• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Daz Studio 4.14 Pro, General Release!
    Dartanbeck said:
    The problem is that the morph dials are set to default. So when I "Zero" the figure, I get Lara's head, this shape adjustment, that one... I go through and it takes forever, since none of them are flagged (in bold white) as being changed, since they're set (in properties) to a default value other than the original "0.00".
    On my system they show up in Currently Used regardless of the parameter default; I loaded "Leony HD for Victoria 8", Currently Used shows the Actor morphs at 100% in white (the default is 0%), I changed the default on every one to 100%, turning the values grey, and reloaded Currently Used.  They're still there.  What is more in my DAZStudio if I then Zero Figure Shape they all get set to 0% and they disappear from Currently Used.  At this point the shape is set to "Genesis 8 Basic Female".  So I have non-default Actor morphs, e.g. 0% for Victoria 8 and they are marked as used (set) after Zero Figure Shape sets them to 0% but they do not appear in Currently Used.  If I Restore Figure Shape at this point I get Leony back and the Actor morphs are still set to 100%; they appear in Currently Used but are greyed because my change to the default parameter setting has not been reverted.
    This is why I was suggesting it might be a good idea to record exactly what these options do.  A DAZ engineer with knowledge of how "Zero Shape", "Restore Shape" and "Currently Used" actually work will probably know immediately where the values are coming from.
    Of course this is not the bug.  It's a sympom of the bug.  Something has been changed, I guess in the CMS, which alters the behavior of G8F and maybe other figures.  I sort-of suspect that the settings are coming from a saved character preset or maybe even a pose preset (in which case Zero Figure Pose and Restore Figure Pose will produce relevant information).  I notice that "Memorize Figure Shape" does not set the defaults of the Leony morphs to 100% whereas that is exactly what happens with "Memorize Figure Pose" with changed (non-0) defaults.  Maybe if the defaults are set to 100% in a CMS Actor they will get set on all derived characters?
    Anyway it will be interesting to see what a de-install/install of the essentials does; if that alone fixes the bug then a simple diff of the files in the essentials package will show where the problem arises.  Personally I'd just do the diff without the de-install/install, but that's just me; I don't like to tamper with a system which shows a bug because all too often the symptom disappears and the bug survives to strike another day.
    By
    jbowler jbowler January 2021 in Daz Studio Discussion
  • V4 will not install on my version of Poser.
    English Bob said:
    Yes, Victoria 4 will work in Poser 5, but it's not straightforward any more. I'm assuming you're running Windows, and if you are, that it's more up to date than your version of Poser!
    Good to hear from you, Stranger! laugh  Happy New Year, E.B.!!
    By
    WandW WandW January 2021 in Poser Discussion
    As others have suggested, Windows will prevent you installing content into a runtime situated in C:\Program Files, which is the default location for the library in Poser 5. There are a couple of ways around this.
    I don't have Poser 5 installed any more, but it does support extra runtimes (this was the version which introduced the Content Room, and its associated Downloads library IIRC).
    You could install V4 into an external runtime, which you would create somewhere other than C:\Program Files - however I don't recommend this, since (from memory) V4 needed to be installed in the main runtime of early Poser versions in order to work properly.
    My recommendation would be to reinstall Poser entirely, and to place it somewhere outside the default C:\Program Files. For example, you could make a Poser folder in your My Documents, and install to that. Earlier Poser versions aren't fussy about where they run from, in fact I had my Posers 4, 6, and 7 running from a portable disk for many years. Doing this will give you free access to your library, which you will need for any further content installations or modifications you may want to do.
    I don't know your level of technical expertise, OP, but ask follow-up questions if needed - and tell us your OS details as well.
    By
    English Bob English Bob January 2021 in Poser Discussion
  • Can anyone I.D. this character?
    Hi all,
    She is a mix of Victoria (%40), Kanade 8 (%30) and Karyssa 8 (%30). I like to mix and create new looking...
    By
    Neikdian Neikdian January 2021 in The Commons
  • 3D Art Freebie Challenge-December 2020-Winners Announced "Holiday Traditions" -Entries Thread Only
    Christmas Music
    The Christmas tradition of singing and playing music.
