• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • The big announcement on September 21, 2022 - place your bets!
    I might not be able to watch it easily now either since Malwarebytes has decided to block Google on my bedroom PC
    can of course on ipad or on my main PC but this sticks a big spanner in my Youtube viewing on my 50" TV
    am trying unsuccessfully to import my browser settings to Opera on it
    Edge it is also blocked
    well obviously can watch Youtube itself but not signed in with Google so cannot get freebie devil
    unless I disable Malwarebytes
    not doing that
    By
    WendyLuvsCatz WendyLuvsCatz September 2022 in The Commons
  • SBH = Garibaldi2.0?
    WendyLuvsCatz said:
    no
    I recall seeing something downloadable once, how much I don't know, but of course no use to me so never did
    Wendy, thanks for replying, it would be nice to have a way to import and export curves as other apps do. The source code could have helped us with that.
    By
    jag11 jag11 September 2022 in The Commons
  • How can I use Victoria 8.1 for example for a base mesh to sculpt a morph in blender
    When you import the morph back into DS with morph loader, make sure to use the "reverse deformation" option so that the morph you create is only the delta between your final shape and the V8.1 shape. Otherwise the V8.1 shape will be applied twice.
    By
    Leana Leana September 2022 in Daz Studio Discussion
  • I am beginner to Daz Studio, I have tried my luck in vain...
    @Halcon Bluesky, I feel your pain there. Daz's implementation of FBX is pretty poor as my exploding hamster would illustrate. OBJ files will often be imported "naked" so just white shapes that you then need to apply the textures and all other surface settings to - this is very frustrating, especially when the textures are baked into the OBJ such that you cannot get to them. Blender can extract them I think but I have had mixed success with that - mainly because I havn't had time to learn Blender yet so I just poke around a bit and sometimes get lucky.
    I do have some of my own car assets in non-daz format ready to attempt to import. Have to get to work now so that will be a struggle for tonight or later in the week.
    Keep going & good luck!
    By
    SofaCitizen SofaCitizen September 2022 in New Users
  • Arch Bridge and Other Bridges. New: Cable Stayed.
    Thinking about it, it may be easier on DS if, once I'm done, I cut the bridge into quarters and import 25% into DS, then play with instances to create the other three quarters. That'd keep the poly count within reasonable bounds if it gets totally out of hand trying to keep the curves smooth. It would also make the tex mapping quicker. Mostly. The road deck would have to have a seamless edge at the middle which might not be that easy to get looking right. Hmm will have to think on this.
    Regards,
    Richard
    By
    richardandtracy richardandtracy September 2022 in Freebies
  • W10 - D/S - space issues - {problem identified - hair shader eating RAM}
    End result.
    Well, the new TEMP folder was found by the AV which offered to empty them for me ;-)
    I set up 4 of the Windows temp references [from the posted image] as well as the D/S temp folder all to the same folder on the D drive.
    The 'red line' activity was NOT solved by making new TEMP folder. D/S was using the new temp folder. Nobody knows what the OS was doing ... there was still a drain on the C drive and no image getting rendered. In trying to capture notes and logs, missed a few but did get these:
    DAZStudio.exe caused UNKNOWN_ERROR in module "C:\Windows\System32\KERNELBASE.dll" at 0033:0000000056B04FD9, RaiseException()+105 byte(s)
    2022-09-21 03:01:42.757 WARNING: QFile::flush: No file engine. Is IODevice open?
    2022-09-21 03:01:43.239 WARNING: QLayout: Cannot add null widget to QGridLayout/
    Cut from Log file:
    2022-09-21 03:20:12.738 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_dfocre High Voltage Hair Base__Ears_5c4_353' uses MDL JIT compilation.
    2022-09-21 03:20:12.739 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_dfocre High Voltage Hair Base__Base_Layer_5e8_391' uses MDL JIT compilation.
    2022-09-21 03:20:12.740 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_dfocre High Voltage Hair Base__Left_Part_60c_429' uses MDL JIT compilation.
    2022-09-21 03:20:12.743 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_dfocre High Voltage Hair Base__Right_Part_630_467' uses MDL JIT compilation.
    2022-09-21 03:20:12.743 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_dfocre High Voltage Hair Base__Frizz_layer_654_505' uses MDL JIT compilation.
    2022-09-21 03:20:12.750 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 192 textures, 25 lambdas (9 unique)
    2022-09-21 03:20:12.781 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (1 light source with 2 triangles, 1 instance) took 0.000s
    2022-09-21 03:20:12.783 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2022-09-21 03:20:13.210 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2022-09-21 03:20:13.217 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2022-09-21 03:20:13.217 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2022-09-21 03:20:13.218 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2022-09-21 03:20:13.220 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2022-09-21 03:20:13.222 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2022-09-21 03:20:13.245 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2022-09-21 03:20:13.257 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2022-09-21 03:20:13.260 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2022-09-21 03:20:13.264 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2022-09-21 03:20:13.298 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 11 cores for rendering
    2022-09-21 03:20:13.306 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using OptiX version 7.1.0
    2022-09-21 03:20:13.376 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX for CUDA device 0
    2022-09-21 03:20:14.529 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 2 device(s):
    2022-09-21 03:20:14.529 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info :     CUDA device 0 (NVIDIA GeForce GTX 1650)
    2022-09-21 03:20:14.529 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info :     CPU
    2022-09-21 03:20:14.529 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2022-09-21 03:20:14.532 Iray [INFO] - IRAY:RENDER ::   1.5   IRAY   rend progr: CPU: Processing scene...
