• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • How do I hide the lower half of g9 if I use centaur or spiderfolk body
    Richard Haseltine said:
    Those would have been set up as GeoGrafts on the original figure, and would hide specified areas of the mesh when fitted 9and weld to the edges left). Using them on a different figure, with different geeomtry and presumably parenting rather than fitting (to avoid AutoFit removing al the custom rigging) that won't work.
    One option would be to create a simple primitive (say a 0.01m cube), rig it via the Transfer Utility (Edit>Figure>Transfer Utility) setting Genesis 9 as Source and the Cube as Target, then make sure it is fitted to the Genesis 9 figure. Now use the Geometry Editor to select the areas of the Genesis 9 figure you need to hide, right-click>Geometry Assignment>Create AutoHide Group for fitted Figures, and select the cube figure. If you then save a Wearables Preset for both the fitted Cube and the parented add-on you will be able to load that and have the lower body hidden (when using a regular pose tool - Geometry editor and soem other tools turn off the hiding). Of course that may leave some fiddling in the join area
    How and where would I add the bottom half?
    By
    milliethegreat milliethegreat August 2023 in Daz Studio Discussion
  • Distorted hands and Teeth
    crosswind said:
    It's great that you got it done with 'dental issue' !  cool As for the new 'ungual issue', it's annoying to have it on a default Base figure... Here're some steps for trouble-shooting -:
    - Press F2, clear DSON cached files there, then reload G8.1 base figure.
    - In Parameters pane, enable 'Show Hidden Properties' from Preferences, select Currently Used, then see if there's any morph dialed unexpectedly from some characters or partial head / body morph. Or from menu -: Edit - Figure - Zero - Zero Figure, then see if there's any strange dial with 0 value(s) in Currently Used.
    If there's some morph dialed, then we proceed... as there might be different reasons and resolutions.
    Thank you Crosswind,  I will try what you have sugested and let you know the results :D.
    By
    Cactuskim Cactuskim August 2023 in Daz Studio Discussion
    By
    crosswind crosswind August 2023 in Daz Studio Discussion
  • CBS/ JCMs Help
    Yes, restore G9's pose first, delete the hijab and reload it to G9. If you ever saved morph assets of fixed CBS, and you wanna rework on them, firstly delete the relevant dsf files from the data folder of your product.
    But if you just wanna rework on weight maps, there's nothing to do with CBS morphs or files, you just go for tweaking weight on bone nodes. Node weight data are stored in the geometry dsf file of your hijab figure in data folder. If the weight are all messy but you don't have the original version of your hijab, you may re-transfer the weight from G9 to the hijab with Transfer Utility.
    By
  • CBS/ JCMs Help
    Nope, you don't need to create new CBS... As for 'body_cbs_upperarm_y110p_r', the cloth of your hijab around the areas of shoulder and armpit will be folded and squeezed, you may use dForce or re-simulate it in MD with morph target, then smooth it with Blender if needed..
    For G9, official CBS morph files locate in the sub-folders from this path - : \data\DAZ 3D\Genesis 9\Base\Morphs\Daz 3D. The full file list is in here -: http://docs.daz3d.com/doku.php/public/read_me/index/86958/file_list
    By
  • Face Transfer Tips
    I've only recently discovered this, but apparently Photoshop has had this tool since CS6, and I thought I share it.
    Photoshop has a tool called Auto-Blend Layers that can blend two layers, and does a very good job matching up their exposure and color.
    And it's not just for Face Transfer users. You can also use it to seamlessly remove eyebrows.
    One small tip using the tool, if it creates a transparent ring around your pasted layer, it means you didn't create a large enough edge for blending.  So, instead of contracting your selection by 16 pixels, try contracting your selection by 32 or more pixels.
    Photoshop QUICK Tip: Auto-Blend (CS6 and later)
    By
    Seven193 Seven193 August 2023 in Technical Help (nuts n bolts)
  • Asian morph for Victoria 9?
    Hi everyone!
    I'm looking to reproduce the model used on https://www.daz3d.com/cyber-edge-hair-for-genesis-8-81-and-9.
    It is clear to me that the skin is from Victoria 9 but the face looks like it has an asian morph added to it. Does anyone knows if Victoria 9 comes with this morph?
    Victoria 9 is kinda pricey so I don't wanna end up buying her for nothing.
    Thanks in advance.
