• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Celebrity Look-a-Likes for 3D figures Part 4
    puredigital101 has recently added to their morph list on DeviantArt -
    Saoirse Ronan
    Katherine Winnick - Kathryn Winnick
    Jenna Ortaga - Jenna Ortega (second version of this person)
    Millie Bobby Brown (second version of this person)
    By
    Haruchai Haruchai November 2023 in The Commons
  • [Partially fixed] Deep Space Suit for Genesis 9 thinks I don't have G9 Starter Essentials installed
    Richard Haseltine said:
    stelari said:
    I just ran into this as well while trying to investigate a problem where some characters pupils/irises suddenly started looking misshapen - still not sure if it's related, as I also updated to DS4.22 and moved from DazCentral to DIM. I tried to open some random older scenes, and hit the missing files. You can see the file list in the documentation and the installed files don't match in the attached.
    Misshapen anything is likely due to a morph saved with a non-zero default value, or to an incorectly set-up adjustment morph.
    Yeah, I wasted loads of hours looking into a similar problem when I first ran into it, before finding the culprit. I haven't had a chance to dig into this one further, but at first glance I couldn't find any non-zero or hidden morph causing it. Weirdly, re-installing the G9 essentials & expansion fixed it (or triggered something that fixed it) for some scenes, but not others. If I can't figure it out I'll post some pics, it's a weird one.
    By
    stelari stelari November 2023 in The Commons
    By
    Richard Haseltine Richard Haseltine November 2023 in The Commons
  • Genesis 9 anatomical elements - SOLVED
    Matt_Castle said:
    anepher said:
    I have the Extended license for Golden Palace Genesis 3 and 8 and for me at least it's a real pain to use it in a game,  the shell is not rigged so I programmatically have to position it, the maps and the textures are not properly loaded.
    I wouldn't handle it that way. The geoshell is just a fairly ugly workaround for the fact that DS/Iray can't accept different UVs for different maps on a surface. (A much better way to handle it would be a custom shader that could blend the details in on the original surface, but not really possible with support for only one UV per surface).
    You're better off using Map Transfer to get everything on a shared UV, and then merging the actual textures rather than having a shell.
    This is actually a great advice, I'll look into it. Thank you!
    By
    anepher anepher November 2023 in The Commons
    By
    Matt_Castle Matt_Castle November 2023 in The Commons
  • HD Body Burns Add-On for Genesis 8 and 8.1
    Hi @majesticcreations, thank you for the support!
    As @Gordig has mentioned, Body Burns uses a custom UV Map that ensures the surfaces have an even density, allowing more detail without creating seams. The resulting maps are 8K since they cover the entire body. As such, you will need to transfer those maps into Genesis 8 or 8.1 UVs and then manually layer things in DAZ Studio using the Layered Image Editor and then grab the baked images and save them somewhere or layering them in a 2D Editor of your choice. Here's a great video that goes over how to use the map Transfer within DAZ Studio:
    As to your DAZ Studio being unable to render, that isn't product-specific AFAIK. There is a thread about it here: https://www.daz3d.com/forums/discussion/50434/unable-to-render-renderer-is-already-in-use
    If your system still struggles with rendering the Burns in DAZ, try lowering the SubD of the character down to 3. If you lower it further, you might as well dial out the HD Burn Morphs (because they do require SubD3 or 4 to show at all) and just use the textures; you can try playing with the displacement settings instead to get more of a texture.
    By
    FenixPhoenix FenixPhoenix November 2023 in Daz Studio Discussion
  • How do I achieve this effect?
    Matt_Castle said:
    No practical way, no.
    The key part is the vendor has made the bumps and wrinkles specifically for those clothes; they won't be right for any other clothes, even if you could transfer them. You would essentially need to start from scratch anyway.
    Okay, well thanks for letting me know :)
    By
    bobety316_c50224ad1f bobety316_c50224ad1f November 2023 in The Commons
    By
    Hylas said:
    It's beacuse of normal and bump maps that are specific to that item of clothing.
    I see, thanks there's no way I can transfer then?
    By
  • Freebie Challenge November 2023 - "Wobble, jiggle, sway, and shake" - Main Thread
    JackyBrown said:
    3D Art Freebie Challenge October 2023 "Wobble, jiggle, sway, and shake"
    [Best watched at full size for details.]
    "Waiting... (don't wiggle!)"
    Starring: Alysha (by emotionaldreams)
    The tale: (Not entirely fictional)
    It's never a good idea to put a glass full of wine on the sofa. It's only a matter of time before it falls...
