Outfit fit-to, but maintain shape
Does the clothing line up with the zeroed figure when you import it, or was it modelled around a morph?
Exporting to Max for Morphs Issues.Having a Max GoZ plugin and a DS GoZ plug-in doesn't mean that you can use a similar bridge from DS to Max - GoZ is a specific way of communicating between ZBrush and another application, communicating with Max would require a whole new system and a whole new plug-in for DS - which I suspect, but can't say for certain, would be deemed not am effectgive use of limited resources.
There's nothing in the OBJ to say what axis (or scale) was sued - hence the need for different presets on the importer and exporter. It may well be that there is a bug here, and I would crtainly encourage you to open a support ticket (even if there is no bug, support may be able to help you resolve the issue). As far as I am aware Blender uses the same axis set-up as Max and people certainly use that for morph creation, so while I don't know of anyone who is creating morphs in Max I have no reason to think it can't be done.
Exporting to Max for Morphs Issues.So DS don't develop workflow plugins for "Pricey" software, wouldn't it be easier to just say Max isn't supported for morph workflow ? It does supprt GoZ style exchange but Pixelogic stopped officialy supporting it a few years back.
I may look into this again when I get time, but from what I've discovered DS is at fault in how it loads the obj from max, it wouldn't be so bad if this software had up to date documentation I could refer to and a support system that actually responds.
What staggers me is this software isn't capable of detecting the correct axis on the incoming obj, or at the very least giving you a "Preview" option so you could see what the incoming result would be, instead it provides a confusing, convoluted and undocumented morph import option.
Anyway my client has agreed to go with AXYZ models for this project, what a relief, I simply can't waste any more time with this at the moment, I've spent about 6 hours trying all configurations and non of them work.
Studio Help in Saving Only Part of a Figure (eg head) but Keeping Morphs and Rigging1 set current tool as geometry editor. with open tool setting tab.
2 select poligons which you need not first.(I use rasso selection and symmetly option first) , or you can select poligons which you hope to remain, and invert selection.
3 hide selected poligons. (those poligons will be deleted) from option menu of tab. or r-click in the 3d view, then geometry visiblity>hide selected poligons. (You can use invert hide poligons too)
4 confrim,, your selection is right, then this time, geometry editting>delete hidden poligons.
5 it may take time to circulate,, and sometimes ds crush, but you can delete poligons with keep rigs, and about current scene, all morph work of the remain parts, work as same as before (you can adjust head moprhs and change shape too, though I did not remember,, ERC or other controller work or not,,)
6 I may plan to save it as new figure,,, I may test what option will be lost,when saved,, , but you can try it too as test. and it may help you lot I think for your purpose.
Aha, thank you thank you!
My hat is off to you. It works perfectly :)
And thank you for taking the time to do the thorough step by step.
That's very kind!
regards from Oz
Josh Crockett Suggestion Page for Monster Characters!What I'd like to see is a huge, muscular guy built along the proportions of The Hulk in Joss Whedon's Avenger movies. Someone who goes way beyond the Freak character. I suspect that a completly new mesh would be required, I doubt the existing Genesis figures would take such an extreme morph without something breaking.
Cheers,
Alex.
I'm quite sure it's possible to go big with G3 as we have had things like The Savage for Freak 5 in the past
https://www.daz3d.com/the-savage-freak5
Althought it was for Genesis, it is pretty much the same process for creating morphs
There's also this for Genesis 2 https://www.daz3d.com/genesis-2-swole-for-the-minotaur-6
Josh,
Thanks for the links. I have added the g2 swole one to my wishlist.
Cheers,
Alex.
Outfit fit-to, but maintain shapeHi everyone
Is there a way to have a piece of clothing fit to a figure (genesis 2 in this case), but maintain it's shape.
I've imported clothing as a fbx file, and the shape as soon as I import is the one I want it to have when on g2f. However, when I use transfer utility to fit it to g2f, it becomes to small and doesn't fit correctly.
I'm looking for a way to fit like clothing, but not change the actual shape when I 'fit-to'. Is this possible?
