The "Animators Assemble!" thread for Daz animation WIPs, clips, and tips
Thank you, guys! Learning how to use the timeline stuff is pretty tricky at first but I'm slowly getting it, I think. :) Filament definitely makes it worthwhile since I can see results pretty quickly and if I mess something up it's not a disaster since it didn't take hours to render out. lol
I'm taking the plunge -
- Updating my nVidia drivers
- Installing the Beta DS
- Currently reading up about it in fear
No guarantees I'll get very far with it, but I want to give it a shot. By buddy, Diomede, is doing some amazing things back and forth between Carrara and DS. I'm perfectly happy with Carrara - it's not that. Just that this whole Filament thing, combined with the new integration of keyMate and graphMate is exciting to me.
Fingers crossed. I work far too much (away from anything that resembles a computer or internet) to be trying to devote a bunch of time into learning new things, but what the heck. Give it a shot!
The "Animators Assemble!" thread for Daz animation WIPs, clips, and tipsThank you, guys! Learning how to use the timeline stuff is pretty tricky at first but I'm slowly getting it, I think. :) Filament definitely makes it worthwhile since I can see results pretty quickly and if I mess something up it's not a disaster since it didn't take hours to render out. lol
Absolutely. And that's exactly how to do it. Just keep slugging away. You wouldn't believe how many renders I throw away - but it's all part of the game!
Daz Studio Pro BETA - version 4.12.2.60! (*UPDATED*)If you get error like that ( IRAY rend error: Cannot render: found no usable devices.)
there is 3 possibilities.
1.your driver is outdated
2. your card is not supported
3. your card GPU is not selected
nothing more nothing less
But in your case I am sure your driver is outdated to work with the last build. I run with the same error in early builds but it was obvious that was old driver issue.
Hi,
Report bug with 4.12.2.54 DL today.
I dont have a problem with Daz 4.12.1.118
Viewport Nvidia Iray not work with gpu card but work with cpu.
Part of log file :
2020-10-22 19:27:05.770 Iray [INFO] - IMAGE:IO :: 1.0 IMAGE io info : Loading image "C:\Program Files\DAZ 3D\DAZStudio4 Public Build\shaders\iray\resources\DTHDR-RuinsB-500.hdr", pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
2020-10-22 19:27:05.793 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating geometry.
2020-10-22 19:27:05.794 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating motion transforms.
2020-10-22 19:27:05.795 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing scene graph.
2020-10-22 19:27:05.795 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Importing geometry for motion time 0
2020-10-22 19:27:05.796 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Geometry import (0 triangle objects with 0 triangles, 0 fiber objects with 0 fibers (0 segments), 0 triangle instances yielding 0 triangles, 0 fiber instances yielding 0 segments) took 0.000s
2020-10-22 19:27:05.796 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating materials.
2020-10-22 19:27:05.796 Iray [INFO] - MATCNV:RENDER :: 1.0 MATCNV rend info : found 0 textures, 0 lambdas (0 unique)
2020-10-22 19:27:05.796 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating environment.
2020-10-22 19:27:05.819 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating backplate.
2020-10-22 19:27:05.821 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lens.
2020-10-22 19:27:05.821 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating lights.
2020-10-22 19:27:05.822 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating object flags.
2020-10-22 19:27:05.822 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating caustic portals.
2020-10-22 19:27:05.823 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Updating decals.
2020-10-22 19:27:05.839 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using iray core convergence estimate.
2020-10-22 19:27:05.841 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Allocating 1-layer frame buffer
2020-10-22 19:27:05.848 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Using interactive scheduling, caustic sampler disabled
2020-10-22 19:27:05.848 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER :: 1.0 IRAY rend error: Cannot render: found no usable devices.
2020-10-22 19:27:05.848 Iray Render error: Invalid parameters (NULL pointer).Anyway, i love Filament (PBR)
Problem solved on beta 4.12.2.54 (driver updated), thanks everyone.
