• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • Can you separate skeleton/weight mapping from a copyrighted mesh for redistribution?
    Squishy said:
    Looking at the contents of the DSF file, I can see where it defines the geometry - can I instead have this point to and load a separate file e.g. an OBJ export of the copyrighted mesh that I can instruct users to create? That might be OK
    e: on second thought I guess that is pretty unlikely as I doubt OBJ would be a safe format to depend on vertex order for things like geograft boundaries and weight maps
    Nah... but..well, it'll be just a little cubersome if you wanna do so... You said asset owner is DAZ, I assume you've modified a Genesis Base Figure, probably...
    For the figure, let's say a Genesis 9, all the geometry (vertices), rigging and weight data are stored in data\DAZ 3D\Genesis 9\Base\Genesis9.dsf. You cannot distribute it and its derivatives at all. You've saved a new figure asset with all the modification, so it's a 'derivative'.
    In this case, you need to 'recreate' a modified figure with no DSON Support Files (dsf), i.e. a pure 'scene-based' modified figure, then save the scene file.... Let's still use G9 as an example:
    1) New scene. Load your modified G9 figure (A) into the scene, Zero it. Load default G9 (B).
    2) Transfer Utility - Source: A, Target: B. Distance Tolerance: 0. Only check Weight Maps in General Options ! Uncheck everything in Post Transfer Options. Accept...
    3) Memorize Figure Rigging.
    4) Delete A. Save the scene file. Now all rigging / weight data are saved within the scene file. Check duf file with Notepad++.
    * If you have also rigged attachments (anatomical elements, etc.), as well as weights, replicate the process on them accordingly.
    PS: As for morph files if there's any, always import objs with Reverse + Delta Only. Then they could be shared.
    By
    crosswind crosswind November 2023 in Technical Help (nuts n bolts)
  • Generation X2 - Anyone recall this?
    Muon Quark said:
    Was wondering if anyone recalled this issue with Generation X2 and if there was a fix?  The attached is the Genesis 3 maile with the Genesis 2 dwarf base dial in.  The eyes stay and don't move.  I vaguely recall an issue with either the genesis 2 male eyes in Morphs maybe needing an edit or I need to transfer more than the basic dwarf shape?  Sorry I can't remember more, just that I had an issue with this when Generation X2 first came out.  Thought I would reach out and see if anyone remembered anything.  Thanks.
    Edited for typo
    Yes... old but still have that memory. Because of the rigging and ERC Freezing issue of Dwarf Base(eyes have translate values...), you have to create another single dial by export / import Dwarf Base, re-rigging ( use Rigger Plus! default Adjust Rigging to Shape is not perfect, with artifacts...) and ERC Freezing. Reload G2M, then go for conversion with GenX. (...while GenX is not perfect though)
    If you know Hexagon or Blender, etc, finetune it a bit (smoothe torso, refine limbs, etc...)
    By
    crosswind crosswind November 2023 in The Commons
  • Is there finally a simple way to import Blender files into Daz?
    As per my exp. with the pipeline in b/t Daz and Blender, obj import / export is the simplest and most accurate way.
    By
    A question that has haunted Daz for years. Haven't asked it in 2023 yet. So here it goes again:
    Just a simple import .blender function.
    Yes, I know there is a Daz to Blender exporter, that's not the question and kind of weird if there is still only a one way street with this.
    By
    novastrider novastrider November 2023 in Technical Help (nuts n bolts)
  • I want to return the "New" Scene menu item to the old behavior. How?
    This is defnitely one of the most annoying changes in the new version so far... I seriously dislike it, already went over the "About plugins" section in hopes that we might be able to prevent the whole wizzard pane from loading but no such luck it seems. I also completely fail to understand the logic here.. when I want a new scene I want just that: a new scene, and a bit quickly if it can be helped.
