• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Novica & Forum Members Tips & Product Reviews Pt 8
    Here's a draft of my guide to using the free Mixamo motion capture animations with DAZ. Hopefully, I can upload this as a .PDF.  Arnold C was instrumental in me getting past the first hurdles of using Mixamo, because I just couldn't get the settings right and the directions on Mixamo were incorrect. He was kind enough to explain things and post screenshots. He gave me permission to use that info in my guide, which I then expanded upon and added even more screenshots.
    Mixamo animations are great - professional quality motion capture - and are pretty easy to use. My problem is that if I go a few months without using them, it takes me an import or two to get back in the swing of it. But then it goes really quickly. This guide covers everything from exporting your character and uploading it to Mixamo, downloading and importing animations to use in DAZ Studio, how to download the thousands of animations from the mixamo.com website, etc.
    It'd be great if someone would run through and test this to make sure I haven't made assumptions, errors, etc. I'll proof it tomorrow after I've slept for a while. ;)
    Great tutorial, I read through but haven't tested it yet. One question I have. Have you found that the animations you make aniblocks out using Mixamo, transfer well to other characters? In other word, if I downloaded all the animations, I tend to think it would be best to probably use a Genesis 1 base, in my own experience, those animations transfer best to a wide range of both male and female G1 G2F G2M. This way I wouldn't have to transfer the same animations for multiple characters.
    @DSDT
    Animations do transfer to the different characters. I felt as if I had to do less correction if I used the same character, but I didn't test it enough to tell if that were a misperception, a misunderstanding/mistake on my part, or only on more extreme morphs. It really would take some benchmark type comparisons which I didn't bother to do, as I was rushing on a deadline.
    But a base G2F definitely worked for all G2F morphs, base G2M for all G2M, with the exception that when I hit Darius and a muscular morph, I felt I had to throw in a correction aniblock to move his hands out away from his legs so his fingers wouldn't go through his thighs. A quick fix. But if that happens you can also just upload Darius, adjust the animation, and download it specifically for him if you don't want to do an adjustment aniblock. I also did some G2M to G2F and those seemed to work okay as well.
    Basically, everything I tested worked on every character. So if I downloaded a walk, it worked on Genesis, G2M, and G2F. I think I did V4/M4 at the beginning, but deleted them. I might test that more in the future. Depends if life slows down. Since I ended up using on G2M/G2F, with one Genesis figure, I quit testing.
    I need to go back and make it clear that while you "grab" all the animations with the script to add them to your assets, that doesn't download them. The benefit of adding the animations to your owned assets is that you actually do own them at that point and you can download them at your leisure. (I was really getting sleepy during that last part and can't recall if I put that correctly; I may have mixed my thoughts together. I'll check it) I only download as I need each specific animation, since right now, packaging the animations in lots doesn't seem to work with DAZ characters because the Mixamo pack download settings are different than those offered when you process a download for a single animation. That said, I haven't tested it for several months to see if they changed that. (It was totally illogical.)
    Even though I grabbed all the animations for my basic characters, I'm only using probably 20 basic ones at the most. I'm doing a high volume of rendering because I have a large number of characters doing the same things, walking, idling, reaching for things, kneeling, etc., in different outfits. If that makes sense. I'll be adding a lot more variety, I hope, here in a month or so.
    And I'm not sure ever I tried starting with Genesis and applying the animation to G2M/G2F. I went the other way, creating the animation for G2M and applying it to a Genesis figure, because I was using all G2, except the one character.
    Hope that makes sense.
    By
    firewarden firewarden April 2017 in Art Studio
  • question about It's Magic outfit...
    So Rod is correct in that the morphs I have made are tailored to a specific outfit.  If the edges do not line up then things may not look right.  However, at Rod's insistence I am working on a more general package that might work on a wider array of items.  Although this morph was made for the skirt this gives an idea of what can be done by making RealFit morphs for more than just bikinis.
    Cheers!
    We are not worthy. We are not worthy. (Gosh darnit, I need to stop referencing movies I haven't seen.)
    By
    Uthgard Uthgard April 2017 in The Commons
    Here's a draft of my guide to using the free Mixamo motion capture animations with DAZ. ...
    By
    FrankTheTank FrankTheTank April 2017 in Art Studio
  • Warrior Wet Hair and head morph problems
    I'm having an issue with warrior wet hair.  In general I love it but I can not get it to cover the scalp enough.  I think maybe this was done on purpose to emulate an older man however it looks almost like the hair is coming out of the forehead of the genesis 3 male, and it is coming out of the forehead of the genesis 2 male.  I've searched for a cap in all the files and can't find one.  I also went through both the smart content clickables, as well as went through all the options in the paramaters tab and the shaping tab.  While there is a button to show more roots it did not seem to do much, especially on the genesis 2 guy.  If needed I'll fix it in photoshop but I'm hoping someone can tell me what to do.  I've even cinsidered loading an extra one, unparenting it and hiding almost all the layers then just placing a piece on the forehead.  I also tried to find a way to make Gabriels head smaller but that was a total fail.  i honestly thought I had every head morph availaible for genesis 2 males.  Is there no way to reduce the height  of a forehead?