    Non-motion Picture Soundtrack:
    Irma Thomas - Time Is On My Side (© 1964)  https://www.youtube.com/watch?v=cn0ZofphEzE
    The Rolling Stones - Time Waits For No One (© 1974)  https://www.youtube.com/watch?v=YsH2In5r2sM
    COUNTABLE FREEBIES: (Alphabetic order)
    #01! Alysha for Genesis 8 Female by emotionaldreams
    https://www.renderosity.com/freestuff/items/83613/alysha-for-genesis-8-female  **
    #02! Antique Photo Camera (obj) by CGAXIS
    https://cgaxis.com/product/antique-photo-camera/  **
    #03! Boudoir Lamp by AllenArt
    https://sharecg.com/v/95417/gallery/21/DAZ-Studio/Boudoir-Lamp  **
    #04! Chameleon ROse2 for Genesis 8 Female by zoro_d
    https://www.renderosity.com/freestuff/items/85859/chameleon-rose2-for-genesis-8-female  **
    [Lashes morph used]
    #05! Counter Table and Bar Stool Set (obj) by Luxxeon
    https://sharecg.com/v/71601/gallery/5/3D-Model/Counter-Table-and-Bar-Stool-Set  **
    #06! Diamonds are a girl's BFF G8F jewelry by perlk
    https://www.renderosity.com/freestuff/items/92567/diamonds-are-a-girls-bff-g8f-jewelry  **
    #07! DOA 6 Marie Rose - Head and Body Morphs for G8F by TritiumCG
    https://www.deviantart.com/tritiumcg/art/DOA-6-Marie-Rose-Head-and-Body-Morphs-for-G8F-825236730  **
    [Head and Body morph 50%]
    #08! ED's Brick Shader (Iray) by Edheldil3D
    https://www.deviantart.com/edheldil3d/art/Freebie-ED-s-Brick-Shader-Iray-788871766  **
    #09! Floral Hair Ornaments Add-on to Tower Hair by MysticArtDesign
    https://sharecg.com/v/98291/gallery/21/DAZ-Studio/Floral-Hair-Ornaments-Add-on-to-Tower-Hair  **
    #10! G8F Saucy Sitting Poses 19 to 23 by richardandtracy
    https://www.renderosity.com/freestuff/items/95280/g8f-saucy-sitting-poses-19-to-23  **
    #11! Historical Corset by MysticArtDesign
    https://sharecg.com/v/98271/gallery/21/DAZ-Studio/Historical-Corset  **
    #12! Iray Jewelry Shaders by AllenArt
    https://sharecg.com/v/95893/gallery/21/DAZ-Studio/Iray-Jewelry-Shaders  **
    #13! Kiara Interior HDRI by Poly Haven
    https://polyhaven.com/a/kiara_interior
    #14! Kitchen Add-on Pack by TruForm
    https://www.renderosity.com/mod/freestuff/kitchen-add-on-pack/64895  **
    [Glass and Glass2 used]
    #15! Labeled Whiskey Bottle by Area-50
    https://www.sharecg.com/v/24358/gallery/11/Poser/Botles  **
    [Also used to label and fill the wine bottle]
    #16! Large Asian-style Lamps by AllenArt
    https://sharecg.com/v/95938/gallery/21/DAZ-Studio/Large-Asian-style-lamps  **
    #17! Lights for Daz Studio w/ Iray by DrBoots
    https://www.deviantart.com/drboots/art/Freebie-Lights-for-Daz-Studio-w-Iray-579993105  **
    #18! Liquids - DS Shaders & Poser MT5s by Fisty
    https://www.sharecg.com/v/82337/gallery/7/Material-and-Shader/Fistys-Liquids-DS-Shaders-Poser-MT5s  **
    [Goblet used]
    #19! Mahogany Herringbone Wood Parquet PBR Texture by CGAXIS
    https://cgaxis.com/product/mahogany-herringbone-wood-parquet-4931/  **
    #20! Material & UV Add-on for MoonCraft 3D's Freebie Ornate Carved Sofa by richardandtracy
    https://www.renderosity.com/freestuff/items/94826/material-uv-add-on-for-mooncraft-3ds-freebie-ornate-carved-sofa  **
    #21! Mirror/Frame (obj) by Hypnagogia
    https://sharecg.com/v/77468/gallery/5/3D-Model/Mirror-Frame  **
    #22! Milkshakes by AllenArt