Studio Help in Saving Only Part of a Figure (eg head) but Keeping Morphs and RiggingGood news, (I usually afraid it may lost many morphs and preset,, etc,, ) but now I test with G3M ,then saved it as new figure,
it seems keep all morphs about head,, with expression,, then I believe most of mat and pose preest may work too. (UV and surface group keep as same as before,, )
unfortunatley I seldom get G3M product,, then not test with many preest for g3m though,, it seems work well than I expected before,,
save it as figure, seems all morphs after you delete poligons with eiditor,, which change geometry (you drastically cut geomeatry,,) can save as new morph with default name,,
(though of course you lost morphs about deleted shape,,even though there is controller (maybe empty) I feel)
I may try re-open DS and reload the head figure,, too,, (Actually it beyond my expectation
I may play more,,thank you)Removing genx morphs with tabYou can delete morphs direct on your harddrive in the GenX-folder : data/DAZ 3D/ (insert Figure Name here) /Morphs /D3D Gen X
Probably you should not delete the folder itself, only the created files in there. Not sure if it is necessary to close DAZ Studio before you delete files in there. But I prefer to do so.
The second way is via the GenX tab in the morphs section. Deleting or disabeling morphs in the GenX tab can not break something nor does it effect the original morphs of the source figures. Highlight the morph and press the delete button and it will be gone.
At the bottom of the GenX/Transfer tab there are different options, to replace existing files or to keep backups of files. Thats what the Restore/Remove buttons are there for. But I have never used those. Usually I do my transfers with the option Replace existing files.
Sorry for rehashing one of my older screenshots. I will post a better one if needed.
Studio Help in Saving Only Part of a Figure (eg head) but Keeping Morphs and RiggingI do not clear remember, it can keep all morph as same as before to adjust value,, after you save it as subset etc,,
but you can use geometry editor,
Having a problem injecting a morph into V4"but a poser morph injection (.pz2) made for v4.2 should still work right?"
Under normal circumstances, yes. It would help if you could provide the name of the product, as that might lend some insight into the issue. It isn't a generic problem, so a generic solution is not likely to work.
Since the product comes from elsewhere, it probably has an old school readme file. Does that speak to anything specific regarding the use of the morphs?
Is there anything showing in the log file pertaining to the attempt to inject the morphs?
Request to improve hair product with ERC ghost bone (Top model hair etc)>Hi daywalker03
yes actually those product with custom rig which can pose easy as bone and weight for hair part. but this problem should happen, about all product which have ghost bone, those follower ghost bones which have not in Actor rig, can not follow morphed shape position by Actor morph which change rig position.
then vendor may plan to make ERC for generated moprh then save it as original morph for hair, to adjust shape.But make all ERC for all daz offered morph is almost impossible, but I hope, if they can add ERC morphs for some base morphs like Height. or Now I am thinking more better ERC to circuloate correct rig postiion, by hair head bone. then set ERC (though it seems difficult about curernt daz offered parameter,,when fit to,,)
>Fisty
Usually adjust rigging to the shape work good I know well, but it depend on much how hair rig and new added bones are assigned to mesh group for weight mapped. This OutofTouch hair is not simple rig. it offer controll bone with parented (there is no weight map), if you try it about same product, you may find , it is not easy ,even though you try to adjust rig one by one, for those control bone, with the option.
(to be frankly said, there is many case, adjst rigging to the shape not work well, about rigging which have many controll bone without weight map)
after all I needed to adjust rigs by may sefl aproximately, for current many mix morphed shape, included height. But adjust rigging to the shape is temp, it work only about current morph value. after all every time re-adjust rigging to the sahpe for each Actor and morph which controll rigs, if you feel it is not heavy problem , it is your opinion . but as customer, I do not like such way.
And I feel, about daz studio and daz figure,, follower ghost rig (include grafting items) can not follow base rig position when fit to,, is Priority issues to improve daz product more for long time. after daz offer genesis figures, (auto genearte morphs , and fit to,, etc)
if DAZ can offer way to auto adjust rigs correspond to generated morph, about fit to item., or vendor offer add on, which can auto set ghost rig positon correclty, I really apreciate.
>Ivy yes, actually I know parenting is one good alternate method. but as you know, it is optional way. because parenting can not auto set ingected morph values from Actor. then if I use many morph, this time I need manually adjust shape for hair, to fit to current shape.I may inject those moprhs once, then un-parent and set those values manually etc. but keep parented not fit to is practical good way I know.
