• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • How to adding bones to strand based hair?
    The SBH you made with SBH Editor ? If so, you have no way to add bones to it no matter with Joint Editor or Transfer Utility. You have to generate PR hair firsly then export it to a static mesh OBJ. Import the hair mesh then rig it. But after these process, the hair is not an SBH anymore.
    By
    crosswind crosswind August 2024 in Technical Help (nuts n bolts)
  • Repackaging(?) Morphs in character product saved as injectable Properties Preset
    The "Morph Call" mechanic in a Character preset does allow morphs to be added from outside the figure's "Morphs" folder, I've done it and even explained how to on here, it has to be manually edited to allow it as DS can't see the morphs to create the preset naturally.
    Not sure about Scene/Subsets as they have a differant "call mechanic".
    Let me guess, it shows up in the Parameters tab either under their name, or under "morphs/morphloader".
    Sadly that is all to common in 3rd party/freebie content, basically it wasn't assigned to a "Region" when it was being created, and it needs a region before it'll show in the Shaping tab.
    Genesis series figures all have "Regions" coded into them, "Actor" is the main region with a selection of sub regions below it, as an example G8F has 14 sub regions.
    By
    Bejaymac Bejaymac August 2024 in Technical Help (nuts n bolts)
  • Face and morph swap after I reload a save
    barbult said:
    Richard is making an important distinction between name and label. We suspect that you are confusing the two. The label is the thing that a user sees when selecting and applying a morph, but the important thing for distinguishing different morphs is the internal name that is assigned to the morph. You can see the name by selecting the morph by label in the Parameters pane, and clicking the gear icon. It will show you both the label and the morph. If you do that for both morphs with the same label, you can see whether they also have the same name.
    How can I see the label. my model name is Andromeda (ROMFX) and when I load the save, it loads another androemda's face (Colm Jackson). Same with cammy, I have 3 cammy models, and I want to load one cammy model in the slider, yet it loads the other cammy's model in the slider, How do I fix it??
    By
    metalisthename metalisthename August 2024 in Daz Studio Discussion
  • can I import curve based hair from blender to daz(particle or extrapolated)
    Im not sure what PAs can/cannot do or the extra functions they have (and maybe i was wrong to say their only tool is the dForce Hair modifier), all I can address is the things we can do as non PA.  We can:
    • add morphs to polylines/splines/curves
    • export SBH made in SBH Editor (anyone can export at any Render Tesselation Sides value)
    • import SBH that was made in SBH Editor (exported at any Render Tesselation Sides value)
    • import Curves from other software
    • Import mesh from other softwaare and convert to lines
    • rig polyline hair using transfer utility
    with those functions available to all users, it is sufficient to make polyline hair.
    you said we can import curves from other spftwear but after that can you use the curves for hair?or just render directly works?
    By
    chakib3 chakib3 August 2024 in Daz Studio Discussion
  • Expressions poses not working with 8.1
    Making the G8 base expressions (and any expressions that are using them) work on G8.1 requires removing dummy/placeholder expressions that are installed to G8.1 morph folders - These dummy/placeholder expression files have no other function than to prevent the base G8 expressions from loading.
    The dummy/placeholder files are located in;
    ...\Data\DAZ 3D\Genesis 8\Female 8_1\Morphs\Daz 3D\Base Pose Head\ (255 files, can be more if you have additional DAZ expression packs)
    ...\Data\DAZ 3D\Genesis 8\Female 8_1\Morphs\Daz 3D\Expressions\ (24 files, can be more if you have additional DAZ expression packs)
    ...\Data\DAZ 3D\Genesis 8\Male 8_1\Morphs\Daz 3D\Base Pose Head\ (255 files, can be more if you have additional DAZ expression packs)
    ...\Data\DAZ 3D\Genesis 8\Male 8_1\Morphs\Daz 3D\Expressions\ (24 files, can be more if you have additional DAZ expression packs)
    Please make sure you are removing the files from G8.1 morph folders and not G8 morph folders.
    Note 1; If you are logging in to DS and letting DAZ Connect (within DS) to install/update your content, you may have these also in an other location that has "\Data\Cloud\" in it's path
    Note 2; Do not remove any files from "FACS" or "FACSExpressions" folders
    By
    PerttiA PerttiA August 2024 in Technical Help (nuts n bolts)
  • Create or transfer "Open Fly" morph for G8 Male Mega Wardrobe Jeans
    Anxious3102 said:
    crosswind said:
    Ah, great ! You're welcome ~ I just updated the tutorial 'cause I found I didn't parent the jeans to G8M before I proceeded... haha ~ But that didn't impact the morph. Only after loading Jeans to the figure, Jeans is not parented to G8M.
    Now the tutorial is correct, if you followed the updated one, everything should be fine. Have fun !