    Free Items:
    1. Le piano (https://www.renderosity.com/rr/mod/freestuff/le-piano/79996)
    2. 1850s Women's Hair Bundle for G2F (https://www.renderosity.com/rr/mod/freestuff/1850s-womens-hair-bundle-for-g2f/75572)
    3. NOEL_DECORS_GUIRLANDES (https://www.renderosity.com/rr/mod/freestuff/noel-decors-guirlandes/75863)
    4. A Few Books (Hardbacks) For DAZ Studio 4 (https://www.renderosity.com/rr/mod/freestuff/a-few-books-hardbacks-for-daz-studio-4/82979)
    5. Charming For G8M (https://www.renderosity.com/rr/mod/freestuff/charming-for-g8m/83939)
    6. Everyday Hair Style for Genesis 8 Male(s) (https://www.renderosity.com/rr/mod/freestuff/everyday-hair-style-for-genesis-8-male-s-/80194)
    7. RW LITTLE LACES DRESS for Genesis 2 Female (https://www.renderosity.com/rr/mod/freestuff/?item_id=81712)
    8. Contemporary Room (https://www.renderosity.com/rr/mod/freestuff/?item_id=77686)
    9. InStyle - dForce Winter Nights G8F (https://www.renderosity.com/article/23509/dec2020-24-days-of-christmas?utm_source=newsletter&utm_medium=email&utm_content=LEARN%20MORE&utm_campaign=dailynl_12012020) – 11th day
    10. Sabby-Lucy for Victoria 6 (https://www.renderosity.com/article/23509/dec2020-24-days-of-christmas?utm_source=newsletter&utm_medium=email&utm_content=LEARN%20MORE&utm_campaign=dailynl_12012020) – 14th day
    No Count Item:
    1. Genesis 8 Male
    2. Genesis 2 Female
    Before postwork:
    After postwork:
    By
    katywhite katywhite December 2020 in Freebies
  • Filling the scene with "Fake" characters
    Unless you deliberately want those characters to look like mannequins or ghosts.  I think a way better idea is to use copies of the same character and instances. to save more memory use the same textures from the main character.
    Genesis 8 figure is an extremely low poly model so they use very little geometry memory clothes are way more expensive in terms of memory and geometry as some simple dress may have more polygons that genesis 8 figure while one decent hair will use more than 10 figures. to avoid that I would recommend using some older hair models from victoria 4 time and avoid long hair or anything complex
    I made scenes with more than 16 figures in them.  and the only problem is waiting until they will get duplicated. but you can duplicate one figure then duplicate those 2 at once and get 4 then duplicate 4 and get 8  and so on.
    If all characters in your classroom use the same uniform there will be no problem adding like 10 copies of them and then you can also make multiple instances of each copy which will be enough for the entire graduation ceremony also you can combine instances of hair with instances of characters. then slightly change the size of your characters and a direction.
    By
    onix onix December 2020 in New Users
  • Growing Up for G8F causing missing genesis3female.duf
     This was working fine yesterday, but suddenly today loading G8F says it's missing data/daz 3d/genesis 3/female/genesis3female.dsf. Fresh scene, restarted studio, and I've already tried uninstalling and completely redownloading G8F.
    /edit - This appears to be caused by Growing Up for Genesis 8 Female as the issue stops when I remove it. I forgot I reinstalled it last night w/o testing it. I've edited the title to reflect this.
    Log file:
    2020-12-31 13:27:01.025 *** Scene Cleared ***
    2020-12-31 13:27:02.726 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5836): Could not find parent for modifier: CTRLMD_N_ZRotate_n20.
    2020-12-31 13:27:02.726 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1660): Failed to prepare modifier: CTRLMD_N_ZRotate_n20!
    2020-12-31 13:27:02.728 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5836): Could not find parent for modifier: CTRLMD_N_ZRotate_20.
    2020-12-31 13:27:02.728 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1660): Failed to prepare modifier: CTRLMD_N_ZRotate_20!
    2020-12-31 13:27:02.756 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1671): Failed to create modifier: CTRLMD_N_ZRotate_n20!
    2020-12-31 13:27:02.756 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1671): Failed to create modifier: CTRLMD_N_ZRotate_20!
