Ow, I have an eyelash stuck in my eye! (Solved)
That's the problem. HS does not apply any morphs to the eyelashes. Under the main figure, there is a Genesis 8 Female/Morphs/HeadShop with a dial for the morph I created from the photo, but nothing gets applied to the eyelashes. No such morph on the eyelashes, nothing for it under Hidden.
Did you have autofollow chcecked for your morph? If not, unfit the lashes, check autofollow and refit the lashes.
As I mentioned earlier, I'll check on that. I'm pretty sure starting with a base G8F should have autofollow on by default. Unless the plugin disables it, or Morphloader Pro disables it, it should still be on.
Ah, sorry @Matt_Castle, somehow missed your comment;)
Ow, I have an eyelash stuck in my eye! (Solved)That's the problem. HS does not apply any morphs to the eyelashes. Under the main figure, there is a Genesis 8 Female/Morphs/HeadShop with a dial for the morph I created from the photo, but nothing gets applied to the eyelashes. No such morph on the eyelashes, nothing for it under Hidden.
Ow, I have an eyelash stuck in my eye! (Solved)I have to admit, I'm surprised. I've created some custom head morphs for G8F (mostly transferring some old characters of mine from stand-alone meshes onto G8F) , and the eyelashes have followed the morphs just fine, so I can't see why these morphs wouldn't work.
Testing one last thing, the headshop morph doesn't have auto-follow turned off for any reason does it?
I'll have to check that later. I don't think so, because hair figures work with the morphed head. I can start with a base G8F and import the OBJ, the head changes but the lashes don't. How did you create your head morphs?
Ow, I have an eyelash stuck in my eye! (Solved)When using the HeadShop OneClick 2 plugin for Daz Studio, it seems impossible to get the eyelashes to come out right on the G8 models. After running the program, the head changes OK, but the eyelashes are made invisible. When visibility is restored, the eyelashes are in the wrong place. For the G8 models, the eyelashes are a separate mesh. You can't just move them because they have to be Fit To the base model in order to work like eyelashes. Also, Morph Loader Pro was unable to load the OBJ created by HSOC onto the eyelashes. The error I get is, "Geometry did not match, failed to create morph." If there's a manual tweak that can be easily made to an OBJ file to get it to load on the eyelashes, I'd try that.
I did open a ticket for this, but it's been a busy time in Customer Support. I thought I'd post here to see if anybody has any solution for this. I tried a lot of tricks, but nothing worked. Selecting the eyelashes and unfitting them, then refitting them to the G8 figure put them right back where they were. I also emailed the script author, but he has no workable suggestions.
New Aeon Soul outfit...but...she has a very baby face to me
in fact she reminds me of my baby photos
I too find it creepy on an adult, I have her V4 body morph not the head/face but I am certain it wouldn't be too hard to do if I were so inclined, just haven't wanted to, you could just try the face transfer or Facegen, Headshop utilities if sculpting or dialing not your thing.
Headshop 12Yes and yes. You can use DAZ expressions as well as using HeadShop exported Age, Weight and Smile morphs
Headshop 12Morning. I'm intrigued by Headshop but the forums here and youtube comments make it seem a little hit and miss. I also have Facegen which is OK but with Headshop does anyone know if once you create your new face if you can then use Daz's inbuilt expressions. I believe you can apply a different Daz material if needed. Also does anyone here have it and recommend it? Many thanks JayNew Headshop Plugin Not Displaying ProperlyI bought this version of Headshop , excited to give it a go. However it is not displaying properly , the dimensions are off and it cuts off the bottom where the apply button is. HELP !!! I really don't want to have to return this like the last version.
1. Support ([email protected]) has not received your email.
2. Maybe changing/reducing your screen resolution would be a good way to resolve. The issue only seem to occur on Retina-type super high-res monitors.
weird pose deforms after upgrade to 4.12my major bad.. headshop will forgive me for all the nasty thoughts I shot there way.
same for xevo, cause it looked like growing up might be the culprit
Oh, but look .. brand new right out of the content library .. gen 2, gen 3, and gen 8
same pose (it's a gen 3 pose, so a bit weird on gen 2, pretty good on 8)
but look the issue is genesis 3
took me a while to figure the source of the problem
now I guess I have to figure out to fix the problem,
any suggestions etc apprecieated I will now uninstall genesis 3 essentials etc.weird pose deforms after upgrade to 4.12Okay, it involves characters created in Headshop.. will contact them.
Headshop 11 QuestionsYou need to have Daz Studio running. Don't use Headshop's exe, you start Headshop from inside Daz. I forget which menu it is under. First have your base character in the scene, then start Headshop from Daz. Do your thing in Headshop, when done it will automatically go on the figure you have in the scene.
You can also find your texture in the Windows temp folder, if it is still there.
but I have a mac ... not so if it is the same thing. I tried a rate this way too, but the plug-in fails to start up and tells me that the headshop has closed for me to manage the fileHeadShop 11 Mac is a Standalone. It DOES NOT start inside DAZ Studio. You simply start the app from the Mac Application Folder and run it. When you finish, you click Export and export OBJ and JPG files in a project folder you create. After opening DAZ Studio and placing the right character on stage (G2, 3 or 8), you import the OBJ files via Morphloader Pro and the JPG files via Surfaces.
Please watch the "How-to" video or read the manual. They represent valuable information that was developed exactly to help you understand how to use the product.
Headshop 11 QuestionsIts important to disclose you have a Mac when trouble shooting because they are so different, and sometimes the problem is because it is a Mac. Most people use PC here, and that is going to be the assumption if you don't disclose it.
There is a video for using the Mac version.
However, I noticed this video is actually filmed running in a Windows environment, LOL. So I am not sure how helpful it may be.
So Headshop cannot be run from Daz using a Mac? In my Daz Studio, I can hit the Edit button at the top and "Start Headshop" is at the bottom of the menu. From there everything is automatic.
Anyway, I don't know Mac, if you keep having trouble, you can try either contacting info_b3470fa520 (the maker of Headshop) or file a support ticket to Daz.
Which on that note, info______ should really change their Dazs forum name to Abalone LLC. <.<
HeadShop 11 Mac does NOT run inside DAZ Studio, period. It was designed as a standalone, that produces files that can be applied to DAZ figures, similar to FaceGen. The video makes it ample clear, sorry if this missed your attention
but I have a mac ... not so if it is the same thing. I tried a rate this way too, but the plug-in fails to start up and tells me that the headshop has closed for me to manage the fileYou need to have Daz Studio running. Don't use Headshop's exe, you start Headshop from inside Daz. I forget which menu it is under. First have your base character in the scene, then start Headshop from Daz. Do your thing in Headshop, when done it will automatically go on the figure you have in the scene.
Headshop 11 Questionshello everyone, I have a problem, I hope you can help me ... I downloaded this program ... everything seemed ok .. I create my model .. I close headshop and open daz. .. when I try to import the texture of the model I created ,it doesn t find any texture folder (lips, face, eyes, etc.) ... not only ... even any file doesn't let me select it anymore .... why?