    I think this pane would have been much more useful as an extended load option. I mean, there is some value in being able to quickly open scenes you previously worked on, but NOT when all I want is to quickly clear my current scene in order to continue working by dragging a new figure in and work on a new pose or morph or whatever.
    Of course the Daz documentation site decided to give up on me with errors making it even more difficult to check up on how I should create such a custom action, which only adds up to my agitation. Never done this before...  ugh!  Eventually I figured it out, thanks to Google and another 3D website...
    SO... here's to those of us who like me never created a custom action before while also wondering how to get rid of this annoying wizzard:
    • Fire up Daz Studio where you should be met with an empty scene; if not empty then you'll have to go through this annoying new scene wizzard.
    • Immediately use: File => Save as.. => Scene. Name it "Empty scene" or something.
    • Optionally (but highly recommended): Go to your content library pane, find this new empty scene in "My Daz Library => Scenes" and after you confirmed its existance: create a new folder in your library called "Templates" then move the empty scene file in there. For 2 reasons: by moving it you'll break the metadata path which means this empty scene won't show up in the "Saved Files" section of the smart content pane (which would be even more annoying!). Second: by using a dedicated "templates" folder it'll be much easier to remember why there's an empty scene file when you look into this at a later time.
    • Either way.. in that same content library pane right click on the empty scene file, then use "Create custom action". You can pick whatever menu you'd like, I went for "Favorites" with the label "New scene".
    • Now follow up on what Crosswind mentioned above: press F3 to open the customization screen, then you'll find your new custom action under the "Custom" header. Here you can assign the Control + N shortcut to it.
    • Also optional: this custom action works independent of any menus. So if you want your pulldown menu to return the way it was you could consider removing the Favorites or Scripts menu. Press F3 and then check the "Menu" tab on the right. Here you'll find "Main menu bar" which will now contain "Favorites" or "Scripts" or whatever. From here you can easily remove the menu item entirely.
    Annoying for sure but fortunately also easily remedied. Thanks for the initial tip Crosswind!
    By
    ShelLuser ShelLuser November 2023 in Daz Studio Discussion
  • G9 Essentials Update
    crosswind said:
    Richard Haseltine said:
    crosswind said:
    http://docs.daz3d.com/doku.php/public/read_me/index/86958/start
    Just a Connect issue fixing... nothing special.
    It says
    • 2023-11-03
      • Re-packaged to include full metadata in all parts of a multi-part distribution
        • Addresses an order of installation issue that can cause metadata to be incomplete/missing when installed via Install Manager
        • Addresses an issue with missing texture files when installed via Daz Connect
    so it affects both Connect (most seriously, missing files) and other methods (incomplete metadata).
    There was just the 2nd point yesterday.
    Yes, I was told it had been updated.
    By
    Richard Haseltine Richard Haseltine November 2023 in The Commons
    It says
    • 2023-11-03
    By
    It says
    • 2023-11-03
    By
  • Daz Studio 4.22[.0.x] Pro, General Release!
    barbult said:
    oddbob said:
    This is odd, I'm using Carole HD which doesn't show in smart content when installed through DIM but does show in the character folder. Won't let me categorize it though. Also using Itsy hair. I get intermittent issues with the second render failing when trying to use both together but can use them in separate scenes ok.
    DIM installs "/People/Genesis 8 Female/Characters/Carole 8.1.duf", so that is why you see it in the Characters in the Content Library. The DAZ metadata included in DIM for the Carole product does not include any metadata at all for that file, though, as far as I can see. I was able to assign an asset type and category successfully with the Content DB Editor and drag and drop it into the product. You can submit a help request about the metadata error, if you think there is any hope of getting it fixed. Or, you can just fix it yourself, like I did and move on with life.
    Thanks, I've reported it along with a couple of other content issues that I've been working around. I'm sure it will be fixed within days laugh
    Otherwise I'll do the fix as you suggested.