    By
    Justin_Ames Justin_Ames August 2023 in Daz Studio Discussion
    Cactuskim said:
    crosswind said:
    For 1), you need to do "Adjust Rigging to Shape" before testing poses on the figure (Edit - Figure - Rigging - Adjust Rigging to Shape), then do "ERC Freeze" if there's no problem.
    For 2), I don't use Hexagon but pls try to set the morph dial "Mouth Realism 8.1 HD" to zero before making your "mixed morphs" as a single dial... After importing the morph, then dial "Mouth Realism 8.1 HD" as needed. I don't use Genesis 1 either but the dial "Mouth Realism HD" on G3 is 100% as default, so try to zero it first in the same way...
    Thank you so much Crosswind,  I will definitly try these sugestions when I get home tonight.  'ERC freeze' sounds like what I was vaguely remembering,  but I had no clue where to do it.  And I know for sure that the mouth realism 8.1 HD is dialed up in both figures,  and good chance it was dialed up in the previous generations for the one character... I had no clue that would effect things in a conversion to a higher generation.
    Thank you again :D
    Hi Croswind,
    Thank you again,  I did what you sugested and it worked great :D.  Teeth are fixed and I now longer need a digital orthodontist. ;p.  It took a bit of time to find out which generation was messed up on my one multi-generation conversion character (and yup,  the HD mouth realisem was defaulted on on all of them),  but it is finally done a looking good.
    I do have a new problem now that has me totally scratching my head. All of a sudden,  the fingernails on the left hand of my Gen 8.1 figure are slightly distorted.... left hand only... and it is happening on a defaulted freshly loaded Gen 8.1 with no morphs in a new scene,  and it gets worse when I dial in a character (Not just mi characters,  but any character including popular ones I have bought at DAZ).  It doesn't seem to be related to anything I have worked on,  and I have gone back and looked at all my previous renders and it was not a problem before.  I considered that maybe my Gen 8.1 figure got corrupted somehow,  so I uninstalled Genesis 8 starter esentials,  and reinstalled it again.  Still happening!  I'm stummped. Any clue,  Or should I start a new post.
    https://www.dropbox.com/scl/fi/ko5k86qb8ggmdw2xsay9z/finger-nails-and-top-of-left-hand-distortion-2.jpg?rlkey=h6mql2zl73zdnlr2hxnnpsdbv&dl=0
    By
  • Moves by Maxon Genesis 8.1 Connect Facial Capture not working
    Hello!
    I was hoping I coud get some help on this. I'm importing a DAZ character with the DazToC4D Bridge and I then want to connect the facial mocap from the moves by maxon app to my existing character. I used to be able to do this just fine but now when I import a character with the face morphs, it doesn't have a Morph controller group to link it to.
    I tried a bunch of different combinations which somehow managed to move the head but not anything else. There is a pose morph in Genesis8_1Female.Shape that is functional so I'm not sure where the link isn't being made.
    Hopefully I'm just being silly and it's an easily fixable thing.
    The first image is how it used to look with the morph controller that had to go into morph controller and the second one is how my hierarchy gets imported with no morph controller with the plugin showing as well.
    By
    Hathores Hathores August 2023 in Cinema 4D Discussion
  • CBS/ JCMs Help
    In my type of clothing, where shoulder corrective morph influences most of the surface area, do I even need to use weightmap?
    update:
    I've tested it on
    body_cbs_upperarm_y110p_r.obj
    weightmap has its usefullness which help when the smoothing is on.
    It help to shape /cover the upper arm.
    Else the intersection will become worst
    I wonder, maybe I should make two or three more jcm to help the smooth transition.
    update:
    Nope, doesn't work that way
    By
    James James August 2023 in Daz Studio Discussion
  • CBS/ JCMs Help
    There's no problem with SY's tutorial as it's the typical fixing process of corrective morphs. But JD's video related to G2 on which there's no Base Joint Correctives mechanism (and no Property Hierarchy either if I remember correctly) so he had to create a JCM and ERC Freezed it manually. From G3 on, you don't fix morphs in that way.
    - When we import the corrective morph, wouldn't it already saved somewhere replacing the old one(s)?
    Yes, it will overwrite the auto triggered JCM dial and update the mesh (vertex positions) of your garment in Viewport but just in RAM. Then you must save the fixed morph assets (*.dsf files) in 'your product folder' with 'your vendor name'.
    - The first time I use ERC [delta add] (default) but then a problem...
    A weight just determines how the mesh (vertex positions) are influenced. Actually it has nothing to do with the percentage of a corrective morph.
    - as for auto follow..
