• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Weird looking Anatomical Elements morph on character (Dracarys G8F)
    You are probably seeing a projection of the body shape into the Anatomical Elements which is not working with the morph applied directly to the Anatomical Elements (if that is what you are doing). Not all shapes mix well in general.
    So what can I do to change that?
    The SAV model is made for V4 and genesis 1, the golden palace figure is made for GF3 and GF8, so that might be a cause of the problem.
    Now there is a Dracarys for GF8 by Sangriart though
    Sry, my mistake. I edited that in my post above.
    I am using the Sangriart Model.
    Btw why got my links deleted? How am I supposed to show the problem without a image?
    Cheers, Nalfy
    By
    Nalfeyn Nalfeyn December 2018 in Technical Help (nuts n bolts)
  • [Released] RSSY Clothing Converter from Genesis to Genesis 8 Male [Commercial]
    I'm having a little trouble with the Genesis to G8M converter ( I have no problem with the G2M and G3M converters). I get an error response "No clothing deteted".  I get the same error whether I choose "Add Files..." or "Add Directory".  Below are the lines of the log file, but it isn't limited to this particular product, no Genesis pieces work.
    Thank you for any help you could provide.
    11:19:15 GMT-0800 (Pacific Standard Time): Adding DirectoryE:/Documents/DAZ 3D/Studio/My Library/People/Genesis/Clothing/DZ Clothings/DZ CowlNeck
    11:19:15 GMT-0800 (Pacific Standard Time): SKIPPING "scene" file: E:/Documents/DAZ 3D/Studio/My Library/People/Genesis/Clothing/DZ Clothings/DZ CowlNeck/CowlNeckLS.dsf
    11:19:15 GMT-0800 (Pacific Standard Time): SKIPPING "scene" file: E:/Documents/DAZ 3D/Studio/My Library/People/Genesis/Clothing/DZ Clothings/DZ CowlNeck/CowlNeckQS.dsf
    11:19:15 GMT-0800 (Pacific Standard Time): SKIPPING "scene" file: E:/Documents/DAZ 3D/Studio/My Library/People/Genesis/Clothing/DZ Clothings/DZ CowlNeck/CowlNeckSL.dsf
    Thank you all for your input, it helped a great deal.
    The Genesis to Gen8 Converter is working nicely for me now with some very old Genesis Clothing.  This is what I've learned so far...
    1. As RiverSoftArt mentioned I had to uncheck "Options/File Overwrite Condition/Check Conent Type When Adding Files" box
    2. Under the conversion Tab I had to use "Add Files...", -- "Add Directory..." would not work for me.
    3. For both .duf or .dsf files, I had to hightlight them and press the "Change Conformer" button that was in the lower-ight hand side of the page (I used the Bodysuit conformer for everything). This would fill out the "Conversion Clothing" column in the "Clothing Item Files" list.  That column must be filled in.
    4. For .duf files I could then press the Execute button at the bottom of the page. -- for the .dsf files I had to press the "Force Convert Item(s)" button.
    5. Conversions proceeded as expected with excellent results after that.
    So far by following these steps I've converting everthing I can find, no matter how old they are.
    When using these converters (which I love) I always have the vanilla Genesis 8 Male figure alone in the scene. The Genesis clothes convert a little loose with him, (I haven't yet put any of the clothes on my custom models), but there a couple of morphs that are included with the conversion (under Actor), Converter Morph and Tighten All.  These along with mesh smoothing takes care of all the looseness.
    Thanks again for all the helpful recommendations.
    You are welcome!  Thanks for sharing and I am glad you have it working for everything.  Here are some extra comments:
    2. Yes, the Check Content Type is for the "Add Files..." button (this is mentioned in the hint and manual)
    3. The script would not fill in the conformer by itself?  Strange, I will have to look into that
    To make sure that we could handle as many clothing items as possible, the clothing can be a little loose.  Using the Tighten All morph (and all of the other morphs), you can tweak a clothing item to your heart's content.  Remember you can also save (overwrite) that clothing item with the morphs set to the way you like so that it will load with the morphs set from now on.
    By
    RiverSoft Art RiverSoft Art December 2018 in Daz PA Commercial Products
  • Is there a way to tell which base figure a character goes with?
    If it's a specific morph the character needs like Zelara or Eva I don't see a way to know..