    By
    oddbob oddbob November 2023 in Daz Studio Discussion
    crosswind said:
    I don't have that char. but usually two reasons : DIM lost connection to cms when you installed the product; wrong metadata. You may try to re-import metadata of that product.
    As for the asset conflict issue, I have no way to test them 'cause I only have Itsy Hair...sorry...
    Thanks, there's a thread from release time that states that the DIM version is missing a file. I've reported and I'll wait for a fix, otherwise I'll fix it and see if it resolves the conflict.
    By
  • DAZ can't find most of my content
    I don't use Smart Content at all. Never even open the pane.
    But if you want Smart Content to work, you Must correct the issues with DIM to get the metadata files where they need to be.
    By
    Dartanbeck Dartanbeck November 2023 in Daz Studio Discussion
  • PostGreSQL CMS Connection not found Studio 4.21
    [PostGreSQL CMS Connection not found Studio 4.21] Title says it.
    Also, in the Content Library tab, it shows:
    DAZ Studio Formats
    Poser Formats
    Other Import Formats
    but not:
    Products
    Categories
    Everything's there, if I load an old scene it shows up and will render, but there are no thumbnails or categories in Smart Content. If I go into DAZ Studio Formats in Content Library, the thumbnails are there.
    I have an identical computer, (Computer 1), and Studio 4.21 works fine on it. Can anyone tell me what I need to copy, and where it is, to make Computer 2 work just as well as Computer 1?
    Thank you.
    By
    Petercat Petercat November 2023 in Technical Help (nuts n bolts)
  • How to export obj in DAZ 4.22 correctly?
    James said:
    Using the G8F on a new scene, I can make it works now.
    But I tried on my real scene and export a character in base resolution (I make sure), it failed still.
    I used the standard export, I tried the script, import morph loader not working, still geometry not the same.
    update:
    Ok I think I know what causing the problem.
    It seems the problem occurs, when a character have a graft.
    When I deleted it, I can exported and did morph loader.
    As far as I remember, it used to be no problem, am I wrong?
    Yes, if so, geograft was the culprit... probably you were not wrong but that would depend. If you exported the selected figure with Geometry Editor activated, the result would be correct 'cause all grafts would be unfitted...
    Therefore if you wanna export such a figure to obj, you may either activate Geometry Editor or unfit the graft(s) first before exporting...
    By
    crosswind crosswind November 2023 in Daz Studio Discussion
  • 4.22 crashes when rendering
    Pitmatic said:
    Hi
    I am getting crashes on some scenes that worked perfectly just before the update for example I have
    https://www.daz3d.com/lyra-hd-for-genesis-8-female
    Wearing
    https://www.daz3d.com/leony-wet-and-dry-ponytail-hair-for-genesis-3-and-8-females
    Which is by Out of Touch and presumably is calling the custom shader with a map in the Transmitted Colour channel - select the hair, open the Surfaces pane, select the hair there, and type transm in the filter box - click the little icon/nano-thumbnail next to the colour picker for the transmitted Colour and select None.
    sitting in the water tank from
    https://www.daz3d.com/mad-science-laboratory
    and it crashes now where as 4.21 had no problem with it and hour earlier.
    the log file shows a load of deallocation errors and i tried deleting items for the scene and found it was the Leony hair another thread mentioned the trans map and i deleted that in surfaces and the scene now renders. I did not update the nvidia driver so why did 4.22 crash on this?
    Also i noticed errors with Lyra's ears in the log is this something to worry about?
    Edit I have tried more hairs and it seem to be other OOT that crash very confused
    2023-11-04 11:32:19.006 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Reached internal texture limit on material instance 'DS_Lyra__Face_18d9_8214', retrying JIT-compilation.
    2023-11-04 11:32:19.010 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Lyra__Face_18d9_8214' uses MDL JIT compilation.
    2023-11-04 11:32:19.011 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Reached internal texture limit on material instance 'DS_Lyra__Ears_18dc_8301', retrying JIT-compilation.