Having a problem injecting a morph into V4I purchased a clothing product from another location and it has 3 waist "shaper" morphs to inject into V4. When I double click on the injection in content library no error is given, but I don't see the morph dials either. I did look though the various body parts as well. When I double click the inject it flashes a loading for a split second, then nothing. The log says they were injected, but I still don't see them. Any ideas? All the other morphs I have work fine. Seems like I am missing something. Granted it is older, but a poser morph injection (.pz2) made for v4.2 should still work right?
Josh Crockett Suggestion Page for Monster Characters!I like the mouth on that! Was the head inspired by the Beast, from 'Krull'? It reminds me of that.
Going to have to disagree with RKane, however. A sense of symmetry is the one thing which I find is vital for creatures. It's bad enough when a human character has a blemish on their face, making it impossible to slightly morph the same character and use several of them in one scene (family relatives and such), but monsters/creatures absolutely need to be able to be depicted in a group.
For instance, I loved the face of Abhorrentus, but the creator missed a sale from me, specifically because of how it has that assymmetrical spike on only one shoulder and not the other. There isn't any way I'd be able to render more than one of them in a single scene (and I would have actually needed it to have done that) and not look weird. Symmetry allows multiple creatures of the same 'species' in a single scene to be believable. If the maker of that character had at least allowed for the spikes to be turned on/off, that would have been an acceptable compromise, but without that? No sale from me until it has a drastic discount in some future sale. And that's a real shame, because the face is amazingly unique and clearly had some excellent work put into crafting it. :(
Fortunately, it looks as if this new Fallen One character could now possibly occupy that niche for me. :)
So you are saying it's asymmetry unseetled you? :) Point made.
I am sorry, but I am just tired of Hell of total symmetry. For instance I LOVED the new figure Dale because his features had a hint of assymetry. THE WORLD IS NOT PERFECT! Make it weird, people. :)
[Just Released]- The Fallen One for Genesis 3 Male [Commercial]How do you sleep at night and NOT have nightmares.
I bet you walk down into the basement with no pause no matter what sounds you hear.
You have a pet black cat that crosses your path several times a day.
As a child, you threw an apple at a gypsy once.
I mean. how do you come up with this stuff?
Are you not afraid of your own creations?
This looks crazy...is it too late to get someone to make a poses pack?
And will this morph with your exile alien - oh dear, the possibilities.
You have a remarkable talent.
Lots of questions there haha
I have 4 cats, none of them are black
I sleep quite well
How do I come up with stuff? I look at other artists work that I admire
I actually did a make a hybrid morph of exile and this guy which I may release later as an add on or a freebie.
Most Genesis 3 poses work quite well with this guy. Particularly the ones for Damien.
And,,, thank you for the kind words
Novica & Forum Members Tips & Product Reviews Pt 8Here's a list of some of the utilities to work across different generations. It will be in the Reference post of this thread (the second post.)
It doesn't matter if you are going from a higher generation to a lower one, or a lower to the higher- this list will put the product in the LOWEST generation involved. This is because some of these products can involve multiple generations as options.
Generation 3
GenX AddOn Gen3 Bundle Transfer morphs for Victoria 3, Michael 3, Stephanie 3 Petite, David 3, The Freak 3, Aiko 3, and Hiro 3 to Genesis and Genesis 2.GenX2 AddOn Gen3 Kids Transfer base shape of Laura, Luke, Maddie, and Matt, using GenX2, to Genesis and Genesis 2. (see Genesis Generation X2 for requirements for using Genesis 2.)
Legacy UVs for Genesis 3 Special Edition: Victoria 3 Use Victoria 3 textures on Genesis 3 Females.
Generation 4
Genesis Generation X2 For Generation 4, Genesis, Genesis 2 to transfer morphs between the generations.
GenX2 also translates poses or expressions with morph values and morph injections or shaping presets to be used with the transferred morphs. (Must have GenX2 AddOn For Genesis 2 to use Genesis 2, and to transfer morphs between the two Genesis 2 figures (Male/Female.)Wear Them All- Autofitting Clones And Clothing Smoothers For Genesis 3 Females
Autofit Victoria 4, Michael 4, Genesis and Genesis 2 Female clothing to Genesis 3 Female (also contains cleaveage smoothers/fixers)Wear Them All- Autofitting Clones And Clothing Smoothers For Genesis 3 Males
Autofit Victoria 4, Michael 4, Genesis and Genesis 2 Female clothing to Genesis 3 Male(also contains bulge fixers/chest smoothers/fixers)Michael 4 For Genesis 2 Males Use Michael 4 textures, morphs, and clothing on Genesis 2 Males. Note: the UVs can also be applied to Genesis 2 Female.