    2020-12-31 13:27:03.221 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: chest:/data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Growing%20Up/chestLower_CTRLMD_N_ZRotate_20.dsf#CTRLMD_N_ZRotate_20?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Growing%20Up/JCMAbdoUChestLSide-sideFixLCombo.dsf
    2020-12-31 13:27:04.570 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLWink_HD.dsf#eCTRLWink?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Wink_HDLv2.dsf
    2020-12-31 13:27:04.571 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLScream_HD.dsf#eCTRLScream?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Scream_HDLv2.dsf
    2020-12-31 13:27:04.577 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLRage_HD.dsf#eCTRLRage?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Rage_HDLv2.dsf
    2020-12-31 13:27:04.577 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLPain_HD.dsf#eCTRLPain?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Pain_HDLv2.dsf
    2020-12-31 13:27:04.585 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6777): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eJCMPain_HD_div2.dsf#eJCMPain_HD_div2?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Pain_HDLv2.dsf
    2020-12-31 13:27:04.585 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLHappy_HD.dsf#eCTRLHappy?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Happy_HDLv2.dsf
    2020-12-31 13:27:04.594 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6777): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eJCMHappy_HD_div2.dsf#eJCMHappy_HD_div2?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Happy_HDLv2.dsf
    2020-12-31 13:27:04.594 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLFear_HD.dsf#eCTRLFear?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Fear_HDLv2.dsf
    2020-12-31 13:27:04.599 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6777): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eJCMFear_HD_div2.dsf#eJCMFear_HD_div2?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eJCMVictoria8Fear_HDLv2.dsf
    2020-12-31 13:27:04.600 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Expressions/eCTRLExcitement_HD.dsf#eCTRLExcitement?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Victoria%208/eCTRLVictoria8Excitement_HD.dsf
    2020-12-31 13:27:05.224 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: chest:/data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Growing%20Up/chestLower_CTRLMD_N_ZRotate_20.dsf#CTRLMD_N_ZRotate_20?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Growing%20Up/JCMAbdoUpperChestLSide-sideFixR.dsf
    2020-12-31 13:27:05.224 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: chest:/data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Growing%20Up/chestLower_CTRLMD_N_ZRotate_n20.dsf#CTRLMD_N_ZRotate_n20?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Growing%20Up/JCMAbdoUpperChestLSide-sideFixL.dsf
    2020-12-31 13:27:05.230 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(6843): Could not find target property for formula: chest:/data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Growing%20Up/chestLower_CTRLMD_N_ZRotate_n20.dsf#CTRLMD_N_ZRotate_n20?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/Zev0/Growing%20Up/JCMAbdoUChestLSide-sideFixRCombo.dsf
    2020-12-31 13:27:05.251 Begin Loading Character Addons...
    2020-12-31 13:27:05.346 File loaded in 0 min 0.0 sec.
    2020-12-31 13:27:05.347 Loaded file: Genesis 8 Female Eyelashes.duf
    2020-12-31 13:27:05.356 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-12-31 13:27:05.357 Loaded file: PHMEyelashesLengthUpper.dsf
    2020-12-31 13:27:05.357 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-12-31 13:27:05.358 Loaded file: PHMEyelashesLengthLower.dsf
    2020-12-31 13:27:05.359 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-12-31 13:27:05.360 Loaded file: PHMEyelashesCurl.dsf
    2020-12-31 13:27:05.373 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-12-31 13:27:05.374 Loaded file: PHMEyelashesLengthUpper.dsf
    2020-12-31 13:27:05.377 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-12-31 13:27:05.383 Loaded file: PHMEyelashesLengthLower.dsf
    2020-12-31 13:27:05.385 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-12-31 13:27:05.386 Loaded file: PHMEyelashesCurl.dsf
    2020-12-31 13:27:05.388 Loaded Morph Deltas in 0 min 0.0 sec.
    2020-12-31 13:27:05.389 Loaded file: PHMEyelashesExpand.dsf
    2020-12-31 13:27:05.447 File loaded in 0 min 0.0 sec.
    2020-12-31 13:27:05.448 Loaded file: Base MAT Eyelashes.duf
    2020-12-31 13:27:05.450 Finished Loading Character Addons
    2020-12-31 13:27:05.462 File loaded in 0 min 5.4 sec.