    2023-11-04 11:32:19.015 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Lyra__Ears_18dc_8301' uses MDL JIT compilation.
    2023-11-04 11:32:19.015 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Reached internal texture limit on material instance 'DS_Lyra__EyeSocket_18de_8377', retrying JIT-compilation.
    2023-11-04 11:32:19.019 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Lyra__EyeSocket_18de_8377' uses MDL JIT compilation.
    2023-11-04 11:32:19.021 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Leony Ponytail Genesis 8 Female__Side2_1913_8571' uses MDL JIT compilation.
    2023-11-04 11:32:19.131 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 644 textures, 56 lambdas (56 unique)
    2023-11-04 11:32:19.132 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Computing 1 flux compensation factor took 0.001 s
    2023-11-04 11:32:19.132 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (3 light sources with 2106 triangles, 3 instances) took 0.001 s
    2023-11-04 11:32:19.133 Iray (Scene Update) : Updating environment
    2023-11-04 11:32:19.133 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2023-11-04 11:32:19.133 Iray (Scene Update) : Updating code
    2023-11-04 11:32:19.133 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled material code.
    2023-11-04 11:32:19.133 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled environment code.
    2023-11-04 11:32:19.133 Iray (Scene Update) : Updating textures
    2023-11-04 11:32:19.133 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating material textures.
    2023-11-04 11:32:19.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment textures.
    2023-11-04 11:32:19.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating BSDFs.
    2023-11-04 11:32:19.140 Iray (Scene Update) : Updating volumes
    2023-11-04 11:32:19.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
    2023-11-04 11:32:19.140 Iray (Scene Update) : Updating lens data
    2023-11-04 11:32:19.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2023-11-04 11:32:19.140 Iray (Scene Update) : Updating lights
    2023-11-04 11:32:19.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2023-11-04 11:32:19.140 Iray (Scene Update) : Updating instance topology
    2023-11-04 11:32:19.140 Iray (Scene Update) : Updating flags
    2023-11-04 11:32:19.140 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2023-11-04 11:32:19.141 Iray (Scene Update) : Updating backplate
    2023-11-04 11:32:19.141 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2023-11-04 11:32:19.141 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled backplate code.
    2023-11-04 11:32:19.141 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate textures.
    2023-11-04 11:32:19.141 Iray (Scene Update) : Updating decals
    2023-11-04 11:32:19.141 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2023-11-04 11:32:19.185 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using no convergence estimate.
    2023-11-04 11:32:19.185 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2023-11-04 11:32:19.229 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2023-11-04 11:32:19.229 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2023-11-04 11:32:19.255 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX for CUDA device 0
    2023-11-04 11:32:19.426 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2023-11-04 11:32:19.426 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060)
    2023-11-04 11:32:19.426 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2023-11-04 11:32:19.426 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3060): Processing scene...
    2023-11-04 11:32:19.426 Iray (Scene Access) : Retrieving geometry
    2023-11-04 11:32:19.426 Iray (Scene Access) : Retrieving device geometry
    2023-11-04 11:32:19.679 Iray (Scene Access) : Retrieving volumes
    2023-11-04 11:32:19.679 Iray (Scene Access) : Retrieving textures
    2023-11-04 11:32:24.669 Iray (Scene Access) : Retrieving device textures
    2023-11-04 11:32:25.192 Iray (Scene Access) : Retrieving flags
    2023-11-04 11:32:25.192 Iray (Scene Access) : Retrieving device flags
    2023-11-04 11:32:25.193 Iray (Scene Access) : Retrieving lights
    2023-11-04 11:32:25.193 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Importing lights for motion time 0
    2023-11-04 11:32:25.193 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Initializing light hierarchy.
