Making anime characters
thanks a lot .. but i still have one question maybe you can help me with ! .. can i get your help by telling me how to find ANIME compatible with Genesis 3 and specially to change the body ? the body i mean like the hole body with the face head legs arms torso .. is that kind exict ? and about the hair if its included it's will be better but for now it's not a big matter for me because am using maya to make robots, tank, etc ... but with characters am very bad but i can make my own hair there so that's why am started using Daz studio .. if you gonna help, am trying to find something is able to be changed not for only one girl shape .. because i saw some videos that there is morph (or figures i don't know what they called) can be changed to 5 or 6 figures .. and thanks again
https://www.daz3d.com/genesis-3-female-head-morphs
https://www.daz3d.com/genesis-3-female-body-morphs
https://www.daz3d.com/genesis-3-female-expressions
https://www.daz3d.com/genesis-3-male-head-morphs
https://www.daz3d.com/genesis-3-male-body-morphs
https://www.daz3d.com/genesis-3-male-expressions
Set the subdivision in the viewport & for rendering to zero when you apply morphs and that will help reduce realistic detail to a degree.
If you can't quite get the head morphed to be anime enough for your taste, you can download, install, & use the freebie below. I don't know of a male equivalent though.
http://www.sharecg.com/v/85535/browse/21/DAZ-Studio/Anime-Head-for-Genesis-3-Female
Making anime charactersthanks a lot .. but i still have one question maybe you can help me with ! .. can i get your help by telling me how to find ANIME compatible with Genesis 3 and specially to change the body ? the body i mean like the hole body with the face head legs arms torso .. is that kind exict ? and about the hair if its included it's will be better but for now it's not a big matter for me because am using maya to make robots, tank, etc ... but with characters am very bad but i can make my own hair there so that's why am started using Daz studio .. if you gonna help, am trying to find something is able to be changed not for only one girl shape .. because i saw some videos that there is morph (or figures i don't know what they called) can be changed to 5 or 6 figures .. and thanks again
Morphing Genesis 3 character into Toon Generations 2?Yes I did!
I load the Genesis 3 figure into Daz Studio. When I apply the Toon Generations figure onto the Genesis 3 figure, or respectivly the "Growing Up" Shape/morph onto the Genesis 8 figure, a dial shows up in the Shaping tab, but nothing happens when I move the dial.
Blacksmith3DEver since I read that Blacksmith3D can port older texture maps to newer figures, I've been wanting to grab it when it goes on sale next. I have a handful of characters that I've portied to Genesis 3/8 using Morph Loader, and it would be nice to port their textures too. For my own use of course! I just like having more posing regions.
Would probably be cheaper to use the cayman studio product to make V4 textures work on G3/G8.
Blacksmith does other things as well...
Well aware, have used it before. For your specific purpose that you posted about about, just thought I would add another option in case you were not aware.
I've used both options for getting other textures onto current figures and both have pros and cons..
MD->Daz->ZBrush->Daz For clothing help?If you are literally editing the item then no, because using GoZ removes grouping (and surfaces). GoZ is mainly set up for morph creation, which should not create a new model in the scene but just add a property to the existing model. More substantial editing is better handled via OBJ export/import.
Thanks! So, in my case a better option would be to modify in ZBrush and the generate an OBJ file which I would later import into my scene right? My question with that approach is how can I place the clothes in my figure with it? Using transfer utility?
Thanks a lot for your help
or you mean exporting my whole figure with clothes and everything, editing in Zbrush and then importing back to daz as 1 obj?
No, export the clothing items separately, and the figure if you want it as a guide. By default DS will not export items that are set to Visible Off.
If all you want to do is convert textures from one generation to another, their Texture Transformer can do that. And there are addons to convert to G3, which is also usable on G8. Those addons work with both TT and Blacksmith 3D. Now if you already have Cayman Studios legacy UVs, you might be interested in the two over at Rendo for under $9 each right now. They are for using V4 and G2F on Genesis 3 Females.
