• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • New DS Filament Render Engine
    First impressions: MAJOR improvement over GL preview rendering. Much nicer to look at, shows HDRIs and bump maps and more. And with a heavy scene it is very noticeably FASTER too. *happy*
    (For me) not a replacement for iRay renders, but definitely my new go-to when I'm posing or otherwise changing geometry (iRay is just too slow here).
    Compared to iRay, it's way too bright. Reason(?): In the Draw settings, Filament ignores the gamma settings. Compared side to side, Filament and iRay look about similar when gamma is ~4.
    Default gamma is 2.20, which makes iRay much darker, while Filament stay at ~4 regardless of the setting.
    By
    cajhin cajhin October 2020 in The Commons
    lights have a slight effect, emitters seem to have none
    we may need new filament shaders
    apparently Filament pbr shaders exist and it's opensource so I guess they could be added and a conversion script (by someone who knows what they are doing)
    also file paths and names don't seem to refresh for new image series
    By
    WendyLuvsCatz WendyLuvsCatz October 2020 in The Commons
    Does this render 3DL textures? And is there a speed improvement over 3DL? Very excited if so, because that would mean I don't have to replace my 8 yr old, low end PC (which I can't afford to do anyways).
    I would suspect not, since Filament, as a PBR engine, is more similar to Iray than it is to 3DL. I'll do some tests, though.
    By
    Gordig Gordig October 2020 in The Commons
    So, with the new way of accessing the tone mapping options, do the already existing presets (like tonal rage) still work? Because if they don't, this will be a huge drawback.
    It appears you can get the old way of tone mapping back in the Render Settings Tab by switching back to the Iray Engine.
    I'm not clear what issue people are having with tone mapping.  I have the additional options in the Parameters tab, but I still have the same old Environment and Tone Mapping options in Render Settings, whether I'm in Filament or Iray or whatever.
    In the Render Settings Tab if you switch to "Engine: Viewport" the Tone Mapping and Environment disappear, even if you're in NVIDIA Iray viewport mode in your preview window.
    By
    3Diva 3Diva October 2020 in The Commons
    By
    Sevrin Sevrin October 2020 in The Commons
    Ok, this is so weird. The LINES that Filament renders appear to be related to the size of your preview window.
    This window layout:
    ...results in these lines:
    Whereas this window layout (making the preview window as big as I can make it):
    ...results in just a single line across his face:
    By
    I'd like tone mapping settings for Filament to be separated from Iray's tone mapping.  I like having an additional preview option, but the requirements of Filament and Iray are so different that its usefulness for the purpose of previewing is limited.  I can live with emissives not working.  If it's not intended for previews, but as purely its own thing, it would be nice to know.
    By
    Cute!
    However there are bad bugs that Filamernt has caused. I actually in my render settings lost the entire sections of 'Enviromental Settings' and 'Tone Mappings Settings'! Do NOT use Filament in the viewport or in the rending don't use 'Viewport' (really Filament) or you risk corrupting your scene duf file and get crashes of DS without crash dump files.
    I still like filament but it's not ready. Just test it on just scenes until it's fixed.
    I'm not sure that's filament causing that. It seems to be part of this new "showing those settings as Nodes in the scene pane", and accessing them via the parameters pane.
    By
    prixat prixat October 2020 in The Commons
    Did I miss something? What is Filament?
    Filament is a real-time physically-based render engine. The new beta of DS (just released) added it as a preview mode.
    Thank you very much for the explanation.
    By
    Vyusur Vyusur October 2020 in The Commons
    By
    Leana Leana October 2020 in The Commons
    I'm trying it on a recent scene and the brightness of it is way too high. Also, it's making too many surfaces look like they've been coated with ice in an ice storm. Other surfaces though have a lovely pastel chalks look to them with I like. I am using an MSI Radeon RX 570 8GB that is only slightly slower than a PNY GeForce GTX 1650 Super 4GB I have that is not installed. I will switch them tomorrow. It will be interesting to see if it improve the Filament renders (it shouldn't). I am wanting to see which recent scenes I'm animating in DAZ that will fit into the PNY GPU's 4GB RAM, some of those scenes have a lot of DAZ products in them.
    Attached: Fliment Preview of scene I've done within the past week. The rendering of the viewport is almost instantaneous but as you see it isn't done yet. The bright levels are too high. A great start though. Honestly the pastel chalk look I'm getting I would like in my hobby video games when I go on with that. Compare with the same scene in my forum icon or my render of the scene in my 2020 Caricature Gallery.