    Auto Follow are checked on all default corrective morphs dials of the figure, and I mentioned we normally don't touch it because the pJCM / CBS will be automatically triggered on the garment and adopt the settings of  relevant pJCM / CBS on the figure, i.e. the corrective morph will be 'delta added' by its Controllers - a Joint + necessary multiplied conditions.
    But if you want a pJCM / CBS to have more complex formulas (like Keyed), i.e. to override the default settings, or create a series of corrective morphs of your own, you should deactivate Auto Follow and set 'your rules' there in Property Hierarchy other than modifying the existing default 'rules'. That is the key difference.
    By
  • Celebrity Look-a-Likes for 3D figures Part 4
    menghienrico said:
    Choppski said:
    Does anyone know of a good Jon Snow (Kit Harrington) morph?
    If you're not in a hurry, I'd wait for this.
    He should be released, but I don't know when... It's by the deviant's UncannyValet. He's the best Kit Harington's character I've ever seen.
    Thank you.  It was released today, so should be up on one of my stores and then on others shortly.
    By
    UncannyValet UncannyValet August 2023 in The Commons
  • CBS/ JCMs Help
    So here's two examples of video of making clothing JCM:
    By Sickle Yield
    By Josh Darling
    The reason why we fix pJCM/CBS on a garment is that the auto triggered corrective morph on the garment is not correct in terms of geometry, then we must save the fixed / imported corrective morphs as morph assets along with the garment (in the data folder of the garment), to override the auto triggered corrective morphs.
    For such a case on a garment, I'm still not sure why you have to give it a 'threshold' of a certain value or percentage,
    The first time I use ERC [delta add] (default) but then a problem appears as shown on the screenshot above.
    So I thought maybe... I should let the weight map handle the situation up to certain degree, and then let the corrective morph kicks in.
    But it make the looks weird, cos the transition looks popping out.
    Hemm... I think can just use smoothing modifier to handle the intersection.
    I saw your video.
    What is the effect of turning on / off the auto follow in this case.
    I know autofollow useful to make the cloth follow the change of the body. if it's off, when there's  body change morph, the cloth wont follow the change..
    But this body_cbs_shoulder_z55n_r isn't related to body change.
    So, is autofollow on or off makes any difference?
    By
  • Star Trek Builders Unite 8: THE REBOOT
    Redfern said:
    Ryuu@AMcCF said:
    ...I might very well have beat Redfern to to the punch by posting something Caitian-related ...
    Well, a few reasons for that.
    *  Niketa is more "pantherine" than how I imagine M'Ress.  Despite the tufted tail and mane, I see her as more cat-like than leonine.
    *  The set lacks a digitigrade option.  When the G8 sets had them, this seems a "downgrade".
    *  I've been living on my life savings since a forced retirement on late '21.  I'm spendingf VERY little on non-essentials.
    *  I'm still a "Poser Luddite".  I'm too lazy (stubborn, whatever) to learn a few workflow.
    I fully get what you're saying. TBH, there were several things I never liked with how the animators drew M'Ress for the show:
    The billowing hairstyle the animators drew her with--a leonine mane that belongs on a MALE cat, for one. *roll eyes*
    The pawlike hands were okay, but then they drew them as THREE fingers. *shakes head*
    Those two features made it very hard to get any of the previous feline figures to fit her as drawn, and they forced me to invest in lots of "external" modifications for those earlier generations, such as the various Creature Creator-type products. Fortunately, for G9, they've come out with the Phenotype (that I got after I made that render) to do the digigrade feet--and Oso's Cat Character lets us pull off the pawlike hands--unfortunately, I still don't see a 3-Fingered morph yet for G9. OTOH, I was able to get her slitted pupils using another of Oso's morphs (probably from his G9 Cat Character, again).
    Plus, every single tail ever made are those bloody "belt tails" that attach at the figure's waist line rather than at the base of their spines *facepalm* But at least thie one is a prop that can be relocated (with a little effort).
    As for the tuffed tail----*cough*----you'll be greatly disappointed, but that was a kitbash from DAZ's Big Cat 2's lion/lioness that I glued to the tip of Niketa's tail--yeah, the artists blew that detail. But hey, I must have done something right for you to miss that. I'm honestly surprised you didn't recognize where it came from cheeky
    And I truly understand the need to cut back to "just the essentials", but cats and felinoids ARE ALWAYS essential laugh
    As for being a Poser Luddite, I used to be one, too. But I mostly gave up on Poser when so much stuff wouldn't import well into it. The question I have is, CAN one even get anything from DAZ into Poser these days--especially the later Genesis generations??? surprise
    Still, what we're talking about.... It's given me an idea.
