• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • Carrara for game modeling - worth the investment?
    My background ZBrush and Sketchup and game modding... IMO for modeling game props (both organic and hard surface) as well as low poly game characters, Carrara is more than sufficient. Quad/tri/subD will help game asset pipeline.
    User interface can also be more robust and made more customizable. Other than that it's a pretty solid and versatile modeling app.
    I was surprised to find that I could work directly on a vertex object that is still in FBX/ Collada/ OBJ format in the Assembly room. Can be a plus for frequent import export users.
    Carrara's UV mapping/ unwrap is good enough for blocky models, but certainly needs updating for organic models.
    Displacement/ normal map baking could be an issue. So will probably need a mapping companion tool. That said, Carrara's ability to 3Dpaint diffuse, opacity and specular map will definitely come in handy for game textures.
    Daz content for games, size wise, Genesis is almost 20K, can be reduced to 6K but its selling point, TriAx weighted skeleton, cannot be used outside of Daz Studio or Carrara. Daz3D store sells other toon resolution characters. Carrara skeleton/weight is apparently quite flexible/ portable to popular apps/ game engines.
    Daz content's bigger issue is texture map numbers and size. But DS comes with Texture Atlas, free, a gem of a tool and a must-have for game devs.
    By
    Mythmaker Mythmaker May 2015 in Carrara Discussion
  • Import Sketchup Model to Daz - Missing textures
    Weiner said:
    What do you mean by duplicate faces?
    Often times, Sketchup models export with what amounts to two copies of the mesh...layered one on top of the other. Sometimes it's not the entire mesh...mainly in areas where 'parts' are joined or intersect (no culling of hidden faces on most exports). Or because of the way the item is made, it is like a 'geoshell' is already applied...or even intentionally done so a 'double sided' object can have a different view/texture on each side (although not all that many are that detailed).
    I've converted a fair number of SU models and I never assume that the textures will work and I'm prepared from the start to have to at least manually install, if not totally rework them, in DS. I've never been disappointed, yet.
    By
    mjc1016 mjc1016 May 2015 in Technical Help (nuts n bolts)
    for a sketchup model export that is actually a good result, most are much worse.
    you can delete the duplicate faces in sketchup as it has front and back ones DAZ will render both sides of a single face and the extra mesh in the same space causes funny effects. Try to reapply the textures manually under surfaces is the only real solution
    By
    WendyLuvsCatz WendyLuvsCatz May 2015 in Technical Help (nuts n bolts)
    I used a sketchup model and imported it to daz: http://i.imgur.com/W6TE713.png
    But here's what I got: http://i.imgur.com/sam2PAZ.png
    Surprisingly, there's some textures underneath it. The rest are just white.
    What am I missing? How do I make the rest of the texture appear?
    By
    useless_1975_837db407db useless_1975_837db407db May 2015 in Technical Help (nuts n bolts)
  • Is it possible to convert/import other specific models for use in DAZ?
    Is it possible...yes.
    Is it worth it...maybe.
    There are several plugins for SketchUp (both free and paid) that will allow for obj (one of the recognized Studio formats) export. But, often the overall quality of the export is such that it would be quicker to start from scratch and just model it. But for some things the quality is high enough to make it worth the effort (usually this is true for high quality or very unusual items).
    By
    mjc1016 mjc1016 May 2015 in New Users
  • "Dark Deco" Archictute City Set - Urban Sprawl
    If you delete the more modern buildings from urban sprawl you can toss older style ones in, the thing I like about the sprawls is all the buildings are separate.
    Use those antfarm ones maybe and others like the Paragon theartre and some of Faverals french ones maybe even if just swapping out streetlights etc, one thing there is no shortage of be it on Turbosqid, Renderosity or even Google Sketchup warehouse is buildings of every style and era, the street base layout being the handy thing to plonk them in.
    By
    WendyLuvsCatz WendyLuvsCatz May 2015 in Product Suggestions
  • Need help exporting morphs to collada and fbx
    Ran across this thread on a search. Looking for much of the same feature ... to be able to export the particular pose. (I'm importing into SketchUp).
    I tried a quick test using the posted screenshots as reference. I listed some but not all of the 'Morph Rules'. Still came across as the original default T-pose. I'll go ahead and list them all in a further test ... but has anyone else had failure/success with this method. What did you do to achieve your results?
    Thanks,
    Eric
    By
    eheberling eheberling May 2015 in Daz Studio Discussion
  • Export pose
    eheberling said:
    It's too bad I can't import a different pose using Collada because all the textures come across perfectly mapped. Have any thoughts on what I may be missing there?
    Thanks.
    Nope...and it's not just going from Studio to Sketchup...it's from Studio to just about anything else. There's no one format that works perfectly. And that doesn't even really say it all...more or less, since there is no common, widely accepted standard that handles both mesh and skeleton data, that is used by most programs (no, Collada isn't quite it), preferably an Open Standard, any exchange between programs means some work redoing things that worked perfectly in the original program.
    When I'm going from Studio to something else I basically accept the fact that the item will need, at a minimum, texture work in the receiving program. The best I've seen is the set of scripts by Casual for exporting to Blender for rendering in Cycles...but even they don't do it all (like no rigging).