    2023-11-04 11:32:25.205 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Light hierarchy initialization took 0.013 s
    2023-11-04 11:32:25.206 Iray (Scene Access) : Retrieving device lights
    2023-11-04 11:32:25.206 Iray (Scene Access) : Retrieving section objects
    2023-11-04 11:32:25.206 Iray (Scene Access) : Retrieving device section objects
    2023-11-04 11:32:25.206 Iray (Scene Access) : Retrieving materials
    2023-11-04 11:32:25.208 Iray (Scene Access) : Compiling custom code
    2023-11-04 11:32:25.345 Iray (Scene Access) : Retrieving environment
    2023-11-04 11:32:25.346 Iray (Scene Access) : Retrieving device environment
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving backplate
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving device backplate
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving decals
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving device decals
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving motion transform data
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving device motion transform data
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving lens data
    2023-11-04 11:32:25.347 Iray (Scene Access) : Retrieving device lens data
    2023-11-04 11:32:25.581 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : JIT-linking wavefront kernel in 0.224 s
    2023-11-04 11:32:25.586 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060): Scene processed in 6.160s
    2023-11-04 11:32:25.593 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060): Allocated 305.335 MiB for frame buffer
    2023-11-04 11:32:25.593 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060): Allocated 1.969 GiB of work space (2048k active samples in 0.000s)
    2023-11-04 11:32:25.593 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060): Optimizing for cooperative usage (performance could be sacrificed)
    2023-11-04 11:32:25.689 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.4   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Kernel [8] (ShadowEvalSr      ) failed after 0.014s
    2023-11-04 11:32:25.689 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.4   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while launching CUDA renderer in <internal>:908)
    2023-11-04 11:32:25.689 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.4   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Failed to launch renderer
    2023-11-04 11:32:25.689 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): Device failed while rendering
    2023-11-04 11:32:25.689 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER ::   1.3   IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 3060) is no longer available for rendering.
    2023-11-04 11:32:25.691 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER ::   1.3   IRAY   rend warn : All available GPUs failed.
    2023-11-04 11:32:25.691 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER ::   1.3   IRAY   rend warn : No devices activated. Enabling CPU fallback.
    2023-11-04 11:32:25.691 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while initializing memory buffer)
    2023-11-04 11:32:25.691 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: All workers failed: aborting render
    2023-11-04 11:32:25.691 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while de-allocating memory)
    2023-11-04 11:32:25.692 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.3   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while de-allocating memory)
    2023-11-04 11:32:25.692 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while de-allocating memory)
    2023-11-04 11:32:25.693 [WARNING] :: D:\DAZDevel\Hudson\HUDSON_HOME\jobs\NB_Studio_Trunk\workspace\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3060): an illegal memory access was encountered (while de-allocating memory)
    2023-11-04 11:32:25.693 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 20 cores for rendering
    2023-11-04 11:32:25.693 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2023-11-04 11:32:25.693 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2023-11-04 11:32:25.693 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend progr: CPU: Processing scene...
    2023-11-04 11:32:25.693 Iray (Scene Access) : Retrieving geometry
    2023-11-04 11:32:25.693 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Using Embree 3.13.2
    2023-11-04 11:32:25.693 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Initializing Embree
    2023-11-04 11:32:26.374 Iray (Scene Access) : Retrieving volumes
    2023-11-04 11:32:26.375 Iray (Scene Access) : Retrieving textures
    2023-11-04 11:32:26.375 Iray (Scene Access) : Retrieving flags
    2023-11-04 11:32:26.375 Iray (Scene Access) : Retrieving section objects
    2023-11-04 11:32:26.375 Iray (Scene Access) : Retrieving lights
    2023-11-04 11:32:26.376 Iray (Scene Access) : Retrieving materials
    2023-11-04 11:32:26.376 Iray (Scene Access) : Compiling custom code
    2023-11-04 11:32:26.548 Iray (Scene Access) : Retrieving environment
    2023-11-04 11:32:26.548 Iray (Scene Access) : Retrieving backplate
    2023-11-04 11:32:26.548 Iray (Scene Access) : Retrieving decals
    2023-11-04 11:32:26.548 Iray (Scene Access) : Retrieving motion transform data
    2023-11-04 11:32:26.548 Iray (Scene Access) : Retrieving lens data
    2023-11-04 11:32:26.548 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CPU: Scene processed in 0.855s
    and thats the end of the log when it crashes
    By
    Richard Haseltine Richard Haseltine November 2023 in Technical Help (nuts n bolts)
    Hi
    Wearing
    By
    Pitmatic Pitmatic November 2023 in Technical Help (nuts n bolts)
    update:
    By
    James James November 2023 in Daz Studio Discussion
    I used the standard daz exporter.
