• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • DAZ Central loading forever / not working
    I can't get past this problem.  I've tried reloading Daz Central several times.  Every time I launch it, it hangs on "loading".  Is there any help for this?
    You may need to opena  support ticket, though there's always the hope that they will be able to find an underlying issue that will fix it for all those affected.
    By
    Richard Haseltine Richard Haseltine November 2020 in Technical Help (nuts n bolts)
  • 4.14 crashing
    Logging in with your browser of Central/Install manager should be no problem - as far as I know - but theer do seem to be some oddities following the store software change that may throw errors if DS itself is allowed to connect (from the Connect menu, but it may be worth checking the update checks and the improvement programme (if you opted in to that) just in case they are an issue. I have update checks and, I think, the improvement programme on and haven't had major crashes - but with all the froum activity recently I also haven't been doing that much with DS.
    By
    Richard Haseltine Richard Haseltine November 2020 in Daz Studio Discussion
    By
    tomasball tomasball November 2020 in Technical Help (nuts n bolts)
  • DAZ Studio a complete breakdown.
    Can anyone help with this please?  I tried to update DAZ to 4.14 yesterday but everything seemed to go wrong. After the update some new products I had bought would not install but they did show on both DIM and DAZ Central.(SKU 19404 was one product, old rowboat) When I loaded a figure it came onto the workspace totally white as if bathed in intense light and with a harsh shadow. I tried to sort this out for myself without success, even tried a factory reset, no luck. What I have now is as you see in the attached pic. So, before I delete DAZ altogether I thought I would appeal for help and guidance to the forum. Thank you for taking the time to read this.
    Have a nice day.
    By
    Cat_Dancing Cat_Dancing November 2020 in Technical Help (nuts n bolts)
    Now it works again..... however i cant have it install stuff on my C: Drive so i will try to change the installation path in daz central again... wish me luck frown
    By
    muellerlasse muellerlasse November 2020 in Technical Help (nuts n bolts)
  • DAZ Studio communication to server failed
    People have been reporting issues logging in, mainly with DIM/Daz central but it would not be altogether surprising if Connect was affected (though I don't believe they use the same servers).
    By
  • Why is Daz Tech Support so bad?
    At the same time somebody find the time to develop Daz Central instead of fixing the existing download managers.
    Daz Central which is a new source of issues.
    The QA team of The Sims 4 is also very busy there is still a ton of things to fix 6 years later, I'm not surprised that Daz Tech support is overwhelmed.
    Even the PAs take a long time to fix their stuff.
    SickleYield didn't fix the too long path of several products (more than 255 characters, 1 year old ticket)
    By
    Noah LGP Noah LGP November 2020 in The Commons
  • Do Over . . how to uninstall so I can reinstall 4.9
    We had the same problem. You need to clear out app data
    Uninstall daz
    uninstall DIM/central
    **this next part is commonly why things are not fixed or reoccur or go to the wrong drive or location**
    Remove the hidden files and stored info from:
    • C:\Users\Your Username\AppData\Roaming\DAZ 3D (this is different based on where it was created on the drive example, C may be E ect)
    • Remove anything DAZ from here
    • Reboot after this
    • Reinstall everything fresh
    By
    sweet-talkin-melissa_26d96ec23c sweet-talkin-melissa_26d96ec23c November 2020 in Technical Help (nuts n bolts)
  • Installing keeps failing?
    I'm having a similar problem, DAZ Central just hangs after starting, with a spinning "LOADING" animation. I've tried re-installing, lots of other things. It affects multiple machines, the old one that's too slow (but worked until yesterday) and the new one that I just got yesterday. Looking at the logs, it seems that it's logging into my account correctly, but then complains of a syntax error in one of the JSON files it's downloading. I think DAZ's server is serving up a dud file; IOW, it's broken on their end.
    I've also trick DIM, but I get the same problem, and a similar error in the logs. I don't think there's any hope of it being fixed before Monday. I filled out a trouble ticket, and got a message that they have a 4-6 week backlog. I'm a newb at this, and regretting choosing DAZ studio already. If they really take 4-6 weeks to get to looking at it, I'll have already asked my credit card company to reverse the charges for my Black Friday purchases.
    By
    steve_3859636 steve_3859636 November 2020 in Technical Help (nuts n bolts)
  • Não tenho mais acesso a galeria que vem ao instalar o Daz.
    Several people have reported issues using both Daz Central and Install Manager today, it is possible that what you are seeing is part of that problem. If so I am afraid I do not have any information on when it will be resolved, though Daz is working on the download issues with its service provider.
    By
    Are you using Daz Install Manager, Daz Central, or the stand-allone installer from the Product Library page? What operating system are you using?
    Eu estou usando o Daz Central, não utilizei o daz install manager, o meu computador realizou a instalação automaticamente. O sistema operacional é Windows 10.