    By
    mjc1016 mjc1016 May 2015 in Daz Studio Discussion
  • Export pose
    I've tried all the presets plus some custom ones as well. So yes, I've tried exports using 'Write Material Library' and "Collect Maps' too. I'm getting closer results now by choosing to invert the XYZ axes. By closer, I mean I'm getting some of the materials now but with a bunch of blocky black areas when I import into SketchUp.
    By
  • Export pose
    Addict,
    I've tried all the presets that come with Daz Studio 4.7 Pro. I've been able to import various poses into SketchUp 2015 now in obj format but in no case have I been able to get the original textures. (The import is all gray-toned). When I export from Daz it creates an obj file and a folder "Maps" with several jpg files inside.
    And, as I've indicated in previous posts, when I try and export/import Collada files, Daz always exports the default T pose no matter what preset I use.
    By
  • Export pose
    eheberling said:
    I do not see the option you speak of on DAZ 4.7 Studio Pro. for obj exports. However, I did something (I'm not sure what) that exports the pose now. But I' don't get the textures when importing into SketchUp. The opposite is true when exporting dae files from Daz and importing into SU. I always get the default T pose plus the textures.
    This is the Carrara Discussion forum, so that may be why you don't see the checkbox that Headwax mentioned.
    By
    evilproducer evilproducer May 2015 in Daz Studio Discussion
  • Export pose
    By
  • Export pose
    Hello all,
    How do you export a figure after posing it differently than the default T-pose? I've tried obj and Collada (dae) but they revert back the default pose. (I'm importing the files into SketchUp.)
    Thanks,
    Eric
    By
  • Importing from Google Sketchup?
    sorry, was referring to my own sketchup models.
    By
    FirePro9 FirePro9 April 2015 in The Commons
    ...where have you been able to find ,objs in the Sketchup Warehouse?
    Everything I looked at that used to be either .dae or .obj has all apparently been converted to .skp. Even a few of the same ones I downloaded a while back.
    By
    kyoto kid kyoto kid April 2015 in The Commons
    I have been wrestling with SketchUp export to DAZ too, but more with textures than geometry. One important thing I did discover, which I don't think has been mentioned yet, when doing an OBJ export from SketchUp Pro or via TIG's Object Exporter plugin, you need to apply your texture to both sides of each surface, I have not had much luck with just applying the texture to one side and leaving the reverse side as default. Hope this helps others!
    By
  • Primitive Parent Children collision with other objects
    Hi guys
    I'm fairly new to requesting assistance like this, so please don't shoot me just yet. My dilemma is as follow:
    Create a sphere primitive. Duplicate or create another sphere. Parent the on to the other. Now, I want both to interact with another primitive or object in a scene as if they were one object when I use the collision option of the targeted object and set the sphere as collision item. How in the name of Zoltan do you get this right?
    What I did for now to get around it is to create two spheres in Sketchup a specific distance apart and exported as OBJ, then moved the spheres closer together and exported again as obj. I then imported the first far apart spheres into DAZ and used morph loader to add the second closer together spheres as a morph. I have attached 2 pictures Collision A is where I used 2 sphere primitives within DAZ Studio and Collision B is where I used the Sketchup spheres with morph. Collision B is the desired effect I want, but with native DAZ primitives. I also want to freely move the primitives around, rather than contain them to a specific morph path i.e. open and close.
    In finalization, I want to create multiple primitive spheres, parent them to one, select the target object, apply smoothing modifier, select the parent sphere as the collision item and have all its children impact the object . Like hael storm on a cars roof. or something being shot with buckshot. multiple dents and points of impact.
    Any help will be much appreciated.
    By
    johannswart johannswart April 2015 in Technical Help (nuts n bolts)
  • Wanted 3D models Listing
    Just bumped into this collection on 3DWarehouse: Real Spacecraft
    "Spacecraft , shuttles, stations, satellites, equipment which have made it into reality"
    https://3dwarehouse.sketchup.com/collection.html?id=2308c9261b05d3447d27abf4648f095b
    Erik
    By
    erik leeman erik leeman April 2015 in The Commons
    And a search for 'space shuttle' gives 1,042 results on 3DWarehouse (SketchUp), there simply MUST be something useful amongst them!
    https://3dwarehouse.sketchup.com/search.html?q=space+shuttle&rsi=sbis&backendClass=entity
    Models by Mandun are particularly good:
    https://3dwarehouse.sketchup.com/user.html?id=0004043920460615056142412
    Space Shuttle Atlantis
    https://3dwarehouse.sketchup.com/model.html?id=153f00bf9b180174b7b0facc2e60c9ce
    https://3dwarehouse.sketchup.com/model.html?id=2c4c30bc85bd7654b7b0facc2e60c9ce
    https://3dwarehouse.sketchup.com/model.html?id=75152b28fa951561ff2eeed83d3e9fb9
    Erik
    By
    Here's an example of a DAZ-Octane render with some of those NASA models and a converted SketchUp astronaut by Max
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