    https://sharecg.com/v/95892/gallery/21/DAZ-Studio/Milkshakes  **
    [Tall Glass used]
    #23! OnFleek for Genesis 3 & 8 Female(s) by AprilYSH
    https://aprilsvanity.com/shop/onfleek-for-genesis-3-8-female-s.html
    #24! Ornate Carved Sofa With 27 Material Options by mooncraft1
    https://www.renderosity.com/freestuff/items/85857/ornate-carved-sofa-with-27-material-options  **
    #25! Pretty Look for Genesis 8 Female(s) by zoro_d
    https://www.renderosity.com/freestuff/items/83823/pretty-look-for-genesis-8-females  **
    #26! RE5 Sheva Alomar Head Morph for G8F by TritiumCG
    https://www.deviantart.com/tritiumcg/art/RE5-Sheva-Alomar-Head-Morph-for-G8F-822643742  **
    [Head morph 25%]
    #27! Rihanna - Head and Body Morphs for G8F by TritiumCG
    https://www.deviantart.com/tritiumcg/art/Rihanna-Head-and-Body-Morphs-for-G8F-838891936  **
    [Head and Body morph 25%]
    #28! Serving Table 01 (.fbX) by Nichgon
    https://sketchfab.com/3d-models/serving-table-01-ff4433c1d5974ed6b9fdecba6d8a3126  **
    #29! SY 200 Morphs for Genesis 8 Head and Body by SickleYield
    https://sharecg.com/v/91888/view/21/DAZ-Studio/SY-200-Morphs-for-Genesis-8-Head-and-Body  **
    #30! Thanskgiving_Gift1_OBJ by Forester
    https://www.renderosity.com/mod/freestuff/thanskgiving-gift1-obj/83677  **
    #31! Tower Hair by MysticArtDesign
    https://sharecg.com/v/98289/gallery/21/DAZ-Studio/Tower-Hair  **
    #32! Vase with Flower prop for Daz Studio by Digi-Dotz
    https://www.digi-dotz.com/index.php/props/vase-with-flower-prop-for-daz-studio
    #33! Whiskey props by AllenArt
    https://sharecg.com/v/99631/gallery/21/DAZ-Studio/Whiskey-props  **
    #34! Winebottle by TrekkieGrrrl
    https://trekkiegrrrl.dk/prp1.htm  (item 4)
    #35! Wine Glass with Contents by Dexterdoodle
    https://sharecg.com/v/50759/gallery/5/3D-Model/Wine-Glass-with-Contents  **
    NO-COUNT ITEMS:
    ---   33 Eyes Materials for the Genesis 8 + 8.1 people by LevKornowska
    ---   Hoops (Earrings) by Lully
    ---   MicCable Set by MDP_MI
    ---   Nose Ring 01 for G2F, G3F and/or G8F by AllenArt
    ---   Scene Lights for Iray by Lali Kamala (Holiday Loyalty Sale 2021 Free Item)
    ---   Skirt Outfit Watch for G8F by Tab (Y_Personal)
    ++    Stucco shader NVIDIA MDL Examples
    PURCHASED/PAID FOR ITEMS: None     100%    Freebies
    *1      E-mail address required
    **     Registration required
    #x!  Countable Items (Bold ones are used by me for the first time I think.)
    ---  No longer available freebies
    ++   Free with DAZ Studio (or the Essentials)
    $x.   Purchased/Paid For Item
    Rendered with DAZ Studio 4.10.0.123 (nVidia Iray®)
    Other free software used: GIMP v2.10.34 and Irfanview 4.62
    Postwork: Used the AltaLux Image Enhancement Filter (Effect) by Stefano Tommesani that comes with Irfanview and some filters that come with GIMP. Also used mcjDenoise (https://sites.google.com/site/mcasualsdazscripts9/mcjdenoise) and mcjLut by mcasual (https://sites.google.com/site/mcasualsdazscripts9/mcjlut) with the free FilterGrade Cinematic LUTs Pack (https://filtergrade.com/free-cinematic-luts-video-editing/) and the Vintage-Look Photoshop Effects Pack/Light Leaks Effect Pack by Michael Jarrott (https://creativecloud.adobe.com/discover/article/vintage-look-photoshop- effects-pack).
    Approved, please move your entry to the Entries Thread!