    By
    jenniferhughey jenniferhughey December 2018 in The Commons
  • All things The Witcher...
    A 1st quick loading and rendering test..... her highness is not amused cheeky
    A bit of an extreme pose; no adjustments done to the outfit to correct for this. Texture used for 'Adda' is from Arabella 7
    Looks great! Hope you enjoy! If anyone else wants this send me a private message and I'll get you a copy. THis will not be sold or put on ShareCG. I never could get the hand pose to work right, dont know why? The boot/feet pose worked great for me though. Her morph, I made her scaled down so she is five feet tall  like the reference. I noticed when loading some full body poses from other content creators sets she would expand back up to 100% scale, I think this is something to do with the data in the saved pose files, not something on my end? Don't know though. Another thing I should have done was add in a smoothing modifier to the boots and skirt. It's easy to do on your own though, I would tell the boots to colie with Genesis 3 and the skirt to collide with the boots. The smoothing on the skirt will fix wierd squar distortions on leg movemnts between the thighs. The smoothing modifier on the boots will fix any pokethroughs, when the leg is bent she's getting a pokethrough on the leg calf muscle; screen shot of smoothing modifier added to the boots. I love the full body pose you chose, it's great! It also looks like you found the hair morphs and played with them too, I added several.
    By
    Type 0 Negative Type 0 Negative December 2018 in The Commons
  • Lips, eyes, nose sudden all increased in size.
    That sounds like somehow you have overwritten the original presets for those characters so that they are using the 'Cartoonized' for G8F/G8M's morphs applied to them but that's very unlikely. I have only ever had to installed the 'Default Resources' when I have new or reinstalled DAZ Studio.
    Are you sure it's not just the focal length of your camera? Not that i can think why that would be persistent across scenes, but if the value were suddenly lower it would tend to produce the effect you describe.
    This is basically what happened to all of my females. Males are unaffected.
    Yeah, it looks like a 'Cartoonized for Genesis 8 Females' head morph or a similar product has been partially applied and saved over the old preset; replacing the old preset.
    Select the Model that has too big facial features & then in the Parameters tab select 'Currently Used' it will show you which morphs are applied.
    Okay so this is really weird. 1 of the character head (lets call it Head X) was at 100%. Though it did not show up in Parameters or Shaping's "Currently Used". Searching for it will display it at 100% for Head X. Though I have no idea why it applied to every female character across every scene. Additionally, I did NOT set any character to have that Head X @100%. It showed up under Shaping>Currently Used but not Parameters>Currently Used. And this was only after I did a Right Click on Parameter>Zero>Zero Figure Shape.
    Finally, when I create any new female character (lets call it Head Y), Head Y is set at 100% like normal but Head X is also set at 100%! The only way I can think of to aleviate this issue is to remove that character completely. So I don't have to redo every scene and every new female character by having to set Head X to 0%.
    By
    AnonTurtle AnonTurtle December 2018 in The Commons
    By
    Richard Haseltine Richard Haseltine December 2018 in Technical Help (nuts n bolts)
    By
    nonesuch00 nonesuch00 December 2018 in The Commons
    By
    Chou-Vert Chou-Vert December 2018 in Daz PA Commercial Products
  • Genesis 3 Male bad joint bends on computer
    What you should probably do is look at the "Shaping" tab for both figures, click on the "Currently Used" item, and toggle on "Show Hidden Properties."  This would let you do a item-by-item comparison of all the morphs being used for that figure.  One possibility is that you're missing a morph on the second system (i.e. maybe a JCM of some sort) that's causing the shape to come out different, or else that the second system has an extra morph that's being triggered.
    By
    rames44 rames44 December 2018 in Technical Help (nuts n bolts)
    So I just got the Dracarys Model from Sangriart on renderosity and I'm using Golden Palace for the genital morph.
    But somehow, the genital looks very weird on the character in comparison to the original Genesis 8 Female.
    What can I do to change it, so it looks more like the Genesis 8 ones?
    Links and images removed
    By
  • Products Converted from Studio to Poser
    M601
    Good Conversion
    This is another one that I had to convert without adding the morphs first as I had the already mentioned problems. However, it gave me no further troubles. I've added the M6 morph here and had to use the Fit Control morphs to get rid of some poke through - there's still a little showing on the V Neck and I had to use the morph brush on the neck of the Turtle Neck. It's a good, sharp looking outfit, so I'm looking forward to working with it.
