Downloader manager is gone then?
I know my paths are right and have not touched either app since each was last updated by Daz. DIM flat is not working. I have orders that will not download.
I am not installing Central till it is close to functional which it clearly isn't.
Can you combine products from two different email accounts?I have a request in now because when I tried downloading Central and opening it ...I now have nothing at all "installed" under either account. But it doesn't matter....I just dumped the whole shebang and everything related to it. Perhaps sometime when I have hours and hours with nothing to do I'll try reinstalling some stuff. Maybe they'll work some bugs out in version 5.
Ok... What DOES work?Hi Choronzon,
I have also had troubles with DAZ Central and then DIM as well. I already had a long password but changed it anyway since DIM was not saving my path settings properly? Still the same problems with DIM with gettings things to install where I want them. Perhaps log onto DAZ first with the new password then try opening DIM and see if that helps. Also make sure you can log onto the DAZ website user account with new password. There may be a bit of a time delay but it would certainly want you syncing with all aspects I presume. Hope that is some help.
Ok... What DOES work?DIM seems to install content into C:\Users\Public\Documents\My DAZ 3D Library on my PC
If I install it the Smart Content tab then it installs into C:\Users\user name\Documents\DAZ 3D\Studio\My Daz Connect Library\Cloud
There was a recent update that you were supposed to update your password to at least 7 characters... did you do this?
I continue to use DIM though I've had a couple of products now that it didn't install properly. In those instances I uninstalled via DIM then installed them via the Smart Content tab in Daz Studio and they worked. Personally I'm waiting until all of the kinks are worked out of Daz Central.
Error Message when Loading G8F CharactersIf you are loading a base figure, you have a morph installed that was updated for G8 (manually), and a reference to G3 was not changed
This happens even when I load a G8 figure without morphs.
There was a product that did that, I thought it had been updated - check DIM/Smart Content for updates, depending on your instalaltion method.
If you recently installed Daz Central it may have changed some of your settings. Look in Daz Studio Edit_Preferences_Content_Content Directory Manager. Click the + sign on each of the content sets and make sure they are pointing to the directory where your daz resources are. You may need to look in DIM also to make sure everything is going where you expect it to be going.
This is a fresh install after I had to re-image my computer. When I re-installed Daz, I pointed my library to a large secondary drive instead of the primary drive. Everything looks how I expect it to. I attached DIM settings, maybe you can see something I missed.
Thanks.
Error Message when Loading G8F CharactersIf you recently installed Daz Central it may have changed some of your settings. Look in Daz Studio Edit_Preferences_Content_Content Directory Manager. Click the + sign on each of the content sets and make sure they are pointing to the directory where your daz resources are. You may need to look in DIM also to make sure everything is going where you expect it to be going.
Downloader manager is gone then?I downloaded and ran Central to see what it did. Apparently it uninstalled every single thing I had already installed and been using.
Daz Install Manager (DIM) 1.4.0.94, Now Available! (*UPDATED*)Is DAZ Central using the same type of Manifest files for installed content as DIM? If, are they shared if you use both (if that's possible)?
In theory yes. I have both and installed and they share what is and isn't installed. At least during beta, now centrals wants me to update to use and i'm not inclined to test my luck again. While i had no issues (i don't use default paths, btw), lots of people shared horror stories with this. I prefer DIM in every aspect except visuals. But visuals can be deceiving. Also search is good in central, but i need that level of good inside DAZ, no in an outside app.
OK, thanks. Yes, though I haven't tried DAZ Central I probably never will, DIM works great for me, and I write my own tools for whatever else I feel I need.
Hear, hear! Why replace what isn't broke? And why upgrade if the main inconvenience(s), like using an external app, aren't what's corrected?
Genesis 3 starter essentials?https://www.daz3d.com/forums/discussion/415586/complete-uninstall-and-reinstall-required-help-please
I trust you are aware that each gender has its own installation files.
If installed with DIM (or Daz Central, II assume) - instaleld through DS there's only the one product for each generation.