    import the obj and here's the scene info:
    G8F
    Primary Selection :
    Name :
    Genesis8Female
    Label :
    Genesis 8 Female
    Class :
    DzFigure
    Vertices :
    65.806 / 16.556
    Triangles :
    0 / 0
    Quads :
    65.472 / 16.368
    Total Faces :
    65.472 / 16.368
    Total Lines :
    0 / 0
    Exported Imported G8F
    Primary Selection :
    Name :
    xxx
    Label :
    xxx
    Class :
    DzNode
    Vertices :
    65.806 / 65.806
    Triangles :
    0 / 0
    Quads :
    65.472 / 65.472
    Total Faces :
    65.472 / 65.472
    Total Lines :
    0 / 0
    By
    I use another script to hide attachment.
    I use ITF kit to export in base model in one click.
    Standard exporter doesnt work too.
    I've tried many times.
    I use a new scene, G8F, even delete the eyelashes just to make sure, export, import morph loader, error
    Here's the scene info:
    Primary Selection :
    Name :
    Genesis8Female
    Label :
    Genesis 8 Female
    Class :
    DzFigure
    Vertices :
    65.806 / 16.556
    Triangles :
    0 / 0
    Quads :
    65.472 / 16.368
    Total Faces :
    65.472 / 16.368
    Total Lines :
    0 / 0
    Primary Selection :
    Name :
    xxx
    Label :
    xxx
    Class :
    DzNode
    Vertices :
    65.806 / 65.806
    Triangles :
    0 / 0
    Quads :
    65.472 / 65.472
    Total Faces :
    65.472 / 65.472
    Total Lines :
    0 / 0
    By
  • Add a Skeleton to a static mesh/unrigged character!
    There's one from Gordig - https://youtu.be/6S-8PAXuRR4?si=Vpko57Tm7PEhK43V though it was manipulated on Dog 8
    I assume you wanna rig a non-Daz figure with just a single mesh.... but you have to really 'rig' it rather than a simple parenting...
    Personally I really don't suggest such a way. I myself use Wrap... wrap the target model with Genesis X figure then import back to Ds as a morph.
    By
    crosswind crosswind November 2023 in New Users
  • Need To Download Everything
    %AppData% is an Environment Variable set by the OS. You can just copy/paste the whole string in a file explorer address bar and it will go there (typically C:\Users\[your account]\AppData\Roaming\ for Windows). If you really want to know, open a command prompt and type SET. The environment variables are listed alphabetically.
    Necessary S/W are all the programs you need to successfully run Studio, DIM, database engine (there might be more, but I can't recall). If you use DIM, open the Default Install Sets popup (Configuration Settings) to get an idea. You'll find out what's missing soon enough. DIM is the only part that is installed standalone, other than maybe Studio if you do it that way, but everything else will be available through DIM.
    Exporting and Importing metadata is done with the Content DB Maintenance suite of utilities, part of Studio. Right-click Content Library tab or Smart Content tab. Export User Data to save your content customization before anything. When re-importing metadata, do the products first, then the User Data after. I have had some extreme adventures trying to do all at once.
    By
    NorthOf45 NorthOf45 November 2023 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