    By
    Hylas Hylas November 2023 in Freebies
  • Shape Shift for Genesis 9 - SS Glute width
    When using this morph (SS Glute width), the shape will be strange when the legs are opened. Is this the specification? Is it a problem?
    https://www.daz3d.com/shape-shift-for-genesis-9
    https://gcdn.daz3d.com/gallery/image/1318946/1700975635/main.png
    https://gcdn.daz3d.com/gallery/image/1318946/1700975187/main.png
    By
    Muramasa Muramasa November 2023 in Daz Studio Discussion
  • The curse of Frame 4
    WendyLuvsCatz said:
    how are you people getting such massive file sizes? surprise
    I do animations of 1K frames or more and unless I save a long dforce sim or import an obj mine are minsicle (I send them over my wifi between computers )
    the animations are mostly just long sections of text in the duf of transforms
    dforce on the other hand saves vertex information as are imported objects
    my 1K+ scene files are all under 400MB BTW the ones over 100MB are Dforce sims over 100's of frames
    Because I used to have 38K+ morph assets (properties) on a single G8F and they were saved with keyframes and the vertices position data of all dForce garments on the figure was stored with each keyframe as well..
    Then after that time, I knew how to "optimize" the selection of Property Types on the timeline...
    By
    crosswind crosswind November 2023 in Daz Studio Discussion
  • Render your buys! Use buys from the current month and the previous month of sales
    miladyderyni_173d399f47 said:
    (Test render)
    I picked up https://www.daz3d.com/krampus-demon-for-genesis-3-male when it was in the 99 cent sale the other day. I don't recall seeing it before then but the main promo had a lot of personality. I thought that Krampus would make a cool centaur, so that's the first thing I tried, with Centaur 3. I wasn't sure how well they would fit together. I needed the Draft Horse morph at 100% plus dialing down the Krampus morph a lot to make the centaur/man join match. Since it was a test I just grabbed a random polearm, belt (to conceal that join), and ground from my runtime and used one of my own photos for the backdrop. Pose is from https://www.daz3d.com/quixotry-s-poses-for-centaur-7-male-and-female & lighting is Sickleyield's Good To Go! set (from her other store) which is one of my go-to lighting sets.
    Very Cool!
    Congrats on the Great Deals!
    Fun, Yes?!!! :)
    By
    Dartanbeck Dartanbeck November 2023 in The Commons
    (Test render)
    By
    miladyderyni_173d399f47 miladyderyni_173d399f47 November 2023 in The Commons
    (Test render)
    By
    [Lashes morph used]
    [Goblet used]
    [Tall Glass used]
    [Head morph 25%]
    NO-COUNT ITEMS:
    By
    JackyBrown JackyBrown November 2023 in Freebies
  • Reverse Source Shape for Target not working properly - Genesis 8 male body
    I suspect it's just the effect of the reversal - it is often going to distort rigid items. If you want it only on the modified shape you could just load that as a morph and not worry too much about how it looked blank; if you want greate flexibility you could export that as OBJ, tidy it up, and rerig the result (then load your original mesh for the morph you originally modelled around)
    By
    Richard Haseltine Richard Haseltine November 2023 in Technical Help (nuts n bolts)
  • Growing Up for Genesis 8 (Commercial)
    Zev0 said:
    4.22 is a pain in the @$$...I reverted back to 4.21 because half my scenes crash when I try to render..Also I have no idea how it manages to break a product that is just morph related. eg no scripts involved.
    Out Of Touch hairs? There is aknown issue in Iray with having a map assigned to transmitted Colour, which soem of their custom shader materials do - they ahve updated many but some are not, and the isntallation order and method can mean those old files are the ones used.
    By
    Richard Haseltine Richard Haseltine November 2023 in Daz PA Commercial Products
  • Character like this
    Actually, if the figure uses the same bone names, a pose will work. Accidentally applying a V3 pose to G8F is what made me look at this. Some bones were unaffected, others had the correct bend value (even if not necessarily looking the same because of zero offsets), and  that eventually led to my pose transfer scripts.
    Regards,
    Richard
    By
    richardandtracy richardandtracy November 2023 in Product Suggestions
  • Any way to split a morph, like eyeballs
    RAMWolff said:
    Thank you.  I just went ahead and created them in ZBrush so I have all three now.  Just need to remember how I get to those areas to drag and drop into the right lines to make each blink morph (full, left and right) work along with the main blink morph.  Sorry to be a pita I'm just SO RUSTY at all this.  Thanks for your help!
    No problem at all ~ and one reminder - well use Mask when fixing eyelids.wink
    By
    crosswind crosswind November 2023 in Technical Help (nuts n bolts)
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