    I'll be back in a few days, assuming my machine survives the attempt.....
    By
    Ryuu@AMcCF Ryuu@AMcCF August 2023 in The Commons
  • Sickleyield, Cobra morph/textures for The Constrictor?
    Better yet an actual cobra instead of a morph (with poses)
    By
    FSMCDesigns FSMCDesigns August 2023 in Product Suggestions
    There's a lack of a good looking Cobra in Daz Studio land, despite it being an extremely iconic form of snake.
    Maybe a cobra add-on for The Constrictor?
    By
    Diaspora Diaspora August 2023 in Product Suggestions
  • Needing some help with a JCM (Solved)
    crosswind said:
    The issue might come from Min and Max values. Pls check if they're absolute values or %... if they're -65 to 40, set the key as 40:1, while if they're -65% to 40%, set the key as 0.4:1...
    A clip as below - : https://mega.nz/file/6CxRRQBJ#0uCjh8mQ6Ntj2qmnKQ_I88LMZ37KhHubTNVh9HD-ns8
    So after the long night I decided to get some rest. When I woke up it just kinda clicked what I needed to do after processing everything you guys have been trying to help me with. When you do the ERC freeze, it takes any morph that is applied and will add it as a sub component (this is why in some of my images you see two of the same controller / components). This was the issue with the not saving and also, me and my small brain was over thinking how this would work for this scenario. All I needed to do was set the corrective morph as a sub component to the X Rotation Bend but rather than manually dragging and dropping it into the X Bend sub component, I let the ERC Freeze do it for me.
    Everything saved and is working now.
    I really appriciate all of your guy's help. It's a little convoluted for someone like myself but I started to wrap my head around how these connections work with your guy's assitance.
    Take care all!
    By
    Dark45 Dark45 August 2023 in Daz Studio Discussion
  • CBS/ JCMs Help
    There's no really different way to fix corrective morphs on G9's clothing, only the naming convention has been changed from pJCM to CBS. However, I myself have not seen corrective morphs or joint rotation on a garment with manual ERC Freeze, let alone a 'video'. Pls show me some examples...
    The SS I showed you was done on a G9's base figure according to your '90%'s case' though we normally never do so... well I just showed you the mechanism of ‘Keyed’. 'Keyed' is stronger than Delta Add. You can define various range of values and of course it brings you the smoothest transition with Key Types (TCB/Linear...). It's commonly used in lots of products depending on various conditions of Controlling.
    For such a case on a garment, I'm still not sure why you have to give it a 'threshold' of a certain value or percentage, but technically if you wanna do so, you need to uncheck 'Auto Follow' in its Parameter Settings, then add a Rotation as its Controller and set Keyed range. The mechanism is always the same, just the settings are different.
    as this clip - : https://mega.nz/file/2SI2gBZb#fsGsRorvoL3oNycTvOho65o_zZ6VkbEdXVvNT97BlFc
    By
  • CBS/ JCMs Help
    @Richard
    ok.
    @crosswind
    Yes, I have made my own corrective morphs for body_cbs_shoulder_z55n_r
    Does genesis 9 have different way on creating the ERC to fix clothing?
    I have watched many videos, but they are all genesis 8 and they are all ERC freeze the joint rotation, for ex: Bend,  of the cloth after importing the morph fix
    I wonder why some people save their modified Jcm morphs as morph asset?
    What for?
    So I tested using ERC [keyed]
    the result not as I expected.
    The smoothest transition would be using ERC [Delta Add]
    But there's a problem as shown in this pic:
    On the way up the fabric intersects the arm.
    any solution?
    By
  • CBS/ JCMs Help
    - Technically you may use ERC [Keyed] as the Type of Controller with proper settings as below... but you should create a CBS of your own to modify the default corrective morph other than directly setting it on default "body_cbs_shoulder_z55n_r".
    - You should not manually ERC Freeze on joint rotations (e.g. that Bend dial). They're defined as a Controllers ( in Property Hierarchy ) to 'push value(s)' to target morph dials, and the definitions are saved within the corrective morphs' dsf files (as formulas)...
    - You shoud not manually ERC Freeze on ...CBS morphs either as they'll have 'pushed values' from their Controllers. You just need to save the defined corrective morph assets to your vendor folder.
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
