• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • V3 Morph Inj Problems
    Finally got it working, only took deleting it about four times
    By
    soulpainter06_36c7012b53 soulpainter06_36c7012b53 June 2016 in New Users
  • Novica & Forum Members Tips & Product Reviews Pt 7
    It's such a strange thing - I don't think any other character i've ever seen, WON'T let other clothes and hair fit her. I mean, heck, you can put any older hair on G3F and it'll work fine. What on earth is wrong with Hayley that she won't take hairs or other clothes?
    Seems to be something that 3duniverse is doing to morph his/her girls - Rayn and Skyler have similar problems ...
    By
    Kerya Kerya June 2016 in Art Studio
  • Weight mapped aikoT3
    I don't have Aikotoon - but I do know that Chip and Cookie have Magnets/DForms for the eyes built in (which creates the interesting shapes for hair until you unhide hidden properties and dial the DForms for the hair to zero).
    I don't know if that information helps you - maybe AikoToon has similar DForms built in?
    There often is a problem with eyes when transferring Thorne morphs to Genesis - many Thorne morphs have an Eyefix morph even for the original base. You have to transfer that one too.
    Does this help?
    By
    Kerya Kerya June 2016 in The Commons
  • New User needing general help
    Question
    When importing a morph through morph loader pro, how do you get a parented object to move/follow it?
    Nevermind, Finally found where parented objects are attached to scale not morph, and afterwords found a tutorial
    *Edited
    By
    GuyGenesis GuyGenesis June 2016 in New Users
  • Shoes morphs help
    OK, that is weird. When you are bending, you are letting go of the paramater not just scrubbing back and forth? When the morph is not working, if you click the gear icon on the slider and select Parameters Settings is the bend listed as a controller at the bottom? Does opening and closing that dialogure reestablish the link with the bend as dialing in the morph does?
    By
    Richard Haseltine Richard Haseltine June 2016 in Technical Help (nuts n bolts)
  • StrangeFate's stuff: Argentheart Crowns promos.
    Well, now that you mention pin up poses... hadn't even thought about that hmm...
    I made morphs for the hammer, axe and cleaver that scale and shift some parts around to make them smaller and shorter. The result is passable 1 handed versions of them, you can just load the default 2 hander and use the morph at 100% to make it into a 1 hander! I'll probably do 2-3 poses for 1 handers and I have to finish assembling the 3Delight versions of the materials and that should be all.
    Also bought the Troll and a few other things today to see how files are structured etc... and ended up goofing around...
    By
    StrangeFate StrangeFate June 2016 in Art Studio
  • Morph loader advanced from Max to Daz
    Morphs are linear - the application stoes the offset from the base position (the morph deltas) and translates the vertices along a line beween the base position and the morph shape. If you rotate the mesh the vertices will be right only at the extreme values (0 and 1) - in the worst case, a 180 degree rotation, the vertices will all be on top of each other at a setting of 0.5. If you want parts to rotate you need to rig the item as a figure.
    By
  • Shoes morphs help
    Are you making a corrective morph that is meant to be triggered by both a morph and a bend
    No, just morph triggered by bend.
     Again, which morph - the JCM or some other morph?
     I mean when i bending foot - morph not triggering by bend. If i dial morph to 100% and reset to zero, it is start working (morph triggered by bend)
    By
    Onnel Onnel June 2016 in Technical Help (nuts n bolts)
  • Samesex couple poses
    SF-Design had some poses for the previous generation, so maybe those would convert over. I have the M6 set, but not the Jayden set, so I don't know if the scaling on the Jayden poses would produce issues. They come with expressions, but also have expression resets so that you can use your own.
    https://www.renderosity.com/mod/bcs/tender-buddies/105630/
    https://www.renderosity.com/mod/bcs/buddies-for-jayden-6/106605/
    I used one of the Pose Converters to transfer Tender Buddies to G3M, but haven't used it yet.
    And these poses are, in fact, EXACTLY "that innocent". (No naughtiness here, no.)
    And all that said, I haven't had that much of an issue with using the opposite sex poses with same sex couples. It can, as Male-M3dia noted, be a bit fiddly about the feet and hands (and also hips and pelvis, depending on the pose), but they can be made to work.