    By
    freni-kyn freni-kyn April 2017 in The Commons
  • mcjVooDooDaz - MatchMoving / Camera Tracking in Daz Studio ( update )
    your tracking looks good, though i wonder if a stabilized-image or anti-shake version of that clip wouldnt track better ...probably!
    It's also possible to transfer a Blender camera to Daz, but that's was a little janky last time I tried.
    I've been wanting to get a planar tracker like Mocha to work with Daz.
    Here's a second test I did.  I didn't make a proper shadow plane. Messed that up in the compositor. But VooCat/mCasual's script got the track done well.
    By
    mCasual mCasual April 2017 in Freebies
    actually didnt i make a blender-to-daz camera animation exporter? ... hmm
    YES! i even made a camera prop for the logo ... which i shall put on my web site when i remember
    https://sites.google.com/site/mcasualsdazscripts2/mcjexportblendercam
    By
    By
    WayOfTheSword WayOfTheSword April 2017 in Freebies
  • [Just Released]- The Fallen One for Genesis 3 Male [Commercial]
    SWEET - glad to see more monsters - was kind of hopping to see your crazied vopal bunny for easter wink
    http://www.monsterfaces.net/uploads/9/1/9/5/9195699/2011509_orig.jpg
    Ha, not sure how well something seasonal like that would sell
    That is probably the scariest bunny I have ever seen.  Pretty sure that is not necessarily seasonal....
    That bunny is amazing. It reminds me of the bunny from the "It's a Good Life" section of the "Twilight Zone" movie, which is still my point of reference for Scariest Bunny Ever.
    I'd buy a scary bunny if it was a G2 or G3 figure, rather than a standalone. I like to make custom monsters by partially applying morphs, mixing-and-matching skins, etc. I find Genesis-based figures offer more possibilities than one-offs, which are pretty much "what you see is what you get". ("The Fallen One" has a date with my shopping cart when it drops, for precisely that reason).
    Speaking of which, more individual morphs are always welcome. One problem that I have with a lot of the monsters sold here is that there seem to be just two morph dials -- head and body. The monsters often seem to have very distorted hands or feet, with elongated fingers/claws, which is not always what I want, and can cause posing problems. If you dial back the body morph to get more standard hands/feet/limbs, then you lose other aspects of the body morph. The creator who allows finer control of more elements will probably get my dollars forever.
    Good to know, I will keep that in mind for sure
    By
    Josh Crockett Josh Crockett April 2017 in The Commons
    By
    bytescapes bytescapes April 2017 in The Commons
  • Supersuit G3M stuff
    Thank you for the input on this. One thing I like about the Guardian is that it has an option to turn any part of the suit transparent, and a second thing I like is that it includes more zones. So, with Destiny Guardian's DG iRay Action Fabrics, I can design my own versions. Also, I found that the extra Guardian morphs show up for the SuperSuit but not for the Guardian version. Anyway, if I want Bat Ears, or any of the other morphs, I can still have them. I just need to start with the SuperSuit.
    Inquire: There is a neat trick if you have the patience to do it.
    Start by adding the G3M Supersuit to G3M. THEN add the Guardian suit.
    In the Scene pane, make the G3M supersuit invisible (i.e. click the "eye " icon).
    Go to the Parameters tab, with the Guardian Suit selected and change the "Conform to" setting from G3M to the G3M suit.
    Go back to the G3M Supersuit and turn on a morph for the bat ears.
    If my calculations are correct, you should now have Bat ears on the Guardian Suit too.
    If you know how to save a morph, you can now do so on the Guardian Suit to have it saved. There TONS of helpful morphs on the Genesis Supersuit that you can move into clothing for better form and fits. Its IS an amazing set.
    By
    RKane_1 RKane_1 April 2017 in Product Suggestions
    Cheers!
    By
    the3dwizard the3dwizard April 2017 in The Commons
  • Figure Metrics has me beyond frustrated!
    Are the measurements fighting each other? Is the morph linked to one measurement also affecting others?
    By
    Richard Haseltine Richard Haseltine April 2017 in The Commons
  • All things Labyrinth
    Thank you Ice Dragon Art, I had a plane in the background with a Goblin King picture on during character creation to see how close I could get with G3M and dial spinning. I was quite pleased with the result, pleased enough to not look at making a custom morph anyways.
    By
    KA1 KA1 April 2017 in Art Studio
  • Showing the Skin Under the No Suit
    I'm trying to make certain sections of the No Suit Morph disappear to show the nose and chin underneath --a la Captain America. As far as I know, the No Suit doesn't come with anything to make those portions of the costume invisible or removed. I've tried to do this by going into Surfaces and changing the Skin map under the matching Diffuse Color, Bump Strength and Specular Strength maps to show the character's skin underneath.