    2020-12-31 13:27:05.467 Loaded file: Genesis 8 Basic Female.duf
    2020-12-31 13:27:05.779 Could not resolve : "/data/DAZ 3D/Genesis 3/Female/Genesis3Female.dsf"
    2020-12-31 13:27:06.141 Loaded image G8FBaseLegsMapD_1003.jpg
    2020-12-31 13:27:06.340 Loaded image G8FBaseEyes01_1007.jpg
    2020-12-31 13:27:06.528 Loaded image G8FBaseArmsMapD_1004.jpg
    2020-12-31 13:27:06.680 Loaded image G8FBaseMouthMapD_1005.jpg
    2020-12-31 13:27:06.877 Loaded image G8FBaseFaceMapD_1001.jpg
    2020-12-31 13:27:07.143 Loaded image G8FBaseTorsoMapD_1002.jpg
    2020-12-31 13:27:07.298 Loaded image G8FBaseEyelashes_1006.jpg
    By
    Lissa_xyz Lissa_xyz December 2020 in Technical Help (nuts n bolts)
    FILLING SANTA'S SLEIGH
    (new with corrected link)
    No count : : Gemesis 1
    FREEBIES
    Ghastly's Big Eye Anime Team -Genesis 1 morphs.
    https://www.sharecg.com/v/70264/related/21/DAZ-Studio/Ghastlys-Big-Eye-Anime-Team-Genesis-1-morphs.
    Ghastly's General Purpose Anime Team - G1 Morphs
    https://sharecg.com/v/70211/related/21/DAZ-Studio/Ghastlys-General-Purpose-Anime-Team-G1-Morphs
    gift outfit genesis (corrected)
    https://www.renderosity.com/rr/mod/freestuff/gift-outfit-for-victoria-5-genesis-/66630
    Genesis Casual Pants & Top
    https://www.wilmapsdigitalcreations.co.uk/view_product.php?id=249
    textures
    https://mooncraftrp.com/index.php/2020/04/24/free-botanical-pattern-iray-shader-set-tips-for-daz3d/
    santas sleigh
    https://sharecg.com/v/73785/view/21/DAZ-Studio/santas-sleigh
    gifts
    https://www.renderosity.com/rr/mod/freestuff/christmas-tree-and-gifts-for-poser-/80616
    wreath
    https://www.renderosity.com/rr/mod/freestuff/christmas-wreath-for-poser-/80625
    Santa hat
    https://www.renderosity.com/rr/mod/freestuff/christmas-santa-hat/75963
    guirlandes
    background (corrected)
     Archiv.zip Fantasy Backgrounds.zip Ordner by Mysticartdesign on DeviantArt
    Happy new year 2021
    emanuela1
    By
    emanuela1 emanuela1 December 2020 in Freebies
  • 3D Art Freebie Challenge-December 2020-"Holiday Traditions" -Main Thread Only
    emanuela1 said:
    I send a new copy, with corrected links
    FREEBIES
    textures
    santas sleigh
    gifts
    wreath
    Santa hat
    guirlandes
    Happy new year 2021
    emanuela1
    All Links Check Out Plz Move It To The Entries Thread
    By
    Saphirewild Saphirewild December 2020 in Freebies
    FREEBIES
    textures
    santas sleigh
    gifts
    wreath
    Santa hat
    guirlandes
    Happy new year 2021
    emanuela1
    By
  • Flash Sale Alerts III (with limited conversations, pretty please.)
    Changed:
    https://www.daz3d.com/save-on-bundles
    https://www.daz3d.com/ellithia-8-pro-bundle
    https://www.daz3d.com/victoria-8-pro-bundle
    https://www.daz3d.com/lee-8-pro-bundle
    By
    Xellosz Xellosz December 2020 in The Commons
  • "There's Always Another Sale™" Sales thread: Report Issues Here
    Charlie Judge said:
    GeoffreyHawkins said:
    Does anyone have a list of all the Blink Bundles offered so far? There are a couple G8 bundles I'm interested in but if they've already been featured, I don't want to be needlessly checking every two hours.  Thanks.