    Like I really REALLY do appreciate it! Your instructions were super easy to follow, and I just appreciate the generosity of you being willing to help me figure it out and then teach me :D
    No problem ! laugh
    By
    By
    Anxious3102 Anxious3102 August 2024 in Technical Help (nuts n bolts)
    By
    crosswind said:
    Okay, pls :
    1) Carefully follow the steps in the attached Screenshots 1 ~ 7.
    2) Extract the "data" folder in the attached Open Fly Morph.zip file to your Daz Library where you've installed this product.
    3) Load the Jeans, dial Open Fly morph to check, Screenshot 8.
    It worked! OMG you are my daz hero!!!
    By
    Okay, pls :
    By
  • Bluejaunte appreciation
    First off, I really liked the those last three releases, June, Isolde and now Cynthia are some of my favorite characters for Genesis 9. Especially the first two really add a lot to the overall variety of Genesis 9 shapes.
    That being said, after installing and loading up Cynthia I did stumble a bit over she shape of her chest. I am attaching two images of what she looks like, when I render her in my version of DS (second picture has the 'Nipples Feminine HD' morph dialed in).
    Maybe I am just seeing things, but the shape of her breasts looks noticably different from the promo shots in the shop (especially the last three) - although, on second viewing, the promo shots themselves look kind of different from one another.
    Is this just me, or is anyone else seeing this?
    I am using an older version of DS (4.15.0.2 to be precise), so that might be the reason, although I am not sure if that could even in theory cause something like this.
    Anyway, I don't really mind one way or the other, but if this is a bug of some kind, I felt I should point it out blush
    *Edit*: replaced the original pictures with screenshots from 'Smooth Shaded' mode. Added a screenshot that shows the relevant section of the 'Currently Used' window.
    By
    Barubary Barubary August 2024 in The Commons
    crosswind said:
    Anxious3102 said:
    crosswind said:
    They have different geometry and vertex positions... even if you transferred Morph Targets by using Transfer Utility from Boxers to Jeans, it wouldn't work. (ss 1)
    If making it with dFormer or Mesh Grabber... it'll be cumbersome and you might not get good result as there's no capability of Mask, Smooth, Crease etc. while using these tools in DS.
    So better make it in Blender or other sculpting software that you know... (ss 2 ~ 3)
    Damn I wish I knew blender because that shot 3 is exactly what I need lol
    I could've attached this morph for you, however, there's a defect on the Jeans which is an unused vertex. I had to remove it but then saving the figure asset has to be a must before saving the delta morph asset. I'm not allowed to give you the modified figure asset according to Daz License Agreement...
    So if you need this morph I made, you have to first of all correct this Jeans figure yourself then resave the figure asset. If you know how to do it, let me know after you have it done, then I can post you the DSF file. If you don't know how to do it, also let me know. I can show you how to...
    I don't know how to do it unfortunately
    By
    By
    By
  • Freebie Challenge July-August 2024 - "Take a Break" - Entries Thread
    Six friends work in different business areas, have gathered together on the weekend and started the conversation.
    - The office sucks, I have to attend the customers calls, deal carefully with any complaints and give some advice for the services the company provide.
    - I am in the same situation like you, I have to go and drink a coffee cup to stay well after too much pressure in the office.
    - I am operating a computer, I have to wrestle with lots of information using the spreadsheets, looking for some trends with the charts and dealing with the invoices
    - How about the forms entry into a Database, isn’t that too tough?
    - Word processing, Desktop publishing and creating PDF documents are taking a toll on me
    - My job demands me to deal with some computer components acquisitions and upgrades
    - Stop complaining, Take a break, let’s party!
    - Yeah, hurrah! Lets do that now!
