• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Filament Preview crashes DAZ
    Anyway to disable or delete the filament plug in from DAZ Studio?
    Every time I try to use it, DAZ Studio ends immediately. No error, nothing.
    I'm fine with the way things used to be.
    Do I just avoid using it in the Preview, or can I free up resources by removing Filament entirely?
    By
    vonHobo vonHobo November 2020 in Technical Help (nuts n bolts)
  • Filament bring out the Renders
    very good and honestly I think Filament would be fine to use if doing postwork anyway especially for comics
    By
    WendyLuvsCatz WendyLuvsCatz November 2020 in Art Studio
  • j.cade is Back! And brought the adorable Bette!
    I made a little very short Filament animation with Bette. I put it in my Dropbox. Can you see it?
    Thats Amazing! :)
    Also great filament still render too! Theoretically I should actually try experimenting with filament.
    By
    j cade j cade November 2020 in The Commons
  • Here we go again - falling back on cpu rendering, yet again
    I was wrong. I don'T even have to load new assets, it already happens when I turn off assets in the scene. Even with the iray preview. I load the scene it renders on gpu, I hide one item, it falls back on cpu instantly.
    Are you using Section Planes? How much memory does your GPU have, and what is in the scene? Do you avoid this if the Viewport is in a non-GPU mode (not Filament or iray) when you start the render? Are you closing earlier render windows before starting a new render?
    By
    Richard Haseltine Richard Haseltine November 2020 in Daz Studio Discussion
  • New DS Filament Render Engine
    I just upgraded DAZ to the latest version and found out that it has this new feature. but unfortunately, it is not of much use because everything looks horrible unless you deliberately tweak your scene for this engine but then it will be not usable for iRay anymore
    That's not true. All you need to do is adjust the Filament Draw Options Node to suit your taste - it doesn't affect the way the scene looks in Iray at all.
    Go to Create >> New Filament Draw Options Node.
    Select it in the Scene Tab and in the Parameters Tab adjust it's ISO Scale.
    That brings the Filament Preview more in line with what you see in Iray.
    Filament:
    Iray:
    And just for comparison, what most people USED TO USE for a preview draw style, texture shaded:
    Filament preview is MUCH more in line with what you see with Iray.
    By
    3Diva 3Diva November 2020 in The Commons
    Not my first Filament render. But one I wanted to share. I'll be going back to it when Filament can use DOF.
    There's a teeny-tiny little bit of postwork
    By
    N-RArts N-RArts November 2020 in Art Studio
    I think Daz developers now need to make some effort in creating proper iray to filament (and also iray to 3gl) conversion system. because now the scene gets too light, too dark, individual item colors are way out of balance making this pretty much unusable.
    Also considering the fact that there are like 5 rendering engines available It would be a good idea to add some kind of "alternate surfaces" option for easy switching between rendering engines and also to make everything properly displayed.  even if this is just cosmetic, but it is quite unpleasant when your viewport looks like some abomination that does not even remotely represent the final result.
    Filament is not intended as an Iray preview anymore than wireframe is.
    Iray and Filament is like apple and orange. Iray preview viewport will represent the final Iray result.
    Cosidering how super ugly is opengl viewport (not only ugly but marginaly dysfuctional because some areas get too dark to even see ) and the fact that this filament renderer is just as fast as opengl it can be used as opengl alternative.
    and it works as preview prety adequate, probably even better than 3delight just that it need some tweaking
    If daz products were optimized for at laest those 2 rendering engines or at lest to iray and viewport it coud not be such a pain to our eyes to work with daz.
    If swithing betwen them was easier it may be even possible to do hybrid rendering where you render environment in filament and craracters in iray. then combine everything,
    this is not even so much about performance but about the fact that we run out of GPU memory  with super complex nature environments that ere not rendered great in iRay anyway.
    By
    onix onix November 2020 in The Commons
    By
    Sevrin Sevrin November 2020 in The Commons
  • AIUTO...CHI CONOSCE L’ITALIANO? PARTE DODICI
    Al momento mi vengono in mente solo 2 possibili cause:
    1. La luce degli occhi si propaga all'interno della testa a causa del SSS. Togli il materiale emissivo agli occhi o magari applicalo solo sulle facce degli occhi verso l'esterno e disattiva il 2 sided.