Hi,
Part of log file :
About 3DelightI use 3DL and Iray but my computer struggles a lot with Iray. I use DIM to install Studio and it's updates but I also do a manual download of the Studio installer and keep it backed up on a USB hard drive. That way if Daz ever drop 3DL I will have an installer for a version that does support it. I don't think Studio needs any sort of online activation so I think that as long as I keep a copy of the installer and my activation key I should be able to keep using a 3DL verision of Daz Studio even if Daz abandion it. Remember, Daz don't allow you to download old versions of Studio so you should keep a backup of any version you want to keep.
This! I have several backups of DS 4.7 (with 3Delight v11) and it's installed and working fine on an old 2007 Macbook. I mainly use DS 4.9, which has the 3Delight v12, and will not upgrade unless DAZ suddenly decide to introduce 3Delight v13:)) The DS Beta is always there if you want to test the new DS features. But...being a Mac user...most new stuff seems to be PC only, like the Filament renderer, so I see no need for upgrading my current 4.10 Beta atm. It has dForce if I need it;)
And, as I said somewhere else, the last resource is the Wayback machine:) The latest available 3Delight standalone is slightly newer than the latest DS version, and...surprise...I have it
Daz Studio Pro BETA - version 4.12.2.60! (*UPDATED*)Hi,
Part of log file :
I suspect you need to update your drivers, though it's possible you have an older card which is no longer supported at all. Including the whole render section of the log for a simple scene, to keep it short, would have been more useful.
I didn't want to post the whole log, to avoid being yelled at by a too huge copy/past ^^
I play with a 1080, and i have Nvidia Studio Driver 430.86 (Best time with Simulation dforce)
Ok you are right, Another log part:
2020-10-22 20:18:59.078 Iray [INFO] - IRAY:RENDER :: 1.1 IRAY rend info : NVIDIA display driver version: 430.86
2020-10-22 20:18:59.078 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - IRAY:RENDER :: 1.1 IRAY rend warn : CUDA module initialization failed with error 'CUDA driver version is insufficient for CUDA runtime version' (0x23); iray photoreal can only run in CPU mode. Please update your NVIDIA driver (www.nvidia.com).
2020-10-22 20:18:59.079 Iray [INFO] - IRAY:RENDER :: 1.1 IRAY rend info : Using iray plugin version 5.1, build 334300.4226 n, 29 Sep 2020, nt-x86-64-vc14.
2020-10-22 20:18:59.079 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - IRAY:RENDER :: 1.1 IRAY rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
2020-10-22 20:18:59.079 Iray [VERBOSE] - IRAY:RENDER :: 1.1 IRAY rend stat : Environment cache size capacity: 5.
2020-10-22 20:18:59.079 Iray [INFO] - BLEND:RENDER :: 1.1 BLEND rend info : Plugin "blend render" (build 334300.4226, 29 Sep 2020) initialized
2020-10-22 20:18:59.079 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK :: 1.1 IRAY_C net info : Plugin "iray_cloud" (build 334300.4226, 29 Sep 2020) initialized
2020-10-22 20:18:59.079 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK :: 1.1 IRAY_C net info : Plugin "irt_cloud" (build 334300.4226, 29 Sep 2020) initialized
2020-10-22 20:18:59.079 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK :: 1.1 IRAY_C net info : Plugin "nitro_cloud" (build 334300.4226, 29 Sep 2020) initialized
2020-10-22 20:18:59.079 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK :: 1.1 IRAY_C net info : Plugin "iq_irt_cloud" (build 334300.4226, 29 Sep 2020) initialized
2020-10-22 20:18:59.079 Iray [INFO] - IRT:RENDER :: 1.1 IRT rend info : Plugin "irt" (build 334300.4226, 29 Sep 2020) initialized
2020-10-22 20:18:59.080 Iray [INFO] - EIAXF:IO :: 1.1 EIAXF io info : Plugin "axf importer" (build 334300.4226, 29 Sep 2020) initialized
2020-10-22 20:18:59.080 Iray [INFO] - ICB:IO :: 1.1 ICB io info : Plugin "cb_importer" (build 334300.4226, 29 Sep 2020) initialized
2020-10-22 20:18:59.080 Iray [INFO] - IRAY_CLOUD_CLIENT:NETWORK :: 1.1 IRAY_C net info : Plugin "iray_bridge_snapshot" (build 334300.4226, 29 Sep 2020) initialized
2020-10-22 20:18:59.080 Iray [INFO] - IRAY_CLOUD_SERVER:NETWORK :: 1.1 IRAY_C net info : Plugin "iray_bridge_server" (build 334300.4226, 29 Sep 2020) initialized
2020-10-22 20:18:59.080 Iray [INFO] - EEMI:IO :: 1.1 EEMI io info : Plugin ".mi exporter" (build 334300.4226, 29 Sep 2020) initialized
2020-10-22 20:18:59.080 Iray [INFO] - EIMI:IO :: 1.1 EIMI io info : Plugin ".mi importer" (build 334300.4226, 29 Sep 2020) initialized
2020-10-22 20:18:59.081 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - IRAY:RENDER :: 1.0 IRAY rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
2020-10-22 20:18:59.081 Iray [INFO] - IRT:RENDER :: 1.0 IRT rend info : Resource assignment for host 0 has changed.
