Renderosity content disappeared.
I can't find any of my Renderosity content in the content Libraray. (NOT smart content, but the other one.) I only have a few and don't use them often, so I don't know how long they've been missing.
I checked, and the files are still in their various folders in My DAz 3D Library. One of the missing is Chihiro, and gen3 character morph. When I open up the file I rendered with her, she appears naked, hairless, in the default g3 pose. The figure in the Scene tab is listed as "Genesis 3 Female" but looking at her it's obvoious she's a morph. The old thumbnail in My Library/Figures shwos here with hair.
What the heck is going on, and how do I fix it?
Duplicate Formulas Error Solved! Thank you Bejaymac!IS there a quick and dirty way to fix the Duplicate Formulas Error
First two errors are due to missing morphs, the Joequick morphs are looking for morphs from other products and you either don’t have them or don’t have them installed.
Thank you, Thank you Bejaymac
The duplicate formula errors are easy enough to fix, DS4.5 or 4.6 will do it for you.
1) load Genesis into an empty scene, you’ll get the error message, just click it to carry on.
2) find the offending morph(s) in the Parameters tab, in this case it Actor/Universal/Fantasy SciFi and it’s the HFS_Shapes_Head01 morph.
3) Dial the morph to make sure it works and then zero it again.
4) at one end of the dial you’ll see a little “cog”, click on it and in the little menu that opens click on Parameter settings.
5) in the new window that has just opened you will see a Color A & a Color B, click on Color B to open the color picker.
6) Set the color to 254, 254, 254 and click OK.
7) Click “Accept” at the bottom of the Parameter Settings window.
8) After that window closes go “File > Save As > Support Asset > Save Modified Assets”.DS will do a quick scan of the figure and open a small window that should only have the one file listed, accept it and DS will replace the old file with a new updated one.
You can now clear the scene and Genesis will no longer give you that error from that morph, you might still get it from others, but you now know how to fix it.
Thanks! This resolved the "duplicate formula" issue that I encountered a couple of days ago in DAZ Studio 4.10 (!)
Hell Ambassador HD for Genesis 8 Male and Female [Commercial]Is the brain-like skin texture necessary as part of the shaping morph?
You can use whatever textures you want with this guy, but all the intricate shapes of the head and body are part of the HD morph.
I’ll make a clay render of him so that you can see him with no textures.
How to install Genesis 8 200 morphs SY2018Or do you mean SickleYield's free morph set from ShareCG: https://sharecg.com/v/91888/view/21/DAZ-Studio/SY-200-Morphs-for-Genesis-8-Head-and-Body ?
Just say this. Yes this is the one
If you mean this one, there is installation information inside the zip file in the Documentation folder. Does that help or do you need more assistance?
[Released] Character Converter from Genesis 3 Female to Genesis 8 Female(Now Conv JCMs) [Commercial]Okay, I have a question. It's probably been addressed but I don't remember seeing this, so forgive me for repeating something. I finally got a chance to transfer Ophelia 7 over. First time I did it, the texture was all over the place. So, I remember reading in the instructions that there was a setting that allowed for proper transfer of the UVs but only for those characters made with the base Genesis 3 model, not the custom ones like Ophelia 7. So I unchecked this option and transferred. As you can see, it transferred great but not the UV. One on the left is Ophelia 7 for Genesis 8...lol.
Can the custom UV issue be fixed for the custom Genesis 3 models, am I doing something wrong, or will we have to use something like the Legacy UV utilities to get to to attach correctly?
I think you are misremembering or I wrote the manual poorly. CC only copies the materials. If the G3F character has materials that don't use the Base UV Set, you are going to see seam problems. In that case, you need to use something like https://www.daz3d.com/genesis-3-character-uvs-for-genesis-8-female
Can someone convince Maelwenn to make Lydia HD for Genesis 8 female?They released a character converter for Gen 3 characters that will convert her for you! I hope that helps!
It won't convert the HD morph though.
Which is a shame, but I doubt it's vital... you could prbably use one another vendors HD morph over the top and obtain similar results.