But as @tj_1ca9500b mentioned, Blacksmith 3D does a lot more than just converting figure textures. I would have purchased it without the texture conversion feature, but I'm not unhappy it has that built in.
dog 8 dog 8 woof woof we finally have a dog 8Still on the fence about the new dog. I barely used the Millennium Dog Bundle and puppy I already have. I rarely need complete realism for anything and the old dogs don't look too bad in IRay. I know the paws look bad but I could brush out the fur on the paws in Photoshop if necessary. If the dog had come with several breeds and furs and a puppy morph, I would have jumped on it. But, as is, not as excited...
I'm a cat person anyway. Do these old Millennium Dogs really look that bad?
MD->Daz->ZBrush->Daz For clothing help?Yes, once you have the final OBJ use the Transfer Utility to rig it to the figure.
Thanks!
Morphing Genesis 3 character into Toon Generations 2?I am transitioning from using Poser to starting to use Daz Studio. I bought Toon Generations 2 Mega Bundle for Genesis 3, as well as Growing up Bundle for Genesis 8. I cannot figure out how to morph the respective Genesis figures into the Toon Character?.
Could someone please help me with this? As I am a total newbie, please explain in simple terms!
Thank you, thank you, thank you!
Anne
Buy Something That Doesn't Work in Carrara? Post your Questions and Workarounds here. (please)it looks like those other vertices are welded to some of the ones you select
the only way you could move parts of it is using magnets or rigging, or reweld the whole thing which could destroy the UV mapping.
Thanks for answering.
I don't think it's that, because if I use "grow selection", it works perfectly. The problem is only with "soft selection".
I just found a way: I tried the various settings for the reimport of the obj file and found that selecting "Create a Polymesh per Material" solves the pb. There's only one material so it creates only one mesh, as with the default setting ("Create a single polymesh"), but this way the soft selection works. Don't ask me why ...
Of course there's no rigging anymore, but I think I know how to put it back with DazStudio. And UV mapping is still here !
you could load it in DAZ studio on the top via morphloader and save it as a morph asset
make sure is base resolution
check with an obj import if it's the same scale and position
I used the figure transfer utility with the original item as a model and I got back the rigging, and it seems to work well, and the soft selection also works now !
There was an additionnal step though as if I imported directly the mesh in studio I got the problem back in Carrara at the end (the option that makes it work in Carrara doesn't exist in studio). So I had first to export the obj in dae format (in Carrara) and import that dae in studio. I had to alter the scale and very slightly the position.
Thank you for your time and suggestions.
Facegen 2.0 Released- Now 2.1thanks for updating us about this just installed and started it up and just looking at the menus looks like we have a lot more options even remembers shows where I've saved to on my other drive. Got a question there is a custom section that has seperate? options for besides face, arms, legs and torso I clicked the buttons and it looks like you can do something to those textures?
You can load up any texture you want now! So you can use Victoria 8 textures instead of base Genesis 8. Or Greylien. Whatever you want, as long as the UV matches the base. I have not experimented much with this yet myself. FG still seems to work best with the base textures. But now you can edit the base textures to your liking and have FG use them instead.
Does this mean i first load victoria 8. Then set the uv to base. The save it. Then load up FG with the face i want then set it to custom and load victoria textures and export then open the file i saved and load in the face dail and tExtures? Or is there another way? I find that if i use the genesis 8 basis model and load in FG textures the face loses its general sructure of the pores... so when you zoom in there is less detail then normalNo, what happens is you can link to whatever texture you want to use before you export the morph/texture settings.
Render crashes to CPUBased on what I've observed, it seems like the process is something like this. If somebody knows better please enlighten me:
- When you hit Render, raw scene data is read from disk into system RAM. On my 64GB system I've loaded multiple scenes until this value gets over 30GB in order to stress my system.
