• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • CAT girl G8
    @Mab , since you're visiting and answering questions, maybe you can shed light upon something I noted earlier when someone asked about morphs.
    Why doesn't this set include a simple "cat nose" or "hare lip" morph?  Back with the original version of this product for Aiko 3, it wasn't much of an issue.
    Another set, the extended morphs for A3 (I think) offered a simple "cat mouth" (hare lip) type morph.  But unless I'm mistaken (and I admit I might very well be), I don't recall an equivalent for the Genesis 8 female, at least nothing that is part of a 'DAZ original" set of morphs.  Maybe in a vendor's set, but if so, I don't know which one.
    Those two lil' morphs would have added so much to this package.
    Sincerely,
    Bill
    We toyed with it, but in the end Catgirl 8 was made in a style similar to Genesis Catgirl only majorly upgraded.  So, we didn't include G8F morphs.  It's possible we might include a morph like that for Foxy Lady since we did originally include morphs with the Foxy and Wolfie set, so the precedent is already set.
    By
    MAB MAB June 2019 in The Commons
  • Can this outfit/Geoshell be worn by any G8 Female, or only the character it comes with
    Well since it is shaped with morphs to look like an android I suspect you are initially stuck with that body shape but can probably add other morph dials
    it does at least say separate head and body morphs
    no doubt you could dial in smaller hips breasts bigger thighs etc though as you choose but that would be your base to start from
    someone with it needs to post as I looked at it a few times too
    By
    WendyLuvsCatz WendyLuvsCatz June 2019 in New Users
  • CAT girl G8
    RawArt's catworld + a little HFS cat head. Used normal ears since they are morphed into place.
    Also moved/scaled the whiskers to fit the morph better
    By
    Oso3D Oso3D June 2019 in The Commons
  • CAT girl G8
    Sincerely,
    Bill
    By
    Redfern Redfern June 2019 in The Commons
  • why is it that all you have on your web is women
    yes, i know but why can't they make it for men and women together so if you make a wardrobe or armor you have it for men or women like a matching set I'm not talking about putting on women stuff on men either.
    Initially I thought the same, Peter. Until I noticed the section I bolded here. The design for a set of armor for men and women would likely be different. They may have the same theme, but if the goal isn't simply to make the woman's armor fit on a guy (which we could do already) that implies making outfits specifically designed for each body type.
    Also don't forget the morphs are very different as well. So even if you're talking about a basic set of practical whole body armor (i.e. non-fantasy / skimp armor) with the same basic shell, adding a morph for Olympia 8 is significantly different than doing the same for David 8. You could get away with "auto follow", but those results typically aren't quite as good as when someone takes the time by hand to support the different body types.
    By
    JonnyRay JonnyRay June 2019 in Daz Studio Discussion
  • Cannot load morph from Hexagon
    Hello,
    I'm not sure what I'm doing wrong.
    I load simple dress to daz 3D (no figure, nothing else in the scene).
    I export dress as obj. If I import this obj file (no changes) back to daz 3D with morph loader pro, everything is fine.
    When I open this obj file with hexagon and export it as obj (I make no changes here) I cannot import it to DAZ 3D with morph loader pro. It writes "Geometry did not match, failed to create morph."
    But I didn't change geometry in hexagon so there has to be other problem. I only export this obj as obj.
    So where is the problem? Why I cannot import morph when I export it from hexagon (with no geometrical changes)?
    I attach my export and import settings.
    Thank you
    By
    others1 others1 June 2019 in Technical Help (nuts n bolts)
  • CAT girl G8
    The renders you all are doing are better than our promo images!  I'm loving them!  For those curious about the morphs I used in the promos:
    The ones by Will were pretty basic just one character morphs like Aiko 8 and Karyssa 8 and Tika 8.   Me, I got a little crazy and used all kinds of morph mixtures, but I prepared instruction images, in case you all had some of the same morphs.
    By
  • AIUTO...CHI CONOSCE L’ITALIANO? PARTE DODICI
    Ancora ti stupisci, Crios? wink Ovvio che per fare i colossal devi usare i software giusti! cheeky
    Riguardo i bambini... Come sono riusciti a farli così brutti? E le pieghe sono del tutto innaturali, sembrano fatti di gomma sciolta male! sad
    Ho visto un morph di una bambina di circa due anni graziosissima su "quel sito là" basata sul pupo ( brutto!) di Sixus1... Magari prendere spunto?
    By
    Imago Imago June 2019 in The Commons
  • Facial expressions - ARKit
    Hi I'm a C4d user who uses daz character and was wondering if there was any way to utilise Apples ARKit to the max.
    I can export general face morph and roughly connect them but some i feel it require alot of tweaking and end up not looking so great
    Im using cinversity CV-ar to connect these morphs and animate my character facial expressions through the front facing camera .
    Would be great if Daz reslease a pack for Gen8 character morphs which allowed the ease of use of to animate these characters facial expressions
    I've attached a screen Shots of the facial expression that the Iphone depth camera can pick up
    If anyone know a smarter and easier way to approach this would be great to hear.
    By
    tommi_3b25a8af6b tommi_3b25a8af6b June 2019 in New Users
  • Another "What hair is this?" Theda for Ellithia 8
    I was going to guess that it's Xenya Hair from Rendo.
    Looks like an exact match to me.
    Assuming the promo isn't flipped, it's almost certainly Xenya. Xenya goes down the right side; Jett goes down the left. Jett also appears to have a stronger skullcap.
    I mean in hindsight, maybe it is the new one with a morph that makes the hair look like it goes straight down instead of back... this is driving me batty.