    I hope for a full blown Filament Render option in the renderer drop down menu!
    Notice that the new public beta created nodes in my scene tab for the Environment and Tone Mapping settings from the renderer. When I hide those in the scene tab two Render Settings subsections called 'Display' disappear. No sure what's going on with that.
    I found the Filament Render option as Viewport. I hope for improvements to that renderer.
    I did find bugs.
    And I did install my PNY GeForce GTX 1650 Super 4GB and if you look in my gallery 2020 Caricatures none of my last 10 render from there with fit in a 4GB nVidia card. Thast's zero. So if you are thinking of buying an nVidia GeForce RTX 30X0 series I advise based on that to save an extra month or two and get a 30X0 video card with no less than 16GB RAM. As you see the scene is complex because that's how it is in real life but from a customer perspective it was very easy to make that scene. So disappointing (not the PA or DAZ fault; the GPU manufacturers need to get on the stick)! I'm absolutely not interested in 'optimizing' my scene although rendering at 720P and using DLSS to upscale it is reasonable thing to do if that fits the scene in 4GB or 8GB or 10GB RAM. Are you willing to spend $499 or $699 though on a 30XX Series video card just to find out your simple scenes don't fit into them even at 720P? I'm not.
    By
    nonesuch00 nonesuch00 October 2020 in The Commons
  • Daz Studio Pro BETA - version 4.12.2.60! (*UPDATED*)
    Note: Bugs
    I have a scene that caused the 'Tone Mapping Settings' and the 'Environment Settings' to cause nodes to be created in the scene tab. I deleted those nodes but the Enviromental and Tone Mapping Settings stayed in the renderer pane.
    I tried to render in iRay Sun-Sky or Dome & Scene with Draw Dome on and in both case the iRay renderer drew the alpha channel for the sky (a grey & black checkerboard).
    However, I saved the scene, exited, start DAZ, over the same scene but DS crash without generating a crash dump. So I open DAZ again, open the same scene again, and this time the 'Enviroment Settings' and 'Tone Settings' are complete missing.
    There are conflicts in state I think in switching between Viewport and iRay to render and in Filament Preview and iRay Preview in the Viewport. Currently I have my scene set to iRay for render and Filament for Viewport.
    By
    nonesuch00 nonesuch00 October 2020 in Daz Studio Discussion
    Cute Diva!
    It's been said in the DAZ Studio Discussion by JellyBean that turning on and then off iRay Preview Mode in the ViewPort will restore your lost Environmental and Tone Mapping setting.
    By
    By
    Thanks ALOT Daz Team for Filament render option.  smiley
    Still don't have alot time ATM, but did a quick test, in filament posing quick with IK by dragging body parts and rendering out a test anim with an image series.  Went fast with tons of morphs and 4 characters in scene.  10 frames took like 30 seconds I think.  Nice big step for creating animations in DazStudio.  Well at least the design for now.  Made my day! heart
    By
    Saxa -- SD Saxa -- SD October 2020 in Daz Studio Discussion
    Out of curiosity, I did a quick Iray render with the same settings:
    So...looks like Filament hasn't made Iray preview mode redundant.
    By
    Just tried out Iray section planes and decal nodes, and neither worked in Filament. I wasn't expecting them to, but it would have been nice if they did.
    By
    Defiantly a difference between iray and filament render quality.  i wonder if filament baked/render,what ever you want to call it longer if it would clear up the artifacts?  I'm holding off on over writing my copy of the beta I have for now so maybe after i know you guys are not getting any bugs I'll update  my copy.
    @3Diva Nice job on your first animation smiley
    That's smart because I've already discovered a bug - trying to do an Iray render with anything in the scene that has the Oso Blendy shader applied immediately crashes Daz Studio. This is a bug that keeps popping up EVERY SINGLE beta release and it drives me BATTY. If they know that it's an issue, and it's been a problem like the past 3 or 4 releases, why oh why do they still not implement Blendy support with the release? ARGH! :(
    By
    Thank you, Ivy! :) I did a couple of other test animations before this (mostly with puppeteer), but this is the first time doing one that I hand did the keyframes. So I'm happy I was able to figure out how to do that! :)
    By
    I changed the shader to the base Iray Uber shader and turned the dome on and rerendered it with Filament preview. This time it rendered even faster at 10 minutes and 44 seconds:
    https://player.vimeo.com/video/468002998
    Edit: The hair still looks weird. I'm not sure why. Perhaps the trans maps.
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