- Once it's all in system RAM, the CPU gets busy, and the Iray code within Studio starts converting that raw scene data into Iray calculations (light bounces and stuff). This Iray data ends up being a fraction of the memory requirement of the raw scene data. In my case, with a total of 19GB VRAM capacity across two GPU's (11 plus 8), the VRAM fills to around 17GB, or 1GB below each GPU's capacity. So VRAM usage is roughly half of the raw scene usage in system RAM.
- Once it's converted to Iray, the code checks to see what memory is available by summing all the available GPU VRAM. This number varies based on stuff like:
- Whether other apps are using some portion of the VRAM on any card (like running a monitor, etc.), making the available VRAM on that card less
- Some overhead required for the GPU driver and other stuff needed to run and schedule each GPU
- The total VRAM requirement. Maybe it doesn't need all available VRAM from all cards for the particular scene
- Other stuff
- Once it sees what's available it allocates/grabs the VRAM, then starts sending the iray calculation code via PCI to the GPU's, using all available VRAM as one big chunk.
- Once the entire scene is loaded into the GPU's and ready to be calculated, the user sees the first grainy Iray render in the preview window.
- After that, the GPU's just keep cranking, with no more transfer into or out of VRAM.
- When enough calcs have been done to make an updated preview image, a new image is sent to Studio and to the monitor.
I'm especially unclear on the first couple of steps above, since when you load a big scene, before you hit Render, the scene is visible, but doesn't load up system RAM very much. Not sure how that happens...
Interesting theory. I have 32 gig of RAM, and like you say, when I'm doing a large scene, my RAM loads to around 20 gig, or 2 gig less than the combined VRAM of my 1080 Ti's. However, when I run 3 cards, it still only loads to 20 gig, and by your theory it should load to 25 gig. On this particular scene, the 980 Ti ran for a while then crashed. On a smaller scene, that allows the 980 Ti to run to completion, the RAM only filled to 11.9 gig. The cards are seeing 5.5 gig, 5.1 gig and 4.1 gig respectively. So 14.7 gig all told. Minus 3 gig, 1 for each card, is around the 11.9 gig of RAM ... so it seems that there are other calculations that the system is doing. In the first case, something is telling the system that the scene is too large for the 980 Ti, and so the RAM loads to accomodate the 1080 Ti's. Why the 980 Ti runs at all for a while is still a mystery. It should have been precluded from running at all, and maybe it would have been if the scene was a gig larger. When it's allowed to run, sometimes it finishes...but when it runs for a bit and then fails, all 3 cards crash to CPU. When it's not allowed to run at all, the 2 bigger cards finish the render. That may answer my crashing question. The scenes were in that in between place that almost allows all 3 cards to run, but not quite.
It is noteworthy that my RAM stays at whtever the load size was until the render is done. I would have thought it would flush itself but it doesn't do that until the scene is completed. I batch render, and when the scene finishes, the RAM flushes and then loads up again for the next scene.
dog 8 dog 8 woof woof we finally have a dog 8Sculpted morphs are actually pretty easy with more modern meshes/rigging... but not the Millennium Dog, which may be why folks have had trouble in the past.
All you have to do is export JUST the dog (not whiskers) zeroed out, base resolution.
Then you do Morph Loader Pro to bring it back, and that... pretty much does it. If you are using the base dog, you don't have to do anything special. Then turn on the morph (may want to change the location in Parameters from Morph Loader to something nicer, like Actor/Breed or something), Edit mode, ERC Freeze the morph, then save the morph as a Figure/Morph asset.
If you are starting from a dog with actual morphs dialed in already, at the Morph Loader Pro stage you want to expand the options and click 'reverse deformations' to, well, reverse deformations.
There might be a detail or two I'm missing, but that should do it. You can go look up how to use Morph Loader Pro elsewhere for a more rigorous description with screenshots.
But Millennium Dog... woof. I actually had this elaborate alien dog morph made up for MilDog at one point, but trying to share the morphs for it was next to impossible.