    Items used for the Freebie Challenge July-August 2024 - "Take a Break"
    Free Items:
    Zhi - Beautiful Chinese Female Character Morph by warloc (G8F)
    https://www.renderhub.com/warloc/zhi-beautiful-chinese-female-full-character-morph
    G8 Female Sifi Outfit (Simple) by Moonlight001
    https://www.renderosity.com/freestuff/items/77682/g8-female-sifi-outfit-simple
    Meena For Genesis 8 Female by zaap
    https://www.renderhub.com/zaap/meena-for-genesis-8-female
    Side Swept ROse Hair (G3F , G8F) Part 1 and 2 by zoro_d
    https://www.renderosity.com/freestuff/items/79533/side-swept-rose-hair-g3f-g8f-part-1
    https://www.renderosity.com/freestuff/items/79534/side-swept-rose-hair-g3f-g8f-part-2
    dForce_Belly Dance Nights Outfit for Genesis 8 Female(s) by zoro_d
    https://www.renderosity.com/freestuff/items/82950/dforce-belly-dance-nights-outfit-for-genesis-8-females
    Pretty Look for Genesis 8 Female(s) by zoro_d
    https://www.renderosity.com/freestuff/items/83823/pretty-look-for-genesis-8-females
    Mukta For Genesis 8 Female by zaap
    https://www.renderhub.com/zaap/mukta-for-genesis-8-female
    Candy Braids Hair for Genesis 8 Female(s) by zoro_d
    https://www.renderosity.com/freestuff/items/88062/candy-braids-hair-for-genesis-8-females
    (dForce) Nisia's Romper for Genesis 3 and 8 Female by freylaverse
    https://www.renderosity.com/freestuff/items/92846/dforce-nisias-romper-for-genesis-3-and-8-female
    Leather Boots for G8F by yomiuri
    https://sharecg.com/v/94464/gallery/21/DAZ-Studio/Leather-Boots-for-G8F
    G8M Walther 2.0 DAZ Studio by Ruslanomar
    https://sharecg.com/v/97276/view/21/DAZ-Studio/G8M-Walther-2.0
    New Walther 2.0 tanned skin + hair system for G8M by Ruslanomar
    https://sharecg.com/v/98463/browse/21/DAZ-Studio/New-Walther-2.0-tanned-skin-%2B-hair-system#cmntL2
    Update package for G8M Walther 2.0 by Ruslanomar
    https://sharecg.com/v/99012/browse/21/DAZ-Studio/Update-package-for-G8M-Walther-2.0
    Scottish Captain Model for Genesis 9 Male by KuraiKya (Mohawk Hair)
    https://www.renderhub.com/kuraikya/scottish-captain
    Fast Food Set by kalhh
    https://www.renderhub.com/kalhh/hamburger-set-for-dazstudio-free
    Delicious Cake Prop by Teknology3d
    https://www.renderhub.com/teknology3d/delicious-cake-ds-prop
    Coffee Urn Set by Richabri
    https://www.renderosity.com/freestuff/items/92571/coffee-urn-set
    Ghettoblaster by kalhh
    https://www.renderhub.com/kalhh/ghettoblaster-for-dazstudio-free
    Camilla Table by BoBo3D
    https://www.renderhub.com/bobo3d/camilla-table
    GTX-Luxury Area by GraphistX
    https://www.renderhub.com/graphistx/luxury-area
    Urban Street 04 HDRi by Andreas Mischok
    https://polyhaven.com/a/urban_street_04
    No Count Items:
    (*) Esha Small Earrings for Genesis 8 Female and Genesis 9
    Obtained free on 2022-12-05 Daz Christmas Freebie
    (**) M3D Versatile Short Hair for Genesis 9, 8, and 8.1 Males
    Obtained free on 2023-12-31 Daz Christmas Freebie
    (*) (**) These items are no longer available
    Genesis 8 Starter Essentials
    Base figure (Female) used
    Fabrice for Genesis 9 Character Preset
    Matt for Genesis 9 Character Preset
    Included in Genesis 9 Starter Essentials
    Paid items:
    Chameleon ROse for Genesis 8 Female by zoro_d (Lingerie panty only)
    https://www.renderosity.com/marketplace/products/126597/chameleon-rose-for-genesis-8-female
    dForce Soho Swag Clothing Set for Genesis 8 Males
    Part of “Blast From the Past Bundle”
    https://www.daz3d.com/blast-from-the-past-bundle
    Belly Dancer Poses for Genesis 8 Female
    https://www.daz3d.com/belly-dancer-poses-for-genesis-8-female
    Z Ultimate Dance Collection - Poses and Partials for Genesis 3 and 8
    https://www.daz3d.com/z-ultimate-dance-collection--poses-and-partials-for-genesis-3-and-8
    Genesis 3 and 8 to 9 Pose Converter
    https://www.daz3d.com/genesis-3-and-8-to-9-pose-converter
    No post work done with any Graphics Software
    By
    Halcon Bluesky Halcon Bluesky August 2024 in Freebies
    By
    barbult barbult August 2024 in Daz Studio Discussion
    So, for instance, you can see there're two or even more Head / Body morph properties in Parameters pane when filtering by "andromeda" ?
    By
    crosswind crosswind August 2024 in Daz Studio Discussion
    By
    If the mesh isn't welded, then you can create your own morph.
    But you can not copy it from somewhere else. In theori you might be able to do it as a projected morph if the mesh is very similar in the source, but I wouldn't try on that.
    You can in DS use Dformer or mesh grabber, but I would go for a modeller, and then import as a morph.
    By
    felis felis August 2024 in Technical Help (nuts n bolts)
    felis said:
    You can't open a mesh that is welded, as that would mean to rip the mesh, and then it is no longer a morph.
    Those jeans are already capable of opening in the right location, as they have several open morphs themselves. But all of the existing morphs undo the top button and open them wide at the waistband before expanding down the zipper line
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
Create An Account