    Unfortunately, the problem is that my character now looks like a zombie when I render him. Looks fine in the Viewport, but when I render him, the skin is gray and pale.
    I did it wrong, so how do I make the skin show correctly?
    By
    megagearx_eaad3c70d6 megagearx_eaad3c70d6 April 2017 in New Users
  • Simtero shape projector and Daz/Carrara morphs
    I got the product at a steep discount during some sale and returned it. It mostly performed as described in the store page, but I just found it easier to use blender.
    Initially I thought shape reprojector would be easier and faster than exporting to another application for collision deformations and then importing the results as a morph.  It wasn't for me.  It might be for someone who doesn't use blender or another 3D modeling app.
    I expected shape reprojector to be slow, since it is a script, but in my case, it took as much or more time than export, collide in another app and import.
    The real killer issue for me can be found in the documentation at the botom of page 3:
    IMPORTANT: The process will work on objects in any orientation, but for best results, it is strongly recommended that all position and rotations be set to zero on the Receiver figure. Transformed objects, especially figures moved and rotated at the hip, may produce invalid morph results.
    In my experience, moving or rotating the hip and/or scaling the character, made it unlikely to get the results one would expect.  It might work for your head as I expect you could do that in the zero/rest pose, but blender and other applications can do that easily as well.  I had no luck trying to create a morph for laying on a flat surface with a scaled figure standing in a T-Pose.  I got results, but they took forever and never were good enough.
    Read through the PDF and see what you think.  I believe the product and its documentation describes itself accurately and that it can do what it claims.  In my case, I had other options that produced as good or better results in a similar or much shorter time.
    By
    zaz777 zaz777 April 2017 in Carrara Discussion
  • greyed out smart content
    Sliders arent there to pose the face.  Under shaping there are a couple sliders to post the face in a general charactr sort of way (victoria 7, vs the Summer caharacter used in the example.  The sliders do appear to be there to move the and pose the other body parts.  For the record.  I haven't bought any advanced morph packages, since basic stuff doesn't seem to work.
    By
    DaleCar_06ae99e4f4 DaleCar_06ae99e4f4 April 2017 in Technical Help (nuts n bolts)
    Actually the "It's magic outfit" from Zoro_d and the "RealFit"-Stuff from the3dwizard are working differently from my understanding.
    The Realfit-Bikins do come with custom morphs for G3F providing that reality-like effect that the outfit applies pressure to the skin. Once the product is installed those morphs are available on all G3F-based characters so you can dial them in whenever you want. Apparently they fit the RealFit-bikins they come with best.
    With the It's Magic-Outfit, the effect is tied to the pantyhose as a morph ("smooth hip"). The skin tint is also part of the pantyhose. There is a show/don't show script included so you can also use the Magic-Outfit without the pantyhose. But then also the pressure-effect is gone. From what I understand that unfortunately limits the skin-pressure-effect in this case to the Outfit it comes with. Even more so actually, as the effect is only shown with the pantyhose.
    Please see the test render for comparison:
    Left
    Magic-Outfit applied with the smooth hip morph on the outfit active. Opacity of the pantyhose set to 0 (which actually removes the legs and panty alltogether). Made visible again through the provided script. -> No pressure effect.
    Middle
    Magic-Outfit applied in default form with pantyhouse. Smooth hip morph from the outfit is active by default. -> Pressure effect.
    Right
    Same as left but in that case, I've dialed in the morphs from the RealFit-bikini which work here as well, although adjustments to deal with occasionally poke through might be necessary. --> Pressure effect, but limited to the areas covered by the used morph.
    Hope that helps!
    P.S. I've removed limits and "overdialed" the morphs in all three versions to better indicate the differences.
    By
    Rod Wise Driggo Rod Wise Driggo April 2017 in The Commons
  • Is export FBX with morphs broken with GF3 / V7 ?
    Most definitely, I just applied a basic ambient moves loop to GF3 and exported, I didn't apply any morphs, I just exported with "morphs" checked, I remove all Morph Export rules and it still happens.
    16 extra unwanted morphs are created.
    Import straight back into Daz and you see this:
    GF2 has no issues.
    By
    asymptote asymptote April 2017 in Daz Studio Discussion
    Nice. I forgot who was talking about rigging in this thread. I may have questions for you. I'm thinking of making a polo shirt in Hexagon, but I want the color to be able to morph along the seam to wear it Cuff Up or Cuff down, like an 80s preppy. I feel like what you're messing around with might be the best way to do that.
    By
    donovancolbert donovancolbert April 2017 in Art Studio
  • Wear Them All
    In my brain, a clone is already a morph, just a special one that's 'hidden' unless using autofit.
    And good call on front fixer. If I had known about that, would've avoided the blender route. Much easier solution!
    By
    Toonces Toonces April 2017 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
Create An Account