Legacy UVs For Genesis 3: Michael 4 Use Michael 4 textures on Genesis 3 Males.
Victoria 4 for Genesis 2 Females Use Victoria 4 textures, morphs and clothing on Genesis 2 Females. See the next product if you want to avoid manually doing the process.
V4 Skins Auto Converter For Genesis 2 Female(s) Reads V4 texture files .ds .dsa .PZ2 and converts them for you so you don't have to do them one by one. It's a "speed it up helper" for the Victoria 4 For Genesis 2 Females.
Generation 4 Legacy Shapes for Genesis 2 Male(s) Use the shapes of Genesis Basic Male, Michael 4, Hiro 4, and The Freak 4 on your Genesis 2 Males.
Generation 4 Legacy Shapes for Genesis 2 Female(s) Use the shapes of Genesis Basic Female, Victoria 4, Stephanie 4, Aiko 4, and The Girl 4 on Genesis 2 Females.
Kids 4 UVs for Genesis 2 Male(s) and Female(s): Check your Product Library, it was a limited time freebie at Christmas and not available in the store. Many thanks to Draagonstorm. Includes the Kids 4 textures and custom boy and girl morphs
Genesis
Genesis 2 Male and Female Base UVs for Genesis Use any textures made with the Genesis 2 Male or Female Base on Genesis.
Victoria 6 and Michael 6 UVs for Genesis Use any textures based on the Victoria or Michael 6 on Genesis.
Generation 5 UV Bundle for Genesis 2 Male(s) Contains the UV sets for David 5, Hiro 5, and Freak 5. (Michael 5 already comes with Genesis 2.) If any of your Generation 5's require the Michael 4 UVs, you must own Michael 4 for Genesis 2 Males. (see description under Generation 4)
Generation 5 Legacy Shapes for Genesis 2 Male Shapes include Genesis (1) Basic Male, Michael 5, Michael 5 Hero, David 5, Hiro 5, Freak 5, Freak 5 SuperFreak, and Young Teen Justin. Additional head shapes are included for Michael 5 (two additional heads), David 5 (three additional heads), Freak 5 (six additional heads), and Young Teen Justin (one additional head
Generation 5 UV Bundle for Genesis 2 Female(s) Contains the UV sets for Aiko 5 and Stephanie 5. (Victoria 5 already comes with Genesis 2.) If any of your Generation 5's require the Victoria 4 UVs, you must own Victoria 4 for Genesis 2 Females.
Generation 5 Legacy Shapes for Genesis 2 Female(s) Shapes for Genesis (1) Basic Female, Victoria 5, Victoria 5 SuperModel, Stephanie 5, Stephanie 5 Curvy and Model Bodies, Aiko 5, and Young Teen Julie. Additional head shapes are included for Stephanie 5 (two additional heads) and Young Teen Julie (three additional heads). Put the shapes on Genesis 2 Females.
Genesis 2 Female Clone For Genesis Use Genesis 2 Female clothing on Genesis.
Legacy UVs for Genesis 3: Genesis Pack Use Michael 5, David 5, Stephanie 5, and Aiko 5 textures on Genesis 3.
Legacy UVs for Genesis 3: Victoria 5 Use your Victoria 5 textures on Genesis 3 Female.
Genesis 2
GenX2 AddOn for Genesis 2 So GenX2 can be used with Genesis 2. Now, it's possible to transfer morphs from Genesis and supported Poser figures to Genesis 2 Male and Female. In addition, morphs may be transferred from Genesis 2 to Genesis or between the Male and Female version of Genesis 2
Genesis 2 to Genesis 3 Pose Converter: Convert your Genesis 2 poses to Genesis 3. (Male and Female)
Pose Builder for Genesis 3 Mix and match Genesis 2 and Genesis 3 poses.
Genesis 3 Female For Genesis 2 Female(s) Autofit Genesis 3 Female clothing to Genesis 2 Females.
Genesis 3 Male For Genesis 2 Male(s) Autofit Genesis 3 Male Clothing to Genesis 2 Males.