    Michael 8 Pro
    Victoria 8 Pro
    Tara World Adventurer Megabundle
    Sydney 8 Pro
    Aiko 8 Pro
    Daisy 8 Pro
    Charolette 8 Pro
    Landon 8 Pro
    Owen 8 Pro
    Genesis 8 Cebtaur 8 Pro
    Jenni 8 Pro
    Girl 8 Pro
    Sakura 8 Pro
    Lee 8 Pro
    Silas 8 Pro
    Teen Raven 8 Pro
    Tasha 8 Pro
    Robyn 8 Pro
    Kala 8 Pro
    Mr Woo 8 Pro
    Mei Lin 8 Pro
    Bridgete 8 Pro
    Olympia 8 Pro
    Edward 8 Pro
    The Brute 8 Pro
    Elithia 8 Pro
    Christian 8 Pro
    Floyd 8 Pro
    Tristan 8 Pro
    Kanade 8 Pro
    CJ 8 Pro
    Zelara 8 Pro
    ExpansiveAPESuit Bundle
    Teen Kaylee 8 Pro
    Thank you for keeping up on this.  I been trying myself, but missed a couple along the way.
    By
    jukingeo jukingeo December 2020 in The Commons
  • Victoria 4 to Genesis 1/2/3 animation converter?
    Is there any script that can convert Victoria 4 animations to the Genesis 1, 2, and/or 3 versions?
    I know there is a pose converter in the Shop for Victoria 4 to Genesis 1 and 2.
    By
    EightiesIsEnough EightiesIsEnough December 2020 in Product Suggestions
    katywhite said:
    Saphirewild said:
    katywhite said:
    Christmas Music
    Free Items:
    No Count Item:
    1. Genesis 8 Male
    2. Genesis 2 Female
    Before postwork images:
    After postwork image (Photoshop):
    @katywhite I need you to repost these images as I can't see any of them!
    @Saphirewild Really? Sorry about that, here they are again. I cropped out the blank space on the spotrendered images for you so it's a bit easier to see.
    Before postwork:
    After postwork:
    By
  • Celebrity Look-a-Likes for 3D figures part 3
    Hylas said:
    Lucy Liu was my first thought as well, but it's not all that clear. Perhaps it's just someone I don't know.
    We already have a strong Lucy Liu in Onishi.
    Limei from P3D's https://www.daz3d.com/p3d-mei-lin-8-enhanced-morphs is also a pretty decent Lucy Liu.
    By
    Sevrin Sevrin December 2020 in The Commons
    By
    Hylas Hylas December 2020 in The Commons
  • [Released] Character Converter from Genesis 3 Female to Genesis 8 Female(Now Conv JCMs) [Commercial]
    nabob21 said:
    No it doesn't. I don't have the HD morphs for Victoria 7. It is odd that it is looking for it though since the character I am converting isn't Makena, and according to the requirements for Makena, it doesn't say the HD morphs are required - only Victoria 7.
    All of the Deva3D files that are not found I do won and are located in the correct data folders in the content library on my external drive (F: drive) and not in the main Daz content library (C: drive).
    I am not sure about the Toon Generations 2 stuff since I don't have that and never did. I have also never owned NGV7 or Bend Control. I do have Bethany and Teen Josie 7 and they are in the content library on my C: drive.
    The Makena error is not because of the conversion.  Makena is a G3F (if it is the one from that other site).  These are often errors the vendor made; updates can fix them a lot of times.
    By
    RiverSoft Art RiverSoft Art December 2020 in Daz PA Commercial Products
    By
    nabob21 nabob21 December 2020 in Daz PA Commercial Products
    nabob21 said:
    I am not sure what the error messages are looking for. Are they looking for the Victoria 7 HD morphs and a character named Makena? If so that is odd because the character requirements only list Victoria 7 for the head morphs and make no mention of a character named Makena (which is a separate character for G3F that also uses Victoria 7).
    nabob21
    The body morph for Makena (FBM-FWSAMakena.dsf) is looking for the body morph for Victoria 7 (in /data/DAZ%203D/Genesis%203/Female/Morphs/DAZ%203D/Victoria%207/FBMVictoria7HDLv4.dsf) (note that %20 is a space).  Does the FBMVictoria7HDLv4.dsf exist in /data/ DAZ 3D/...?  In any of your content directories listed in Content manager?
    By
    Also I have the characters that I am converting in a separate content library from the main Daz default content library. I have Victoria 7 but not the HD morphs. Are these also concerns?
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
