So.... March Madness?
If you own either RiverSoft's or Zev's converter product you can also port V7 to G8F. I haven't tried out how V7 converts myself but all G3 figures I have converted so far look good as G8. You can even use G8's skin shaders and swap V7's maps and see how it looks.I picked up the free Victoria 8 offer at the start of MM and don't really want any of the older versions... I'm guessing the alternate purple banner is for people who already own all of the Victoria figures?
I recommend still picking up the other Victorias even if you don't install/use them. That way you'll qualify for banners like the one today in the future. I believe that for Victoria's birthday (for example) if you own all the Victorias you often got another type of incentive.
Not to mention.. The skin textures. Especially the Genesis 3 version (Victoria 7) works perfectly fine on Victoria 8, and vice versa!
Genesis 8 really is more like Genesis 3.05 than a radical improvement. Even whether it is a noticable qualitive improvement is debatable. But, it's actually really nice that the skin textures are so interchangable. A change of skin can radically alter a characters' appearance, and there adding some Genesis 3 / Victoria 7 skins can exponentially increase your option for appearances.
Useful for those who want to keep the distinct looks of the base characters. V7 looks different to me than V8.
Why doesn't cr2-exporting function work for G3?G4-7 were skipped to avoid confusion (basically Victoria 7 was on Genesis 3 and the numbers were confusing some so they made Genesis 8 to match Victoria 8).
From Genesis 3 to Genesis 8, they reduced the base resolution polys even further but made more of the HD morphs for expressions. Expressions look a lot better in G8 than G3 IMO but otherwise you could use both generations in the same scene without a big disconnect. There were other under-the-hood improvements I think (like the base-pose was changed from a T-Pose to an A-Pose to help with the modelling and fitting of dforce clothing) but mostly I notice the expressions.
I see. It's clear that DAZ is doing better. But I guess I have to stick with poser. It's easier to use for amateurs. I can make figures with a text editor.
I don't understand the file system for DS. Files are not text-based. I expected to find huge files but found only small ones. And no obj!
So.... March Madness?It's sort of easy to miss in today's banner as the free Victoria offer is still live, but today you can pick up a dragon/dragonesque figure for $0.00 with a new release, including Daz Dragon 3 :)
So generous of Daz again!!
Looking for specific style of pigtails hair model for V4Looking for a pigtails hair model similar to the one in the attached image. Anybody got any recommendations?
See if one of these 3 styles is close enough for you…
https://www.daz3d.com/pookie-hair
https://www.daz3d.com/kiriko-hair-for-genesis-2-female-s-and-victoria-4
https://www.daz3d.com/school-girl-hair-for-genesis-2-female-sSo.... March Madness?I recommend still picking up the other Victorias even if you don't install/use them. That way you'll qualify for banners like the one today in the future. I believe that for Victoria's birthday (for example) if you own all the Victorias you often got another type of incentive.
I agree! V7 is top flight and earlier Vickies are useful, too.
The products "victoria 7 for victoria 8" etc.You can either load V7 for V8 on top of the selected base G8F and get a figure that otherwise behaves like a G8 but looks like a V7, or you can load a new figure, in which case you'll end up withe the same thing.
It gives you sliders under the Shaping tab. If you start with a G8F and dial the Victoria 7 sliders to 100%, your G8F will otherwise behave like a G8F but look exactly like a V7.
$419.98 Banana Suit?...it's also the "Key Item" for today..
Wow ended up with "1130,70$" worth (not including the PC+ monthly Freebie) for about 8.50$ which includes 3 DO items off my wishlist totalling almost 90$ for a whopping 75¢ (something like a 99% discount on each, not sure what triggered that particular deep discount, but not complaining).
If you own all Victoria items you get 20$ of free DOs.
...but it states "...and any Newly Mad Item".The only "new item" I bought was the bonus one so did that qualify?.
Bugger, as I could have got another 19.25$ worth of DOs had I known that, as it also states
*Items must be in cart simultaneously for discount to apply.".
yes yes it does worked for me and went a little over so used my non daz coupon for over $18 didn't get the full extra 6 off but that was fine pretty good deal really there was a fair bit to choose from and there was extra discounts me thinks
So.... March Madness?I picked up the free Victoria 8 offer at the start of MM and don't really want any of the older versions... I'm guessing the alternate purple banner is for people who already own all of the Victoria figures?
Written in white ink 'cause it's a secret okay ... you can buy the Banana again and another newly mad item and get $20 of free DOs.
So.... March Madness?Got some things off my wishlist with the 3 extra $6 coupon deal, so quite happy with that.
Skipping on the purple banner alternate deal for Victoria bases owners. Jusr not into any of today's Newly Mad items. If it lasts more than 1 day and there's something interesting in Newly Mad, I'll revist.
Try putting in the banana suit and the 70% off new item (resto shop) in your cart, then add a few select DO's and see what happens...
Also, were you able to use your April Plat club code 4 times, 3 times, or did you use a different code for the 'bonus' coupons?
...I had both so is that what knocked the price of the 3 DOs I had in the cart down to a total of 75¢ from nearly 90$?
Im also PC + and although the honorary PC offer has been extended (which is awesome!) it doesn't make any difference for me and there doesn't seem to be any extended bonus for PC members, so no fun for me today!
There is, the DO coupon for April is usable 3 times: https://www.daz3d.com/honorary-pc-plus-membership
...crikey had I caught that, I would have used the PC+ April Coupon instead of the "Platinum-Perks" code, added another DO or two to get the total for those up to 6$ and effectively got all of them "free".
...same here.
Report sales errors here: "There's Always Another Sale™"I apologize if this post is inappropriate. How petty would it be to submit a ticket about not getting the purple banner for owning all the victoria base models? I feel Daz is already very generous so I'm torn because I was pretty excited about grabbing a particular new release today. (It's Gutz don't judge me.) Just seems like I could probably wait on it for a day or two to see if any other sales pop up rather than whining about not being able to take advantage of this one. What are your thoughts?
Have you checked your Messages? Onsite messages, (banners, currently Purple,) have to be in your Inbox to show up as a banner. And sometimes the message is there but the banner isn't. These messages are usually in the Exclusive Messages inside your inbox.
Yeah I did a bit earlier. I checked again just now to be sure. No luck on that front unfortunately. I appreciate your insight.
Well not necessarily, I own all Victorias and I have no purple banner today. On the sales page today the store even shows that I own all Victorias involved in today's sale.I picked up the free Victoria 8 offer at the start of MM and don't really want any of the older versions... I'm guessing the alternate purple banner is for people who already own all of the Victoria figures?
Not gonna spend money today although I want to but I'm a petty person :(
That's great advice and information @FenixPhoenix :) Thank you so much for sharing!
I appreciate it and maybe I will indeed pick Victoria 7 up today then! So.... March Madness?I picked up the free Victoria 8 offer at the start of MM and don't really want any of the older versions... I'm guessing the alternate purple banner is for people who already own all of the Victoria figures?
Carrara Sale Email Message Alert threadAha, so the deal is to get the banana with a new item, then you get a Victoria or 20$ off, if all are in the cart.
