, etc. and import to Daz to update the Base geometry of Hanfu.
    Besides, there're still some more tricks in the workflow from MD to Daz, depending on your expectation...
    PS: As for the weird result from the poses, you better add dForce modifier and simulate it with a timeline or at least from memorized pose... and some pJCMs fixing have to be needed as well.
    By
    crosswind crosswind July 2023 in Daz Studio Discussion
    By
    nlbs nlbs July 2023 in Daz PA Commercial Products
  • Which figure converter is better (xx to Genesis 9)?
    Figure Converter in my opinion is better tried both. Figure Converter is simple to use and has had very good results from tests. but have not tried complicated monster-type  morph type characters as they are not my bag. But I would suggest going and having a look and reading the comments on both the sales threads on the  commercial Products  forum
    By
    ragamuffin57 ragamuffin57 July 2023 in The Commons
    By
  • July 2023 - Daz 3D New User Challenge - Portrait Rendering and L.I.E.
    Portrait Challenge.
    I am probably cheating because I did not make this render specifically for the challenge, but it is a test render of a morph I made. But, it is after all, a portrait.
    I am calling this model Irene. (I did not make the textures. That is on my to-do list)
    Irene
    This is probably my favorite render so far. I need to update my gallery!
    By
    Rafael Rafael July 2023 in New User Contests and Events
  • Julius 9
    By
    AllenArt AllenArt July 2023 in The Commons
  • How to make imported clothing work with Genesis 8
    I have the opposite problem where the model perfectly fits my model but the material didn't transfer over so that object is completely white.
    By
    djricky088 djricky088 July 2023 in New Users
  • Support for exporting all "options" (ie clothes, skins, textures) a character has.
    aweswan said:
    I used the free mcs with UMA2 a good while ago, and made a very basic character creator. Didn't know there a MCS package here on DAZ though. Still, a concentrated effort between reallusion, daz, unreal and Unity could produce an amazing character solution for games.
    Does Daz have a plugin system ? Maybe I could write an exporter myself?
    The code for the bidges is on github
    https://github.com/daz3d/DazToUnity
    What is great about the MCS code is that it streams morph data programatically and also allows attaching the clothes on the fly (with the morphs).
    No reason with a bit of effort if couldn't adapted to G8 or G9 imho as the code is in the files to create the steam data from an fbx.
    https://forum.unity.com/threads/released-morph-character-system-mcs-male-and-female.355675/page-79
    https://github.com/mcs-sdk/mcs
    By
    TriCounter TriCounter July 2023 in Unity Discussion
  • Julius 9
    By
    xyer0 xyer0 July 2023 in The Commons
  • Old Content.....
    FirstBastion said:
     I generally dont do cross generation conversions.
    Personal choice and I respect that. It's certainly not something that works for everyone or with every product. Personally, I don't like to buy something and not feel I've got my moneys worth out of it. So to buy a $15-$20 converter app and extend the life of something that I enjoy using really does work for me, and as an (extremely) amateur 3D artist, justifies the process needed to myself. I'm not selling my art so this meagre expenditure satifies my needs.
    For example. I love Syltermermaids V4 textures, not just for themselves but they work well with most of the output jpegs I get from Faceshop 6, especially her Pia set. I like FS6 more so than Abalone's recent versions of Headshop and Daz's Face Transfer so to use those head textures and morphs that I've already created only needs a texture converter for V4-G8 (thank you Blacksmith3D) and D3D's V4-G3 morph converter coupled with RiverArts Software's G3-G8 character converter. Trying to recreate the characters I've already made with the new apps hasn't worked yet and would add too much additional work to make a render worthwhile.
    It's whatever you are happy with.
    By
    Beyond_Dreams Beyond_Dreams July 2023 in The Commons
  • Face Mojo importing Facial Animation Morphs to Unreal Engine
    It worked on Daz version 4.12 but after that they broke it. I'm now looking into Poserecorder and it does work but the results aren't as great as a thought. I'll keep playing with it to see if I can improve it but I am also looking into Face Live Link.
    It works in the newsest version of daz3d.
    I'm not sure how it worked back when it was 4.12 but there is a way to get it working in the newest version of daz3d.
    There is probably a better way to do it than the way that I am but here it is:
    Run the FBX mojo bake as normal but do not delete the facial mocap fbx(shows up as grp_scale for me inside the scene) file that you imported into daz3d.
    Instead after running the bake, make the g8 figure a parent of the grp_scale then you can export to unreal using the bridge rather than saving as a fbx file. I'm not sure but I do think it's important to include the animation when exporting to unreal. Also when you send all of the morph targets(I sent all face mojo targets(wrinkles and strength didn't export but I still include them but I'm not sure it's neccassary to include them) on the last window before you accept the export you need to go and change the morph target rules and change all the FaceMojo morphs from export to bake and then it should work.
    if it says animation failed to import due to the animation time not lining up with the framing, try decreasing the total timeline range by 1 frame that usually works for me but I just now started getting it to work so I haven't played with it too much.
    I have been having an issue with the G8 female mojo animations in Unreal where it will ballon the character but once the morphs are in Unreal you can retarget animations to her from the male figure.
    good luck.
    By
    boatangelkeith boatangelkeith July 2023 in Technical Help (nuts n bolts)
  • [Released] ManFriday’s Figure Converter for Genesis 9 [Commercial]
    Successfully converted a couple of my G8Ms over the weekend and am generally happy with the results. I have the following questions:
    1. The manual made reference to an auto-rig option that I'm not seeing in the UI. Will this feature be available in a future version?
    2. This plugin doesn't scale the eyes which are now a separate attachment, so some of the characters eyes will be too small/large for the sockets post-conversion. Any chance this can be automated so we don't have to manually translate/scale eyeballs and link them to the morph?
    By
    3DRT 3DRT July 2023 in Daz PA Commercial Products
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