Genesis 3 UVs For Genesis 2 Female(s) Use Genesis 3 textures on Genesis 2 Females
Genesis 3 UVs For Genesis 2 Male(s) Use Genesis 3 textures on Genesis 2 Males
Legacy UVs for Genesis 3: Victoria 6 Use Victoria 6 textures on Genesis 3 Females.Legacy UVs for Genesis 3: Genesis 2 Male and Michael 6 Use the Genesis 2 Base Male and Michael 6 textures on Genesis 3 Male.
Genesis 2 Legacies For Genesis 3 Male: Heroes Shapes for Michael 6, Gianni 6, Darius 6, Lee 6, and Scott 6, as well as an optimized version of the Genesis 2 Base Male, to put on Genesis 3 Male.
Genesis 2 Legacies for Genesis 3 Female: Stylish Shapes for Giselle 6, Keiko 6, Lilith 6, and Ninive 6, as well as an optimized version of the Genesis 2 Base Female, to put on Genesis 3 Female.Genesis 2 Legacies for Genesis 3 Female: Beauties Shapes for Olympia 6, Monique 6, Mei Lin 6, and Gia 6, as well as an optimized version of the Genesis 2 Base Female.
Genesis 2 Legacies for Genesis 3 Female: Classics Shapes for Victoria 6, Aiko 6, Stephanie 6, and The Girl 6, as well as an optimized version of the Genesis 2 Base Female.
Genesis 3
Genesis 3 UV Swap: Male and Female Base Put the female textures on the male, and the male on the female.
GenX2 AddOn For Genesis 3 Now, it's possible to transfer morphs from Genesis, Genesis 2, and supported Poser figures to Genesis 3 Male and Female. Read the description for more information.
why is my properties preset not saving the morph dial?Kitakordedaz is correct. Saving the preset without saving the morph will lead you to the situation you speak of. (I speak from experience. :) )
Here is a hopefully helpful guide that may answer some questions for you too.
Purple Reptilian 6I'm beginning to wonder if there's a problem with my computer or my DAZ install. It's been fighting me about every little thing I try to do for the past week, and freezing up for long periods before responding; even just while scrolling my content library. I really can't afford a new computer right now.
*SIGH*
Maybe I'll just reinstall DAZ.
Wait. You are sure you arent changing any other settings? Youre on the most recent daz version?
No, I hadn't changed any settings, until after I noticed the purpleness in my test render. And my futsing neither helped nor made it worse. And I am still using 4.8, but I suppose grudgingly I shall install 4.9 when I get to the reinstalling portion of this exercise. I have the installers for both versions so maybe I'll just install both and see which one works better for me.
Did you load the default character or did you apply the morph then materials? Did you apply more than one material before ubering?
I loaded the default character, and applied the uber shader.
Which specific surface groups are affected by the purple wierdness?
Well, I cant reproduce the issue. It looks like something you should be able to fix manually but without looking at your surface groups its difficult to see what could be wrong. Maybe daz has a solution? Maybe try another shader package?
Sorry, not ignoring you. Like I said my computer is reeeeeeeeeaaaaaaallllllyyyyyy slow and DAZ keeps locking up when I try to select the reptilian's surfaces. I had to re-open DAZ, reload the reptilian, and uber him. The affected surfaces seem to be the face, lips, tongue, teeth, gums and inner mouth.
OK, heres the good news. The face and lip surface groups should have exactly the same settings as the Head, Torso and pretty much everything else that is an exterior skin group. So try this. After you get the purple wierdness, select the face surface group and then control click the Torso or head surface. You should see exactly the same settings (with the exception of texture files). If you see a question mark on any of those settings for the face or lips, you have found a discrepancy. Change those settings to reflect the settings of the correct surface groups. For the tongue, teeth, gums and inner mouth, it could be that those settings are messed up as well. They wont be the same as the torso, etc., but it should give you an idea of what to adjust to find good settings. If you compare the good surface groups with the bad surface groups and all the settings and numbers are the same, then I dont know what to tell you other than to try updating or changing your shaders, write a ticket, whatever. Let me know what you find out.
*SIGH*
Ok, thats good to know. Let me check something real quick. By the way, do you turn off CMS? If your using 4.8, you can turn off CMS and then daz may run faster for you. The down side of course is that if you use CMS then you wont be able to after turning it off (duh). I used to turn off CMS all the time. Unfortunately, it is BROKEN in the current version of 4.9 and turning it off drastically impacts daz performance. OK, ill check the reptoid again and get back to you.
