Upgraded to Daz 4.11 and now Headshop 11 doesn't show up
I also do no longer have Headshop showing since i upgraded. Has there been a fix arranged yet ?
Upgraded to Daz 4.11 and now Headshop 11 doesn't show upIn answer to Richard's comment, in the c:/programs files/daz3d there is a plugin folder with the .dll file in it. There is also a a folder in C:/ Program Files/Daz 3D named Headshop Plugin. Should the Headshop Plugin folder be inside the the same folder that the .dll file is in?
Upgraded to Daz 4.11 and now Headshop 11 doesn't show upWhen I upgraded to 4.11, it made a separate install instead of overwritting 4.10. Oddly, all the other plugs I had were still there except for HeadShop. With the 4.10 install, I did have similar issues; it was there, then it wasn't. So I studied the install to other than default section of his notes and installed to 4.11 and it went w/o any problem. I suspect performing aa new install of HeadShop might resolve the issue.
Upgraded to Daz 4.11 and now Headshop 11 doesn't show upThanks for the quick response. It is not showing up under the installed plugins. The install path is c:/Program Files/Daz3D/HeadShop plugin, the same place as the Carrara8.5 , Daz3DimM1 and DAZStudio4 folders are located. Its the same location that it was previously located in when it was working. Any help is greatly appreciated.
Upgraded to Daz 4.11 and now Headshop 11 doesn't show upI just updated to the latest version of Daz using DIM and now Headshop 11 doesn't show up under the edit tab. It was there under the previous version. I tried reloading it to Program
Files Daz3d and the Headshop Plugin folder is there with all the files but it still doesn't show up in the new version of Daz. Are there some settings that I need to change in Daz 3d?
Headshop 11Not so sure Walther Mathau would be if he was still with us.
Might be fun to try more characture stuff like this with it.
When you upgrade, most folks find that it installs to where 4.10 is currently. In that regard, I'd make sure you uninstall Headshop first so it all starts clean.
When I upgraded to 4.11, it actually followed my prefs & installed to D:\Program Files; 4.10 is under D:\Daz 3D so I have both. Both still use the same folder for the downloads so the new DIM looks at the same place for that.
Headshop 11Does Headshop 11 work in DS 4.11?
Headshop 11 QuestionsArghh, just read in the manual that:
""Make sure that your DAZ Studio Temp and DSON Preferences are set to Default"
I use custom locations for the cache dirs.
Can you confirm that headshop does not work in that case?
Headshop 11 QuestionsYes, you can change the location. In fact the current version requires you to pick a place to install. Take a look at page 3 where I made several long review posts. Those points all still stand, both good and bad. I still prefer Facegen, and you'll see my direct comparisons in this thread. But I might use Headshop at times.Is it possible to copy skin texture from a photo?FaceGen would likely do a decent job, but depends on the quality of the images, although it does faces not hands
https://www.daz3d.com/facegen-artist-pro
It goes on sale, so you could wait; there is also Headshop, but never fancied it, no idea on folk's opinions on it.
My advice would be to copy the distinguishing characteristics from your hand images onto a texture you like; details such as moles, freckles, scars - etc.
Thanks nicstt - I was thinking of Facegen but I'm guessing that it's highly optimized for faces. Might be worth a try I suppose but I don't want to outlay money if it's a waste. Maybe someone on here with Facegen would be kind enough to try it out on a hand?
Copying the distinguishing features (moles etc) is one thing - but I doubt that would work for matching colour and size and things like that? I guess I'm basically looking to "graft" skin on a model?
AIUTO...CHI CONOSCE L’ITALIANO? PARTE DODICIHo comprato Comic Life 3, e gli sviluppatori se gli fai notare qualcosa di sbagliato (e di bug ne ha davvero tanti, lagga molto e crasha sempre), ti rispondono che ormai il software è fatto così :/Benvenuto nel club!
Tempo fa ho acquistato HeadShop. Non ho avuto modo di farlo funzionare in nessuna maniera a causa del fatto che la mia installazione di DAZ non è quella di Default, ho tutte le librerie posizionate e gestite come dico io.