Character, hair and outfit?I am guessing since Kanade mentioned
The fairy from this morph addon
Technique for delicate dforce adjustments?dForce Magnet might be useful to you: https://www.daz3d.com/dforce-magnet
(For a different type of fine adjustments, exporting the results of dForce to an OBJ file and editing it as a morph in something like Blender can also be a very useful tool).
You know you use Daz too much when...you tell a girl she's got nice morphs.
You look for the morph selection to add a little more oomph to your look...
Hell Ambassador HD for Genesis 8 Male and Female [Commercial]He is so cool!
Will he have separate head morph?Unfortunately no. I did try to make him with separated head and body morphs but it didn’t work right because of all the intricate HD details he has in the neck. But you can still combine him with other body morphs like bodybuilder or emaciated and such. Doing so you can change his proportion to your liking.
AIUTO...CHI CONOSCE L’ITALIANO? PARTE DODICIE' lento nel posing.A me capita solo quando uno dei personaggi o un vestito è settato nel modo sbagliato. E nemmeno con tutti.
Controlla nei parametri, non ci sia un qualche opzione troppo alta, tipo SubD o Iterations.
Se non risolve, prova a rimuovere un oggetto per volta dalla scena e vedi quale genera il problema, io sono riuscito a scoprire così che i pantaloni Capris creavano un sacco di rellentamenti sia in fase di posa che di rendering.Grazie!
Purtroppo non è che abbia molte alternative, devo usare quei vestiti/capelli per la storia, che sono già stato mezza giornata a sceglierli xDHo abbassato le iterazioni al minimo, e magari ci mette meno di 1 secondo, ma sempre non è fluido...pazienza!
Allora prova questo, è un livello un pochino più avanzato ma spesso risolve.
Per prima cosa devi avere ben chiaro per quale figura sono gli abiti/capelli che vuoi usare. Se sono per la figura base che usi (per esempio Genesis3) salta questo passaggio, altrimenti devi caricare la tua figura base e il vestito/capelli che vuoi usare. Con AutoFit fai adatta il vestito alla figura base e aggiusta le iterazioni e lo smoothing fino ad avere il risultato migliore. Se lo smoothing è assente, aggiungilo.
Ora nascondi la figura base (non cancellarla dalla scena!) e tieni solo il vestito/capelli visibile. Ora che abbiamo il vestito pronto, esporta in OBJ mantendendo i materiali e esportando le texture (basilare dopo)Ora che hai il vestito esportato in OBJ, crea una nuova scena e importa il OBJ appena creato e carica nella scena la figura base che vuoi usare.
Adesso devi solo adattarlo alla figura con il Transfer Utility. Di solito le opzioni di base sono buone, ma non dovesse andare bene alla prima usa uno dei preset.Ecco fatto, ora hai un vestito identico al originale ma privo di qualsiasi fronzolo che rallenta DAZ Studio. Se poi hai esportato i materiali correttamente potrai usare quelli creati per il prodotto "originale" senza problemi.
Se poi tu avessi bisogno di uno dei morph del abito/capelli, dovrai esportare uno per uno, un OBJ per morph, tutti quelli che ti servono e reimportarli con il Morph Loader Pro.
A scriverlo sembra complicato, ma è una cosa da meno di venti secondi.
Grazie Imago! :D
Si vede che ci lavori su queste cose! Io sostanzialmente non ho mai esportato nulla in OBJ xD
Ho disattivato un po' quello che potevo disattivare e va accettabilmente bene! Tanto è per 3 settimane o meno
How G8F morphs automatically work on her dress?The morph is projected - I don't know the details, but it seems to look at how the vertices of the figure near any given vertex of the drss have been moved from their zero state and then to move the dress vertex to match. This is an aplication feature, not a content feature - if the game engine doesn't have somethign similar you would have to provide the derss with matching morphs yourself, and have the game engine apply the morphs in both.
Will he have separate head morph?Auto Face Enhancer [Commercial]Where can I find the facial morph expression presets?Genesis 8 Female>Pose Control>Head>Autoface Enhancer>
Whitney hair soft look morph
I don't think so. But, you could dial in my morph to pull the bangs forward, then add a dformer to pull them over the eye, then save that as a new morph.That does look good, nice work! Anyone who has it, are there any built in morphs that may take this even further over the eye? If so, I may be tempted to buy it!