That's interesting. Obviously I'm installing manually ;-)
[Released] Character Converter from Genesis 3 Female to Genesis 8 Female(Now Conv JCMs) [Commercial]I think it's this new "DAZ Central" thing. I recently upgraded to it and found that morphs I had before installation of DC, afterwards weren't there. It was very noticeable on Genesis 8 starter stuff. I had to go back and manually install (after downloading the zip from my product page) for the starter pack morphs to work again. It was weird when you go to raise the eyebrow of your Genesis 8 Female, only to discover that the morph didn't appear in the parameters panel. Not exactly sure as to why DC did that.
Huh. I have not tried it yet as I don't like to mix install methods. Thanks for sharing.
Complete uninstall and reinstall required - help please!!I'm not installing Central. I told you that DIM allows you to uninstall Daz Studio so should Central.
Sorry, I misunderstood. I've checked Daz Central and there is no option to uninstall that I can see.
Then put in a support ticket. I'm pretty sure its there.
DIM, Smart Content, DazCentral all biffed by DC InstallIf you haven't already you might check in DAZ Studio Edit_Preferences_Content_Content Directory Manager. Click on the + sign in each content set and verify all are pointing to the correct directory. This worked for me. DAZ Central had changed some of them and I had a heck of a time getting everything working. Good luck!
You and Fixmypcmike were absolutely right. There were several garbage paths in both Daz Studio and DIM, and one of them was set to be used on DIM. Seems like the Daz Central install must have changed some of them, but deleting them all, finding all the products that had used them in an install, uninstalling those products, then reinstalling using the proper install path worked.
What is the correct directory? I guess I mean what is the default supposed to be?
Complete uninstall and reinstall required - help please!!You need to see if Daz Central can let you uninstall stuff. DIM does.
When/if that gets done, If you want to install everything to D: you have some hoops to jump through.
DL and install DIM. Then, before you DL anything, open up the DIM basic settings and point every path there to your D: drive. Then do the same in the advanced settings. then DL and install everything, be prepared for this to take a while.
Also before you get in too deep, since you just bought the computer, get bigger drives. I didn't think 128Gb boot drives were still a thing. Also 1 Tb is very small for 3D qassets particularly if you'll be installing everything else on that drive as well, and you will 128 is tiny.
Thanks for that. DAZ Central will let me d/l stuff, but I need to uninstall DS from the SSD first, which is the whole point - the SSD isn't big enough and I want to reinstall d/s and all content on the HHD. Daz (system and content) on my current computer only occupies about 300gb, and works fine, so 1Tb will be ok. Plus I have an external HDD if I need it too. Its the processoer, memory and graphics card improvements I want, not arces of memory
Complete uninstall and reinstall required - help please!!Ok, I apologise if this has been covered in other threads, and I'll try not to make this too long. I have just got a new computer, and am wanting to install DS 4.12 onto it along with my content (and existing characters/scenes if possible). So, I d/l Daz Central and Studio 4.12 yesterday, and begin downloading my content via Daz Central. All seems ok until it becomes clear multiple files are missing for G2 and G3 figures (the "actors"), so something is wrong anyway. I think I should have installed via DIM but I didn't
I guess I should have thought of this before, but the bigger problem is that my new computer has a 128gb SSD and a 1Tb HDD. I have started with d/l DS to the SSD and had planned to put content on the HDD, but its clear that even this way, with my other other programs the SSD will soon fill up. Therefore my new plan is to completely uninstall and reinstall ALL Daz Studio and content on to the HDD - in other words D Drive. But this isn't simple
1) I can't uninstall DAZ Studio as there is no uninstaller - where is it, and if there isn't one how do you uninstall? I don't really want to do a System Restore, even thought with a new computer it won't be the end of the world. So I'm stuck here at the moment with a partially working 4.12 that I can't uninstall
2) Assuming I can clean uninstall, what is the best way to reinstall DS to get best result? Is it via DIM or is it manual? If its via DIM, I see there are other threads showing how to change the paths from the default C: to the new drive, but is there anything else that needs to be done for a new install on a different (in this case :D) drive?
3) Having done all that, and assuming all DAZ content is then d/l and installed via the DIM, what is the best way to move 3rd party and poser content from "My Library" to the new computer - do I simply copy on a storage device and transfer it across - if I do this will DS recognise and find the files ok? I understand that saved scenes and characters may not work, it would be nice if they did but again its not the end of the world
Could really use some help on this so TIA