    2022-09-21 03:20:14.538 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce GTX 1650): Processing scene...
    2022-09-21 03:20:14.546 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Using Embree 3.10.0
    2022-09-21 03:20:14.549 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Initializing Embree
    2022-09-21 03:20:15.203 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(359): Iray [ERROR] - IRAY:RENDER ::   1.4   IRAY   rend error: Unable to allocate 163.379 MiB from 2.147 GiB of available device memory
    2022-09-21 03:20:15.219 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(359): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: CUDA device 0 (NVIDIA GeForce GTX 1650): Scene setup failed  [read CRASHED]
    Then I started over "one by one" to find the problem. It is the shader on the Hair. The earrings render fine, so does the hair cap. But not the hair. And in trying to do whatever with the hair, the memory on the C drive rockets down.
    Applying a regular Iray shader [had to clear it out by going to 3D then back to Iray] to the hair, then it would render fine, no red line.
    Attached image is with the regular Iray shader.
    By
    Catherine3678ab Catherine3678ab September 2022 in Technical Help (nuts n bolts)
    @SofasCitizen, Aaaarrgggghh!
    Nothing goes well.
    I have downloaded a cool lot of cars in either OBJ and FBX file formats.
    When imported the OBJ files, these do not display correctly and while the FBX model is seen, the problem is that some of the elements that are out of place.
    The tires are not in place and same happens with the doors.
    These models looks good in theory but in the practice is hard to put it back together.
    I followed a misleading tutorial on how to import the OBJ files.
    By the way this is the most frustrating experience I have got.angry
    Daz should provide at least some more free downloads of usable content, I am not interested in silly cartoons, I want people, transport, and some usable props and environments.
    I am getting tired of seeing no results!
    By
    Halcon Bluesky Halcon Bluesky September 2022 in New Users
  • Different compatibility bases for one item - duplicating or cloning to make it unique
    hello.
    in among my bunches of outfits there are some items i have used multiple times throughout, e.g. hairbands, bracelets, shirts, pants, skirts and such.
    previously i would save each 'theme' as its own separate wearable, e.g. 'jeans and jacket black' or 'jeans and jacket brown' as well as 'skirt and jacket grey' etc. etc. and naturally it would work that way.
    recently i started making up Hierarchical Materials Presets (HMP) instead, which highlighted the problem that once an item has been assigned to one compatibility base for one outfit, i can't use it for another outfit's HMP - i thought that saving it as a different wearable under a different name would be enough, but not so - even older stuff i haven't touched recently shows up with its comp. base set to a different item that was assigned only recently
    so! how can i make an item unique without having to re-import and re-rig everything again? stuff like bracelets and hairbands are simple but i don't want to have to re-do jackets and pants and complex stuff all over again just so i can use it in a different outfit
    is there any easy way of cloning/duplicating/instancing an existing wearable so it can have its own unique compatibility base/node ID?
    By
    clivewil2 clivewil2 September 2022 in Daz Studio Discussion
  • Carrara Community Art Gallery - Show us your Renders!!!
    This is a character i've created about 10 years ago and rendered in DS, her name is Cara Joyce. https://www.renderosity.com/gallery/items/3078935/cara-joyce-very-first-render (this was about the first version rendered in DS)
    the last weeks i've recreated her in Carrara as the import didn't worked proper (don't know why), made a few adjustments, changed the textures and changed modeled hair to a similar cut with dynamic hair.
    The most interesting part for me is to see how just the haircut will change the entire look of the character, even if it's similar in style.
    So after all the work, this is her now.
    https://www.renderosity.com/gallery/items/3078936/cara-joyce
    Btw. just wanted to add that there are a lot of beautiful artworks on this thread, i mostly like the environment renders that wants me to also try again some of Howies scenes but don't want to render them on Carrara's native engine, on my old pc it took me about a week to render it :D
    Even if i now have a much faster pc with a much better cpu, it still would be faster with Octane.
    However, the last time i've tested octane on trees it didnt rendered the leafs but with Octane 4 it should be possible. Maybe i'll give it a try.
    By
    Chris Fox Art Chris Fox Art September 2022 in Carrara Discussion
    @SofaCitizen, I have found some free resources somewhere else, also I got a tutorial on how to import the files.
    Now with this at hand, I will try to see if I can conquer this hurdle and get into the contest.
    I suppose you may have got some, isn't?