    By
    vwrangler vwrangler June 2016 in Product Suggestions
  • virtual penny 4 yor carrara thoughts ?
    THANKS!! smiley  helps to know the correct terminology.
    470$ >.<  wantz it though  http://www.sonycreativesoftware.com/sfxseries1-10
    need a morph on Aiko's eyelashes to make em roll down when she closes her eyes
    By
    Mistara Mistara June 2016 in Carrara Discussion
  • anything to convert g3m skin to m4?
    texture converter?  map transfer utility?
    thanks!!
    By
    Mistara Mistara June 2016 in The Commons
    I searched for help on this but have not been able to find this particular problem. I am sure I am just missing one step. I created an object in Max and imported to DAZ through Figure setup. In max, I made a change to the model, an object translates backward while an object rotates within, exported the object. In DAZ, I used Morph Loader Advanced to load the new model, it worked beautifully. Went back to Max, zeroed the objects back to it's original form and chose two other objects to move and rotate. Object A (see figures) rotates forward while object B translates right, when I do the same steps to import the morph, object A scales down.
    By
    Hoplite490 Hoplite490 June 2016 in Technical Help (nuts n bolts)
  • Orphaned Soul's Ola
    I've just imported all the obj files, Used transfer utility to fit to G2F and added textures. All saved in a seperate folder so at least I can use it.
    By
    Wilmap Wilmap June 2016 in The Commons
  • "An error occured while reading the file" SOLVED
    I just finally updated from DS 4.9 to the newest 4.9 (forgot the number) and every time I try to load something I get the message "An error occurred while reading the file." I tried with connect on and off. I was able to load a character morph but can't load any materials for any character (G3). This is from the smart pane. I couldn't even find where all the G3 characters are in the content pane... It says to check the log file. Where is the log file??? Please help! Thanks.
    By
    Wonderland Wonderland June 2016 in The Commons
  • Shoes morphs help
    Yeah, i do everything correctly.. But bend start inreacts with morph just after i randomly dial my morph.
    I'm not sure what you mean here. Are you making a corrective morph that is meant to be triggered by both a morph and a bend?
    And when i reupload saved product JCM not working if you do not dial the morph.
    reupload = reload? Again, which morph - the JCM or some other morph?
    By
  • Shoes morphs help
    By
  • Installing 3rd party morphs and understanding UV maps
    Now I am having an issue where I polypaint clothing with color and the color does not transfer to Daz.
    Also, instead of a shirt showing up as plastic or matte, etc in the properties, is there a fabric preset or do the render shaders make things look like fabric and other materials?
    By
    christinaparissi christinaparissi June 2016 in New Users
  • Bandaids, bandages, wound wrapping
    I picked up the Band-Aid at Poserworld. This is sort of a step in the right direction, but OMG it is tough to pose. It has a curve morph but It really is tough to get flush with the skin. I think making it conforming would likely be the way to go.
    By
    Serene Night Serene Night June 2016 in Product Suggestions
  • Converting to G1, G2, G3, G8 & G9
    Has anybody seen this morph conversion tool for V4 and G2 to G3? In the absense of a GenX update for G3, maybe this could help. The item is sold on DeviantArt, and there is one small NSFW pic at the bottom of the description. The item is $25, and requires Windows 7 or newer along with the .NET Framework. You basically export a V4 or G2 figure to object, run the tool on that object, and then import the updated object back to Daz through the Morph Loader. Most of the comments on DA are positive.
    http://darkhound1.deviantart.com/art/Legacy-to-Gen3-morph-converter-1-0-buy-it-here-589021408
    Does anybody know, if it is possible to buy that converter without having account/ DApoints at Deviant Art?
    He will accept PayPal as payment, but that still requires contacting him through Deviant, which of course requires a Deviant account. I just want to know if anybody here has used it. I've seen talk of it on DA, but I've never seen anyone mention it here. I can't be the only person from this forum who's seen it.
    By
    outrider42 outrider42 June 2016 in The Commons
    By
    Artini Artini June 2016 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