    2. Lo shader ha settato il SSS in modo che le parti più fine siano più scure... fai una prova vedendo cosa succede in geometrie con lo spessore simile alla testa
    No, vista la non uniformità della parte scura direi che si tratta di un'ombra. Fosse il materiale sarebbe su tutta la testa e non dominante su un solo lato e se fosse l'emissività degli occhi si poragherebbe maggiormente verso la parte alta della testa, proprio vicino all'occhio. Controlla non ci siano oggetti che bloccano la luce o che le luci siano posizionate correttamente.
    In ogni caso, controlla anche che tutte le UV abbiano lo stesso colre di base (bianco o grigio, immagino), qualche volta i materiali IRay sono talmente buttati lì che i colori Diffuse sono praticamente casuali. Non so perchè....
    In alternativa, riporta tutto allo shader di base e applica la "ghiacciatura" daccapo su una parte alla volta, e vedi se ci sono differenze man mano, io ho scovato molti errori shder così.
    Se alla fine non risolvi, molla IRay e usa 3Deligh o Filament, che funzionano meglio. wink Come saprai Filament utilizza correttamente un gran numero di shader IRay, io stesso sto ottenendo effetti incredibili anche solo con i materiali 3Delight.
    Filament è carino, ma non è ancora implementato in DS per la vendita...
    By
    Muscleman Muscleman November 2020 in The Commons
    @Imago senti ma non capisco una cosa, Filament può usare sia gli Shader di Iray che di 3Delight?
    Esatto, ma non tutti. Alcuni non vanno proprio, come quelli delle rifrazioni per 3Delight e gli emissivi IRay.
    Ne ho provati un pò e qualcuno 3Dlight sembra funzionare, ma la compatibilità maggiore ce l'hai con IRay perchè è un motore puramente fisico e IBL come Filament.
    In ogni caso, i materiali di bvase per 3Delight funzionano perfettamente come le bump map e le reflections.
    Io feci un test veloce con un item per 3Delight (Rama Drums | 3D Models and 3D Software by Daz 3D), e devo dire che ne rimasi sinceramente sorpreso. Ma se il viewport è piccolino, come nel mio caso, non posso renderizzare in un formato più grande?
    By
    Crios Crios November 2020 in The Commons
  • Why do YOU use DS instead of something else?
    DS is stupid-people friendly.
    No, no, no, currently Filament is not friendly with hair etc. However somehow Wendyluvscatz makes her people Filament friendly along with their fur. Now her people are smarter than Filament, those people are smart and can make sounds like meow! hence smart-people are friendly with DS Filament. smiley
    By
    Galaxy Galaxy November 2020 in The Commons
    By
    By
    Imago Imago November 2020 in The Commons
    By
  • Filament - wet skin, emissives, DOF?
    I just tried the new DAZ, and I'm quite fond of filament's speed :) However:
    a) has anyone figured out yet how to make wet skin in filament? Iray tricks are not working
    b) are emissives going to be supported in future releases?
    c) why is the DOF not working with filament?
    Thanks for any input :)
    a) is the most easiest to do! just move reflections at 90% and anysotropic at some 55-75%
    b) inside DS?, probably, because Filament Documentation consider emisives doable.
    https://google.github.io/filament/Materials.html#materialmodels/litmodel/emissive
    c) you can ask the creator of Filament for that on twitter @romainguy
    Thanks a lot :)
    Great news about the emissives, let's hope the DAZ team will get it working in no time :)
    By
    mwasielewski1990 mwasielewski1990 November 2020 in Daz Studio Discussion
    By
    Zilvergrafix Zilvergrafix November 2020 in Daz Studio Discussion
    By
    By
    By
    I see it - Very cute! :D I like that smile at the end. :)
    Thanks for checking it out. Bette is a cutie.
    By
    barbult barbult November 2020 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