    Now, to the drawing board and vroom!smiley
    By
  • Daz to Blender does nothing in DAZ
    I don't know if this can help but for me it work, i installed plugin 2,3 days ago with DIM
    my versions of software and plugin
    try to check / uncheck "Import-Export daz to blender in preferences"
    By
    Limun Limun September 2022 in Blender Discussion
  • can't find cyclorama files in latest Daz Studio
    richardandtracy said:
    There seems to be a very common theme with people who can't load stuff, so common it's hard to ignore. The common theme seems to be DAZ Central. There are people who succeed with DAZ Central, but large proportion of those who do have problems & ask about it in the forums use DAZ Central.
    It's the whole process that is being presented to new users that's essentially bound to create problems.
    At DAZ site, they are given a link "Download Studio", which doesn't download DAZ Studio, but offers to install DAZ Central instead.
    When the user has installed DAZ Central, downloaded and installed DAZ Studio and the assets that come with it and starts DAZ Studio the first time, the user is presented with a dialog asking for login credentials in a way that one thinks they should be given.
    Having given the login credentials to DS and permission to go online, DAZ Connect within DS starts updating the metadata and 'bugging' the user that the content has not been installed (with DAZ Connect) and makes the user think it has to be installed again, which DAZ Connect does to an other location, taking twice the space on users C-drive (default location)
    As any content installed with DAZ Connect takes priority over the installations made by other methods (DAZ Central/DIM/Manual installation), even when DAZ Connect installed content is corrupt, the user ends up with content that does not work and no way to figure out why...
    There is no warning or notice explaining that logging in to DAZ Studio, is only needed when one chooses to install content with DAZ Connect within DAZ Studio and if one does choose to do that, there is no point in using the other installation methods.
    By
    PerttiA PerttiA September 2022 in Technical Help (nuts n bolts)
  • [Solved] Diffeomorphic environment export not working for specific Scene
    So Ive exported a few Daz environments to Blender and it usually works perfectly fine with some tweaking.
    But I have been trying to export this particular environment (attached) with no success.
    In Daz:
    • Save as Duf
    • Export to Blender with dbz with same name
    In Blender
    • Import Daz
    • Mesh Fitting = dbz (or any other option has same results anyway)
    All i get is an empty collection.
    By
    lilweep lilweep September 2022 in Blender Discussion
    @SofaCitizen, I thought I nailed it.
    I have found a place with some cars.
    These are individual zip files containing *.obj files, also include some texture file, the problem is not easy to import the later into daz studio.
    At first the file went too big, then tried another way but it seems not perfect.
    Now, what is needed is some background with some road view, I can put that into the viewpoint.
    As you can imagine is bad luck again! crying
    If anyone comes to and read this please help! I am struggling big and I am in no good mood now!
    By
    When you say you can't load it, do you mean that
    1. you can't load it from smart content
    2. you can't load it from the library
    3. or you can't load it from products?
    I definitely can load it from the library (Content Library > Daz Studio Formats > My 3D Library > Environments > Landscapes > Multiplane Cyclorama) and Content Library > Products > Multiplabe Cyclorama) but it is probably too old to have smart content metadata.
    By
    nemesis10 nemesis10 September 2022 in Technical Help (nuts n bolts)
  • Mapping Issue with Bellowtalons armor
    It is not your setup. The UV mapping appears to have been made from a different version of the mesh. How it got through QA is anyone's guess, and who knows if anyone else noticed, or if they filed a help ticket. This is not some trivial metadata problem or file path error, and correcting it requires tools that are likely beyond the average user. It could literally take years to get officially corrected. I will add my own complaint to the queue, and so should anyone else with the product.
    ETA: Looking closely at the promos for the original and the texture add-on, you can see the mismatch when you know where to look, although they are strategically positioned so as to not emphasize the defects. It has been that way from day 1, and somebody knew about it.
    By
    NorthOf45 NorthOf45 September 2022 in Technical Help (nuts n bolts)
  • Full conversion - Blender model to Daz3d model
    You must import in FBX format (OBJ doesn't save rigging).
    look here for FBX settings/version to use: https://youtu.be/eRWzMtZViyo?t=2218
    By
    Kainjy Kainjy September 2022 in Blender Discussion
    Hi everyone,
    I would like to use this free robot in Daz3D. It was created with Blender, is rigged and has nice surfaces:
    https://open3dlab.com/project/33935/
    How would it be possible to convert it / import it to Daz3D with the rigging, surfaces, etc?  I have been able to import it, but without rigging and surfaces.  If you could give me some suggestions, that would be nice!
    Thank you for your help!
    M.
    By
    MultiverseFantasies MultiverseFantasies September 2022 in Blender Discussion
  • Import Daz environments props etc with emissive intact
    How do I import Daz stuff into UE5 with the emissives intact?
    By
    milliethegreat milliethegreat September 2022 in Unreal Discussion
    @SofaCitizen, How you go?
    I am trying hard to do some renders, these got displaced after I thought I saved.
    And up to this moment there are no freebies around here; in Rendo there are some usable frebies I got, I had to spend some time there.
    And now I need to catch some zzz, if I have time I will try again.
    Also I saved one tutorial I will follow up and hope this can be useful for a later project.
    Unfortunately the BMW and Audi cars are in another format, I can't import into Daz Studio to work with.
    Take care buddy.
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
