Beta for DazCentral, your new Content Manager
One request!
Instead of completely removing the option to download via DIM from completed sales pages, can we have that as an alternative option?
Something along the lines of some "Or download via DIM" text under the button would be fine.
Right now we have to manually open DIM to download via it, which is slightly irksome!
As Central is intended for new users it makes sense to retain the usability for "advanced" users too..
Yes I would like that as well, to have that option rather than getting shoehorned into Daz Central. .As right now although not a overly real hassle, still annoying having to manually start DiM to download new purchases..
OK, but - if it works like DIM - should yu wish to go back to using Daz Central you may need to go into Chrome's preferences/settings and tell it which application to use to open a whatever file - I'm not sure what Daz Central uses, assumkng it's different from, DIM, and looking at an order page isn't enlightening.
I am using Firefox and in my settings it is set for DiM as default no changes made, but when I click on the download and install link after a purchase it sends me to the Daz Central page, instead of activating DiM.. So it looks like the option to auto start DiM has been removed completely..The DIM link is still in the Product Library. I was assuming that there would be two different kinds of link, each with their own application, rather than a change to the application launched by the one extension - which is necessary for both types to be supported.
As for it not recognising that Daz central is presedt, are you running any script-blockers on the Daz site? I'm still not at all sure how the process is handled, but if there is a scripted portion that isn't running (correctly or at all) that migth stop it from realising Daz Central was already present.
The thing is prior to DazCentral whenever clicking on the download and install link after product purchase, it would auto start and auto log into DiM.. Doing the same thing now just sends you to the Daz Central page, where it wants you to download and install it.. I tried Daz Central but it screwed up all my settings, and had no option for custom folder install of content..
Yes, I understand that - and if you don't want to/can't use Daz Central then you need to use other options - the Product Library, start DIM manually, use Daz Connect.
I know how to install products, I was just pointing out the issues I noticed with DAZ Central. Thank you.
Beta for DazCentral, your new Content ManagerI haven't had any trouble, really. It was a little slow when I first installed it, but my system has been acting weird for weeks with the latest Windows10 updates and drivers for various things conflicting. Now that my drivers are up to date (manually, which is a huge pain), Central hasn't been an issue at all.
thats good to hear. My system is all updated to current for a bit already, but this DC thing is really not working well on it. We shall see how it goes. My 1st thing would get it to recognize DS is actually installed, and perhaps it would work a bit better.
Beta for DazCentral, your new Content ManagerI've been looking for all the threads but cant even find them...merge if needed.
I installed DAZ Central a bit ago ... downloaded and installed manually. It opened after install and just sat there and spun for 10 minutes. When it completed, it wanted email and password. Email was already there , I typed in password. It would not do anything.
Figured maybe I needed to do reset, so restarted my PC ... When I opened Daz Central, it had the loading icon, and then everything locked up. Mouse wouldn;t move, I could not get to desktop, nothing would open. I had to do a hard reset by turning off power.
Once PC came back up, I launched Central again .. it took a long tiome to open, and then a huge banner that I do not have Daz Studio installed. I do have have had it. I then went to settings and changed them to reflect correct install paths, etc ... It toook minutes for it to change everything. It still cannot find DS.
This is very frustrating.
Hopefully suggestions here otherwise I'll place tiucket, but right now I'm more inclined to uninstall as it is hosing up my system.Beta for DazCentral, your new Content ManagerOne request!
Same problem here. Clicking on the download and install link after a purchase now just sends me to the DAZ Central landing page. Even after installing DAZ Central it just goes to the landing page after each purchase, and offers to install DAZ Central even though it is already installed. So there is no way to install a product after a purchase anymore, unless you go directly to the product library, or run DIM manually.
I have always used the default directories for both DAZ Studio and DIM, and I did the default install of DAZ Central. There is nothing special with my setup.
If that is the case then not sure what the point of having that after purchase page now, more so if the download and install button doesn't do anything even with Daz Central installed..
One request!
What should happen now then is that after each purchase it should redirect to the purchasers product library or something like that, since the after purchase page has no real purpose anymore..Beta for DazCentral, your new Content ManagerOne request!
DAZ Central not workingThanks HighElf,
that helped, in Central there was nothing in the Base folder. Now I specified the folder of the Daz installations, and Daz Studio finds files again.
- But lists lots of products to install that are already usable.
Even less now knows Central, which recommends installing Daz Studio. I would also have to reinstall almost everything.I miss the path information like in the old manager.
I see products and now I don't know what is available and where something is being installed.Banging my head against my desk (can't log in to DS after replacing motherboard) {SOLVED}you might need to use Crap Cleaner from Piroform
I don't use connect so that might be different but my second completely new virgin computer I just plugged my external in with the zips and it installed it all so something residual is on your computer stopping DIM, I cannot run DIM on both at once.
My passowrd lets me log in to DAZ Studio but will not let me log into Install Manager or log in to DAZ connect so I think it may be a little deeper like having to do a full clean install.
Daz Studio and Daz Connect are the same thing - did you mean the Daz site when you wrote Daz Studio, or did you mean the new Daz Central when you wrote Daz Connect?
DAZ Central not workingHello, after installing Daz Central, Daz Studio no longer finds any data when I click the icons to use it. Data paths in search with browser are available. Failure to do so says file ... cannot be found.
I ask for help.Greetings from Germany
FalconThis one can be solved by reassigning the paths inside DS for Central. Central sets them to a new default, where they probably aren't.
Yes I would like that as well, to have that option rather than getting shoehorned into Daz Central.. As right now although not a overly real hassle, still annoying having to manually start DiM to download new purchases..
I agree with this too. Why replace DIM completely on the download page after purchase. So annoying... what on earth was the rationale?
I have no idea why, the install download link does what it does.. But what I do know is that DiM has loads more configuration and functionality, compared to DazC which is problematic as it does look good but looking good does not make it any better if it does not have good functionality and configurability..
FalconDAZ Central not workingSimilar issue here. DAZ Central didn't show up, DIM is my current way to go. In addition, I have an issue with Studio as well. since the most recent update, I cant restart Studio without rebooting my whole system. -.- So no render queue or RAM cleaning for me, which sucks.
DAZ Central not workingThe first time I downloaded DAZ Central, it installed itself along with the purchases that I made. Since then, however, it will not load. Today, I made a purchase and clicked on the link. The DAZ Central window came up and I walked away to have supper. When I came back about half an hour later, the DAZ Central window was STILL loading. I killed the window, started up DIM and in a few minutes the packages were installed.
Anyone have any idea what the problem might be?
Beta for DazCentral, your new Content ManagerI think the whole idea of DAZ Central is nice. I just wish it was working properly for me.
DIM is great and works just fine, but a more visual interface similar to DAZ Central would be good too.
Beta for DazCentral, your new Content ManagerI'm almost afraid to try this, but I know it is only a matter of time. Question is, if I *TRY* DAZCentral, will I be able to revert to just using DIM again if it doesn't work out for me?
I tried DAZ Central and then quickly uninstalled it when I saw all the complaints here. The DAZ Central install was causing problems from the get go, like not recognizing DAZ Studio.
Also, when I purchased a new product and clicked on the "Install with DAZ Central" button, it kept taking me back to the page for installing DAZ Central. * WTF, sorry but I'm kinda mad right now *
After uninstalling DAZ Central, I now have to take an extra step after purchases to run DIM manually. Thanks. I spend a lot of money here, so making my life harder makes sense, right??
But everything is still the way it was in DIM except for a few products that show as "recently installed" even though they were not. Whooo! Dodged a bullet this time!
I hope nothing else is screwed up.