2020-10-22 20:18:59.081 NVIDIA Iray GPUs:
2020-10-22 20:18:59.081 GPU: 1 - GeForce GTX 1080
2020-10-22 20:18:59.081 Memory Size: 7.9 GB
2020-10-22 20:18:59.081 Clock Rate: -1 kHz
2020-10-22 20:18:59.081 Multi Processor Count: -1
2020-10-22 20:18:59.081 CUDA Device ID: -1
2020-10-22 20:18:59.081 CUDA Compute Capability: NA
2020-10-22 20:18:59.081 PCI Bus ID: 1
2020-10-22 20:18:59.081 PCI Device ID: 0
2020-10-22 20:18:59.081 TCC Mode: disabled
2020-10-22 20:18:59.081 Display: attached
2020-10-22 20:18:59.081 NVIDIA Iray Scheduling Configuration:
2020-10-22 20:18:59.081 CPU Load Limit: 8
2020-10-22 20:18:59.081 CPU Thread Affinity: disabled
2020-10-22 20:18:59.081 GPU Load Limit: 1Minimum driver requirement (on Windows) is 451.48
Ok, Thanks.
Part of log file :
About 3Delight...Sven thanks, when I saw this thread I was about to link to those myself.
Yeah the latest Daz Beta has the new filament engine, but I feel I have enough on my plate with AweSurface, Iray, and Blender (for modelling) on top of still rebuilding after the drive crash to devote time to understanding a whole new rendering tech and shader/material system. Also, it still relies on a GPU for best performance whereas 3D doesn't.
Part of log file :
2020-10-22 20:18:59.081 GPU Load Limit: 1"Iray [WARNING] - IRAY:RENDER :: 1.1 IRAY rend warn : CUDA module initialization failed with error 'CUDA driver version is insufficient for CUDA runtime version' (0x23); iray photoreal can only run in CPU mode. Please update your NVIDIA driver (www.nvidia.com)."
Part of log file :
2020-10-22 20:18:59.081 GPU Load Limit: 1Daz Studio Pro BETA - version 4.12.2.60! (*UPDATED*)Hi,
Part of log file :
Did you disable the 3dlight plugin if you did iray stopps working
I have nothing disabled or deleted about 3delight, I never even use 3delight.
Part of log file :
Part of log file :
Part of log file :
The "Animators Assemble!" thread for Daz animation WIPs, clips, and tipsThe new Filament draw style renders super fast. I've been experimenting with it as I've been trying to learn how to do animations. Here is a quick animation I did with Filament:
https://player.vimeo.com/video/469408305
It rendered 472 frames in 21 minutes. It would have taken hours to render it in Iray on my machine.
nicely done.
That's Awesome!
Daz Studio 4.14 Coming This Month?I hope some Filament shader bricks and base shaders for stuff like emission
and opacity, I am pretty sure the engine supports opacity better that we are seeing just not using the mathematics of the existing DAZ shaders
I think it could be a twosided issue too
it does apparently support emission too from the documentation
+1