    I thought it might be Pepper Hair but it isn't that either, I don't think.
    What do you mean, "straight down instead of back"? Both Jett and Xenya split over the shoulder.
    By
    vwrangler vwrangler June 2019 in The Commons
  • Toon Hero for Genesis 8 Male
    I just picked this one up. I've been on a serious purchasing diet, but as soon as I saw this one I knew I had to get it. It looks like it will play well with the many G8 (and G3 and G2!) toon morphs that are in my library.
    Always excited to have a new toon morph!
    By
    Sphinx Magoo Sphinx Magoo June 2019 in The Commons
  • Alistair HD for Genesis 8 Male
    Just a heads up to those who have purchased Alastair HD, I had to uninstall him via DIM after I discovered he's dialing in to all Genesis 8 male characters even the base character. I will submit a bug report later. I'm on my phone and can't get on my computer to connect to the internet at the moment.
    That happened with James for me. But with Alistair it's not quite the same, when he loads he looks more like G8M base character especially the body, The Basic G8M does load and I can load my own morphs, they are as they should be. There is no Alistair morph at all in the Parameters. Characters don't load properly from Smart Content though.
    How did you install?
    By
    Richard Haseltine Richard Haseltine June 2019 in The Commons
    By
    AbnerK AbnerK June 2019 in The Commons
    By
    elliebean elliebean June 2019 in The Commons
  • 2nd of nine lives Cat Girrrl render thread prrr
    In this image the cat girl space cadets were created using Genesis 8, the Catgirl Megapack, HFS Ultimate Shapes for Genesis 8 Female, and EJ Teeth Collection for Genesis 8 Females. I picked up the HFS Bundle ages ago in one of the sales in the hope that I'd pick up some useful textures along the way. This is the first time I've used it.
    Love the characters and the render. The contrast and the nice back lighting really make the render pop.
    I was just searching the other day for cat / feline morph packs to take the new mega cat pack faces to the next level. Same for the teeth. Thanks for posting that as I just added both to my wishlist. Quick side question since you own the HFS Ultimate Shapes for Genesis 8 Female pack. Does it include that untextured strandy hair mesh seen in the promo pictures? I'll attach a screenshot below.
    By
    ZMcKraken ZMcKraken June 2019 in Art Studio
  • dForce Hair (as well as strand based hair and the strand based hair editor) in public beta
    I know I'm just getting started with seriously learning to use the Strand-Based Hair, but I think hair caps for human figures, at least, is the way to go. I'd love to see Redz put together a skull cap product with skull caps for all the Genesis generations. Maybe a second skull product for generation 4 and earlier. Maybe Daz could buy them and make them DOs or, better yet, PC+.
    Then if Daz ever adds the capability to move SBH from one object to another, (please, Daz, this would be awesome,) we could create a hair on a G8M cap, then transfer it to a G8F cap. From there, a simple matter of modifying the existing settings to optimize the style for the ladies. Or transfer it to an earlier generation male, and tweak. And so on…
    dForce Hair has the potential of being totally awesome, and I'm looking forward to seeing a lot of it in the store within the coming months. However, we don't have to wait for a PA to create the hair we've been hoping for. We can do that ourselves with the SBH editor. I get that SBH isn't going to work well with animation, but it can be great for still images.
    And who knows? Becoming adept at SBH could be the first step toward becoming a PA.
    By
    L'Adair L'Adair June 2019 in The Commons
  • "GYN-01 for Genesis 8 Female" problem using it on figures
    I tried using [GYN-01 for Genesis 8 Female] it on another figures. But seems not to work like in product photos.
    My results are only something like bodypainting with weak depths (e.g. ribs) also at 100% morph.
    Any suggestions?
    By
    chrom chrom June 2019 in Technical Help (nuts n bolts)
  • How to set up a follower morph for clothing?
    OK. SickleYield helped me understand this with her tutorial about JCM's from a Blender tutorial she wrote a while back.
    What I needed to do was of course make my fix morph (I use ZBrush), save it out as what ever name you want as you will change that when your hooking it up, which is actually done automatically.  So my current fix was for the pJCMThighSide_85_R so when I brought up the Morph Loader Pro and browsed to my fix morph for the trunks I renamed it to "pJCMThighSide_85_R" and then chose the Reverse Deformations option and chose the Overwrite Existing: Deltas and ERC Links and clicked OK.  Trunks issue was fixed perfectly.  I knew it was easy but my old brain was just really having a time with remembering.
    Wrote down and saved it out a new text file to refer to!  WHEW!
    By
    RAMWolff RAMWolff June 2019 in The Commons
  • Daz Breast Control for female figure
    Any character preset should load all the avaialble morph assets, so that sounds very odd. Are you using the character preset that came with the set to load, or are you using some other method?
    By
    Richard Haseltine Richard Haseltine June 2019 in Technical Help (nuts n bolts)
  • Darwins' Schtuff Pt Deux
    Next morph: Named Jo Yun.  Base reference is Park Hyung-sik.  Skin is my Yukio for Lee 8.
    I have two more rendering which I'll post when they are finished.  I still have to go through each morph set to check the eyes (if they close correctly) and make corrective morphs, as well as a couple of JCM's for certain areas.  But, I have one more base head/body/full morph set to finish before starting the fine tuning process. :D
    A full front face shot: I do believe I am in need of much more practice working on facial structures for Asian features.  While I like this morph, it is not where I want it to be.  However, I at least managed to get the lips/nose area to look how I wanted it to.
    By
    DarwinsMishap DarwinsMishap June 2019 in Art Studio
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