    By
    marianacaplim marianacaplim November 2020 in Technical Help (nuts n bolts)
  • Files Not Downloading in Install manager
    It seems likely the CMS is down. Both the DIM and Daz Central are not responding, all content is inaccessible. It is also likely that there is no one at Daz to fix it until Monday. They are home for Thanksgiving weekend. Very bad not having someone there to ensure systems are running during the Black Friday shopping weekend. This could cost someone thier job.
    I know I'm irritated.
    This is not universal, however - I just logged into DIM and downloaded four updated products. As for theer being no one on, the person in charge of the web features was on and posting earlier. I appreciate that this is deeply frustrating for those who can't log on at all, or who can log on but whose downloads fail - however, the fact that it is not a universal issue makes it much harder to track down, and much harder to tell whether a fix has worked; it's not the answer you want to hear or that daz wants to give, but I can only ask you to exercise patience and perhaps try again after a while (especially in the wee small hours, US or European time, if that's an option).
    By
    By
    TheFantasyPhoenix TheFantasyPhoenix November 2020 in Technical Help (nuts n bolts)
  • Managing my libraries
    Do multiple libraries have content isntalled by Install Manager/Daz Central? If not then, as long as the folder that they use iss till available, you can simply merge the folders - everything else uses relative paths. If you have used different destinations for DIM/Daz Central over time, and still have the content isntalled, then you will need to update the destination path in DIM, select everything in the Installed tab, and then right-click and choose the option to reinstall all selected using the current path - I'm not sure if Daz Central has an equivalent feature.
    By
    Richard Haseltine Richard Haseltine November 2020 in New Users
  • Need Help Starting Over With DAZ -- SOLVED!
    You shoukld be able to set a base path in Daz Central's options; for the non-beta there should be a stand-alone isntaller on the product page; use DIM as normal https://www.daz3d.com/get_install_manager/
    By
  • Valentino 8 slowly installing during render
    If an item is greyed out when you've installed it trhough DIM it may be that PostgreSQL was closed when you installed - that can happen if you close DS and immediately open DIM (or, I assume, Daz Central). There's no need to close DS to use the installers (except with the application itself and plug-ins), but if you do make sure that the one has fully closed before starting the other; for now, I would reisntall the product through DIM - otherwise you will end up with two sets of files if you double-click to install through DS.
    By
  • Daz Studio 4.14 Pro, General Release!
    Hamfast said:
    It might still be supported (for products), but NOT for an update or download of DAZ Studio 1.14. D|S 1.14 appears in DIM and tried to download and update but the download fails every time and it cannot be installed. DAZ3D are trying to strongarm their users to use DAZ Central.There is no choice to update Studio except DC.I don't think many users will be happy about that. Just like Microsoft and Windows 10!
    I saved a copy of 4.5 and as I was having so much trouble with 1.14 I uninstalled it. When I installed 4.5 however it opens as 1.14 and Im back where I started. They have this control thing where they have changed the rules and we are stuck with it. I cant go back to working as I used to at all.  This update is sticky,laggy and crashes a lot. I am very upset that Daz has taken all our money and given us a new crap version so they can keep tabs on whoever is using it. They should call it Daz Control instead of daz central. It only works in their favour,this way they can monitor all the different bridges and assets going out ,but we are left with something that doesnt even do what it used to do!
    If you install through DIM, put it in offline mode, place the old zips in its Downloads folder, delete the .dsx files that have the same name in the Downloads folder (not the ones in the Manifests folder), and install. If DIM is online it will see and use the newer version (because DIM does work normally fro instaling DS updates still - any issues are down to external factors, possibly with the servers or perhaps account or security software issues).
    By
    I haven't tried these instructions out yet as besides that I was first waiting for a reply from the Help desk - I've not has a reply in 2 weeks - I have some questions, but just for now there's one key one:
    Re Instruction 7 above, how does one install Daz Studio on an external drive without going via Daz Central? I've twice tried installing DS itself but I always get taken to Daz Central which automatically installs on the C Drive and doesn't give options for an alternative path.
    "7-- Install Daz Studio and any plugins you use."
    By
    Prince Wao Prince Wao November 2020 in Technical Help (nuts n bolts)
  • Daz Central, DIM, and Downloading, Closed Doors on Black Friday Weekend.
    everything worked fine for me yesterday. But now daz central dashboard wont stop loading so i can literally not do anything. Also put thousands of dollars into this...
    By
    I have got to say, after seeing all the posts in the last 2 days about CMS failing, This has got to be the biggest mess up ever..... Absolutly no download and install capabilities during the biggest sales days of the year. People with new computers trying to port over thier content only to find total frustration. Someone is going to get fired for this.... Support is going to be overwelmed and your customer service is in an unfortunate condition. You've got some really angry customers, and I am one them. I have purchased thousands of dollars in content and I can't access anything. I'm fuming.
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