Ho contattato l'assistenza che mi ha rimandato allo sviluppatore. Lo sviluppatore mi ha detto che poteva aiutarmi solo tramite videochiamata. Mi organizzo e quando ero pronto alla videochiamata, lui era fuori città ma di aspettare che presto sarebbe rientrato. Attendo.
Quando poi finalmente è rientrato abbiamo fatto la videochiamata, ha dato uno sguardo ai percorsi e ha detto "Non funziona se le librerire non sono default".
Stavo per dirgli "Eh, ma va?!" ma mi sono trattenuto e gli ho chiesto come risolvere.
Mi risponde "Non si può, chiedi il rimborso." e chiude la chiamata senza nemmeno salutare.
Ma il periodo per il rimborso era passato da un pezzo e io non lo avevo chiesto visto che mi aveva assicurato che mi avrebbe risolto il problema.Ma dico io, come ha fatto a passare il controllo di DAZ un programma che funziona solo sul PC di chi l'ha creato?
...Forse perchè non è previsto che tu modifichi le cartelle come ti pare? XD ...poi che sia un cafone è un altro discorso...
Magari è previsto che il programmatore perlomeno si immagini che non tutti fanno next-next-next-next-next ad ogni installazione...
E non è una ipotesi tanto remota dato che ci sono centinaia di post che chiedono come usarlo su librerie non default.
Una volta volevo prenderlo, visto che l'avevo trovato sui 10$ con tutti gli sconti sommati, però ho visto che le recensioni erano peggio che pessime!
Parlano bene invece del concorrente, come si chiamava? Tipo FaceGen mi sembra
Il concorrente ha anche una demo gratuita, che ti dà texture inutilizzabili coi loghi, ma in generale ti dà un'idea.
Fa la texture anche per tutto il corpo.
Il problema è che hai bisogno di foto perfette!AIUTO...CHI CONOSCE L’ITALIANO? PARTE DODICIHo comprato Comic Life 3, e gli sviluppatori se gli fai notare qualcosa di sbagliato (e di bug ne ha davvero tanti, lagga molto e crasha sempre), ti rispondono che ormai il software è fatto così :/Benvenuto nel club!
Headshop 11 Questions"You start Headshop from inside Daz itself. I can't remember which menu it is under at the moment, it is not like the Hexagon bridge. Once you find it and are ready to start, you must name your model BEFORE you start Headshop."
Not true. Don't have to name anything. Just start HeadShop from the Edit menu and it is all automatic. When you finished, again, don't have to do anything. HeadShop closes and your shape/texture is transfered to the model on stage.
However, if you choose not to name anything you are stuck with a morph and texture named "fs". I don't think most people want that.
More over, if you create another HS character with the same name, it overwrites the previous one! So if you go to create another character without changing the default name of "fs", then your previous "fs" will be replaced by the new one.
So to say that it is not true that people do not have to name anything, this is a bit misleading.
Who is the beautiful girl used by Goldtassel in promo pics that looks like Felicity Jones?That's pretty impressive, too, arglesw007. I think that one important thing that this illustrates, is how important the texture set is to creating a credible clone, not just in this case, but every case. Of course, the people behind Facegen and Headshop certainly know this.
Headshop 11 QuestionsI don't remember. The app has a guide as you use it. There may be a link from the app itself to a full one.
I wouldn't worry too much, because adjusting the sliders or dots usually resulted in more problems that anything else. Just let the autodots do their thing and transfer back to Daz. If you just use the autodots the process is very simple and fast. To be blunt, messing with the deeper functions and Headshop dials resulted in glitches, often deforming the head without a way to revert unless you restart the app.
You start Headshop from inside Daz itself. I can't remember which menu it is under at the moment, it is not like the Hexagon bridge. Once you find it and are ready to start, you must name your model BEFORE you start Headshop. This threw me for a bit because I am not in the habit using Facegen. I often do not know what I might name my model until I am done with it, so this goes against my nature. I forgot to do it, and I ended up with models under the default name.
HeadShop 11 WINHello
I am new to DAZ in general and it is a very interesting software. So I started investing in buying products and I came accross HeadShop 11 WIN.
I would like to know how good that add-on is before I buy. There is no documentation or videos showing off the product in action.
So is the 99$ price tag justified for this ? How accurate is the software when creating a head based on a photo ?
Thanks !