    By
    philebus philebus December 2018 in Poser Discussion
  • Aeon Soul 20.50 Cyberpunk clothes for G3M dforce issues
    • Transfer Utility to convert the OBJ into wearable (Source: the figure, Target: OBJ)
    • Add Smoothing Modifier
    • Add dForce Modifier: Dynamic Surface
    By
    Noah LGP Noah LGP December 2018 in The Commons
  • Welcome to Hatsune Miku Anime Manga Cafe ☕
    Model Links
    The following are the models I use.
    Aiko 3.0 https://www.daz3d.com/aiko-3-0-morphs-and-maps
    Mizuho https://web.archive.org/web/20150906222713/http://homepage1.nifty.com/garbagesoft/chr_download.html
    Aiko Guy: https://www.renderosity.com/mod/bcs/?ViewProduct=33463 probably need to contact creator as Character is no longer avail.
    Kioki (main Morph used) https://www.daz3d.com/kioki
    Any questions of the clothings feel free to ask.
    well I seen you have found the right hair for Tifa and others,any tip on where I can find FF Shiva hair?
    By
    mach25 mach25 December 2018 in Art Studio
    Model Links
    By
    Hatsune Miku Hatsune Miku December 2018 in Art Studio
  • Is Daz Studio working better with Intel than with AMD CPU's?
    For example the Intel Core i9 Extreme Edition i9-9980XE! It has 18 cores with "just" 3,0 Ghz base clock for around 2.500 €. But Daz Studio would work even slower with it!!! Really???
    No, because of turbo clocks under low thread workloads . It might go up to 4.5 under a single thread
    Also , clock speed is only partly responsible. When you are loading a big scene , sometimes you are transfer limited and the bottle neck is your hard drive or ssd .
    And clock speed does not indicate the same thing between  architechural generations , because of "instructions per clock"  .  In short, a 3Ghz CPU from 5 years ago will be slower than  a 3Ghz from a recent generation at 3Ghz with the same core count
    By
    pdr0 pdr0 December 2018 in Technical Help (nuts n bolts)
  • [Updated] Chimpanzee for Genesis 8 Male [Commercial]
    Got the chimpanzee - only character I've bought for G8M. Thank you and Merry Christmas. Any chance for an orangutan morph in the future? I have Ape World 2, but it's a bit lacking in realistic proportions.
    Yes there is also an orangutan work in progress and other monkeys/apes too...
    This is great news. Could definitely use more apes and monkeys. Thank you very much.
    By
    cathan01_wwg1wga cathan01_wwg1wga December 2018 in Daz PA Commercial Products
    By
    Alessandro Mastronardi Alessandro Mastronardi December 2018 in Daz PA Commercial Products
    By
  • Genesis(1,2,3,8) clothes on V4 and M4.
    There's no direct way to do it in DS as V4/M4 figures and earlier don't support autofit.
    Well, I suppose you could use a figure with a V4 shape morph to morph the mesh to fit V4, then export the morphed clothes as obj, then use the figure setup tools in DS to rig the figure to V4 using parametric rigging, but that would be quite complicated. And from memory you'd have to group it like V4 and separate the various groups in a modelling program before rigging...
    If you're willing to use an external program, Evilinnocence's Crossdresser program can convert items from Genesis 1 to various figures including generation 4 figures (the program itself is free, you only have to buy the XD license for the target figures, and they're quite cheap). You need to export the clothes from DS as cr2 first, using cr2 exporter (included in DS). XD doesn't support G2M/F or later figures, but if you have autofit clones to "go back" from G2+ to G1 you can try autofitting clothes for newer figures back to G1, then using XD on the G1 version to go back to V4/M4.
    No guarantee on the quality of the result though....
    I do the first step ie morph the figurewearing it to the V4 or M4 clone, not shape, (feet are posed streched down and some other differences) then under edit rigging convert the clothes to props
    can then convert V4 or M4 to weightmapping and use transfer utility then save clothes as a support asset
    it will then in DS fit V4 or M4 not converted to weightmapping too
    but only in DAZ studio not Poser
    By
    WendyLuvsCatz WendyLuvsCatz December 2018 in Technical Help (nuts n bolts)
    By
    Leana Leana December 2018 in Technical Help (nuts n bolts)
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
